- throttle won't shut down?
- TH400 converter?
- Tips for pan filter seal removal
- 400 help
- PTC Torque Convertor
- 04 gto trans cooler question
- 220* Temps?!
- 4l60e build question
- WTB: Harness for 4l60-e car 1999-20002
- Beast sunshell causing clearance problems?
- transmission issues..
- chosing a new converter...?
- SS4000 or PT4000 Bolt-On 3.23 only
- 4l80e help
- Got P0753 Code: Shift Solenoid A , Electiraly. NOW NO OD ??
- Quick question about Bell/Tail housing
- changing Shift Solenoids
- Will Older 4L60E bolt up to LQ4
- A 4l65e can be used in a 4l60e car?
- Will my 4L60E be destroyed?
- 4L60E or 200 4R? HELP!
- 4L60E tranny 4.3v6 and LS1
- too much oil in trans?
- Wrong year for tranny?
- new trans, need pcm tune?
- How "streetable" is a powerglide?
- need converter advice...
- SS4000 or PT 4000
- another +1 for circle D
- oil pan gasket
- TCU Wiring Harness
- ? about this harness
- low buck glide
- Trans or converter problem ??? please help
- *Transmission builders come in*
- i think i'm riding the short bus!!!!
- Leaking fluid after converter install
- 4l80e into an f-body
- Rebuilding a 4L80e??
- 4l80e Gto Hdt2 Transgo Car Locks In 1st
- C5 Converter
- Need Help! Tranny issue
- What kind of parts to buy for rebuild?
- What blew up, my trans or my converter?
- New Circle D converter is installed!
- Fuddle converters?
- Yank PT4000/4L60E Owners Jump In Here
- What are the cooler fitting called on the 4L80E
- 4L60E won't upshift at the drags
- Flexplate question
- Lockup Issue(PerformaTranny TCI Converter)
- How much did your converter weigh?
- Need a tune?
- tranny in limp mode
- My new bonestock LS1 is here...now what...
- New G8 trans
- What Tranny are high HP cars running for race??
- tci flexplate
- 4l80e help please info for updating main trans electrical plug
- Is a tranny cooler worth it if i am only keeping the car for another 10k?
- converters with lockup damper
- TCI Costed me $1000
- Looking for Vendors offering 6L80 Torque Converter
- Selling built 4l60 trans and converter
- need a full rebuild "KIT"
- electronic shift improvers/kits???
- Need Help with a solution for triggering B&M tranny cooler fan on a 4L80
- PT str question.
- urgent help !!!!!!!!
- Tranny Removal Question
- What size are the bolts used to bolt the transmission to the block on ls1?
- how much HP for a Level V 4L60E transmission
- 6l80 conversion
- cruise control
- Should I flush or replace the filter ??
- Good Books 4L60E
- LT1 Transmission question
- YANK's new website is up
- transmission problem?
- Does your A4 car feel slower than a M6 car?
- What is the difference
- Better of the Two?
- What size converter to use daily driver
- torque converter
- Need Trans Help ASAP 98 Z28
- 4l80e Shifting Way To Hard!
- Anyone have the blueprint or flowchart of a 60E?
- 6L80 Issues
- Please help with bad whine/squeeke coming from converter
- 4L60E harness versus 4L80E pigtail
- Synthetic ATF
- Can a 4L60 be built to run consistant high 6 Sec pass on motor & Low 6s on spray?
- Whats wrong with tranny????
- Tranny gone?
- Transogo Seperater Plate?
- 4l80e overdrive sprag failure
- Sponsors that can cut and clean converter?
- what rpm should my a4 shift at?
- ARP Converter Bolts
- 4l80e It Is!
- A4 > th400...Wiring?
- 700r4
- needing my tranny rebuilt stronger
- Yank 4L60E Crossmember???
- Trans gets hot when sitting still?
- Trans shop in MD
- New Products! Torque arm Relocation Kit & Crossmeber for the TH350
- Circle D - Free Shipping
- custom input drum? intrested?
- Tranny question
- 4l60e
- 93 painless wiring 4L60E engine harness work for my 96?
- torque convter bolts
- pic of kickdown cable please?
- TAP shift not shifting into 3rd...
- 4l60e Or 4l80e
- stall for turbo
- Need some tuning info for 4l80e
- raising shift point gains???
- Powerglide Temp Sensor
- 4l70e vs. 4l60e input drum
- stall leaving on spray
- A4's...3200 or 3600 ?
- What kind of TC is best for street?
- 4l80e ?
- Question for expert trans builders.
- t56,th400, 4l60e
- Wierd Linkage Problem
- 06 LQ4 to 200-4R
- Stretching converter or slipping trans?? pic of log inside
- need help figuring out what went wrong
- where to put FAST tranny controller in C4?
- Got my car back after ss3600 install. OMG
- part number for tranny mount?
- SES from new TC
- speed sensor replacement???
- What 4L60E for LQ9 Chevelle swap?
- 98 Z want shift into od at wot
- oil pan leak
- TCI 3500 stall/turbo
- Broken speed sensor harness on tranny
- shift kits
- rebuild kit?
- Transmission Question
- Reactor flexplates
- Transmission is OUT!!!
- Typical stock 4l80e fluid capacity?
- 6L90E in 69 Camaro
- TCC Question
- Need help with 4L80E swap ASAP!
- Shifting the auto with a stall
- typical shift kit and install prices?
- Can I visually identify the brand of converter?
- Great idea for measurement of loss in TC slippage
- locked?? unlocked??
- Yank converter lock up problem?? what next
- Forgot to sand down mouting holes on tci flexplate
- th400
- Why is the Yank 4l80 transmission for the Vette $27,500.00??
- which gears
- Just finished my M6 to th400 swap.
- Transgo HD2 install?
- tranny problems only 1,2,r work
- Thinking about swaping from M6
- New Tranny
- 02 Z28, pick my shift kit
- Fuddle HP/S with 500rwhp N/A and 650rwhp N20
- trans shield ?
- converter choice
- TH350/TH400/or Powerglide
- 3200 convertor w/ 2.73's
- Are flywheel and flexplate bolts the same??
- 4l80e questions---LS vs Non LS
- th400 4l80 questions.
- please help
- How bad is this? (pics)
- 4l80e
- Size of Transmission Pan Bolts
- Automatic question...
- whats needed to install a trans-brake on a th350
- Hard pull when shifting into drive...
- anyone use this shifter on a 60e?
- 4l60e problem HELPPPP
- Flexplate for a lsx to a 200r4
- TH400, 80E... Questions..
- 98 transam shift kit questions?
- Who has a SS4000 and cam got ?
- th400 2 power glide swap
- Lockup Switch for Vigilante 3200?
- What is it ?
- question about shift firmness after fluid change
- stall
- 4L60E Transbrake complete!!!!!
- 99 SS with 4L80e dipstick ?
- How much did your T56 to auto swap cost?
- Im confused about the bell housing.
- Quick question.
- Length of stock 3.5" PST Aluminum Driveshaft
- 400 swap
- Need Torque Converter for 200-4R
- ? about 12 o'clock bolt on bell housing
- help fast
- Converter question
- TCC Lockup Issues HELP!!!
- Yank 3000 Stall? Good?
- Tranny Doesnt Shift
- Tranny fluid
- Tranny slipping, repair question
- What's wrong with my transmission??????
- forgot front seal retainer clip in 4l60e, HELP
- question about converter spacing
- P1810 Code. Overfilled?
- trans problem
- Stock flexplate bolts for converter w/tci plate =no no.
- Tranny leak
- trans temp sender ?
- So confused
- lost 3rd and 4th gear any ideas?
- 4l80e question. need help!!!
- Bigger stall tuning issues
- Flexplate Bolt Issues, Tci Users inside please!
- nitrous converter?
- Need help deciding on TH400 or 4L80E
- Vig 3600...my first impressions.
- Who sells Yank converters?
- 700 vs 400
- back yard tranny flush
- need help! 4l60e
- Draining a converter...
- Does STR value have anything to do with how "tight" a converter feels on the street?
- Big power TH-400 builders inside
- Installing ss3600 saturday..any advice
- tranny help
- plastic accumulator pistons?
- Converter Reccomendation
- quick question
- using transbreak to back up?
- How long would the tranny last?
- Best converter for mpg?
- Converter holding me back?
- converter issues
- after transgo HD2 shifts way too hard
- Fuddle converters: Good or Bad?
- New TH400
- B&M Shifter
- Hitting limiter 2-3 shift on track.
- Trailblazer torque converter run hard
- Did any one buy from www.700r4l60e.com?
- Best ATF?
- Another T56 turbo car going auto
