View Full Version : Automatic Transmission
  1. is this company any good
  2. th 350/400 w/ stock DS?
  3. Install the Vig 3200, or go bigger?
  4. What 4l80e yoke (see pics)
  5. code po700 transmission control system malfunction
  6. yank converter and stock converter bolts
  7. A4 Big Stall External Cooler only
  8. remove hard line fittings from tranny instead of clips?
  9. Transmission noise in R?
  10. 4L60E core price
  11. M6 - A4 swap ?'s
  12. Buying a converter today need some input
  13. Glide for 1000+ HP drag car?
  14. TH350 no 3rd gear
  15. Shift Kit??
  16. manually shifting a A4 98 Z28? 4L60E
  17. planet replacement question
  18. had a hellacious tranny problem
  19. flew plate rub?
  20. 4l60 problems
  21. 4WD question
  22. Allen head TC bolt size?
  23. ms4 converter
  24. Locking Up The Converter Manually
  25. OD non 4l80E trans
  26. anyone interested in rear 6an coolant fitting for the 4l80e
  27. Stock Aluminum D-Shaft out of 02 SS M6 fit a 00 T/A with A4?
  28. why does Yank not recommend thicker trans fluid?
  29. converter question
  30. post times with th350
  31. bellhousing question
  32. Rebuilt trans Problems
  33. new trans
  34. where to stuff a b&m trans supercooler???
  35. Speed Inc. 4L60's
  36. Stock stall/MS4
  37. Diagnose my tranny problem. 4l80e
  38. install help on b&m trans cooler
  39. turbo 400
  40. converter chioice
  41. Trans in my 00 Z28 acting strange
  42. Prelimanary Powerglide Results:
  43. Noob question about Tranny fluid changing
  44. help mocking up 80e (need to find one)
  45. Stage 4 FLT (5 Pinion Planets?)
  46. converter install writeup
  47. What are the differences between a 4wd 4L60e and regular one?
  48. for sale b&m 3800 stall for 350 turbo
  49. shift kits
  50. B&M cooler clearance ?
  51. 4l60/4l80 Tranny Temp Sensor Locations?
  52. 4l80e Shifter bracket help on trans..pics inside
  53. 4l60e front bushing replacement?
  54. Speedo readout delay????
  55. Planning on going to the track this weekend with my performabuilt 4l80e
  56. trans noise
  57. e40d ????
  58. what tranny cooler do you run?
  59. does the 4l60E need a computer???
  60. Full Manuel 4L60E
  61. GOOODAMMIT!!!! tranny is slipping.
  62. 4L60E acting funny
  63. Racing from a roll?
  64. th350 or 700r4 ????????daily driver + drag racing?????????
  65. what size tranny coolers are you guys running
  66. Tranny Rolls in Park and in gear
  67. transmission troubles
  68. Torque Converter
  69. How Much Will It Hold?
  70. videos of driving with a stall
  71. What Stall R U Big Cube Guys Running??
  72. anyone know what's the biggest tranny cooler u can fit in an ls1 car?
  73. I think I lost third, please help!!
  74. Is there a procedure to determine the stall of a torque converter (out of the trans)
  75. Pan gaskets... What do you guys recommend?
  76. trans pull questions
  77. how do trans lines lock in? help!!!
  78. 4l65e
  79. 4l60e update question
  80. Why they swap from 4L60E to 700R4?
  81. 4L60E interchangeability Qestion
  82. Anyone With Vig 4400-4800 ?
  83. Happy with your Vigilante?
  84. 93 z-28 hits limiter
  85. Fitting a 4L60e to LSx - Help!
  86. How often do you change your trans fluid/filter?
  87. help....which stall?!?!
  88. A4 lt1 into A4 LS1
  89. Wish I had gone bigger
  90. spray question
  91. Vig Converter!!!!
  92. anyone need a 4l60e output shaft?
  93. Trany for camaro
  94. Older 4L80E
  95. Flexplate questions
  96. 4L65E Selector Switch Wiring Diagram
  97. is this a tranny problem or something else?
  98. Guys running a 4L80E, come inside.
  99. A Rare, Rare Thing These Days...
  100. 4L60 to 6L80
  101. Which other starter can I use?
  102. how much room between shift point and rev limiter for nitrous
  103. Factory trans temp sensor
  104. Need some info on HP levels with the 80e...
  105. anyone run a ati th350 and converter
  106. whats so good about rmvb?
  107. Another stall question
  108. How long does it take you to......
  109. Free Shipping or Installation / ACE Racing Transmissions
  110. Flush It
  111. vibration at idle in forward gears
  112. pics of 60e and 80e
  113. 3rd gear only p0757 with stock stal
  114. Holly shibatman!
  115. limits of performabuilt stage 3?
  116. TransGo shift kit questions
  117. lost all of my gears
  118. TH350 Converters
  119. Is it weird that it feels slower to me?
  120. Trans 4l60E shifts slow into reverse
  121. short throw shifter
  122. Tranny cooler with or without a fan
  123. 4l80e parts at dealership
  124. Which tranny cooler uses AN fittings?
  125. Is my tranny f@ked?
  126. Tranny Questions. HELP!!
  127. gear vendor
  128. tranny issue?
  129. 4L80E Sensor Questions
  130. how to make a non lsx 350 work in a lsx
  131. Looking for the best tranny cooler to run in a c5 vette
  132. Transmissions acting REALLY wierd.
  133. what size converters are you turbo guys using?
  134. Is there a protection thing in my A4?
  135. Dyno Numbers Through 3200 Stall
  136. Trans. Break question
  137. Stall ? for th-400
  138. smaller stall behind a 408
  139. Need a new Tranny
  140. Need help on a ford e40d
  141. 97 Trans Cooler Lines
  142. 4l80 converter wont lock up...
  143. 4l60e noises...
  144. Vigilante TC advice
  145. 700R4 question?
  146. Need help on what to do
  147. tranny rebuild
  148. Doing a burnout at track on slicks to heat up tires
  149. Installed a Yank, but what's wrong?
  150. tranny cooling lines
  151. My POS car v.transmisson
  152. FLT Level 4?
  153. Honda Passport Cold shifting Problem.
  154. Gear Shifter Button (Automatic Tranny) Gets Stuck
  155. Shift Solenoid B stuck ??'s
  156. flywheel turned??
  157. Did I Hook Up The Trans Cooler Correctly ??
  158. 4l60E Upgrades....help/suggestions needed.
  159. help on 95 4l60e
  160. Looser stall???
  161. coverter rattles!
  162. Tranny slipped twice.
  163. The question is......Can you?
  164. 4L60E Bolt Pattern
  165. Got a stall? You need a trans temp gauge!
  166. 6.0 flexplate with 4l60
  167. What tune should I use for diablosport w/3500 TC
  168. HELP!!!!! older 4l60 in to a ls1 car
  169. Exner 4l60e
  170. 4l80 install goes bad when you receive a 4l60 converter
  171. wierd problem with 4l60e
  172. I Need Help With A Th400
  173. how much
  174. A question about ss 3600 and STR's.
  175. whos cammed + stalled with stock tranny?
  176. wheres john AGAIN
  177. flt
  178. Tranny Line E-Clip problems
  179. Tranny and transgo shift kit?
  180. performabuilt 4l80r
  181. Converter and tranny cooler???
  182. how much is it worth?
  183. 2 Speed Powerglide for sale $900.00
  184. Vig Stall change
  185. tranny problem?
  186. How long will my stock A4 last with H/C?
  187. 2-3 shift is going bad
  188. Tune and new trans/converter
  189. Which shift kit should i buy?
  190. Quick ?
  191. Th400 problems
  192. 4.56 Gears with a TH400
  193. i switched to a TH350 no speedo now but it's banging the rev limiter?
  194. just how heaby is a 4l80e???
  195. Torque Converter education
  196. will a 4l60e out of a s10 work on a lt1 camaro
  197. Top Bellhousing Bolts on 4l80e
  198. Too much stall???
  199. 4l60e wont shift out of 2nd to 3rd what should i do???
  200. 2-3 shift slip after transgo kit?
  201. Convertor Question
  202. digital trans pressure gauge?
  203. Can't Decide...
  204. Does this look like a cracked flexplate?
  205. Just got done rebuilding my tranny,?
  206. (4l60e)-p01416 what is it?
  207. Which cooler for trans?
  208. Recommendations on trans parts??
  209. Why can't I lock up on the dyno?
  210. installed prothane tranny mount today ned opinions and help on something...
  211. converter question???
  212. 4l60e
  213. Need advice on torque converter
  214. opinions on this converter
  215. Hughes Overhaul kit
  216. Lokar users inside
  217. will this stall work
  218. Odd 2-3 shift problem: 4L60E
  219. Who knows Fuddle torque converters
  220. How many have a stall on the stock 4l60e
  221. spraying nitrous through shifts on stock 4L60E?
  222. Another 460le goes boom..
  223. 4l80e Trans Cooler
  224. 97 vette with 4L80E
  225. shift linkage on 4l80e
  226. Problems with the tranny!! Help!
  227. Hooking up Speedomter to 4L60E
  228. long time to shift on 100 shot?
  229. lt1 th400 crossmembebracketr bracket w/ T.A. relocation
  230. 700-R4 attached to LS1. Convertor Question
  231. Performance 4L80e rebuild
  232. Has anyone here went from 3.73s to 3.42s?
  233. Stock 4l60E pan depth?
  234. What is this sensor called????
  235. Anyone know what I need to use to bolt a C5 trans to the motor? No torque tube
  236. need the speedo wiring
  237. LT1 -to- LS1
  238. th 350 guys come in
  239. Yank 3600 ?
  240. 4L80- will not shift into overdrive
  241. 4l80-e dimensions
  242. new tranny slipping
  243. put trans back in now gas guage and tcs not working???
  244. Help! Calling out to the 700R4 pros!
  245. PN for AN fittings
  246. Converter experts please teach me
  247. Torque convertor clutch circuit code came up
  248. Strange Transmission Problem
  249. 4L60E 2nd gear slipping?
  250. converter burn out
