- Tranny cooler lines~ how do they connect?
- V6 3800 Trans??? What is it??
- At Trans available.
- Flexplate int or ext Balance? Or Neutr for Stock 95 Transam?
- tranny install
- Auto : Approx. RPM SHOULD it shift?
- 4L60e Worth
- rpm transmission number
- To Be or Not To Be? ..... Vacuum Modulation?
- HP loss thru a Powerglide???
- random slipping?? i think
- servo installation...
- WTF: tranny acting wierd
- Yank 3600 VIDEO
- Do you think my trans is slipping.
- Tranny help again.
- help!!! rebuilding a 4l60e!!
- T56 To 4L60E. Have Some Questions.
- 4l65E
- code 753
- flexplate good to handle 600rwhp??
- WHAT CARS/TRUCKS DO 4L80e's COME IN?????
- th400 specifications
- 4l60e power limit
- TCI Super Street Fighter Questions
- built 4l60e what should i pay?
- How do I change the filter on my 4l60e tranny?
- 4l60 flexplate shield
- 4l80e shutter
- flexplate shield for 4l60e, I know this is FI
- 4l80e trans for c5 corvette
- Camaro/FIrebird A4 shifter identical?
- 4L80E-HD2-D Shift kit firmness
- need rebuild parts list... everyone PLZ help
- vss ?
- shift kit 4l60e
- Is my trans. goin out?
- how much stronger is the 4l65e?
- Which Transmission to Choose?
- tci 4200 stall drivability?
- 4L60E shifter linkage help!
- Step by Step How to remove 4l60e transmission!!
- need step by step tranny removal
- is my tranny mount bad?
- Sound from transmission volant???
- dexron VI
- Broken Sprag?
- 700R4 Shifter
- lose lock up until I turn my car off
- This may be a dumb "cooler" question...
- Quick ???
- What Aftermarket Shifter For TH400?
- Tranny bouncing off limiter 2-3 shift
- 4L60E or T56
- Question about C5 auto transmission
- car lurches forward
- a4 not going into o/d
- Sould it shift so hard going into second at low speeds?
- transmission slipping??
- Broken 4L60E#2
- Which converter for me?
- no shift or speedo need help
- Scattershield for a 2004R
- **%&** Trying to put 4L****tyE in tonight.. Damn Bell bolts
- 4l60e To Turbo 400 Speedometer Help!
- TH350 or 4L60
- So it's time for a shift kit...got some questions!!!
- M6 to A4 swap parts listing please?
- non lock up converter for light street duty.
- Tranny or stall problems? Maybe?
- 6L90 Aftermarket Parts
- A4 not shifting out of second
- flex plates for LS engines
- 4l60e to th350
- Mileage went down with trans rebuild?
- LS2 flexplate
- All 4L80e owners, I need feed back please
- Built 4L60E stage 3 tranny Makes car jerk around???
- 4L60-e, 4L60e? Difference? Bellhousing difference? HELP!
- tranny mount?
- low gear set for th400
- A4<-->M6 Upper Consoles Interchangable?
- 3rd gear slips...help....
- List of Bolts needed for a 4L60E install?
- Trans. temps.
- help me settle the cooler debate Plus trans update
- best stall for Corvette
- Gearvendors overdrive unit
- servo vs. shift kit
- Couple videos of FLT Lvl 4/PT4400
- Broke another 4L65E input DRUM (pics)
- converter for ms4 cam?
- PT4400=ST3500 in normal driving
- 4l80 shift kit
- aeration in trans fluid
- wheres john at fuddle?
- how bad a burnouts for transmission's
- should I change out the tranny oil...
- Some questions about a stock 4L60E and a D1SC
- Trans cooler and FTRA
- TC lockup question
- 4l80 retorfit in 90 Burb
- wtf did I do???
- clutches burn
- need help
- Performabuilt Level 1 & 150 shot
- 4l80e rebuild - How much power is yours taking like its there job? What upgrades?
- Small screen important?
- 6l80e
- 4L80 right from the start??
- 4L60E cores
- 4L60E transmission & radio
- No third or fourth. 4l60e
- Torque Converter Sugestions
- got a new level 3 race 4l60e!!!!!!
- Going bigger??
- Is it okay to buy a used converter
- New to converters - need help
- Which LS Series OEM Flexplate has a Dual Bolt Pattern for TH350 Install?
- Question on 4l60E
- another th350 ?
- th400 and 5.3L
- 2-3shift revlimiter stall before shifting???? solenoid???
- Lock-up with 4L60E full manual valve body
- seating the converter
- What converter?
- Anyone ever heard of this brand?
- another TH350 question
- 4l60e or 4l65e ???
- Yank SS vs PT series
- What 4l60e rebuild kit???
- What's actually "beefed up" to your TH400?
- $3,000 + Toy Shop= No car. Help Anyone?
- Stall Jerk
- Shift problem at w.o.t
- Pwm ?
- Advice on converter choice (Yank SS3200 vs 3600)
- 1996 4L80E question
- need a sturdy 4l80e
- trans coolerS in series???
- 4L80E Install Pics
- No second gear
- shift kits
- Flexplate bolts
- 4l80e swap.. Good Price?
- Need help badly, P1870
- Had a flex plate come appart on you? inside please
- Pulling trans.... have a few questions.
- Help Me Build My Own Powerglide
- New tranny Yahhhhhhhhhhhhh!!!!!!!!!
- Difference Between Lt1 And Ls1 4l60e
- Quick question, th400 vs 4l80e
- 6-pinion planet gear
- Simple question regarding PWM
- Is there a difference in an LT1 converter and LS1 converter???
- Where can I find new cooler lines?
- I need a 4l80
- turbo 400 on an lq4
- Shifts from 1st to Over Drive!?!?
- 2nd to 3rd shift problem please help
- GOt a ? about tuning with new Stall
- vibration once converter locked up around 50-75 mph
- Tranny slipping
- stock flywheel resurface Q?
- 4l80e log lockup seems to be slipping
- Blown Tranny???
- 4l80e lockup?
- RPMtransmission level 4 4l60e
- new setup
- Yank SS series vs Yank PT series and nitrous
- help with 12 o'clock bolt!
- trans temp guage sender in pressure port and temps take forever to rise
- Fuddle 3400 quit locking up
- Please help! Bolt size for mounting the trans to the rear of the motor???
- 2800 Stall question
- Won't shift 1-2 under WOT, after trans and converter install.
- What would help? 2-3 shift
- i need a good transmission rebuild kit any recommendations
- Performabuilt 4l80e installed
- Looking for reliable BACK-TO-BACK stall data
- Yank Pro-Thruster 4000 vs 4400....Which for me??
- Tranny Fluid
- Locked/Unlocked Converter...what does this mean
- Is a Yankss4000 To BIG???
- Good street/strip converter for TH-350
- 4L80E TCC limit Valve in pump question (FLT),others help
- Cryo treat?
- 4l65E for 2002 suburban
- 4L60E problems
- Can any sponsor get me....
- Effect of a low lockup mph with aftermarket converter?
- Shifter install help needed
- whats the deal with gear vendors??
- Checklist needed for odd noise. Please?
- Which is a better option, rebuild or replace?
- Silverado SS converter question
- Will the stall work fine?
- 700r4 on ls1...
- 4L60e help!!
- What shifter would you buy?
- hp on a stock 4l60e
- Rebuilt 4L60E Price too low??
- Add spin-on filter to cooler line?
- Need Trans Help!!!!
- Digital Trans PSI gauge found!!!!
- flexplate question
- whats best
- Torque Converter install ISSUE!!
- Shift MPH question
- Planning on doing my performabuilt 4l80e swap this weekend
- Whats a good size stall
- TH400 as a DD
- trans cooler
- What is the stock trans in a 2000 Firebird?
- won't go into gear
- unusual t/c question...road race
- Drop car into 1st, takes off in 2nd
- slipping around 85ishMPH?
- Whats goin on?!
- Converter for Powerglide.
- Converter or Gears
- Torque converter
- Installing aftermarket shifter...Help!
- Yank 3200
- what to get: 4L60e tranny and Torque Converter
- made a mistake?
- Vacuum Line hook up?
- what stall and gear? help me decide
- 2001 Chevy Van 4l80e
- THis the right SFI Flexplate for 4l80e?
- temp gauge
- No lock up, brake light switch?
- Transgo HD-2 C sep plate drill sizes
- Need some help please!
- Yank PE Series?
- which converter is best
- 4l60e lockup
- Vibrating Noise at lock-up
- stall?
- What size stall for a 383 lt1?
- 4L80E parts interchange DETAIL
- new turbo 400 install by ace racing perf-
- B&M trans temp sending unit
- deep tranny pans.
- Lock-up intermittent at highway speeds...
- 4l60e shifting issues when warmed up
- Need 4l80E
- Ordering a performabuild this week
- Did i install the trans cooler line correctly ???
- Question for Tranny Pro's out there~!
