View Full Version : Automatic Transmission
  1. Vacc Modulation Explained
  2. Can someone take a look at my TCC charts (pics)
  3. Need M6 Conversion Package - Interested in a swap?
  4. Shifting issues
  5. 4.10s and stock converter?
  6. quick fluid question
  7. M6--->A4 Pedal Swap?
  8. Will changing rockers screw with my converter?
  9. 4l60e question
  10. ACC Converters
  11. Torque Converter Installations
  12. Th350 build
  13. just rebuild the transmission but it wont move
  14. HElp to find a 4l60e for a 95 camaro z28
  15. need 4L60E recomendations
  16. My Trans worth anything?
  17. At the track with the lvl 2 performabuilt (vid inside)
  18. b&m shift improver kit?
  19. how much for converter swap??
  20. stall
  21. 4l65E WOT overdrive shift, DEAD!
  22. Stickies are in here!
  23. 4L60E Case Length?
  24. Grrr vacumn modulation sucks!!!!!!
  25. 4L60E with Fuddle 4000 stall
  26. synthetic trans fluid.....
  27. Shift Kit
  28. Trans fluid change
  29. 4l60e highway TC lockup...tunercat
  30. Launching in OD?
  31. grinding noise after convertor install
  32. raptor converters
  33. Transmission Mounting Bolt Size?
  34. Which clutch wires do i jump?? HELP!!!!
  35. Which better for a 600HP/600# TQ LSx stroker a "performance built" 4L60E or a 6L90E??
  36. 4L60E interchange and shipping
  37. Tranny thoughts on 1-2 slip
  38. lock up when cold?
  39. Funny activity in 3rd gear on 99 LS1 (A4)
  40. m6-a4 conversion *I need wiring help*
  41. PerformaBuilt Special!
  42. Tail shaft question. Same as v6 as on v8?
  43. Help. Converter wont lock...
  44. th700r
  45. NEED COMPLETE INFO 4l60e to th350
  46. weird problem
  47. pt vs ss
  48. A4 trans pros I need your help
  49. Transmission install write-up?
  50. 4l60e converter on a 700r4
  51. Transmission mount problem help needed ASAP
  52. Convertor Lockup
  53. need help
  54. Quick 4l80e question
  55. The Real Deal From FLT
  56. TH-400 Planetary Sets
  57. Just got a B&M Trans Cooler
  58. lt1 tranny and ls1 tranny??? A4
  59. dope cooler install and daily driver
  60. newb question
  61. My trans. is leakin where to check first???
  62. No reverse??
  63. vig3200 good... vig3600 bad??? WHAT!
  64. Street driven Powerglide users....
  65. no reverse, noise in park/neutral
  66. Question about my TH350
  67. stall question
  68. Two questions...
  69. A few A4 Conversion Questions
  70. Which Converter for me
  71. Neutral Safety switch wiring help.
  72. Car won't stay running NEED HELP
  73. Will a Stall for a 4l60 E work on a 1979 Corvette 3speed tranny
  74. SES Light after TH-400 install??
  75. shift solenoid??
  76. Shift Kit...Need help
  77. 4l80e trans lines
  78. Tranny cooler
  79. What is STR when talking converters?
  80. What to do with core transmissions?
  81. 4L80E Code 73 running out of gas in my truck
  82. transmission weight
  83. Anyone try a ebay sfi flexplate for $59.99?
  84. Help
  85. ahhh no drive
  86. Yank 3200 or 3600
  87. has this happened to you
  88. keep popin trans lines
  89. 00 ls1 with 95 tranny
  90. Vigilante 3200 or 3600 for 402/Procharger. Suggestions PLEASE.
  91. 4l60e to t-56?
  92. Yank pt4000 and spray.
  93. No third or fourth gear. help.
  94. cooling line question
  95. Ummm.... This is not cool
  96. No forward gears.
  97. tail shaft and bell house
  98. What did you think of your exhaust sound after your stall?
  99. Brake vacuum and automatic transmissions
  100. Drag racing with stock 4L60E and stock converter
  101. M6 to TH-400 conversion, need help
  102. M6 to TH-400 conversion, need help
  103. Yank converters year end sale going strong
  104. Trans plug
  105. Single Wire tbrake button
  106. WTF!!!!! Tranny wont shift from 1st
  107. Shift Solenoids gm part #
  108. th-350 to M6 or 4l80e/4l60e
  109. Is the 98-02 v-6 auto trans the same?
  110. Performabuilt seal/O-ring packet. What are these?
  111. Yank PT4400 for $250, but have acouple questions
  112. Valve body, help needed
  113. A4 Hard to shift from park
  114. a4 shifter linkage problem
  115. 2.2 STR vs. 2.5 STR
  116. TH350/TH400 Frequently Asked Questions
  117. Transmission Advice Please!!!
  118. Anyon heard of Boss Hog Stalls?
  119. TH400 Shift Kit
  120. question
  121. Anyone have a flexplate twist apart, not just break?
  122. Converter unlocks everytime I let off the throttle
  123. Any A4 Shifter Kits Available For 02 Camaro?
  124. Yank, Nitrous?
  125. Weird Noise
  126. slip
  127. Powerglide & speedo
  128. Tranny Problems?
  129. Converter locked up all the time...PCM???
  130. Stupid question
  131. Powerglide dipstick
  132. To much power for converter?
  133. Shifting problems
  134. Which converter?
  135. URGENT GUYS...WTF happened
  136. Can I install a TH-400 without pulling longtubes??
  137. camaro a4 burnout
  138. Bop Th400
  139. 35 to about 45 mph car doesnt seem to do anything
  140. sbc flex on an ls1 and th350
  141. Removing Console With Auto Trans?
  142. whats the most hp a 4l60 can handle reliably
  143. Transmission Oil Cooler Question
  144. do TC's kill the top end?
  145. 85-87 700R4 Convertor in a 1999 4L60E (for a V6)
  146. 4l60e To Th-400 ????
  147. Best gear and stall combo?
  148. 4l60e help.......
  149. 4l60e clicking
  150. yank ss4000, can it be rebuilt for a th400?
  151. what do you guys think about this stall?and a question
  152. check light came on again! p0757
  153. converter slip?
  154. converter advise
  155. torque converter question
  156. Insterested in 4L80e, talk me into it*
  157. 3/4 clutches burnt in an otherwise "Slick" Core!
  158. HELP!!! converter install question
  159. Rev limiter Problems - Any Suggestions
  160. Converter swap.... half way there HELP!!!!!!
  161. Slack in the tranny?
  162. Finish Line Transmissions Holiday Sale
  163. m6 guy needs some a4 help
  164. 4L80 + 525rwhp...
  165. need trany rebuild in houston
  166. Lost 3rd and 4th gear after filter change
  167. has anyone went from a Yank SS4000 to a Vig 3 disc 4000 stall?
  168. shifting questions: TM, firmness, lock up, etc
  169. Transmission Mounts
  170. What type of tranny in 93 f-body
  171. Anyone using this Hurst Shifterfor their 4L60?
  172. car wont go!!
  173. What tab needs to get cut off on a th400?
  174. ACE Racing Transmission Sale
  175. Pictures of a Unique Tailhousing for Old School Apps!
  176. Oil leak
  177. T400 driveshaft work on 4L80E
  178. How do i adjust the line pressure?
  179. T/c Slips Too Much
  180. 4l65e converter in 4l60e?
  181. Anyone Using This??
  182. vibration problem please help.
  183. Tranny Cooler Line ???s
  184. 4l60e dipstick tube help
  185. 02 F Body/350 Turbo Shifer
  186. Anyone here order a Performabuilt tranny?
  187. Should I get my tranny flushed?
  188. Tranny programer?
  189. Tranny going out or what???
  190. Converter not locking when cold
  191. Slack in the drive line.
  192. TH-400 gearing
  193. Pig tails
  194. Flywheel to Flexplate Question
  195. Solenoid Qestion
  196. used yank
  197. someone please help with my th400 please please please
  198. Tranny Harness
  199. Fuddle Holiday Sale
  200. 700R4 Help please
  201. P1870 Transmission Component Slipping
  202. good trans for a lifted truck?
  203. Tci
  204. Will a 3.8 4L60E retrofit to a LS1 or LT1?
  205. m6 --> a4 swap
  206. Will it damage my trans running a pressure gauge?
  207. ACCEL 4L80E programmable transmission controller
  208. how much to send my converter for a freshening up?
  209. listen to my transmission please
  210. Flt Lev 4 + 600rwhp
  211. 1st to 2nd shift
  212. Effect of altitude on stall speed??
  213. Stall problems
  214. how long does 99Z auto have left with 118k miles
  215. converter bolts
  216. 1.82 in a glide
  217. What kind of gain to expect goin from SS3800 to PT4400 converter?
  218. Any Ideas?
  219. How much hp can a stock A4 hold?
  220. Auto Trans Problem - No Reverse
  221. Blew the front pump seal, have a few questions?
  222. Crate transmission or have one built?
  223. How much??
  224. transgo hd-3
  225. car will not shift into o/d 0753 code
  226. Trans cooler
  227. Help me decide guys!!!!
  228. Car sucks from a 60-70mph roll
  229. transmission whine?
  230. Harmonic balancer bolt
  231. rev limiter issues
  232. should i pickup any MPH
  233. Shift Kit Options
  234. Transmission cooler mounting dope setup
  235. M6 to A4 question about noise.
  236. 2002 Lq4 to 4l60e flexplated issues
  237. Redline:6500 Fuelcutoff:6600 Latest point of disengaging and shifting?
  238. My 99 TA has given me its first bad problem :(.
  239. Yank SS4000 and a 200 shot.
  240. 3600 Stall
  241. tranny acting up when shifting into 4th
  242. 2004-r 6.0
  243. trans temp good or bad
  244. delay in shifting
  245. Changed fluid/filter in my performabuilt
  246. Help with Fittings?
  247. torque management question
  248. drive shaft with th350
  249. trans break
  250. What happened to your trap?
