View Full Version : Automatic Transmission
  1. Help. is it normal or something is wrong?
  2. Th400 Experts Help Needed!?
  3. How does a 4l60 1-2 Accumulator operate?
  4. PO757 Fluke? 2-3 Solonoid
  5. Tune PCM to make converter lock in 3rd?
  6. 2001 Caprice 4l60e
  7. TCI now has 4l80e to ls1 flexplate
  8. th-350 in LT1 car
  9. Converter Wont lock after Manual Valvebody
  10. Trans problem??
  11. 4L60E Vacuum modulator or not??
  12. difference?
  13. Wot Lockup
  14. FLT takes the wow factor!!! Lot of Pics
  15. Guys w/ TCI SSF4000's come in..
  16. what tranny could i use?
  17. Help
  18. difference between lt1 and ls1 4l60e's
  19. WTF ....tranny bolts breakin / rusted!!
  20. How did you guys get the top 4 bellhousing bolts out?
  21. Tranny or rear?
  22. is this streetable???
  23. Need a tranny tune.
  24. 4th gear flare need help from the pros
  25. Huge Tranny Problem Please help
  26. Prothane trans mount Problem
  27. What tranny cooler for YankSS4000?
  28. Looking for feed back on Fuddle Racing Converters
  29. Converter install question/problem...
  30. Will an LT1 verter work in an LS1 tranny??
  31. What size stall for a TR 230??
  32. Finish Line Transmissions Is Proud To Announce
  33. Because you Asked!
  34. info needed on stall's....
  35. Stall Recommendation
  36. My Art Carr 3600/3800 Nitrous stall sucks on motor!
  37. Converter Question
  38. Strange Vibration
  39. So i blew my tranny
  40. Clips for cooler line coming out of trans. 4L60
  41. 4l60e help
  42. Tranny problems, revs in gear but rev. works
  43. Solenoid Problems
  44. car won't shift out of second @wot
  45. How long did your stock trans last w/a stall?
  46. what shifter cable
  47. Fresh Rebuild acting up bad!!! HELP!!!
  48. Help me Please
  49. Lockup Trouble..
  50. transmission leak after converter install
  51. can you downshift a rmvb th350
  52. 200 4r
  53. Time to rebuild or tuning issue?
  54. does anyone's stock 4l60e eat fluid?
  55. picking up my first th350 tranny.. questions
  56. how to shift a A4?
  57. Transmission service port above linkage, safe for temp sender?
  58. Another 4L60e problem
  59. 4l60e drive and overdrive revving out
  60. Yank ss3600 on street tires
  61. downshifts are firm after tune
  62. 4l60E car won't move
  63. Fluid
  64. Rebuilt Trans and seems slower?
  65. Yank SS3600 Installed....
  66. Transmission Fluid
  67. 4L60E Transmission Mounts
  68. The hole this is funny
  69. LOUD clunking noise coming from stall convertor area....
  70. 4L60E interchange
  71. what would cause car to misfire in first and second but not 3rd
  72. How soon must I tune? Installing a Fuddle 3600...
  73. Trany Slipping!!!
  74. Code-Torque Convertor Quad Driver Module?
  75. just got my th400 almost in...
  76. 94 camaro 4l60e tranny problems
  77. 4L80E in 67 bird
  78. tail shaft housing?
  79. transmission shift points
  80. Th400 Or 4l80e
  81. tune for yank 4200
  82. Help with t56 to turbo 350
  83. Broken/Cracked Flexplate..
  84. Need a 4L80E built. I think????
  85. 4L85e
  86. 700r4 dilema
  87. listen to this!!
  88. What stall do i need??
  89. Where to get pigtail for TH400 VSS
  90. Best trans cooler
  91. ACE Racing Transmissions Halloween Sale
  92. 4l60e problem
  93. What size fitting is the pressure port on a 4l60e
  94. shims between converter and flexplate?
  95. I have a tranny ?
  96. converter for 4l60
  97. anyone have a clip of a th400 with a 4500 stall
  98. Excellent...
  99. Best deal for Vigilante Conterters
  100. TH400 Shifting
  101. OD in my 4l80e doesn't work correctly...
  102. M6 Tranny Mount work on A4#
  103. not again...:(
  104. tci flywheel choice for th-350 swap?
  105. Need tranny help!!! A4
  106. P0757 symptom
  107. stock tune with 4000 converter
  108. what everyone shifting at with yank pe 4200
  109. 4l60e rebuild kits.
  110. Blew up torque converter
  111. M6 to TH 350 SPEED O
  112. trans problem need help!!
  113. Please Help ? About Trans Cooler Lines
  114. Am I askin for trouble???
  115. computer shift OR manual shift??
  116. Fuddle 3600 to Yank PT4000..opinions?
  117. shift bracket (side transmission)
  118. turbo 400 questions?
  119. Th-350 Swap What Flywheel?
  120. To stall or not to stall?
  121. 3200 Stall?
  122. TH 350 to an LS2
  123. Hows it look? Yes? No?
  124. Converter Question.
  125. How Tuff Is A 6l80
  126. Anyone have these problems after 4l80e swap?
  127. motor oil in your tranny???
  128. speedometer problem
  129. Is this Normal?
  130. Lock the convertor while running?
  131. PT4000 or PT4400??
  132. Newbie Needs ur help
  133. tranny weights
  134. Hurst QuarterStick install
  135. Is anyone running a PTC converter? Is it any good?
  136. fuddle 3600 stall, please commet
  137. PTC Converter any good?
  138. Is $250 a good price for a converter install?
  139. Will a 4l60e cooler fit on my 4r70w?
  140. Please help!!! Is my transmission going out?? Slipping in 4th
  141. Need Help With Drive Shaft Length
  142. fuddle 3400 or 3600
  143. Where can I get a th350 rebuild kit
  144. Whine from tailshaft
  145. Pro Yank 3400 Extreme
  146. what tranny mount?
  147. kinda of a newb question.
  148. TH400 Bellhousing Question
  149. torque management delete???
  150. Vig or Yank?
  151. Help!! P1870
  152. Going rate on used 4l60e
  153. What can I do with Mercon V?
  154. Stock Auto Shifter Button Won't Depress
  155. Finishline 4L60E Burnout ?
  156. Who did their own stall installation?
  157. YANK'S Big October Fest Sale is here!
  158. A4 Tranny Problems!!!
  159. hot to use stock shifter with th400
  160. Factory filled units
  161. What stall for a turbo?
  162. Yank SS3600
  163. Help.....Tranny shifts hard from 2-3 ?
  164. th400 with 4500 stall
  165. 4l60 question
  166. M6 to TH-400 flexplate question...
  167. ATI/402 Stall Recomendations
  168. My Ta Shuts Off At 4500 Rpms After New 4l60e???????????????
  169. ses: P0757
  170. STR??? what does it mean???
  171. which stall please help
  172. Basic tranny upgrades?
  173. TCI converter/ls1 pilot
  174. Problem with my 4l60E
  175. How high does your 2nd gear go?
  176. ls1/lt1 tranny but other way around
  177. Who has the STRONGEST BUILT 4L60E??
  178. Stall Converter Qs
  179. '02 4L60e won't shift out of 2nd
  180. C5 corvette output shaft measurement needed..please help
  181. 2nd Accumulator Piston
  182. Stall size?
  183. 4l80e in gm hightech shootout
  184. tranny fluid?
  185. ATF and converter question.
  186. Is it possible to fill the tranny this way?
  187. Urgent LS1 AND 4l80E problem
  188. was there a th375 produced after 1976?
  189. 4L80E post-install followup...
  190. pros/cons th350
  191. tranny whines in reverse
  192. 4L60E, MAF and LS6
  193. 4L60E Shifts hard from N to Drive
  194. need new transmission-DFW area
  195. best place to put
  196. 4l80e difference
  197. need asap help th400 or 4l80
  198. 350 turbo
  199. Can anyone help explain the TH375
  200. Tranny noise
  201. What would you upgrade?
  202. torque specs
  203. what will cause tranny to bounce of rev limiter at WOT??
  204. 4L60E to TH-350
  205. Q's about input shaft 4l60e
  206. yank ss3600 is in an runin!
  207. Pt4400 Users Only-inside Please
  208. Anyone use aftermarket radiator w/trans cooler?
  209. What Stall?
  210. setting shift points
  211. Neutral safety on A4 to A3 conversion with an aftermarket shifter?
  212. what size stall should i go with
  213. 4l80e -> 4L60e wiring
  214. rmvb best place to get one
  215. Need opinions!!!
  216. Help!!!! lock up and speedo issues...
  217. Bolts - Flexplate to crank
  218. Trans shifting question
  219. Need some Help
  220. Got my 4l80e swap done, one question...
  221. Need some help! Car won't go doesn't go forward anymore
  222. Trans slipping in overdrive . . . . .
  223. t-lock questions???
  224. th-350 guys
  225. stall acting weird
  226. 4L60E techs
  227. largest cam on stock converter
  228. Many 4l60e problems
  229. life of trans after converter
  230. th400 in 2000 Trans Am
  231. decoding the th 400
  232. Transmission is going out...What should I do??
  233. 1st gear gone?
  234. 4l80 Output Shaft Pic... which yolk do i need
  235. Wiring nightmare
  236. trans cooler
  237. Case differences
  238. Automatic Get me more MPH????
  239. Dropping a 4L60E...
  240. PG Driveshaft
  241. anyone ever run an in-line tranny filter?
  242. Final word on transmission mounts
  243. Want to manually shift my 4l60e
  244. TransGo 4L60E HD-2 ?
  245. Which Stall Should I Go With????
  246. converter help
  247. clips for hard lines
  248. help 4L65E
  249. stock pan burning up 2-3 clutches??
  250. a4 tranny
