- is my flywheel(flexplate) warped?
- 1-2-3-2-1 when should all be in first
- LT1 Tranny Swap Questions
- Trans is dead...no 3rd or 4th
- TCI SSF 3500 Vibration
- B&M Shift kit good?????
- Tranny Line Connections...
- Lokar 4l60e tranny dipstick
- c5 tranny removal? any tips?
- 240* trans temp!!!
- turn off while in drive hurt it?
- PLEASE guys. i need your help ASAP!
- Trans or stall??
- what does this seal go to?
- Best Aftermarket flexplate?? you tell me
- Trans Still Wont Come Off Motor Hellppp
- Car Won't Shift at WOT
- Stall install guides
- converter help
- 3/4 Clutch pack install ?
- Installing new trans and tc in 1999 c5 balance question...
- 4l60e cooling lines
- 1-2 accumulator help
- trans experts needed
- LS-1 VIGILANTE stall on an LT-1
- Lockup issue revisited...it "kinda" locks up?
- TH350 flex plate
- In search of built th400
- TH400 + 67 LS1 TT Nova which ratio
- HD3 and Converter lock up
- I'm on my 4th rebuild / 2nd tranny in 1 YEAR!! HELP!!!
- any good write up on shift kit install?
- Y cant i take bolts out intead of pins on cooler lines on tranny?
- converter hesitates to un-lock
- Shifter sticks, doesnt line up..
- 3-4 accumulator, which way do the pistons go in? pics
- Do Not Put Tc On Flexplate First!!!!
- daily driving question
- 2000 c5 tranny change now immediate slip!
- wich line is wich
- My tranny cooler
- 4L80e tune help needed
- i think my trans pan bolt holes are stripped.
- TCI Flexplate
- Lower tranny temps can help power???
- ~~Stalled car trans temp??~~
- LT1 OBD2 Converter Lockup Speed Stock and Modified
- How Many Bell Housing Bolts On 01 Ta??
- Tranny Is Dead!!!!
- trans problem its in limp mode
- Trans comes out of lockup
- stall/trans, how do they change what gear ratio is needed?
- Where do i put in temp sensors for gauges
- PERFORMA BUILT tranny level 2 running 10s
- How do i pry my transmission off motor?
- 4l60e to th400 question, done but somethings dont work ?
- Need Help! Parking Brake Button
- Just installed TCI SSF
- help transsmission wont come off motor
- Hp tuners Line Pressure
- is this the right bearing that goes ontop of selective washer?
- Trans problem?
- problems with TH400...
- bad shifts
- Yank SS 4000
- painting transmission
- 2nd gear gone?
- A huge thank you to Ace Racing Trans - Gilbert and John
- TCI th350/400 converter for ls1
- whats it worth?
- My car will not 60 at all with my converter is it wrong for my ap?
- yank pt 4400 to ss3600?
- Th400 w/trans brake
- Overdrive
- tranny problems??
- Wiring..
- DEXRON VI now available...
- A4 to TH400 swap, do I need to buy a new dipstick tube
- Tranny cooler lines on Tranny ACCESS??
- performabuilt converters
- No Reverse,Late shift in second
- Weird Problem.
- TH350 aftermarket shifter question?
- Stock 4L80E w/ New TC & TCU... or Built 200-4R ?
- Shifter Rattle
- Yet another ss3600 TCC Lock-up ISSUE
- Torque arm bushing 10269131 or 10269129?
- Why is my trans leaking?
- Broke New Trans With 0 Miles!
- ACC (alabama) torque convertor?
- Yanks new Address
- 4L60E problem,added lucas now strange shifts and speedo bugging
- Didnt shift outta 2
- What tranny to Runnn???
- M6 to A4 problems HELP!
- 4L60E problem
- for those who have 98 LS1's what's your bellhousing serial number?
- Yank Converter wont lock even when commanded to
- Blown corvette servo in new trans?
- after market shifter in a4 console???? what to get and what works and looks good
- RPM Stage V 4L60E ?
- PCM tuning for 4L60E's !
- What else to upgrade with new stall...
- lost third?
- what are common symptoms of a bad stall
- Anyone ever run a Rock On transmission?
- valve body swap
- What stall and trans cooler to use?
- 4L60e Converter
- Why cant anything go as planned?
- shift kit washers
- Problem with 4L60E build
- the last c-clip, is it suppose to touch the spring clip?
- Need opinions on this parts list for stall.
- Price List / Introductory Sale
- stupid question inside
- yank ss4000 in daily driver and know car shifts erradically...come in.
- Update: Yank Install
- 4l60e gurus please help
- shifting question
- Trans cooler help
- Is it normal for a rmvb th350 to shift automatically after failure
- what's a good trans oil cooler?
- Front seal keeps going out???
- new boost ready vig 3200 not hitting hard
- if your trans fluid smells like.......
- Who is running a 4L60E Trans with 600 RWHP
- Can I rig up a device that will flush my A4 for fluid change??
- temp gauge
- TCC wil not lock up please help.
- can anyone tell me what this is on my 4L80e?
- broke the rock-on down...
- shift points and mph
- The Yank Has Arrived!!!!
- b&m transpak question??
- 4th/OD vibe?
- who builds the best powerglide?
- Torque Converter for DD Vette?
- 3-4 accumulator, is this normal? pics
- Clips...
- Finally we signed up as Sponsors!
- No OD after rebuild
- Valve Body
- PerformaBuilt transmission FAQ and help page check out interesting stuff.
- Think I lost 3rd & 4th. Please help!
- Anyone have any lockup issues with any yank converter? (specifically ss4000)
- help with converter
- where can i purchase a tranny cooler "true cool"
- converter question
- where can i purchase a hughes converter
- converter advice
- How to shift a Auto for Drag?????
- b&m transpak??????
- The classic will the tranny hold question?
- -Speed Density and Shift Tables- not agreeing with one another :HELP:
- Trans removal
- Need help picking a stall.
- 4l60e only lookin for 400hp
- powerglide
- building a th400 any tips?
- help!!
- Performabuilt 9.5 Converter Sale And New Offerings!
- Th400 Installed Now Bad Vibration
- Bulider in the New Orleans Area
- Trans slipping?
- 4l60e to 6l80 swap?
- What is considered Normal Trans oil Temp?
- RPM Stage 4
- 4L60E shifters??
- built 4l60e, no downshift to first
- Th400 bellhousing mounting
- Yank ss3200 converter- where to buy?
- WOT 1-2 shift question
- transgo 4L60e-HD2 kit
- Need gear ratio's for a 99 4l60e
- Acceptable trans temps?
- M6 -> TH400 VSS / Speedo Correction Via HPTuners Info
- A4 cores
- Trans Install Tools???
- Slow 3-2 downshift/kickdown - why?
- Dipstick needing dipstick help
- Torque converter install?
- 3.73s vs 4.10s with 3500 stall?
- newb help with harsh shifting
- YANK will be closed on Mon.18th,Tue19th
- important stall ?
- 4l60e fluid swap
- trans problem
- 4L80E Trans Brake
- Billet Midwest Conerter Lockup Chatter
- Some Question on Changin from m6 to auto
- Is something wrong?
- so far not impressed with vig 3200.
- 94 4L60E Problem rebuild 1st 2nd drag
- 5 pinion planets
- 4L70E built tranny w/ whinning or moaning sound
- A good trans cooler.
- HELP for a DUMMY!!!
- matching cam with converter
- 4l60 help!!!
- 4l60e bellhousing
- 94 Camaro with LS1/TH400 which trans mount?
- Tricky Question: Stall and zex kit
- 1-2 Accumulator springs! Help!
- Whats The Lastest Info On 2001 Flexplates
- What Rpm Are You At Going 80 Mph?
- Lost 2nd gear...need advice
- 2000 Z28 A4, Weird trans problem...please help me diagnose this!
- aNYONE REBUILD THEIR th400? WHAT GOOD PARTS?
- Trans Temp guage installed with sender in test port
- Goin with a 402 stroker need opinions on my trans...
- bye bye 2nd gear
- Need Input!!!
- Rebuilt Trans Problems
- 4l60e wiring harness inside trans?
- How do I find my converters STR (stall torque ratio)
- trani cooler any pics
- question about v6 vs v8 4l60e debate
- How do you remove the 4l60e pump?
- how much power?
- 1st gear AND overdrive issue - need help
- Wanting to rebuild 4l60... what all is needed
- I need some trans help with code P0748
- what kind of 60-foots with yank ss3600
- 4l60e
- OD isssue
- Trans slipping and surging?
- Stalled car drivers - please enter!
- Gear change or convertor change or both??
- Going from OD to Neutral
- input shaft checkball
- tranny troubles ... need your help
- Is there a diff. between lt1 and ls1 4l60E
- Conversion M6 to TH400
- Couple of tranny question's????
- will my trany handle it?
- Rebulit 4l60 × CAM swap,, Which first??
- V8 vs. V6 4L60E?
- 700r4 vs 4L60-E for mock-up
- Installed: Performabuilt lvl 2 4L60E
- How big is my stall? Vig 3600???
- what to do with my old tranny
- Help Taking Off 4l60e Help!!
- 4l60e, 4l80e, or other?
- Trans guys help me out.
- Tips on installing my PI stall converter?
- My 4L80E Swap with pics
- Trans Guru's Inside!
