View Full Version : Automatic Transmission
  1. "Torque management" should I cut it off or reduce it?
  2. shift kit? which one?
  3. Torque Specs on new Flexplate
  4. will a 95 Impala SS 4L60E work in LS1
  5. East CoasT Trans Builder?
  6. tci conveter missing bolt and causing vibrations
  7. Trans ???
  8. shift kit a good idea??
  9. Powerglide ?
  10. Blowing Tranny fluid out coolant lines at WOT only, TH350
  11. Looking for updates from peeps w/TCI's.
  12. FUBAR'd my 95 Silverado 4l60e 4l80 upgrade and 4l60e ??questions???
  13. Help with tranny problems, lost 3 and 4
  14. what is the stock stall speed on an a4 z28?
  15. 3-4 shift at 6500+ rpm - What can go wrong?
  16. 4L60E installing parts list
  17. TCI super street fighter
  18. LS2 GTO Guys, Which Converter?
  19. Trans Question!!??
  20. half a quart low
  21. 4l60 e
  22. Do I need to lower shiftpoints
  23. converter install
  24. Tranny Capacity Question
  25. how to check what gears you have.
  26. TCI-built Street fighter TH350, worth the $$$??
  27. physical differences- 700r4/4l60e
  28. Car will not turn over after transmission swap (Help!)
  29. Tansgo HD-2 kit installation instructions
  30. Transmission Replacement parts
  31. 4L60E bouncing off rev limiter WOT 2-3 shift?
  32. New trans rebuild - No 3rd or 4th gear!
  33. Need help quick! TCI 3500 to Yank 4000
  34. Anyone using a Hughes flexplate with their LS1/4l60e combo?
  35. Stock Z with a TH 400!??
  36. Wanted opinions on whether or not a tranny can get this hot
  37. Throwing it into Reverse
  38. engine surge after lock up
  39. trans cooler
  40. Swapping in a 350
  41. b and m
  42. convertor lockup??? or 02???
  43. Can a stall hurt you top end and mph?
  44. Tranny problems, think I finally killed it
  45. TH400 swap help
  46. 4L80E fittings to Tranny cooler Questions
  47. Firewall Dipsticks????
  48. Stall Install
  49. What tools will I need??
  50. will I need to raise my stock shiftpoints with this setup?
  51. Shift kit on the way!!!
  52. neutral safety switch
  53. auto question
  54. Pic of the converter hub crack
  55. stall suggestions?
  56. tci controler info
  57. Will this hurt my Transmission?
  58. Edge stall converter's?
  59. Yank Please help
  60. Shift Kit?????????
  61. Th350 Vaccuuuuuum Modulator Question
  62. How do I lockup my converter for dyno testing???
  63. Installing a trans cooler
  64. Performabuilt th400 Questions
  65. Tranny fluid leaking
  66. **more Problems**
  67. Harlan 2-Step
  68. V6 4L60E as good as a V8 4L60E
  69. Nitrous may be blowing through the converter - which route to go now???
  70. VSS Changes for the M6 to TH400?
  71. Stripped bolt in Aux Valve body, HELP!
  72. Any LT1 guys runing the 4l80
  73. Atf Changing stall Speed?
  74. >>>Any good Socal Trans. shops around?<<<
  75. How hard can it be to rebuild a th350?
  76. Is 4th gear usable WOT 4L60e?
  77. Royal purple tranny fluid
  78. mount
  79. Tuning for stall conveter, info needed!
  80. Is this 3/4 clutch right?
  81. TH400 Question
  82. 4L60E - Time to change fluid! How?
  83. Yank SS3600 on the way!!! What should I expect??
  84. just got a hayden cooler from yank
  85. Wiring harness question
  86. Overfilled causing slippage?
  87. no second gear?
  88. 4L80 w/o electronics parts list for 98 F-body
  89. necessary to break in new tranny??
  90. TH350 cooler lines??
  91. Pictures of aftermarket shifters????
  92. car wont go into park....
  93. Saturday.
  94. Where are you guys dope mounting your tranny coolers??
  95. 95 trans am i need help with my lt1
  96. What 4l80E performance parts would you recommend
  97. 4L80E performance rebuild documnetation (Photos)
  98. Computer Tuned or Tranny Installed Shift Kit
  99. What stall with a GM 847??
  100. how to tune my new stall?
  101. 4L60E Manual Valvebody. Who sells it? Need help
  102. tractor fluid results
  103. Please Help 3600 Stall Do I Need To Do Anything Else Besides Put It On
  104. First time stalled.
  105. Tranny paint?
  106. Help Help Help
  107. TCI Troubles
  108. problem 4l60e
  109. 4L80e information needed
  110. pics after trans willnot shift into 3rd
  111. 4L80E performance parts
  112. Trans Temp High?
  113. question on torque converter fluid and trans fluid
  114. stall ?
  115. M6 2 A3 shifter????
  116. 1995 Z28 A4 wont shift out of 1st at wot
  117. 4L60E - Manual Valve Body, what does it do?
  118. hard to install shift kit?
  119. transmision going bad?
  120. Trans question...please help.
  121. speedo signal issue
  122. biggest trans cooler
  123. Diif between V6 and V8 4l60e
  124. Stall converter question?
  125. Buying a used converter? Good Idea?
  126. 4L80e swap underway, Final questions-those who did it chime in!
  127. Who carries a 4L80 converter for F-bodies
  128. trade a4 for m6
  129. 4L80E flexplate & 4l60e converter
  130. ~~How to replace 2-3 Solenoid??~~
  131. need help
  132. steel or aluminum pan?
  133. 3600 or 3800 stall
  134. broken
  135. Tranny not shifting! HELP!
  136. who's pushing 400+ RWHP on there stock 4l60?
  137. How much can my Vig 3600 handle??
  138. ANYONE RUNNING A TH400 Trans COME IN!!!
  139. New FLT trans
  140. TC Bolt thread and length????
  141. 1992 4l80e...after 60 mph no 4th gear
  142. 4l80e question
  143. No Balls
  144. school me on stalls
  145. 4L60E - Someone school me on shift solenoids
  146. 95 4L80E from 4x4
  147. A4 guys with a cam and no converter, Come on in!!!!
  148. tranny issues???
  149. Stall!!
  150. ~~~Trans Will Not Shift Into Third!!!!~~~
  151. 400 in
  152. cold starts = hard shifting
  153. why shouldn't i use a hughes stall????
  154. problems after stall w/pcm
  155. tranny problem come help!!!!!
  156. Tranny finally crapped out
  157. Putting a prostick in and..
  158. Continental Converter
  159. th400 pan gasket?
  160. 700r4 ?
  161. Transmission Rebuilt Questions/Concerns
  162. driveshaft breaks while idling through a parking lot...pic
  163. Car is slow as Christmas
  164. 800rwhp 800rwtq
  165. best way to measure trans temp
  166. 4L60e Fluid Capacity?
  167. Transmission Conversion
  168. simple question
  169. 2800 stall not enough???
  170. Quick crank torque question...
  171. VSS O-Ring??
  172. Tranny vibration or not?
  173. Performabuilt lvl2 installed
  174. th350 speedo ?
  175. new th400
  176. 4l80e downshift points help
  177. got a pt4400 and a tci flexplate
  178. Stall or gears
  179. High Trans Temps
  180. Vig 3600 converter?
  181. New tranny already having problems.
  182. tranny help! PLEASe
  183. Yank 3200ss stall???
  184. 2-3 shift problem at WOT
  185. 4L80E differences?
  186. (((Help)) last transmission
  187. wtb a m6 trans crossmember
  188. 4L80E QDM or PSM?
  189. Whats a streetable th400?
  190. trouble shifting out of 1st
  191. My Poly Tranny Mount Experience
  192. how to paint transmission
  193. Does Mileage On An Engine Matter With A Stall
  194. Truck pan questions
  195. Shifter stop removal?
  196. anyone with a py4000
  197. flexplate question
  198. TH350 pricing
  199. TH350 reverse and 2nd gear not working???
  200. B&m temp guage anyone have problems with it
  201. 4l60e problem
  202. 4l60e 1-2 shift problem help!!
  203. shift kit or no?
  204. When does the stock 4L60E become inadequate??
  205. 4L60E Changes (builders?)
  206. Tq coverter opinions (Stock Z)
  207. so cal area reprogram my tranny back to stock
  208. those of you with TCI and PerformaBuilt LOOK
  209. Rebuilt 4L60E - SES Code 1-2 Shift Solenoid
  210. Yank 3600.. too big! what's the best option ?
  211. 4l60E Issues?, Check this out!
  212. Is my pump cover trashed?? Guru's inside please!
  213. I'm thinking about keeping the factory converter and getting a heads and cam combo
  214. Shifter Cable Probs???
  215. trans fluid
  216. ATI treemaster or fuel and blown verter?
  217. tranny help!!!!!!!
  218. Police Package 4l60e
  219. stall?
  220. Opinions about TransGo Shiftkit
  221. don't really know what happened!?!?!?!
  222. transmission mounts?
  223. The powerglide effect
  224. Transmission Help
  225. Vacuum Modulated 4L60E??
  226. A4 Tranny Problem
  227. Installed my B&M rachet shifter
  228. 95 tranny with a 2000 ls1 help
  229. TH350/shifter questions??
  230. vette vs camaro vs trans/am
  231. installing TCI controller for 4L80E swap, will there be SES lights?
  232. Aftermarket Shifter A3
  233. well i blew my transmission
  234. Cannot get 4l60e trans filter seal out sugestions...
  235. guys with the hurst 1/4 stick
  236. Planetary gear inplay?
  237. H/C with Stock Stall?
  238. new converter installed...couple of questions
  239. Spraying thru the shifts...
  240. SY3500 with twin bolt patterns?
  241. tranny removal? HOW TO?
  242. Yank PT4400-how much slippage?
  243. slow to shift into gear 4L60E?
  244. I want the biggest tranny cooler
  245. EL60E Problem
  246. Anybody installed a TCI trans shield on a T400?
  247. To those with the TCI SSF4000 converters...
  248. Carrier questions? Trans guys help me out.
  249. Almost wrecked car...
  250. Car will go into reverse, but when applying gas hardly moves?
