View Full Version : Automatic Transmission
  1. need help, trans 210*, feels like its not shifting
  2. Need Help Fast!
  3. solid mounts + changing TC's?
  4. What thread type on the 46OLE Tranny Case for cooler lines?
  5. Doin the TH350 swap???
  6. Doin the TH350 swap???
  7. trans break?
  8. Whats the best size converter for
  9. Help-need a good cooler-small size.
  10. Where to get a good deal on Vigilante stall???
  11. looking for a ratchet shifter in a 4l60e
  12. Stall on street tires?
  13. Where can I buy a Yank converter for a good price?
  14. trans break?
  15. lock up
  16. Torque converter noise?
  17. whats the difference in V8 & V6 4L60E
  18. Converter noises
  19. Overfull 4l60e what will it act like
  20. TH350, Nitrous, MS3, what stall?
  21. oil pan bolts
  22. How does a torque converter work?
  23. 4L60E overdive ratio plz help ?
  24. Another trans dead
  25. 4L60 question
  26. 97 tranny to replace in 96
  27. Yank 4L60e to LS2
  28. Ls1 Powerglide
  29. Mystery Solved A4 vs CPU
  30. need help with 4l60e
  31. Do you guys lock your verters when running the 1/4 midway?
  32. install for 4l60e
  33. Upgrading a 4L80e?
  34. what should i do
  35. Is a 3400 Yank too small?
  36. need help on torque converters..
  37. 3-4 Shift Flare?
  38. Another VERY satisfied CPT customer !!!!
  39. 114,700 miles on originaltrans Fluid change?
  40. Track Problems
  41. 4L60 to TH350 swap..what do i need?
  42. Any sponsors running any sales on stall converters?
  43. What's wrong with this picture?
  44. Whats needed for A4 to A3 conv.
  45. Tunnel Clearance
  46. A4 wiring harness?
  47. A4 problems (shifting from 1st at 25mph under light load)
  48. Tools for a4 removal and replace?
  49. ATI Converters?
  50. Anyone Have any experience with 4600 Fuddle??
  51. 4l60e ratchet shifter
  52. removing tranny dip stick?!?!?
  53. 4l60e not shifting under load
  54. 3200 vig/3:73/a4
  55. What's this part?
  56. VIG antiballoon?
  57. Trans Cooler
  58. P0758b trans not shifting after car ran hot
  59. Difference in Yank converters?
  60. Yank ss3600 being installed...
  61. EbAY stall converters
  62. vig converter on the way.
  63. Strange sound at 5,500 rpm on '97 LT1 - *Help*
  64. 4000 or 4200 stall?
  65. Fuddle Converters?
  66. Picking the right converter
  67. Please help real strange issue
  68. TC and driving in the snow
  69. tranny filter/gasket
  70. Tranny Temp Guage
  71. 4k fuddle stall
  72. Best Stall for DD
  73. triple and single disc???
  74. What converter?
  75. Good Shift kit for a 4L80e?
  76. Stall speed effect on hwy rpms?
  77. cleaning out a converter
  78. trans
  79. What size stall For my application?
  80. Tell me why my tranny keeps...
  81. Feeler: 4l60e tranny or TH350
  82. How do 4l60E's hold up under boost?
  83. TH350 dipstick??
  84. th400 w/rmvb ?
  85. yank ss3600??
  86. 98 ls1 tranny in 97lt1 camaro(will it work)
  87. help - new motor awesome - old trans bad
  88. Clunking noise
  89. Stalls good for 40,50,65mph rolls ?
  90. Vacuum modulated 4L60e?
  91. everbody says this is gonna break??
  92. I know this is dumb but..
  93. 4l60e Problem, Please Help!
  94. Hot! Hot Yank converter specials for April
  95. 4l60E with Yanko 3500 stall converter
  96. highest speed in each gear
  97. I need help please
  98. tryin to switch transmission
  99. Price on Shipping Transmission??
  100. Interchange Question
  101. What power should this 4l60e hold up to?
  102. will i run slower??
  103. Can a 4L80E run without a computer?
  104. A4 Tranny/ trq arm mount....
  105. 4L60E sheild or blanket?
  106. 4L60E Problem
  107. 4l60e valvebody
  108. Tranny Tune?
  109. Swapped valvebody, what did I screw up?
  110. Shifting wierd!?!?
  111. wiring options for the m6 to a4 swap
  112. Well, Well, Well...............
  113. converter difference (Yank)
  114. A4 transmisson noise in Neutral
  115. 700r4 in 93 Z problems! Help!!!
  116. Wont go into Drive?
  117. More Power= New Tranny?
  118. New trans, no D or OD
  119. Transgo install ?s
  120. Can i lock my yank in 3rd at the track?
  121. I need a pinout or wiring help
  122. Wtf Auto Trans Mount!!!!!
  123. New to converters: hope this is a good one!
  124. A4 good for road/autoX ?
  125. new built trans problem???
  126. Rebuilding a th350.
  127. Bad idea here?
  128. 4L60e warranties?
  129. 475 rwhp tranny
  130. Car falls on its face when in D!!!
  131. converter, car wont shift
  132. Tranny stuck in 2nd
  133. 96 cad seville no shift
  134. need faster response from trans
  135. Is the V6 & V8 4L60E the same?
  136. stock Torque arm mount on tailshaft pics?
  137. YankSS3600
  138. Blew cooler line off....what kind of damage can I expect?
  139. ran 11's 4l60e paid the price
  140. 3.73's plus 3800 Torque converter on turbocharged car??
  141. Round trans cooler?
  142. Converter install howto?
  143. Performabuilt 9.5 inch converters
  144. When will my car move? (converter?)
  145. Need info on this...
  146. Tci Converter HELP ME!!!!!!!!!!!!!!!!!!
  147. noise in my tranny help!!!! please
  148. Torque Converter Code P0757
  149. 2nd to 1st Clunk?
  150. after built tranny & stall install spedo bouncing
  151. People with stalls, are you using a shift kit?
  152. 4l60e not shifting!
  153. Performabuilt weekend FREE cooler special in sales section
  154. Dynamic braking went out the window
  155. 700-r4/4l60 non-ecm controlled transmission?
  156. Unknown Issue
  157. Weird 2004 A4 GTO Problem..
  158. Street/strip oriented repair kits (4L60E)
  159. RPMS rise in gear?
  160. Th400 on LT1...
  161. Shifters for the 4l60e
  162. slips in overdrive, hits all other gears fine
  163. Will I got any benefit from a stall when racing from a roll or say 30 mph?
  164. from stock to a vig.3200??
  165. Info needed on 4L60E Transmission
  166. Custom cooler lines?
  167. 4L60E pulses
  168. Which Tranny cooler?
  169. 4L80e Swap Questions
  170. 4L80E Conversion Ground Clearance
  171. What happens if a Yank blows up?
  172. HELP with bleeding Hydra tranny 91 C1500
  173. 2nd gear start (abuse mode maybe)
  174. TH400 RBMVB Downshifting
  175. i need help
  176. odd thing happened at the track
  177. built 4l60e + trans brake
  178. 4L80e - stock?
  179. stall/xsmn probs HELP!
  180. Fluid for a 4L60E
  181. Stall Help!!!!!!
  182. torque management??
  183. trans tune. how important?
  184. Gas mileage with 4.10s and Yank 4000 stall in an A4
  185. Can A 2002 4l60e Be Used In A 2000 Car?
  186. Which torque converter??
  187. What OD tranny to use?
  188. 408 with Yank PY4000E ?
  189. I think my tranny gave out on my way home.... help me!
  190. 2-3 WOT Flare
  191. C5 auto tranny problem
  192. converter install on a 70e leaking fluid??
  193. Anybody done this 200r4?
  194. which tranny
  195. anyone use the pro super kit for the 4l60e made by TCi???
  196. 4l65e 3-4 piston
  197. Stall???
  198. getting 4th servo out?
  199. What RPM should the 4160e/shiftkit ?
  200. Matching a Converter with a Cam
  201. jasper trannys?
  202. 92 Chev Van G20 5.7L 4L60(?)
  203. 4l60e + 420rwhp = ???
  204. TH400 conversion conversation
  205. Th-400 no reverse!!! HELP
  206. ss3600 or ss4000
  207. 1970 Chevelle TH400 to TH700r4... easy?
  208. Help me pick my T/C
  209. I need help ASAP
  210. TPS question
  211. TH400 lost reverse
  212. New converter in Big Problems...Opinions please!!
  213. just a quick question....
  214. powerglide to ls1
  215. Converter noise?
  216. drain plug on 4l60e tranny
  217. Who's builds the best TH350's?
  218. Roll/Coil Tranny Lines
  219. Installing New Tranny?
  220. Installed new 4L60E and clunkc clunk clunk
  221. TCI SSF 3500 for 408?
  222. 2 To 3rd Shift In A4
  223. TC slipping?
  224. need help badly
  225. 4l60e overdrive issue
  226. 4l60e boost valve difference???
  227. 1/4 mile times with new converter
  228. MADMAN dipstick for th350
  229. Trans Shifting Earily Please Read And Help Asap
  230. Th 350 in CA
  231. no 1st 2nd 3rd 4th or reverse.. just park and nuetral, locks up when put in gear
  232. throwin codes after stall install
  233. Stoney (SAE) Michigan:contact?
  234. B&M shifter for 4L60E???
  235. torque managment
  236. Adjustment Questions.
  237. no fourth, 4th gear, intermittent.
  238. fuddle p.3400
  239. Neil Chance
  240. changing 4L60E filter grommet is a biotch
  241. Any overdrive tranny out there that handles 1200hp?
  242. TCI jumbo servo
  243. The all new FuddleRacing.com Clearance Page
  244. 4l60e to 2004r swap
  245. Keep the 4l80e or....
  246. Help
  247. Props to Yank. My PT4000 is awesome.
  248. 93 z28 a4, 2 different auto trannys?
  249. 93z28, racing from a roll question A4
  250. ?'s on building up stock tranny
