- Cam and Stall converter question
- Should I get a vac. modulator?
- How many use a Pro Stick for a DD???
- Whos had a Performabuilt tranny?>
- code P0757 again, but solenoid is new?
- Need help.
- What tranny fluid and tranny filter should I use?
- Switchen sides...T-56 to auto...lots of Q's.
- Anybody have this problem with a 4L60E/ converter
- Transmission Troubles?
- which converter and shift kit?
- TH350 Picture question..please look
- Nitrous on the 4L60E
- 4L60E 3-4 accumulator
- Th350?
- Shift Kit?
- Big Stuff 3 & 4L80E
- Dp i have to rebuild my trans if i put in a tci converter in?
- Torque converter lock up problem
- Question for a friend
- 4l60e rebuild cost?
- 4l60e woes
- fastest in a 4l60e 4l80e?
- definitely need converter help, Vig killed my FLT
- 3rd and 4th gone?
- Help With Th400 Swap Brake Problems
- Car sat for 7months..flush tranny??
- I really did it this time (PICS)
- Torque Converter...
- has anyone tried the TCI 4L60e rebuild kit?
- 4L70E Question
- What rpm do you idle at?
- tranny issues
- Is this TOO BIG?
- Bad stall = low dyno #'s?
- Converter Clutch Signal Valve
- overfilled tranny by about 1/2 qt. okay?
- Tranny Cooler with a Fan?
- stall on a 111k trans
- Precision shift converters???
- EDGE Racing Converters?
- transgo shift kits
- In between 3 converters
- Where do you add ATX fluid?
- Performabuilt to the rescue. (again!)
- New stall installed?
- is that true ..??
- Pro Rachet has an extra shift - problem
- temp gauge wiring ?
- Guys With 700R4 Shifters
- big stall guys please chime in..
- which Pistol grip to get
- shifting problems
- Installing A 4l80e
- How bad did this hurt my tansmission
- Trans Temp gauge Help
- WTF now? (tranny issues) 4L60E
- Transmission noise?
- shipping a tranny help request.
- what all trannys will work in my 98
- Mines leaking too
- Tranny fluid leaking
- Th400 Gear Sets?
- Hows this for a rebuild kit...
- how much is it worth?
- 4L60E no 1st or 4th gear. HELP
- So is this all i need for my TH350 swap??
- 1st, 2nd, 3rd, NO 4th??????
- Pics of your trans. cooler install??
- Does a TH-400 Have a pressure test port?
- Trans-brake switch installed on the 97'…and works good!
- pre - buildup question
- Blew my trans up
- Won't go into gear(drive) TurboNoma
- Leak from inside bell area
- Does Manual shifting hurt a stock 4L60E?
- Easy Changes/Upgrades to the 4L60E?
- Trans fluid turbo 350
- What Tranny??
- Any And All Stall Videos!!!
- Locking up and releleasing on 3-4 shift?
- looking for a tranny
- slipping tranny
- Speedo doesn't register until I hit 2nd...
- Back again with same problems
- 98 4l60e wont shift into 2nd
- Need trans help
- 4L60E shifting into 3rd and some times it wont. Brand new Shift solenoids
- Wierd 4l60e problem
- Stall and no tune??
- Transgo Vacuum Modulator problems
- 700r4
- Rebuild = Crap. Help?
- 93 4l60 question
- VIG 3200 installed!
- Need strongest Possible 4L65E
- Shot in the dark...anyone know vw tranny's?
- 4L60E behind 6.0 LQ9??
- Trans Brake
- TH400 Newbie questions..
- more YANK converter issues...
- what should I do
- Anyone use Precision Performance Kwik Shift Power shift
- TCI Converters
- 6 Speed or T400
- 4l60e Trans problem after shift kit and high stall conveter installed
- Torquer 2 shiftpoints A4
- Car wants to go forward...in park?
- 727 Torqueflite to LS1 questions
- 4l60e lockup
- Yank converter special for LS1tech members
- 4L60E Valvebody help!!!
- lost sending unit.
- 450hp
- New Converter = engine problems?
- A4 Cooler Line Question
- Trailblazer converter
- How are the tranny cooler lines properly installed?
- TH350 what speedo gears?
- Manual valvebody 4l60e
- Tranny cooler leaking..what is everyone using for cooler lines?
- A4 bucks alittle in OD ?
- 4L60E lockup question???
- where to get rmvb for a 4l8oe
- Will a Transgo 4L60E-HD2 Kit work?
- TH350 worth?
- Installed shift kit and some other trans parts (!!Warning alot of pics!!)
- TransGo Shift Kit Going In...Any reputable installers in VA?
- 13 vane pump
- 700r4 to th400 swap ???
- temp gauge
- Maybe it's the transmission section, but lookin' for advice.
- Car Wont Go Into Park
- trans problems
- Need shifter options!
- Performabuilt lvl 2 going in
- PG Driveshaft Length
- B&M acquires Hurst
- so... lets talk lines and fittings....
- Would you buy it?
- Do i need tranny cooler?
- manual lock up
- V6 4L60E case and bellhousing same as LS1?
- What pan with SS4000
- Converter Problems?
- TH 350 Transmission Pan Leak!!! Please Help
- I blew my tranny out.
- DIY 4L60E Rebuild?
- important question about stock performance numbers
- Clutch clearances
- Over-run clutches
- Easiest way to take out trany?!?
- Turbo Stall.wich Yank?
- 4l60e swap question
- Anybody tried a Torqueflite 727?
- Life of stock tranny
- 4L60E Trans Problem
- Broken a Built 4L60e??
- 4l60e valve body kit
- Tranny problems please help !!!!
- Which converter for th350?
- Hardened input shaft assembly
- converter slip question
- Question for a Stall Guru - Yank SS3600
- Stall With a Cam??
- bumping RL in 2-3 shift
- 93 z 700r4 questions
- best stall size for d/d?
- Tranny and oil coolers tech
- ooh ooh that smell
- more tranny cooler pics
- Yank break in question
- Tci Ls1 Flexplate
- Is there a defference in ratios?
- do you use a deep pan on your th400 - how far does it hang down?
- Difference between years or type 4L60-E
- FLT tech article in GM High Tech
- Differences between early / late 4L80E's
- pilot spacer/ 350 turbo converter to ls1
- torx head bolts
- TH350 conversion
- For those that have gotten a tune with a Torque Convertor (TCI SSF 3550)
- Power Glide OR TH400
- GREAT transmission :)
- P0757
- which size converter for me
- Do I need a tune with a 2500 stall?
- Pulse Width Modulation
- a little bench racing
- T400 Swap. Which Converter Flexplate
- Two stall questions....
- 4L60E Transmission problems
- Trans Mount?
- bout to come into 1,500 bucks! help
- Temp Guage Question
- TCC lock up (Have searched)
- What size of stall for my setup?
- Rattled when shaken? Converter
- TH400 Question
- another stall question
- 3500 stall
- 4l60e experts in here! Need rebuild advice!
- Is my 1994 4L60E a 30-spline, with a 1.703" pilot?
- 4l60e losing fluid.
- which stall for street/strip and road trip's?
- Best Tranny Pan
- Just some interseting information about ratios in various transmissions
- th400 questions
- bye bye 2nd gear..
- Getting my Vig 3200 installed
- connections needed or not for the a4 swap
- 4L80E Driveshaft
- Where to find a cheap used 01+ 4l60e?
- Bolt-on & Converter cars(ET, 60', MPH)
- 408 w/TH350??
- Fuddle/Howard??
- 4l80e ?
- OverDrive Question..
- Aftermarket tranny controller
- Trans Shifting Softer
- help on th e.t.?
- flywheel question
- Solenoids stuck? can they be replaced?
- trans stuck to motor
- 4L80E and fitment in the F-body questions.
- converter???????
- Need converter help
- Vig3200 or other? (NA and nitrous)
- 2-3 shift clunk
- 94-95
- powerglide in an f body???
- 4L60E switch to a T400
- YANK th400 crossmember help
- flow diection
- DTC P0758 2-3 Shift Solenoid Circuit Electrical
- 4L60E leak
- LS1 style engines to old style trans(th350, 400, 2004r, 700r4, 4l60e)
- question about converter install
- turbo 350 pilot spacer
- 4l80e and TCI controller box
- tranny cooler qustion
- Can C6 paddle shifters be adapted to F-Bod??
- bolts for pilot spacer
- 4l65e
- Firm 2-3 shift?
- trans brake?
- tranny help
- TCI converter issue
- what flexplate for a ls1/turbo350?
- st3500 vs ss3200
