View Full Version : Automatic Transmission
  1. driveshaft? LS1 for LT1?
  2. cooler question
  3. How do A4 cars dyno without downshifting, etc
  4. Shift Kit
  5. LSx + 700r4 info. and ???
  6. th350 convertor
  7. Rebuilt trans help
  8. 4l60
  9. th4oo swap this weekend
  10. What has more potential to be quicker? auto or manual?
  11. Tranny Issue??!!
  12. 3200 vig, pt4000 or ss4000 which one?
  13. Performabuilt 4,000 stall installed
  14. The Fuddle worked...
  15. what trans to go with
  16. Auto Help
  17. Yank PT4000 is in
  18. New Converter offerings at Performabuilt
  19. Strange Noise ????
  20. question for yank owners???
  21. Th-400 crossmember??
  22. tell me what you think
  23. Bad Vibration
  24. trailblazer converter???
  25. TH 350 intall in 99 LS1
  26. B&M hammer
  27. To those about to do a th350 swap.
  28. What does "Built" mean
  29. 4L60E swapped fro a 400 Questions...
  30. TH400 install
  31. what happens if i run too small of a TC?
  32. Peoples Opinion Of ZPack Clutches
  33. Trans-Go
  34. Why Should You Not Use Synthetic Fluid In A 4L60E?
  35. Early Version 4l80E
  36. th350/400 converter? STR related
  37. Help!!!!please Come In
  38. i'd like to hear from corvette owners who have TC's
  39. Lockup/Not locking up
  40. Vette Servo ??
  41. should i change tranny fluid?
  42. How to check a torque convertor
  43. Tranny fluid all gone,won't shift 3rd to 4th
  44. 4l60e shift problems
  45. Broken Flywheel, help please!!!!
  46. front seal??? 4l60e
  47. Tranny that has been sitting for a year
  48. Does Yank put serial #'s of the stall?
  49. Driving in 3rd
  50. what size converters are the dd drivers runnin?
  51. Fix Tranny or buy new one
  52. Strange.. any ideas?
  53. Edge 'Verters
  54. Is my tranny done?
  55. Overdrive question
  56. TC Questions.
  57. 92 S10 4L60E. does it fit in a 98 camaro?
  58. Hurt tranny, few questions...
  59. I need part prices immediately!
  60. 4L60E Slipping Problem, 3-4 Clutch Pack?
  61. Lock Up Switch On 4L60E?
  62. 4L60E gone after 46K!!
  63. newbie with trans problems
  64. TH350/400 question
  65. Shift Problem!
  66. What else do I need before I put my Yank 3500 stall in
  67. Yank and RPM great to work with
  68. 4L60E Question
  69. Coverter Install At Home?
  70. 4l80e yoke question
  71. 4L60E shift cable part number
  72. 98-99 4l60e guys do we have a bolt on bell housing?
  73. Just Incase - BTE Transmissions
  74. torque converter??
  75. Second gear goes Neutral?
  76. How Do I Know If I Have An Ls6 In My 2002 Z28?
  77. How Do I Know If I Have An Ls1 In My O2z28?
  78. Fuddle stalls and N2O results
  79. how strong is a stock 4l60e?
  80. ACC converters?
  81. Any Tranny Coolers I should Look Out For? which is good and bad?
  82. How long did it last poll
  83. What flexplate to use?
  84. anbody tried the sea foam trans additive???
  85. Would you recommend this?
  86. How cold is too cold?
  87. A4 shiftpoints with 3600 2.5 stall
  88. Lockup speed/tuning
  89. do shift kits really improve the life of your tranny?
  90. Sonnax 77805E-K and Converter Troubles
  91. how much would it cost...
  92. ? about trans problem
  93. TH400, brake: Spragless converter?
  94. th350, rebuild or new?
  95. wont go into park
  96. Difference in tuning?
  97. 3800 stall
  98. tranny's slipping
  99. Bang Shift
  100. converter questions
  101. 4l60e Problem
  102. Can i put a thermostate inline w/ cooler?
  103. converter??
  104. 350th swap
  105. why do big stall cars dyno so low? lets calculate.....
  106. Ok, I'm confused how a stall would help me any right now, Anyone wanna help out?
  107. what converter with my setup?
  108. TC operational info
  109. Transmission Mount
  110. Just a quick 4l80e Question
  111. Vigilante Stall
  112. a tech question for th400
  113. No Reverse HELP
  114. After-market shifter recommendations??
  115. torque converter change ?
  116. Installed Yank have questions (slipping)
  117. Gearstar
  118. New Gm 300 Mm Input Shaft And Drum Package
  119. Going th350 and have a question about the flexplate.
  120. Manual valve body or trans go stick type shift kit for my th400?
  121. question ?
  122. Trans experts, need advice. John Kilgore?
  123. Tranny cooler mounted pics with temp gauge sending unit too.
  124. Whats your RPM at...
  125. Tranny Swap Questions
  126. edge or performabuilt converter?????
  127. Not your typical (lock-up) question
  128. 71 Buick GS
  129. What to do to an A4...
  130. How about The TCI converters?
  131. FLEX PLATE INSTALL the spacer
  132. SS3600 yank
  133. Lock-up questions
  134. TH400 Guys how you running Tranny Cooler
  135. torque spec for flexplate
  136. Need lauching tips
  137. Whats the connector # for "Park Neutral Position Switch"
  138. Rmvb 4l80e
  139. 3:73s with Torque Converter,Yes or No?
  140. Tci
  141. Thanks Alot Guys !!!!
  142. thinkin of getting a cam soon need so some
  143. T/C and Gear advice for new T/A owner
  144. Rebuilt 4L60E Question
  145. Ls2 and Powerglide?
  146. Odd but - Differential Fluid in Tranny ?!?
  147. TQ Convertor install need help
  148. SS4000 on the street?
  149. Driving a RMVB t400 - downshifting
  150. Neil Chance Converters
  151. Questions Arrised During TransGo Install
  152. LT1/corvette convertor
  153. When launching 4L60E it takes off in 2nd or 3rd, have to manually put in 1st
  154. How much more torque?
  155. What size converter for a 228R on a 112LSA
  156. Invincible Series Is Back On Performabuilt
  157. Question about changing tailshaft on 4l60E to use cable driven speedometer
  158. Transmission Fluid
  159. Buy a shift kit??
  160. post your favorite 4 speed auto shifter!
  161. Rebuilt the tranny, now have no 2-4.
  162. question about installing a converter...
  163. something off my chest
  164. N00b here, help me with some ???'s?
  165. 4l60e can it hold
  166. tranny question
  167. Yank PY3400 is in the car with Century 4L60e
  168. How Do You Know If Your Tc Is Not Locking?
  169. Well Guys...
  170. ss3600 from a roll
  171. Th350
  172. What size stall to go with!
  173. Coverter help
  174. rebuilding tranny do i need to get a trans go shift kit?
  175. Tranny Dead? No first gear
  176. What to do????
  177. ANYONE ever have their 5 pinion planetary crack????
  178. Help! I got a full lockup TC...
  179. th350
  180. Torque Converter
  181. Looking for a good convertor for my new th350!
  182. asap iam duing it now please quicj question?
  183. Whats up with my trans
  184. installed shift kit 1-2 problems
  185. Shifting too early? Need input!!
  186. Could this be why i dont have 1st gear
  187. Just a quick ?
  188. Big thanks to Kevin at TCI
  189. Car not Downshifting?
  190. Vacuum modulator people!!
  191. trans experts please come in. Locks in 3rd gear
  192. sbc converter on an ls1???????
  193. what kind of U joints to buy???
  194. Look what UPS dropped off to me this morning!
  195. 4l80e worth
  196. shift selanoid
  197. Inconsistent 1-2 shift point
  198. converter help
  199. Matching stall size with cam size
  200. Question 4 U Guys About Convertor ?
  201. solenoids in Rock-on....
  202. *** Need Help Asap ***
  203. DD Stall
  204. th400 in 93 camaro
  205. TCI Issues
  206. is my trans gone?
  207. What happens when...
  208. TH350 stall
  209. Fuddle 3600 questions
  210. Torque converter install and brand questions
  211. Gear Vendors Overdrive!
  212. som bitch wont shift
  213. UK chap needing g/box guidance
  214. New Pricing on TRANSMISSIONS and converters PerformaBuilt
  215. torque converter poll
  216. TH400 shifters
  217. Wow, Auto is just not looking like a winner!
  218. th350 cooling line outlet size?
  219. Harsh 2-3 shift at part throttle but fine at WOT?
  220. Help Quick!
  221. Shift Speeds
  222. Yank SS3600
  223. Cooler pipe size
  224. New FLT tranny installed
  225. th400 problems :(
  226. Transmission Fluid Thermostat
  227. Rebuilt 700r4, added shift kit, now problems.
  228. Tranny guys inside: Cooler plumbing question
  229. What transmission?
  230. vehicle speed sensor
  231. TH400 swap what wire for reverse lights??
  232. Unlocking Torque Converter Question
  233. Best going deals on a TH400????
  234. Th350 Th400 and 4l60e
  235. Install vac. modulator in car?
  236. New Converter - slight rattle / grinding noise ??
  237. th350 problem
  238. stock tranny, big stall, n2o
  239. need a 4l80 stall, help
  240. Will a Verter loosen up with Break in miles?
  241. 1900 stall
  242. How long will my A4 last?
  243. Effect of worn converter clutch?
  244. OK i got the tranny working but...
  245. Torque Converter
  246. price of a th350 or th400 swap?
  247. TH400 guys what flexplate boilts??
  248. What size stall???
  249. Lookin For 4000 Stall
  250. stall of stock
