- raleigh/charlotte tq. converter install
- Trans Cooler question
- 4L80E newb questions
- Pulling Tranny Question
- drag radials with torque converter
- I cant hook up!!
- 4L60E Trans Question - Is It Dying?
- Car won't shift
- 4L60E questions
- How many A4's went out on Dyno
- TCI SSF3500 vs. SSF3800
- Flex Plate
- Torque on Flex Plate bolts
- vaccum mod. 4l60e
- buying a use converter
- Transmission help
- RPM Stage IV 3rd and 4th gear gone!
- 4L80E tuning
- Which RPM Stall?
- 4l60e weight
- 4k stall= gas $$$$$$$$$$$
- How many splines are on the tail shaft for 4L60 and 4L80...
- whats wrong?
- how much does a a4 conversion go for usually?
- A4 to M6?
- Yank converter problem?
- 4l60e suburban 99 to formula
- tranny goin out
- Fuddle sponsor elsewhere
- Budget tranny 700r4 help
- 4L60E build-up
- Th400 or 4L80E
- Th400 Into F-body
- what size converter for nitrous?
- trans trouble
- Bell Housing bolts
- Can It Be Saved.
- New Converters Are Available Now See Inside
- Fuddle converter
- wont accelerate unless you push down on the pedal more.
- 500rwhp n/a +N2O....350 or 400?
- Big stall bad for tranny?
- what's going on in my 4l60e?
- Converter problem?
- New converter line rolling out this evening watch here for details
- PT4400?s
- shift kit necessary?
- A4 wont shift fast when N2O is on, HELP
- Transmission clicking problem New A4
- do converters help from a roll at all?
- Need Dipstick for V8 TH 350 swapped F-bird
- tranny went out in my 93' will 94' work?
- A4 shifting hard
- Shaking when in fourth,please help!!
- where can i find this part?
- quick tranny question
- neutral safety switch wiring
- does this sound right?
- Which rebuild kit should I buy? Ordering now.
- converter question
- power loss from conveter
- a4 less than 2k
- What causes an A4 to not Go when floored?
- Vig stall converters
- 4l60e experts in here please
- transgo shift kit install help
- Need tech help 4l60e BINDS????
- LS7 with PG
- I can hold my car in any gear as long as i want and its stock tranny???
- Th350 or converter issue?
- Brand Of Tranny Fluid Are U Using!!
- maybe it's broke? or maybe it just doesn't like me...
- What trans
- Trailblazer SS - 4speed auto to 6speed auto?
- 4L60E Question!!
- I need pics of you th400.... from the bottom of the car
- 4l60E from a V6 Firebird
- How do you know if the 2/3 is going..?
- Need a new Tranny... I have a Turbo 350...
- Lowest stall for TRak cam and 3.15's
- p1087 caused by low tire pressure?
- Downshifting
- Post you B&M shifter pics here
- 700r4 third gen ?
- What is the best tranny option for me to do to support between 750-850rwhp?
- Tranny Vibration
- Tuning 4l60e question?
- TransGo Shift Kit and Corvette Servo Help!
- cheapest turbo 350 for ls1
- Shift points on stock A4 F-body?
- Need help with A4 problem
- Burn fluid
- Drive or Overdrive?
- Where to find a good C5 valve body?
- Bad tranny or tc?
- guys with th400 in ls1, exposed converter/flexplate!?
- C5 shifter in a '99 TA?
- Tranny problems
- Stroker Guys what RPM Stall Verter are you Running?
- Odd problem
- Trans problem?
- converter info
- Weird Tranny issues?
- Drive Shaft
- there's a vibration through the car
- 3000 or 3500...big difference?
- TCI Shift kit low rpm 1st to 2nd change.
- Does a 4l6oe have electronic or manual valve body?
- 4l60e leak question..
- TCI Flexplate to Yank Converter: Ok?
- question about torqe conv. please help !
- TC and Cheatr h/c package
- Thanks TCI
- Transmission problem!! please help
- Help! Where did this come from?
- Testing strength and integrity of tranny?
- Post up pics of your trans cooler set up.
- Trans Go Shift Kit
- Help with Trans Cooler.
- Converter questions and advice..
- building a 5.3L need to pick a transmission
- tailshaft question about angle.
- Tranny Builders 2-3 Shift ?
- *HELP*should i buy a TCI converter?!?!
- *HELP* should i buy a TCI converter
- Vaccum Mod In A 4l60e
- who builds the best 4l60e
- some of auto tranny troubles..?
- Powerglide price?
- trans shift hard?
- Shift kits!!!
- Vasco th400
- stall for 4l60(700-r4)
- Is my Fuddle torque converter going bad?
- how hard is it to rebuilt a 4l60e?
- Tranny sponsors inside
- Big HP TH-400 cooling question
- i think i have a trans problem
- Tranny or computer gremlins? (shift problems)
- tune after converter?
- Best Rebuild And Performance Parts For 4L60E
- Converter for th-350?
- Th-350 stall question!!
- Break in time on new tranny?
- car jolts when shifting from R to D
- AWESOME POLL on 4L60E's!
- Deep pan or cooler?
- TH350 tailshaft switch
- th350-400 guys help inside!
- Does ATF go bad the older it gets?
- converter lock up after cam heads swap
- changing tranny fluid bad?
- Deep-pan/tranny temp
- Anyone Use Jet Tranny Controler?
- Top speed or high speed auto tranny setups?
- recommend a tranny
- 4l60e tranny cooler
- Anybody have a Derale deep pan?
- What is the best way to diagnose a TCC no lock?
- Who has installed a transgo shift kit in their A4??
- 700r4 skipping 2nd gear
- BMR torque arm non-adj. question??
- tranny cooler noise
- Who would you pick to build your 4L60-e?
- WHAT DOES " STR " MEAN ON A CONVERTER
- those that have a 4400 stall
- year differences in 4l60e 2000 and 2003
- Best Shift Kit
- Which Flexplate do I need? 6.0 and a t-350
- A couple TH350 questions
- auto transmission shifter button
- What is stock stall RPM?
- Radiator Trans cooler question.
- Full flush or just pan
- Is my transmission slippin?
- "Fuddle" definition
- is my tranny on the way out?
- Final drive ration for an a4???
- does a Big Converter need more pressure or less?
- Fan or no fan for trans cooler???
- Hangs onto revs...
- Crank wont turn after converter install.
- Is there suppost to be 2 covers on the bellhousing?
- Corvette Servo's
- TCI or ATI???
- Aftermarket control box
- TCI MaxEffort Converters??
- New with an A4
- what stall with t-rex
- How Much did your times drop with high stall converter!!!!!!
- Th350 rebuild, amoung other questions
- part number for bolts for a th350 behind ls1
- Change the Fluid or not?
- WTF fuddle
- 1999 ta mission 2nd to 3rd gear problem
- th350 help
- Someone explain to me what a transbrake is....
- Tranny cooler question
- What is this?
- YANK'S new website is up!
- Which clutches are the best for a 4l60e?
- Which Converter
- 1LE Trans Mount
- idea of ET improvement with different stall
- dipstick tube problems... PLEASE HELP
- Which tranny for 700+?
- Budget 4L60-E rebuild?
- 4l60e bolt question
- Question about Th350 housing....
- what cooler?
- servo cover
- speedo wires th400
- Problem with my trans?
- help with taking out tranny
- a4 ws6 99 won't crack second somethin wrong????
- th400 swap parts
- best 4l60e mod
- wont go into second?
- torque converter help
- Rossler Transmission what do you guys think?
- Tightest High stall converter
- Used stall/converter experiences?
- tci 3200 2.6
- Tranny should be ok right?
- Shift Firmness
- Parts List Please
- M6 to 700R4
- Built my tranny and converter
- Does a lighter weight torque converter free up horsepower?
- 4l60e pistons
- Lockout Q
- Anyone have pics of a modified M6 crossmember for a TH400
- Do i need a PCM to run a 4l60e..
- Transmission Problems...HELP!!!
- Manumatic conversion on 4L60E?
- Tune with Converter
- Proper transmission lockup behavior question
- Transmission condensation?
- Yank Stealth 3100 Installed and Running
- Broken Tranny Mount...
- 96 Grand Am V4
- How much will my mpg go down after stall
- my tranny's acting up!
- Percentage difference in rwhp and torque between locked and unlocked converter?
- M6 to TH400 speedometer conversion
- Guys with TCI flexplate and ARP bolts.
- Stock Flexplate
- which linkage for th400? 4l60 bracket wont work on pan
- TH350 problem
