View Full Version : Automatic Transmission
  1. Big Difference going from 3800 stall to 4000?
  2. Which one would you do? Rebuild your own or buy a used built one?
  3. need help asap
  4. 4L60E & 4L80E Shifting
  5. What does a dry th400 actually weigh?
  6. what shifter to get
  7. 383 lt1, th400 w/ transbrake?
  8. what is an alternative converter to tci 242933 4400-4500 stall
  9. BHP affect on stall rpm?
  10. 4l60e question
  11. How to tell if a car's transmission is slipping with a stall and shift kit?
  12. Died when put in R?
  13. 2-step,foot brake,or off idle?
  14. stall speed and weight
  15. Did all 2000 LS1 fbody owners w/ auto came with...
  16. transcooler
  17. thanks rock on
  18. tranny problems, what gives?
  19. TH400 rear gearing
  20. shiftkits
  21. C6 Auto 6speed
  22. 4L80E/tranny questions
  23. car slower after tranny rebuild
  24. Yank SS3600....WOW
  25. Z06 auto tranny?
  26. Shift Kits
  27. Heavy towing
  28. torque converter ??'s
  29. New Tranny & TC A4 NOW Shifting 400 RPM's Lower?
  30. Help!!!
  31. Built tranny internals (4L60E.com)
  32. race trans?
  33. weird tranny/converter problem...need input
  34. Driving with A4 tune with a TH400?
  35. m6 to turbo 340-400
  36. TH350 gearing
  37. Tune after Converter?
  38. vigilante multi disc converter on a camaro
  39. S10 converter
  40. Need Help Th350 In My 98 Camaro???
  41. It ONLY shifts DOWN!!!!
  42. rock on transmissions level 5= how MUCH$??
  43. just curious...
  44. Cooling the A4
  45. Trans getting Hot or Converter??? Which ONE?
  46. stall to big?
  47. tranny fluid Q....
  48. Tranny not downshifting from 60-65mph???
  49. Which trans is for me?
  50. Gauging Interest
  51. thanks to rock on trans.
  52. m6 to auto questions
  53. whats a good stall
  54. 700R4 - 3rd gen experts please!!!
  55. No 1st gear,...now it works again.
  56. Stall Question!!!!!!!!!!!!!!!!!!!!!!!
  57. converter to flexplate clearance ?
  58. TH350 experts... Couple questions and pics inside...
  59. 94/95 4L60E Parts Swap
  60. new rebulit 4l60e race trans
  61. Tranny re build
  62. Symptoms of converter failure?
  63. steetable stall
  64. Tranny rebuild.
  65. How fast do you cruise on the highway wiht your Th400?
  66. TCI streetfighter good for a F-13 cam?
  67. Converter doesn't seem right... Fuddle 3400
  68. no reverse or nuetral in auto ta 95 i need help bad
  69. Redneck Performance
  70. Torque converter bolts
  71. Stock Flash Stall?
  72. Just want to say thanks...
  73. Budget 4l80e build
  74. th350 troubles
  75. yank PT44000 and rev limiter
  76. 3600 or 3200 for DD
  77. Where can I find E clip for trans lines
  78. 3 speed people..simple question
  79. built tranny, new program??
  80. Need Help with removing dip stick tube!
  81. Help! trans problems after swap
  82. SS3600 or SS4000?
  83. Who's running the Yank SS3600....
  84. TCI converter question
  85. Help- Energy Tranny Mount
  86. Converters available for the 6l80??
  87. Does anyone need a tranny???????
  88. Art Carr stalls?
  89. Flex plate for a 408 crank problem
  90. Converter before Cam or Cam before Converter?
  91. Won't go into park / start in neutral?!
  92. Converters for camaro and vette
  93. Standard bellhousing pattern onto an LS1??
  94. tranny tick?
  95. what is this guys????
  96. TransGo Shift Kit...Any Good???
  97. Trany slipping
  98. 4L60E fragile?
  99. Building my 4l60e myself. . .help me out.
  100. need help on converter choice.
  101. TCI converters
  102. TH400 speedometer adapter
  103. TH400 or 4L80e????
  104. tc
  105. Rossler Terminator 3
  106. no movement in 3rd or d??please help!!!
  107. Trans Cooler???
  108. Setting my Converter for street??
  109. Stall question
  110. sponsor's, tranny techs, etc...i need parts ideas
  111. Output shaft bearing
  112. Ok I need Help ASAP about Torque converter
  113. FLT Labor Day Sale
  114. Strange ticking coming from my new tranny.
  115. Broken sprag?
  116. yank converter making noises already??
  117. TH-400 pilot question
  118. 8" street converter?
  119. General Questions
  120. 4l60e Blues
  121. How much will they handle?
  122. broken clutch asm, lo and reverse roller??
  123. Got my Pro Yank 3400 today and custom 4l80 x member.
  124. Rebuild or M6
  125. how to figure out what torque converter for me?
  126. can you use royal purple syn. in a th400
  127. th400 kickdown cable install question
  128. hard shifting from first to second
  129. New Rear main.. New stall?
  130. Attempting transgo install this weekend.. Qs?
  131. do i need a tcu if i have efilive for a 4l65e conversion?
  132. My Experience with Yank so far...
  133. Locking/Unlocking
  134. trans buckin
  135. Front Seal
  136. those who went from M-6 to 4L60E
  137. 4L60E Pump
  138. Ever Bought Tc From Perf. Torque Conv.??
  139. question about the health of my tranny
  140. torque converter problems
  141. transmission yoke replaced?
  142. What else do I need?
  143. Anyone running Hughes TH350 flexplate/pilot adapter?
  144. 4L80E....vs....TH400 w/GV overdrive
  145. 94 and 95 4l60E
  146. 2-3 shift problem
  147. Anybody have a tranny cooler install write-up??
  148. does anybody know how to wire up a manual coverter lock up switch
  149. edge converter
  150. Does the Corvette 4l60e have same length tailshaft as F body?
  151. **uh Oh!!!**
  152. just pulled trans pan off, how much fluid do i need?
  153. New Tranny Fluid?????????
  154. Supercharger and converter
  155. Hard shifting.
  156. Transmission Fluid Level (a4)
  157. Did H/C and now I have 2-3 shift problem....
  158. slippin tranny help
  159. 3500 converter?
  160. 4L80E or TH400 w/GV overdrive work in a Vette????
  161. Transmission Cooler Question - Pre radiator or after and effects
  162. Changing Shift Solenoid, Need help identifiying part
  163. 4l80e cooling line question...
  164. How much Trans fluid on a filter change?
  165. A4 to M6?
  166. yank ss 3600 and ms4 cam?
  167. what shifter in stock council
  168. *sigh* 1st, 2nd...but no 3rd? or 4th?
  169. Trans overheating
  170. Is 3200 stall w/ 2.1 STR a good match against...
  171. Cheapest/easiest way to make my car stop shifting into 2nd so early?
  172. Lowering the 2-3 shift speed...
  173. Yank SS3600
  174. Transmission fluid pressure at idle, 4l60 type
  175. stalls
  176. Tranny oil leak after torque converter install
  177. B&M Transpak how hard does it actually shift
  178. shift solenoid question?
  179. Aluminum driveshaft?
  180. a4 shifer info
  181. 550rwhp+150shot-who sells my tranny?
  182. Please Help
  183. Does an auto tranny with a stall need a cooler?
  184. Ok, need some serious help.
  185. Brand new 98-02 B&M Shift kit for sale
  186. M6 to TH400 conversion question
  187. Help with Converter lock up
  188. A4 question
  189. The common 2-3 delayed shift, diagnostic step...
  190. Are my tranny brackeys loose?
  191. This Is Prob A Stupid Question
  192. shift solenoid replacement procedure
  193. tune after TC install?
  194. Trans won't shift after big tire spin??
  195. What is a good trans fluid?(post up)
  196. anyone know anything about these converters?
  197. TH400 torque arm question
  198. Flexplate to crank bolts for hughes flexplate?
  199. TH 350 question
  200. Code PO753, I think my transmission blew up...
  201. Any Suggestions For A Nitrous Tc??
  202. Drive-plate not rotating after install
  203. Hey Mr. Yank?
  204. Automatics and autocross races?
  205. $$ to install conv/cooler
  206. ADVICE transmission poll 98 Ta mods listed.
  207. stall or shift kit
  208. Would you buy a used 2800 vigilante converter
  209. 4l65e with b&m megashifter in 88 bird
  210. will my a4 last longer in a light car
  211. What mileage??
  212. A4 durability?
  213. so im getting a stall now..
  214. Stall + daily driving..
  215. Tough converter (TH400)
  216. yank ss3600
  217. trans hic-up
  218. Deep Pan Guys Please Come In
  219. original stall or not?
  220. Local Shop to build Stall?
  221. Should I put on a Temp Gauge for the Auto?
  222. One thing that Annoys me about having a big stall
  223. 4l80e conversion ina 98?
  224. Yank converters...
  225. Which stall will be "tighter" with 2.73 gears?
  226. what are wires on driver side of 4l60e for?
  227. How am i chirping every gear?
  228. Question about OD
  229. A few Q's about going from M6 to auto??
  230. advice on picking out a stall
  231. Anyone know where to get trans for a '96 V6?
  232. Driveshaft length for a th400 to stock rear?
  233. No Gears
  234. tune with stall
  235. converter swap
  236. rossler th-210?
  237. Problems with downshifting and convertor lock up
  238. 4L80E in an F body come on in!!!
  239. How to test a solenoid?
  240. have no 2nd gear at all?
  241. help with my 95 Formula tranny....
  242. tranny problem..need help fast!!
  243. What size converter
  244. Major issue after long idle
  245. Whats a stall converter
  246. where to download vid or manual??
  247. 4l80e in a Trans Am?
  248. hitting nuetral at 5000rpm???
  249. How many miles do you have on your Tq convertr..?
  250. FLT a good pick over one from GM?
