- Drivetrain issues
- 2wd trail blazer SS & 4l80e?
- Yank PT 4400 DD
- trans is broke. help!
- 6-7 lbs of boost on tranny!!
- best rear gear and stall rpm choice
- Torque converter bolts
- B&M pro ratchet shifter question
- which stall for my mods
- To much converter?
- stall converter with 273's
- Superior Shift Improver Kit and P1870
- Going TH-350
- FLT got a question? 4l80 case adapters fittings
- Need Advice On Launching A4 For Best Et's
- manual valve body
- 4l60e dead
- what is a 4l80e???????
- Tranny Mount ???
- Are TH350 and 700r4 input shafts the same??
- Wheels moving in neutral?
- Trans problem
- lock up?
- Am i makin a newbie mistake?
- another ignorant flexplate question
- Will stock stall work with LS6 cam
- P1870 and Shifting Trouble
- What flex plate?
- max rwhp for 4l60
- Stock shft knob removal
- tranny installed now car runs like crap...
- Please help..
- Trans Go vaccum modulater...
- shift kit install???, no reverse or 3rd,4th
- best shift kit for 02 Z28...?
- need help>vent line location??
- Advice Please: Which would you purchase Yank or Vigilante.
- ls1 to 350 turbo
- Where do I mount a transmission cooler?
- trans issues
- 4L60E - 4L80E swap in a 94 Z28
- M6 swap to a 700R4
- Whit kind of tranny?
- TH2004R Help, WTB
- What to get with $1000 bux??
- what mph lockup is recommended?
- Looking for feedback from people with a glide...
- audi s4 trans in a Z28?
- Got my stall in and..............
- Help, what is....
- trans took a dump.
- Tranny Coolers
- My beater has a tranny issue. Please help diagnose.
- What company makes the strongest 4l60e?
- What is your launch rpm with stall?
- I need an SFI approved flexplate
- different transgo shift kits?
- Installed the Fuddle today....
- Anyone in here running a Th350 or th400 as daily driver
- Gear vendor questions.
- auto tach question
- Do i have to many miles too....
- tranny question
- what is this called?
- Vigilante 3000 and 3.73's Good Match?
- how long will it last???
- Sponsor Feedback and Sales Questions Do not Belong in this Forum!!
- stall
- cross member when converting to a th400
- Some Help "STR" ???
- nitrous on stock converter
- 2-3 shift hitting the rev limiter???
- Bad Flexplate? In need of some help quick
- 700R4/4L60 shot craps.new one coming.. non lockup or lockup stall
- 4l60e converter in 4l80e?
- Stock trans temp sensor
- torque convertor dust shield
- Roll Racing
- 4l60e 1st Gear Only...help Please?!?!
- 4l60e B&m ratchet installation HELP!!
- i sacked up and pulled it out
- 4L60E OEM flaws?
- Is the 98 4l60e different from the 99-02?
- Measuring torque converter efficiency
- Stall ET times?
- stall
- how can i drain alittle tranny fluid
- SFI Flexplate for TH400
- shift linkage and 02
- Holes in TCI flexplate won't line up
- stalling the car up
- 4l60e: How to replace the transmission pump?
- Stall Installed
- 2000 Monte Carlo 4T60E, hard shifting
- pinging noise when in reverse ?
- 97 chevy 4l60e 1st and reverse grabbing
- Clunk when shifting
- Torque Converter?
- Drivetrain clunk...
- tranny broke , any ideas?
- Fastest on 4L80, Who makes it??
- rapid shifter?
- Yank/ Vig 3600
- i have a small problem...
- Tranmission Sound
- Help got a P1870 Code
- 4l60e wont go into gear
- Paging Fuddle...
- stall question
- which one works best
- tightest converter???
- 4L60E/Th400 info
- tranny temps
- help please with 2-3 shift
- screwed of course
- where to get B&M cooler kit for our cars
- Help!! Car Kills Pumps Asap!
- tranny cooler fan - on all the time
- TCI SFI Flywheel
- 3 Pumps Broken
- stay auto or go six speed?
- Will this tranny fit my car?
- what does everyone think???
- C5 Tranny Install, how many hours? Labor Cost?
- trans cooler install
- What size stall???
- Oil Pump Removal
- Need stall help....
- yank?
- yank?
- Anyone running a small stall like 2,600, 2,800 or 3,000 and if so why?
- FLT stage 3 or 4?????
- Gear calculations on th-350 swap
- What MPH should 3rd gear take me to?
- Tranny Temperature Question?
- rock-on transmission????????
- rebuild kits
- help with good transmission service
- Where should I shift?
- new 4k fuddle installed
- New Tc Tune
- flt stage 3?????
- Installing TC need some help
- F-Body 4L80E conversions - help please
- gettin a 3400 stall
- tranny
- problem with rock on tranny
- low tranny fluid?! why! so confused...
- Change tranny fluid or leave alone?
- Can anybody help with a harlan 2-step?
- Flushed my trans fluid this weekend...
- Need Transmission Help! No Gears
- Will a yank for a 4l60 fit the new A6 6l80??
- need help on stall!
- Newbee question 4L60E v.s. TH400
- If I go with a Fuddle stall should I get the Performance or the HP/Street Series??
- Average cost to get a 4l60e rebuilt?
- help! where did 2nd gear go?!?
- Shout out for Fuddle
- Just curious
- stalled guys, just a quick question..
- about my tranny....
- Well tranny finally went...
- Difference in 4l60e???
- what stall should i get ??
- Th400, low torque #'s????
- Tranny Fluid Change - What do I need?
- YANK SS4000 Torque Converter GREAT SHAPE!
- Help
- P1870 Code on the 4l60e
- Auto Gear Shift Expertise Needed
- Wondering whats the normal temperature for a auto to run?
- part numbers???
- Looking for an indepth book
- Transgo Shift Kit:How hard to install?
- converter lock-up solenoid...4L60E...part number?????
- th400 is in!! why is there lag going to second gear??
- ratchets?
- Anyone want to take a shot at why
- Need stall help
- Can you fill the TC with fluid...
- Who Has Got The Yank SS Series Converter the Cheapest?
- What pins to tap into
- shifting problem?please help!!
- only reverse?
- Bm shift install help
- It Wont Shift Out Of First!
- What Is this on my Converter? Pics Inside.
- what kind of gear are you guys running with a 26" tire?
- Tranny/TC Problem?
- shift points and pressure
- 4160e 98 trans Wont shift out at WOT....
- 4l80e speedo
- 4l80e To Fit In A Corvette
- Stalled Guys from a roll
- My stage 3 trans lost 2nd
- 400rwhp+H/C A4 cars please come in
- anyone with Big Stuff 3 and auto transmission
- Is this tranny on its way out? times/MPH
- Is B&M Shiftplus really bad or just a myth???
- Chatter comming out of lockup.. ?
- New stall for 95
- Rmvb 4L60e??
- I got 95 transam convt. I got its transm. down.. burned the clutches of trans..
- Transmission problem??
- M6 To Th400
- th400 swap does it need retune
- stock HP Vs. 4l60e tranny. UHH. look
- Stock Stall ?
- how hot does your tranny get?
- bad leak broken part please help!
- Anyone have this problem??
- 4l60 trouble
- WTF's going on with my A4
- 4000 stall people with granny gears
- Gears or Stall???
- 1-2 and 2-3 shifts
- thining of going M6->TH350, read faq's and still have questions
- tci tcu help
- 1LE tranny mount fit 01 A4?
- who has over 400rwhp on stock trans?
- kickdown
- Happy fuddle customer
- DS length
- Redline Transmissions Ft Lauderdale
- My Tranny Soudns Like Its Slipping Help!!!
- Stalled A4 owners...
- Big thanks to Dave @ Rock-On
- I'm nervous about this stall I just bought...
- Out Put Shaft Seal R+R?
- 4l60e worth keeping?
- rock-on transmissions..
- "Planetary gearset noise" any suggestions or ideas?
- 4l80e?
- $2600 to rebuild auto tranny?
- a4 problems?
- P1786: 3-2 downshift fault
- what shift kit you guys buyin?
- screwed up my shift kit install. need help badly
- kickdown cable on th-350
- Will a 4l60E bolt into a Old Small Block Chevy???
- Need a quick question answered.. tranny cooler..
- coan transmission
- torque converters????
- 1>2 WOT shift getting soft
- DRC built TH400
- Tranny Rebuild - What Rebuild Kit?
- tranny pressure is all over the place!!!!
- quick ? on new tc install?
- John Goebel Transmission Done... Pics
