- Need a quick question answered.. tranny cooler..
- coan transmission
- torque converters????
- 1>2 WOT shift getting soft
- DRC built TH400
- Tranny Rebuild - What Rebuild Kit?
- tranny pressure is all over the place!!!!
- quick ? on new tc install?
- John Goebel Transmission Done... Pics
- hp loss?
- 3000 stall guys/gals come in!!!! Or others folks can help
- help!
- 4l60 parts list
- 4000 stall
- AC effecting OD?
- fuddle guys what 60's u cutting?
- TH350 or 4L80E swap
- 400-410 rwhp
- slight vibration when in D(3rd)?
- th350 & th400??
- other automatic trans options?
- TH350/12bolt VS TH400/9inch
- having trans problem
- Will a shift kit......
- trans question?
- MY car wont MOVE!
- Anyone Done This Before
- Is it possible to put dual tranny coolers?
- Help me keep my head up (long post)
- Is this abnormal wear on my TC? *Pic inside*
- Secret 1st Gear in 4L60E? Any damage caused?
- A6 torque converter?
- Tranny & Stall are Done!!!!
- Deep pan and prokit
- TCI flexplate problems
- Shift Solenoid Stuck On
- Will a Vig 3200 and 231/237 Comp Cam net me 12's??
- soft shift
- Please Help I think I have a tranny problem.
- 4l60 intermediate band installation.
- will it last?
- trans wining
- 4l60e no od or d but have low 1 2
- Radiator trans cooler lines...What size, thread pitch??
- help me downshift
- Back to stock TC - impression
- Gear/Tranny/TSR issue, poss. problem
- Stall for my car...
- lt1 4l60 in a ls1 car
- Line pressure????
- Quick Question
- need someone quick!!
- puttin in converter
- solenoid for the converter lock-up......????
- 4L60E Manual Valve Body?
- Tranny fluid spilling from pigtail plug(wtf?)
- auto tranny problem"s"
- Will same Converter stall higher in higer HP car?
- Stall speed vert requires a cooler ?
- Think my converter is shot
- Th400 drivability with stall
- Maddogtransmission
- trans problems
- Advice: Input on stalls that give better MPH and also from a roll type race.
- Any interest in a billet extention housing?
- the shipping company misplaced my tranny
- strange tc problem???
- Art Carr?
- Installing Vig 3200 & DEXRON VI
- Your opinion on changing my tranny fluid...
- Installed TCI stall
- turbo 400 th400 ls1 bellhousing conversion/adapter
- Just installed TCI Stall
- 700r tranny
- No VSS, problem??
- 4l60E ID Please!
- On a Stall - what is a STR Rating? and which one would I need?
- Weird tranny noise or rearend noise
- TH400 '04 GTO Complete
- Tranny heading south, or just typical??
- Stall
- 1LE Transmission Mount
- 94 a4
- 3200 vs 3600 yenk
- burnout question
- a few 4A questions......
- How to remove trans filter seal ?
- Tranny acting up after tune
- looking for some trans parts...
- Advice: Stalled cars what MPH does your car go into O/D under normal driving.
- New to auto, switching from M-6
- 4L80E for a 1200hp car. I am looking for some answers.
- how much ATF?
- TH350 Trouble
- Why doesn't anyone....
- Too late for a Transgo?
- Dexron III in a chrysler?
- Spraying a 100 or 150 shot with a PT4000
- Converter Wake up
- vacuum mod or not?
- What is the best converter for the 4l80 with boost and spray?
- Who Is Running A Vacuum Modulated 4L60E
- Trans brake on 4l60e?
- Trans cooler install
- anyone know what this code is?
- How much can the 4L60E handle
- low trap speed...
- Is sale over for fuddle?
- No Idea What The Problem Is!!!!!!!
- no overdrive... suspecting tuning issue
- Tranny Going out????
- 4L60E and converter question
- Shift Kit or Tune?
- is this my converter locking/unlocking?
- 700R4 Yoke work in 4L60e?
- ? about which one I could use.
- OAD swap
- Advice: Need a little help with my shift points and O/D on my new set-up
- Hitting Rev Limiter @ Strip
- Built 4l60e...Rock-On vs. FLT *poll*
- transmission slipping
- 4l60e question
- 4L60E extra part goes where? Help
- Tranny whine
- Lost lockout...
- deep tranny pan a must?
- in the driveway
- Transbrake Wiring, Sound Right, Questions inside?
- Swapping to a th350 or th400
- 4l60 rebuild kits
- Stock Stall Converter
- th350 ???
- 4l60e stuck in second gear
- Anyone keep breaking extention housings?
- Thinking about m6 to a3 or a4 swap, what do you think?
- New FLT trans and some install questions?
- TH350/400 with 700R4 1st and 2nd gear????
- what a4 do you have in your car?
- Car sits still
- Best pan gasket for A4 ?
- 4L60E shit everywhere...what should I get now?
- Theory Or Fact About Choosing A Converter?
- shift kit + hand held = ?
- Sponsor???
- 4th gen shifter???? NEED HELP!!!!!
- Str?
- 2800 to 3800 Converter change But Still Same 60', Why?
- 3000 or 3500 stall?
- Car shifts extremely early, converer won't lock up, only when compressor is on
- Trans temp gauge mounting?
- Questions about stalls
- Trans slips when turning....?
- 2nd gear slip under wot downshift
- Need help in deciding! Please!
- Best Stall for a Daily Driven LS1.
- Is my transmission on its death bed?
- Got my first stall
- Cant seperate tranny/engine
- HELP***press gas...rpms go...car doesn't..sometimes??
- valvoline or m1 tranny fluid
- rossler 4l80e t-brake
- Dexron 4
- Might Buy Car w/ TH400, Few Questions.
- Changing back to 2.73 gear from 3.73..Question
- P1860...
- Which 4L60E do I have?
- shorty headers
- Fuddle question
- a4 shift kits
- My CPT rant.
- Perfect converter for 402 or 427?
- I have the wrong 4l60e
- What are the stock shift point's set at?
- Stock Cooler Heating Fluid
- Tranny slipping
- TH350 shifter, linkage, etc
- trany choice help please
- 4l60E LS1 tranmission questions
- test port on a th-350
- Transmission or TC problem?
- synthetic trans. fluid
- Went to track with new mods, i am not happy
- The Best Trans. Cooler
- Converter Question????
- Stall speeds explained
- 2002 Trailblazer Transmission issues
- converter efficiency
- 4l65e stock in LS1?
- Hmmm, tranny fluid pouring out.
- WTF??? Converter does not flash on highway roll... it shifts into 4th?????
- Converter does not unlock when WOT
- shift point
- Fuddle owners >
- th350 driveshaft size?
- cheap strong 4l60?
- Does anybody have install instructions for the B&M Shift Plus
- trans cooler
- Tune after Converter install?
- switching From LS1 to LS2 flexplate questions
- 2-3 WOT Bumping Rev Limiter
- Tranny Cooler
- Throttle response experts??
- mileage from 4l60 to th400
- Advice: From a Roll which is faster a stock stall or a 3,000 plus stall?
- tranny temp gauge
- Manual Vavle Body
- th-350 or th-400
- vig and styrofoam
- Inconsistent shifting...
- Need some help...bad problems
- help needed on fluid choice
- converter install..
- Best Converter
- Launch question
- Advise on 4l65e performance parts for an engine swap?
- Free Slap Shift Mod!
- how do i install this shift kit??
- tranny cooler cause car to over heat!!!
- trans lines
- Trans Cooler
- Automatic gearbox questions...
- all around stall size?
- Just a general question
- Need your thoughts
- Advice Please: Problems with my new built trans and Fuddle Stall.
- Help with Shifting
- Ati Or Precision Industries Converter.... Strip / Street ???
- Anybody ever seen this happen?
- Converter + ????
- Which Transmission!!!
- Tranny R&R
- 4L60E transmission with an Stock LS2
- Automatic 4L60E Transmission Questions !!!
- rear seal change instructions..
- aaaahhh I f*ckin aaahhh 4L60e
- 2 questions
- which converter
- Reverse Clunk
- Stall
- Flushed Transmission, 2 days later, 1-2 Problems and P0751 Code
- Hate to admit this, but you guy's were right...
- transgo performance shif t kit question
- tci 3500 stall??
- New Tc Question...
- TC Grinding on Lockup
- Kick Down Question
- Weird tranny issues 4l60e
- Does the TC needed to be filled before install?
- Which str??
- break in period for TH-400
