View Full Version : Automatic Transmission
  1. Can Anyone Help Me
  2. Help?????????????????????????????????
  3. 4l60e lost reverse
  4. no reverse
  5. 4L60E ls1 in a lt1 car??
  6. fuddle 3200 or 3400
  7. Whats an acceptable TC clearance...
  8. Help!!!!!!!!!1
  9. Converter or Tune?
  10. th400 fittings
  11. converter problem
  12. Lockup in an A3?
  13. stall for a blower
  14. Vigilante or Fuddle?
  15. wont shift to 3rd-4th
  16. 2-3 takes for ever to shift on spray
  17. 4L80E Conversion Pics
  18. shift kit
  19. torque converter clutch= lock, unlock, lock, unlock, etc.. ~5min intervals
  20. 4l60e Only Works in D or 3
  21. TH 400 wont shift to third on the jug!
  22. Tranny wont shift
  23. Bought everything to get my transmission rebuilt.
  24. Throwing code.. HELP
  25. Lockup speeds?
  26. Stall and Superchips???
  27. 700 R4 trouble...need help
  28. Bought 3500 Stall Fuddle - Top End Speed?
  29. TCI SSF 3500 lockup problem
  30. Pageing Fuddle.
  31. FLT Transmission Arrived !
  32. p0571
  33. Trans parts question
  34. 4l60 problem
  35. Anyone try CK Performance Racing Transmissions?
  36. Down shifting
  37. screw the previous problems i have w/ my tranny
  38. which tranny?
  39. stall question
  40. need help w/ the lil things on the tranny install
  41. couple th400 q's
  42. Computer Not Telling Converter To Lock, Anyone Tell Me Why?
  43. M6 console with A4??
  44. 4l80 wierd shifting
  45. tci ultimate street fighter
  46. How many quarts of tranny fluid
  47. m6 to th400
  48. So f*cked...
  49. conversion time
  50. surging after converter?
  51. Cost of trans flush ?
  52. lockup clatter
  53. Tranny fluid question
  54. Stock Stall Speed?
  55. Went to the track last night, is this normal for a stock A4?
  56. Installed rebuilt trans, now will only shift when I let off gas?
  57. th400 bellhousing difference
  58. Converter unlocks on itself
  59. Estimated top speed with th350?
  60. Transmission problems
  61. Dropping Tranny this week...
  62. Stall Converter??
  63. where to buy tranny parts
  64. 4L60E or 4L80E?????
  65. Turbo 400 or Glide? Help me decide.
  66. wtb th-350 o rth-400
  67. Which is the best rebuild kit?
  68. Need Help Picking stall
  69. 4l80e & 6.0 lq9 2002
  70. wont shift at WOT?
  71. Highest LT1 Stall
  72. quick question,how much power does the corvette 86 automatic tpi stock generate?
  73. Tranny cooler install
  74. making my tranny go 1-2-3?
  75. A4 shifting weird
  76. is this normal w/ my stall??
  77. what converter for my t76 turbo set up??
  78. No 4th Gear!!!
  79. hughes converter ??????????
  80. Will I Need a Tune?
  81. Code P0751 - Do I really have a problem?
  82. shift kit affect tune?
  83. Converter wont lock!!1
  84. Trans Mount Help
  85. Launching
  86. 97 3.8l Torque Converter The Same As 97 5.7l Torque Converter?
  87. Is this all I need for a th350 to work on my Lt1?
  88. i must be dumb
  89. Tuning or 3-4 Toasted
  90. th400 vent tube
  91. How much does a factory 4L80E and factory 4L60E weigh?
  92. slipping trans
  93. Trans need rebuilt?
  94. Installed fuddle 3400 2.1 str
  95. Who sells ultrabell for PG
  96. Torque converter questions
  97. Vid of street driving with a 4000 stall
  98. Rearend
  99. FLT Stage IV and Yank PT4000 installed
  100. 4L60e w/ Nitrous
  101. how much of a difference will a shift kit make?
  102. 94 formy, transmission shift botton..
  103. Installed Transgo - Now P0785 trouble code
  104. Lookin for a stall..
  105. tranny.....uuH
  106. 8" stall converter
  107. trans brake for 4l60e
  108. 4l60e rebuild or th 350 transmission ?
  109. formula for rpm with changing gear ratios
  110. gear ratio
  111. help with auto trans
  112. newb style question..i know...explain a STALL
  113. I need a good converter for a 89 TTA
  114. Great Tranny Guy!
  115. Broken exrension housing
  116. Advantages/Disadvantage of stall
  117. is there an aftermarket shifter for a 4l60e
  118. TransGo or B&M Shift Kit?
  119. will a loose converter hurt gas mileage
  120. shifting problems
  121. problem removing transmission
  122. Is solenoid on 4l60e electrical?
  123. Anyone using the Neal Chance racing converters?
  124. turbo 400 rebuild
  125. What do you do when.........
  126. 3400 + 2.3 STR + 3.73 = Close to stock feel?
  127. Warranty Question?
  128. Mounting trans cooler w/front bumper cover off
  129. Temp Difference with B&M Deep Pan
  130. Need advice
  131. anyone need a 4l60e?
  132. need some 4l60e help
  133. transmission acting up !
  134. crossmember question
  135. Are there any good converter swap walk throughs?
  136. Vig conveters.
  137. its 4l60e rebuild time...parts ????
  138. will this transmission work for my friend?
  139. P0751????
  140. 4L60e took a dump
  141. question about 700r4 conversion..
  142. Converter Break In
  143. is my torque conv blown?
  144. trans problem... HELP
  145. th 350 ?
  146. how many run rock on 4l60e?
  147. can my tranny handle it?
  148. 4l60?
  149. crossed transmissions lines?
  150. tci 3000 what should i do buy it or not?
  151. trans cooler connection to TH400
  152. 4L60E rebuild help
  153. Tired of how hard the clutch hits...
  154. TH350 and custom driveshaft
  155. Two-step on auto car?
  156. Anyone running a PE4400?
  157. automatic shift kit or manual
  158. deciding on new tranny...4L80e
  159. Tranny Tuning after Rebuild?!?!
  160. anyone need a 4l60e?
  161. quick flexplate question
  162. Quick!! need to know something!!
  163. Sponsor's come in: Convertor buying decision
  164. ss3600 or ss4000 for this application?
  165. My tranny hates me.
  166. Best DD tranny replacement
  167. LS1 4L60E bolted to an LT1?
  168. Using the B & M Quick silver shifter???????
  169. 3600 stall?
  170. What stall and str Fuddle?
  171. Helpppp Asap!!! 1995 Transam Auto Transmisson Problem
  172. 4L60E Help
  173. shifting probs?
  174. What could my problum be? 4L60E
  175. Fuddle keeps getting better
  176. Manually shifting the 4L60E during road courses
  177. No Engine Braking in 1st-3rd, 4L60E
  178. Which stage, mods to 4l60-e to hold 600 rwhp?
  179. Any Differences in 700R4 and 4l60
  180. help on th350
  181. a4 crossmember?
  182. 4l60e issues
  183. anyone need a built th350?
  184. SS4000 Track results
  185. What breaks in the 4L60E?
  186. 4 speed auto with overdrive in 70 Chevelle?
  187. bad converter??
  188. New 6-speed, Esclade, Corvette?
  189. AOD trans
  190. th400 shim - how much
  191. How long will my A4 last??
  192. pro/con to manual forward valve body TH400?
  193. Could my tranny possibly be built wrong
  194. PRoblems
  195. Launching
  196. Best shift kit?
  197. what transmission is in a 92 V6 firebird?
  198. valve body question??
  199. raising shift points with converter?
  200. Whats with the inconsistent pickup??
  201. Where to set shift points?
  202. ssf 3800 stall with nitrous
  203. Tranny issues
  204. 99 Z-28 A4 4L60E shifting issue
  205. modulator valve hookup
  206. Energy Suspension Tranny & Tq Arm mounts
  207. Help Me Please !!!!! 1985 442 and lt4 swap
  208. Vigilante vs Yank
  209. Ticking noise coming from my 4L60 in 99 Z28...
  210. ? tranny probs
  211. converter question
  212. Someone weary about getting a stall...me
  213. Installed my Fuddle 4000
  214. If I were going to get a Fuddle...
  215. T56 -> powerglide swap, help!!
  216. Manual Valve Bodies
  217. Transmission Mount Replacement?
  218. Those with a3, big stall and 2.73`s-3.42`s!
  219. WTF am I doing wrong?
  220. Is this normal??
  221. How much did your stall and driving change when going from 2.73's to steeper gears?
  222. Too Much Tranny Fluid?
  223. A4 with heads/cam and stall - what kind of gas mileage?
  224. Getting restalled to 4400-change STR??
  225. Is this stall too big?
  226. 4L60E interchange question
  227. Flexplate Question, A4 Trans Pro's step in please
  228. 4l80e speedo sensors with a 400? not working..
  229. Dyno Numbers....
  230. torque management
  231. stalled a4 guys how many miles out of tank of gas?
  232. Transmission crossmember
  233. stall help
  234. trans swap
  235. Trans Temp Gauge?
  236. what rpm should i be at???
  237. converter lock-up
  238. Th400, 800 hp, 2.75 gears and a 3500 stall
  239. 4L60E Shifting Problem
  240. Tranny Advice
  241. any way to manually shift the 4L60?
  242. 4l60e question
  243. Is this a solenoid problem???? Help!!!!
  244. Shift points 3.73+4000stall help?
  245. Torque arm
  246. how much will i gain
  247. fuddle intalled et's down, but so are traps..?!?!
  248. I should know this already but...
  249. anyone w/ a fuddle 3600/2.0-2.2 str
  250. Fan for my tranny cooler
