View Full Version : Automatic Transmission
  1. viglante stall
  2. tranny cooler?
  3. I Got Yanked!!!1.520 60ft 11.50@117.09 N.A.
  4. Max RPM on 4L60E? 300RPM Change on shift point = hit limiter?
  5. ATF change question
  6. 4L60E Shift Kits
  7. question on the 4l60e important
  8. Tranny cooler and deeper pan...
  9. ENERGY SUSPENSION tranny mount
  10. Converter lockup mind of its own
  11. New 4L80E Conversions Now Available!!!
  12. 3800+ Convertors Tranny temps?
  13. Dyno sheet question torque spike
  14. 4L60E & Transfer Case
  15. Is it out there?
  16. anyone regret adding a converter to their car?
  17. skip shift
  18. Props to Doug Rippie Motorsports (DRM)!
  19. Squeel during shifts
  20. 4200+ guys
  21. Cheetah Shifter Owners need your help
  22. Shift Kit VS Computer Tune
  23. New guy with tranny question.
  24. yank and PI
  25. ATTN: Pro Built Transmissions
  26. Turbo 350 wont go in gear
  27. 4l80-E in C-5 /C-6
  28. looking for a good rebuild kits
  29. another TC question
  30. rebuild stock or buy aftermarket?
  31. TC install PITA?
  32. Torqe Converter Question
  33. shifters with th400
  34. Who in here is good at polishing??
  35. shift kit issues on 4L60E
  36. which one th-350 or th-400?
  37. getting a fuddle, what stall? str?
  38. Royal Purple/Amount of Fluid?? A4 Goat
  39. Another Fuddle 3400 2.1 review
  40. converter question/problem
  41. Where to mount bung for trans temp gauge?
  42. B&M hammer shifter for 4l60E? HELP
  43. 700r4 vs. 200r4
  44. Fuddle 3000 Q's
  45. 4L60E line clips
  46. Transmission Mount Height
  47. What should my 60' be?
  48. th400 on freeway?!!
  49. Th400 Won't Go Into Reverse
  50. Not sure how much longer trans is going to hold up!
  51. 4l60e to a 700r in a 94 4x4 ?
  52. need help
  53. What to replace?
  54. What is the best Trans Oil to get for a 4L60e Trans?
  55. No first gear
  56. rebuilding difficulty 4l60e
  57. 460le rebuild question
  58. Str?
  59. shift problems with fast 78 tb?
  60. fuddle 3600 stall
  61. rossler trans problem?
  62. Picking my FLT transmission will a Vigilante 3200 stall Fit a TCI Flexplate?
  63. converter and gear ratio
  64. trans for an '87 trans am GTA
  65. New FLT tranny installed!
  66. TCC lock-up issues
  67. th400 short shifting problem
  68. Tranny cooler question
  69. How much dur. on stock convertor
  70. ? about tras swap
  71. Converter ordered!
  72. 4L80E First gear question
  73. How hard is it to replace the universal joint? (rear)
  74. tranny is dead....
  75. Tranny Pros Come on in....
  76. ANOTHER 3600 FUddle vertor track results
  77. What could it be
  78. code po757 need help
  79. B&M Shift Improver or Transpak?
  80. will 60e converter work for 80e?
  81. 2 quick Trans cooler question
  82. question on lentgh of sender in port
  83. Cost of tranny swap?
  84. Installed a MS3 cam and now tranny problems
  85. Firmer shifts
  86. 4L80E Questions, please inform/help!!
  87. what shifter will work with no cuting
  88. rubber hoses and trans cooler 4l60e
  89. Transmission temps
  90. 4L60E to TH350 Swap??
  91. tune?
  92. 98 c5 help
  93. BURNOUT question
  94. One shot deal.
  95. What is the best trans mod auto
  96. stall question
  97. How much play in the tailshaft?
  98. 373 gearing on auto
  99. Link or instruction to install Super Servo
  100. BIG Converter Problems HELP PLEASE
  101. 4L70E experience
  102. What is your experience with Finish Line Transmissions??
  103. T-56 to TH400 VSS reluctor ring?
  104. Anyone running stock tranny tune with high HP and shift kit?
  105. 4L80E Trans and MS3 cam
  106. Shift kit installed = Crappy shifts....
  107. Has anyone changed their clutch inside of their Converter??
  108. Has any one heard of this?
  109. best place for tranny cooler
  110. Help:TH400 LS1 Starter Problems
  111. 6l80 in a fbody?
  112. should i stay a m6 or go to a th 350
  113. Where to get built th350 and other questions?
  114. I did it this time…
  115. 3400 TC installed,
  116. Does anyone lock their converter at the track?
  117. LT-1 to th-350 or th-400.
  118. Tranny rebuild/TC nightmare!! HELP!!
  119. Trans Temp
  120. convertor advice
  121. "D" or "OD"?
  122. how do i launch a 3600 stall from a roll.
  123. converter: how big?
  124. 106K Too High For High Stall Converter?...
  125. Codes,Codes, and more codes
  126. Stall Size, STR and MPG???
  127. Cleaning the tranny cooler lines
  128. torque convert lock up
  129. Transmission removal, NEED HELP!
  130. 4L65E comes in what vehicles?
  131. Weird Tranny Problem
  132. B&M deep pan on a TH350?
  133. shifting seems different?
  134. need some help
  135. 4L60E Rebuild??
  136. Need help. No shift from 2-3
  137. PY 3400 trouble here...
  138. what else to do while in the a4???
  139. gm 2004r transmission technical manual
  140. Broken tailshaft (cheap fix?)
  141. My 4L60E lives with ? HP
  142. stall converters kick ass!!!!
  143. 200r4
  144. Better Fuddle 3600 track results... 1.71 60'
  145. Transmission wont shift out of second at WOT
  146. Getting a TCI 3800...Tune???
  147. I got a tune for a ssf3500 stall. Do I need to retune for stock torque converter.
  148. Vacuum modulation without a shift kit?
  149. New Converter Hitting Rev Limiter 2nd to Drive Shifts, Help!
  150. Because you guys asked. TCI Deep Pan Pics
  151. What have you done to your 4L60E?
  152. Getting A New Tranny?
  153. 4l80 late shift
  154. TCC Manual Override?
  155. A4 shifter pigtail after TH350 swap
  156. th400 shifting rapidly in 3rd
  157. Is it time for a flush or overhaul?
  158. running shift kit with shift time turned down?
  159. Dead spots?
  160. transgo shift kit
  161. 228R what size stall?
  162. 408+4000lb =trans???
  163. 400 in an f-body
  164. bolt on cars & stahl
  165. pulling my tranny
  166. got a noise
  167. shifting problem, please help
  168. How to remove brake pedal assembly?
  169. bypassing Park/nuetral switch
  170. LS1 w/pg
  171. 400 vs. built 4l60e
  172. What you guys think???
  173. can you hook up 2 coolers?
  174. trans temp high, and shift error reported
  175. yank ss4000 and slower times?
  176. TH350 trans into and ls1?..?
  177. Why my th400 is bleeding oil like crazy when driving
  178. Ordering a Yank?
  179. 700r4 into an LS1
  180. 4L60E trans leaking
  181. Someone please help me understand what a stall is
  182. Transmission help!!!!!
  183. Tranny Rebiuld Help
  184. shift kit with custom tune?
  185. Do I need a shift kit?
  186. 4L60e rebuild/performance kit
  187. 4L60E need builder
  188. Going with a FMVB 4L80E
  189. 400
  190. Corvette torque converter question?
  191. Just Installed: Fuddle 3400 Stall 2.1 STR Wow!!
  192. will 02 midwest stall fit my 98
  193. Transmission question
  194. stock ls1 w/ stall converter
  195. Leather A4 shifter boot and new knob
  196. vibration at higher speeds may have been solved, what do you think?
  197. Got my Fuddle in today-They ROCK
  198. TQ Converter Problems
  199. shift kit
  200. Daily driving a forward manual TH400???
  201. My stock transmission shifts "slowly."
  202. car won't go into park
  203. Manual shifting a 4L60e
  204. How much power will 4l60e hold?
  205. Chrome Moly 4L60E to TH350 crossmember?
  206. new shifter
  207. tranny Question
  208. fuddle ?
  209. My FLT got here yesterdy
  210. bolting trans crossmember to floor
  211. Bypass radiator trans cooler ???
  212. TCI SSF3000 track results
  213. 4L65E Transmission Cooler and Shift Kits - What's Available??
  214. Stock auto shifter headache, help!
  215. automatic transmission bellhousing bolt part number
  216. th400 builders
  217. B and M hammer shifter.
  218. stall question
  219. 4l60e vs. 4l80e
  220. 4l80e and a trans brake
  221. 6l80/90
  222. How much to install 4L65E?
  223. Is there a writeup for changing trans fluid?
  224. 4l80e pricing
  225. Need some info plz help..
  226. Trans cooler lines...
  227. 3200 yank stall ?
  228. Just ordered a Yank PT4000
  229. Which PCM wire to ground to lock up converter?
  230. Driveshaft size needed TH400!!!!
  231. trans temp sending unit?
  232. Weird Noise Coming from Tranny, only in Overdrive, Help...
  233. Bypass the factory tranny cooler 4l60e
  234. need a poly trans mount...
  235. What a difference a DA makes ...
  236. 2800 converter
  237. Tranny took a dump
  238. 4l65e vs 4l60e
  239. shift kits?
  240. does anyone elses transmission do this?
  241. whats a 4l65e?
  242. Fuddle update from LS1 NATS - Australia
  243. Sanity check on RMVB shift action???
  244. Fuddle 3600 track results...
  245. What's a "saturday night special" torque converter?
  246. Fuddle 3500/1.7str
  247. th350 conversion
  248. Started transgo shift kit install.....Q
  249. Code PO757.
  250. TCI SSF4000 vs Yank SS4000, on the street
