View Full Version : Automatic Transmission
  1. built 4l60e
  2. Car threw a P1870 code months ago I got back from the Shop today and it does not move
  3. Is there a vaccum modulation kit so I can install it myself?
  4. 4L80E Manual VB Question...
  5. I know this board has seen plenty of these threads but...
  6. Tranny
  7. Rock On Tranny Is Here!!!
  8. tranny cooler with FTRA
  9. TH-350 question
  10. RPM transmissions does great work and great service
  11. Newb ?, What is lock vs unlocked??
  12. Thinking of swapping my T56 for Stage 2 4L60?
  13. Fuddle 3600 2.2, B&M cooler, Wait4Me MOT, and 160* installed
  14. converter flush/clean?
  15. Torque management
  16. Who's broken an output shaft?
  17. 4l60e billet output and input shafts.
  18. 4l80e
  19. Tranny deep pan. bmm-70260
  20. str ratio?
  21. Corvette Servo Part Numbers
  22. Is this bad for the A4 transmission?
  23. Uses of a torque converter?
  24. transmission not wanting to shift while racing
  25. How long will stock 4l60e survive on MS3?
  26. M6 to TH400 experts inside please...
  27. Trans-go and Yank Problem
  28. A4 shift knob options
  29. tranny filter?
  30. converter problems?
  31. What kind of tranny/shift kit?
  32. Vacuum mod guys
  33. 400 computer mods to fit in a 4l60e
  34. 3400 converter
  35. Torque Management
  36. Flash point
  37. Will any of the 4l60e transmissions work
  38. dumb stall question
  39. Question on 4L60E, Which ones will work on the LS1?
  40. shifting problems! help please!
  41. is the 4L80e better than 4L60e?
  42. Need help with converter!!!!
  43. 4l60, 4l60e output shafts
  44. Just ordered new tranny!
  45. Thanky you fuddle
  46. Yank SS3600 or SS4000
  47. 4L60E transbrake is installed
  48. TCI Flexplate bolts?
  49. Let's play "What did I break?"
  50. Hughes 57-1012 4000+ L.U. Stall, thoughts???
  51. 2-3 upshift noise?
  52. tranny will be out: flywheel?
  53. Opinion Needed after Cam install
  54. Counting down the days till LS1speed installs my fuddle
  55. Shifting to Overdrive... Sometimes. Help
  56. getting a built tranny, here it is
  57. A4 Gas milage?
  58. Cam Installed now not really wanting to shift to OD
  59. How should I mount the trans cooler?
  60. dynos and high stall converters
  61. how much will a th350/400 swap cost me?
  62. what are the important things to consider when selecting a TC
  63. Ss3600???
  64. Need Help Identifying Used Converter
  65. Playin' the tail...
  66. trans cooler part #/ question ??
  67. Does a 4L60 converter fit fit a TH trans?
  68. What to do?
  69. th350 trans temp guages
  70. is 3800 stall to high???
  71. tranny will not go into reverse and redlines 1st
  72. Have the converter loosened?
  73. A4 Shifter knob clip
  74. Guys in the tranny business
  75. opinions of all those with manual valve body
  76. Converter Bolt size
  77. refreshing converter?
  78. Th 350-400 users.. What console are you using?
  79. !!!!! NEED HELP FAST PLEASE Fuddle T/C !!!!!!!
  80. Should I go Vacuum Modulation?
  81. Do I need a tranny cooler??
  82. Converter Size
  83. Transmisioin Fluid
  84. Yank SS3400 and 3.42's installed
  85. What year is this tranny
  86. Which TQ I will need with G5X3 and ....
  87. stall question
  88. Tranny ECU
  89. biggest tranny cooler
  90. for all who have B&M tranny gauges
  91. Which stall for m………?
  92. 3600 Stall 2.2str?
  93. TH400 with a clutch
  94. 3600 or 4000 for this application: Quick response needed!
  95. Tranny Cooler
  96. yank 3200 + 2.73's
  97. Converter Installation
  98. Cam And Stall
  99. what t.c to go with on 98 c5
  100. Corvette 2001 A4 ?
  101. Rebuilding 4L60E, should I change tranny cooler?
  102. Is anybody running a Trailblazer torque converter?
  103. Deep pan or shallow pan?
  104. broken sprag? loosing overdrive? ** come flex that tranny knoledge**
  105. FREE way to get speedo to work in th350/th400.
  106. tci 3500 stalled at 4500
  107. yank 3600 and 2:73 geras??
  108. 9" center section "HELP"
  109. TH350 Conversion
  110. suggestions for mildly modded daily driver TC
  111. The parts have started to arrive!!!
  112. Stalling out ... cam and stall converter
  113. From 4L60E to TH400 install advice
  114. Leather shifter boot for A4 console
  115. Yank SS3200 being installed in a 3.15, C5. What should I be looking for in a tune?
  116. torque specs for transmission mount bolts
  117. Corvette TQ converter in a 02 Z28?
  118. ? about shift mph !
  119. TH350 Crossmember?? Need some help
  120. Shift points
  121. Slippage?
  122. 1le tranny mount
  123. TCI Flexplate
  124. Help! P0706 Transmission Range Switch Performance
  125. 3800 stall vids
  126. M6 to A4 swap problems.help needed.
  127. vacuum modulation upgrade
  128. Vig 3600 installed...questions
  129. Locked Converter?
  130. 4l60e
  131. what is the best Clutches ???
  132. 4L80 vs. TH400 vs. ??? in 4600# Car
  133. Stall MPG?
  134. supercharger torque converter
  135. Fuddle 3600 2.2
  136. Should I go TH400 A3? hmmmm
  137. how hard to convert to vacuum modulation?
  138. Anybody have a rebuild "guide" like the M6 guys have?
  139. Tranny slipping through 3-4, can I firm it up?
  140. Transmission Temp Help Please!
  141. cam and converter question
  142. tranny mount vibrating
  143. Who is running a 3000 stall 2.5 str and 3:73?
  144. What tranny to use?
  145. Modified Transgo ??
  146. Best place to buy 4.10s
  147. hurst promatic shifter and neutral saftey switch on 3rd gen camaro
  148. Trans leak ????
  149. selonoids
  150. sonnax "super hold servo" piston
  151. my transmission or torque converter broken?
  152. th350
  153. oh crap, is this my problem????????????
  154. Too many problems to summarize, plz read (long)
  155. 4L60E trans brake
  156. Stalls
  157. Thanks Fuddle!
  158. Need new shift knob: Which one?
  159. No downshift - 4L60E
  160. Poppin noise on launch
  161. Stall Converter Help Please
  162. 02 SS - stall converter???
  163. car shifts at 6500 rpm
  164. C6 Automatic 6 speed
  165. Does anyone know what the TCI clutch is made of.
  166. Stall Speed vs. 60 ft.
  167. what converter to get!
  168. Need some input...
  169. New B&M Trans Temp Gauge
  170. Blew my stall?????
  171. A4 shifters
  172. TC difference
  173. Starter and Flexplate
  174. converter lock up
  175. Will not go into gear after Shift Kit and Converter?
  176. what stall with hot cam
  177. adding a shift kit, worth it???
  178. Buying a conveter do I need a shift kit?
  179. Tranny noises?
  180. Will a Vig 3200 stall fit with a TCI flexplate??
  181. Tranny cooler
  182. trans temp\fuild level?
  183. what is STR? (converter wise)
  184. need help
  185. Any idea?! Need help...
  186. 4:10s and what stall???
  187. tranny problem?
  188. What tuning with a Stall on 2001?
  189. 2002 Z28 shift kit?
  190. Advise: Is it time to step up to a better stall then my TCI
  191. Shipping a 4l60e
  192. Low tranny fluid make it seem broke
  193. 4l60 gurus in here please!!!!!!
  194. Energy Suspension Trans Mount
  195. 5.3/th400 Parts help
  196. Whats wrong with my tranny?
  197. rattling noise coming from converter
  198. A4 4.10 gear ratio guys help!
  199. Another Big thumbs up for Fuddle
  200. Trans cooler and dope style
  201. 224 224 cam = manditory stall?
  202. fineline or rock on
  203. Aftermarket converter guys ->
  204. brand of tranny fluid?
  205. 4L60E coolant lines
  206. Fuddle Converter?
  207. sbc/Turbo 400 n a 97 ta
  208. M6 to 4L60E swap
  209. How many quarts in a TH400
  210. converter
  211. where to buy a shift kit for my 98ls1?
  212. how to remove reluctor in the trans
  213. rock-on and fuddle in
  214. what trans is in my 98 c5 a4?
  215. Worst day ends with P0751 code
  216. stall issues, please help!
  217. tune with stall
  218. tranny problem!
  219. bought new tranny
  220. B&M COOLER IS THERE A HOW TO GUIDE
  221. Where does the converter located precisely in the car?
  222. Post your t/c times before and after
  223. line lock
  224. stahl help
  225. Need some help or advice......
  226. th350 guys in here...
  227. Tranny cooler+ ssra
  228. who makes a good shifter for an A4?
  229. OK... i think ill buy a torque converter
  230. Royal Purple trans fluid
  231. TCI 378000 Deep Pan Install
  232. what 60ft time
  233. Fuddle Ultimate/Street Series
  234. transmission temp guage
  235. When your tranny goes, does it take anything with it?
  236. Where to find a 4LE80?
  237. No first or fourth, somtimes.
  238. Transgo HD2
  239. the same tranny problem,only worse
  240. DO any ls1's come with factory tranny coolers?
  241. TCI vs PI Vigilante vs Yank
  242. Tranny options need help
  243. stall size... again
  244. Post your track times Fuddle users
  245. Hurst Shifter Cable Mount
  246. Who's got the best stall prices?
  247. HELP!!!Trans hits revlimiter and wont shift(long post)
  248. Lowest stall w/trex??
  249. vibration problems
  250. done a lot of research...fuddle 3500 w/ 2.0 str for dd?
