PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. 4L80e no reverse after rebuild
  2. 4L60 Not shifting on time on 2-3 shift only at WOT
  3. just bought 94 Camaro Z28 with automatic transmission issue
  4. First time 4l60e rebuild, which kit fits my application?
  5. need recommended stall with nitrous
  6. TH400 Reverse Pattern Auto Shift
  7. th400 or 4l80e?
  8. Advice on plan B
  9. TH400 cooler install lines? - pics
  10. Making base to mount shifter M6 to TH400 swap
  11. Stick with 4L80e or go with TH400
  12. More 4l80 rebuild questions about clutches
  13. 4l80 removing springs from direct and forward hubs?
  14. My T56 to 4L80E Build
  15. 4l80e rebuild log, input welcome
  16. 4l80e
  17. rebuilt 4l60e with new converter shudders on lockup
  18. Need advice
  19. 4l60e vibration in park and leaking oil seal
  20. shift kit and tm/line pressure settings
  21. 4l60e shift kit install=no 4th gear
  22. TC lock up thump/vibration
  23. Merry Christmas and New Year from Jake's Performance
  24. w ad noting a turbo 350
  25. 4l80e, only one case lug broken, any ideas?
  26. 99-00 6.0 with th400 questions
  27. Another 4l80e problem thread!
  28. 1996 4l80e transgo hd 2 kit
  29. In the market for a 4L80 converter.
  30. slipping trans
  31. best mods for a 07 4L80e?
  32. 4l80 issues??? where to start??
  33. TH350 trans brake wont hold
  34. ISO 4l60e
  35. ptc stalls
  36. Why does my trans eat my converters?
  37. Hey guys astro van 4l60e
  38. Transmission won't shift
  39. 2001 Ls1 4l60e corvette servo?
  40. th400 or 700r4
  41. torque converter wont seat all the way please help
  42. 4T65E-HD torque converter
  43. Will stock 4l60e handle 4000 stall?
  44. 4L60e inspection cover removal????????????
  45. My 98 TA ..4l60 will not engage any gear,
  46. Choosing a Lock up converter
  47. 4l80 and Frost Harness
  48. Rpm drop 1-2 shift 4l80
  49. 4L60E on last leg, Stock 4L80 vs rebuild
  50. driveshaft slip
  51. 4l60e questions (99 silverado 4wd)
  52. tranny cooler line routing pictures?
  53. NEED HELP 4l80e guru's
  54. 2wd Silverado trans into my 1999 camaro with lm7
  55. 1994 T/A 4L60E, Shifts, Shudders, Shakes...NEED HELP!!
  56. Calling the Trans gods!
  57. transmission build, mixing up different thickness steels and frictions ?
  58. 4l60e shifts from 1st to 3rd (no 2nd)
  59. shift kit question
  60. tranny cooler and braided hose kit?
  61. transmission slipping?
  62. Need help finding Th400 VSS!
  63. Transmission wiring harness leaking, suggestions?
  64. Circle D - The Box
  65. 4L60E Problem
  66. TH400 late 2-3 upshift
  67. 40k tru cool install
  68. Is my flexplate spacer in the correct spot? Th350, pic inside
  69. 4l80e swap and need flex plate bolts
  70. You guys see this?!?!?
  71. So California transmission shops
  72. LS horizontal automatic transmission / transaxle?
  73. What's a good 4l80e worth?
  74. th400 dual feeding direct clutch w/ manual reverse trans brake valve body ?
  75. 700R4 TCC lockup with LS swap
  76. If you don't have L1 in your car shifter, read this thread !!!
  77. What Flexplate are you using? LQ4 to 4L80e
  78. New converter break-in SS3600
  79. ls or non ls 4l60e
  80. th400 foward / direct steels, is .068'' to thin?
  81. 4L60E fluid advice
  82. 08 h/c/i c6 a6- rebuilt trans, 4200 pi stall- pushes car at idle in gear?
  83. Vibration after th400 swap
  84. picking the right converter
  85. Neutral saftey switch issue?
  86. Trans mount options
  87. 4l60e troubles
  88. Black Friday Sales?
  89. conveter install with 132k miles?
  90. TH400 dipstick fit a 4L80E?
  91. Flexplate and hub adapter confusion.
  92. random 4L80E no gears or only some or one
  93. 4L65E converted to 4L70E
  94. th350 build questions
  95. what stall do i need
  96. Adding heads/cam this spring.. When to add a stall converter?
  97. 4L60E Troubles
  98. What would happen to a junk converter and 700whp?
  99. North Texas Converter Black Friday Sale on all transmissions and converters!
  100. 4L60 makes noise.
  101. 4l60e 3/4 clutches
  102. Who has done the "3rd gear spool mod"
  103. Third 700r4 I need to upgrade.
  104. JD Hy-Guard fluid in 4l80e
  105. B&M Pro Ratchet with 4l60e
  106. Auto shifter help
  107. Trans temp sending unit and teflon tape
  108. Circle d converter id'ing /marking info
  109. need transmission information help
  110. Advice on th400 parts?
  111. Max Power for 4L80E
  112. Boosted Th400 guys chime in...
  113. weird 4L80e issue, slipping at part throttle but shifts at WOT
  114. 4L80E manual shifting
  115. 04 GM transmission in a 03 GM truck
  116. RPM 4l60 swapped 2010 Camaro
  117. 4l60e won't shift bad pcm??
  118. Why can no one provide a detailed answer? 4l60e to th400 swap question!?!?!?
  119. 4l80e connector clearance issue
  120. Thinking 4L80e swap, need advice.
  121. Flexplate Question
  122. TH350 or switch to PG?
  123. torque converters
  124. Its that time again!!!!!
  125. 2005 5.3 Silverado engine. What year trans will fit?
  126. Which builder for 4L80E's?
  127. FMVB 4L65e, shifts 1-2-1-2 instead of 1-2-3-4
  128. need 4l60e help. no 1st gear
  129. 4L60E clicking with high line pressure
  130. 4l80 tcc issue
  131. Fluid Leak at dipstick tube grommet
  132. How to check 4l60e pump???
  133. Fresh rebuilt hard shift
  134. What type of transmission is this?
  135. How is your 4l60e doing with mods similar to my planned ones?
  136. Trans wont shift from 2nd-3rd under full throttle.
  137. TH400 shifter and flex plate
  138. performabuilt 460le 3800 yank stall
  139. TH400 Shield???
  140. Spacing on converter?
  141. 4L60E ready to go.
  142. 6L80E install - anything specific about converter/alignment?
  143. 4L60E Ratchet Shifter
  144. 1200 hp 4l80e build
  145. 4l60e to 4l80e
  146. New texas speed by yank torque converter
  147. Need advice on rebuilding 4l60
  148. 95 4L80E Cooler Lines
  149. Torque converter question
  150. Beafing up stock 4L60e (from S10) to use with 4.8 or 5.3 ?
  151. Is it safe to use a Yank PT4000 with nitrous?
  152. Fluid change issue/rattle noise
  153. SOLVED - P1SC SD OL 4L60E TransGo Kit w/violent P to R and N to D.
  154. 4L60E with P0748 code
  155. 4l60e question...thank you in advance.
  156. MSD Atomic TCM Controller
  157. 98+ SBC 4l60e vs LS 4l60e
  158. Flexplates, which one
  159. what kind of 60' to expect with a 4k stall
  160. brand new b&m 4l60e/b&m 2k stall lockup issues
  161. 4L80E billet shaft question
  162. Opinions on buying used trans
  163. Th400 3rd doesn't work on highway
  164. 4L80e Slip issues!?
  165. 2000 4L60E rebuild
  166. 4l60e quick shifting through gears
  167. 4L70E no second gear *update #2 Fixed!*
  168. 700R4 won't stay in 4th gear
  169. stall installed finally
  170. 4L80E Sale
  171. Flex plate bolt ?
  172. 4l60e dragging/Slip?
  173. 4l80 yoke and riveshaft question
  174. No gears after rebuild
  175. Circle D vs Yank
  176. TH400 line pressure???
  177. th400 converter cover??
  178. Need Help With 4L60E Choices
  179. rpm+gear = wrong speed?
  180. Cam and no converter..
  181. Built 4l60e Popping out of gear under any load.
  182. PerformaBuilt Holiday giveaway is back check inside.
  183. Best way to drain 4l60e
  184. 4l65e holding 2,3, gears
  185. what stall to use in my swap?
  186. Question about 4L60e and issues regarding
  187. Th400 lq4. Converter to flexplate gap.
  188. Yank stall question
  189. Nv3500 to 4l80e
  190. Converter question
  191. automatic shifter/hurst/ b&m for A4 transmission?
  192. A4 4l60E third gear vibration
  193. 4l80e converter slippage issues
  194. 4L60E Slipping In Second only
  195. Anyone running a TCI built 4L60E (StreetFighter 371016)?
  196. Which solenoid is the 3-2 downshift?
  197. 4l80e shiftting issues, help?
  198. 4L80E performance build
  199. servo pin extender
  200. Yank SS3600 on high mile LS1....
  201. 2000 model 6.0 and 4l80 converter question
  202. Turbo 350 or glide in Turbo Camaro ?
  203. 700r4 transmission helo
  204. 4l60e 300m Billet output shaft in stock?
  205. Is there any shifters that allow 1st to 3rd?
  206. The black edition
  207. which stall?
  208. 2nd stock ecm for 4l80e control?
  209. Lazy downshifting in 4l60e
  210. TH400 swap parts
  211. GM Supermatic 4l85E
  212. 1998 k1500 4l60e
  213. 4l65e smokes from vent tube? issue
  214. Yank SS3600 Lockup or Not
  215. 4l80e Yoke Dilemma - Please advise
  216. ?? on a transmission
  217. need help quick
  218. Exedy vs Borg vs Alto vs Raybestos Clutches on 4L80E
  219. 4L80E LS converter to LT1?
  220. 700r4?
  221. 4L80e slow shift 2nd to 3rd
  222. 4l60 questions
  223. Converter's Physical Size
  224. 4l60e Help
  225. 4l60e won't shift into 2nd
  226. 4L60E tuning...
  227. Help Reading Fliud level
  228. Tourqe converter bad outta box? Please help
  229. c5 w/trans issues
  230. rpm level 5 4l60e 2-3 shift problems
  231. 2002 s10 4l60e bolted to 2002 5.3???
  232. 97 4l60e Trans Shift Cable Issue
  233. 4l60e Tail Housing
  234. Question on torque converter unlocking
  235. Th350 conversion wiring question
  236. 4l80e "binding" in reverse
  237. 4l60e no 1st or 4th
  238. Th400hd
  239. 4L80e input shaft stripped
  240. 4L80E shallow pan
  241. 6spd to 4l60e swap
  242. different versions of 4l60e
  243. New setup need advice on 4l60
  244. 95 4l60 rebuild advice
  245. Speedometer reading way too fast after 4l80 swap
  246. How much power are you making through your 4L60E?
  247. 4L60E replacement.
  248. 4l80e vss signal wire
  249. Swapped T56 for 4L80, driveshaft interference
  250. 4l60e slipping?
