PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. Anyone using a tranny brake on a 4L80E?
  2. Rossler TH400 info needed
  3. Tranny issues..
  4. TX AL MS LA: Where to get a TC install?
  5. Using a laser thermometer....
  6. 4L60E - Vibration in 3rd only...
  7. Another Yank Vs. Vig thread
  8. Torque Converter...Sounds Great!
  9. a4 swap help
  10. Converter Slip %
  11. vent tube on top of 4L60E?
  12. Any Transmission?!
  13. How do you install a Torque Converter?
  14. OK...should I go auto or manual???
  15. what is converter?
  16. Here’s some info I found about running in OD while Drag Racing.
  17. can i swap my lt1 converter w/ a ls1 converter?
  18. 4l60e WHAT THE!!!
  19. Valve body wiring
  20. Vig ratings, anyone who knows the actual stall; come inside.
  21. Update on Performabuilt Converter
  22. 4L60E soft shifting into 3rd
  23. gear install ?'s
  24. My trans died!!!!!!!!!!
  25. 1/4 mile difference Bone Stock + 4000 Stall?
  26. yank 3600
  27. C6 6 Speed Auto on Camaro...
  28. sorry dumb ?
  29. TC and transbrake?
  30. Pulling out 4l60E question HELP PLEASE!!!
  31. Shrifter ..anyone have one
  32. Finishline Trans for sale!!!!
  33. i was woundering if this is posible
  34. car bucking when locked up help...
  35. Uh oh
  36. 700r4 installation ?
  37. 700r4 what converter
  38. Tranny Problem
  39. What RPM to stall at?
  40. Best Shifter for 02 WS6?
  41. dipsticks tube
  42. Replacing trans mount on 99 TA
  43. Tips for filter and Fluid change?
  44. 4L65E Shift Kit
  45. hitting the rev limiter
  46. 4L60E tuning?
  47. 700r4 w/6.0
  48. Street Fighter TH-350?
  49. tci 4000 converter
  50. 700-r4 question?
  51. Tranny spitting out fluid
  52. whats a 4l60e worth?
  53. "STALL" noobie
  54. how much stall
  55. How to lock TC?
  56. TH350 / 400 Behind an LS1
  57. 4l60e, 700r4, or 200r4?
  58. G5x4 Cam With High Stall Autos,anyone?
  59. 4l65e wiring ???? Please Help
  60. Help Needed.
  61. Compare and Contrast 4l60E and 4l80E
  62. Need some advice on a TC
  63. So basically
  64. need some help monaro 4l60e auto
  65. New unethan trans mount - big vibration at 45 mph
  66. 3500/4000/4500 stall???
  67. 4l60e lt1 transmission options
  68. SS4000 to much on N2O
  69. New YANK item --a must have!
  70. Ft: T56
  71. Identify part from location & description..
  72. Shift Kit
  73. how much gap b/w converter and flexplate?
  74. Disable adaptive learning with Shift Kit?
  75. Quick shifts off the line only at WOT
  76. Couple of questions before I order my converter please!!
  77. Has anyone used the TCI controller on 60E in F-body
  78. Auto 4L60E Trans Question
  79. how reliable are the 4L60E tranny's
  80. Weight of a 60E?
  81. Sonnax HD Red vs. Kevlar Bands?
  82. Where do you mount your transbrake button?
  83. Bought a used tranny w/ vac mod, do I have to hook it up?
  84. Tranny Question
  85. th400 output shaft has A LOT of play in it
  86. Check out the performabuilt layaway plan front page on site
  87. Tci 4000?
  88. tranny going out
  89. Yank 3600 Stall question
  90. A4 Problem
  91. Performabuilt transmission = happy customer
  92. 4l60-e rebuild
  93. Manual shift w/stall?
  94. Trans removel HELP
  95. Got a weird th350 problem
  96. I need advice but now please!!!
  97. Will a 4l60e from an 98+ ls1 car bolt up to an lt1?
  98. Help! Am I Missing a bolt?
  99. 4L60E help...
  100. New PerformaBuilt front page check it out!
  101. Will i be ok with 3500 stall through the winter with no cooler??
  102. sludge 4l60e
  103. Good RPM to launch at with my setup?
  104. Help! 4l60e
  105. Yank Pt4000 Guys Come In
  106. ***Best Atermarket Transmission***
  107. regular TH350 vs. lock-up TH350, lots of ?s
  108. New Performabuilt 'verter
  109. adjusting pressure control solenoid 1/8 of a turn?
  110. throttle body
  111. Paddle Shifter Vette?
  112. Need a big trans cooler, what is the biggest....
  113. Converter Install
  114. Disconnecting Transmission lines from radiator
  115. 100shot + stock trans!!!!! Yikes!
  116. Help
  117. Who is still using a rubber mount?
  118. Convertor swap with Poly mounts
  119. shift kit!!!!
  120. Trans whining in 1st and reverse
  121. Th350 Valvebody Question
  122. Who can build a TH350 that can handle me?
  123. TH400 shifting compared to TH350??
  124. Megamax Trannys
  125. PT4000 guys, quick ? for you....
  126. High stalled and big cammed guys come in!
  127. is it a big problem ?
  128. what trans cooler if any other than stock
  129. Restall Converter? (Procharger)
  130. Fuddle is a new sponsor on the Corvette Forum
  131. Need info on Mad Dog trannys.
  132. How much did you pay for your m6 to turbo 400 swap
  133. Stop wasteing money and buy a Gearstar.
  134. Tranny suggestions for my turbo'ed GTO...
  135. Auto swap advise please
  136. Converter and mph?
  137. Fair Price?
  138. A4 Transmission Rebuilt, now what?
  139. How hard is it to go to A4 from M6?
  140. Cammed guys with stock stall
  141. Pulled the pan down today couple ?'s
  142. How many of you have broken the 10 bolt w/automatic?
  143. Dragstrip damage w/ pics... anyone ever done this?
  144. problems with tranny
  145. Converting my 98 m6 to TH350 any links?
  146. dipstick tube
  147. how many mph does you car pick after the 1/8?
  148. Worried about top end on th350.
  149. Powerglide questions
  150. do I need a cam for 3500TC
  151. Quick 700r4 ?'s
  152. Performabuilts Converter Division Site
  153. 4l60 question
  154. New tranny or just a stall?
  155. 4L70E Sprag "weak link"
  156. TH 350/drive shaft
  157. Converter to Flywheel Picture Inside. Look.
  158. Trans slipping *pic*
  159. Shift Problem
  160. New tranny & converter, but ran 2-3 tenths SLOWER! Which is the culprit..
  161. Question For The Pro Builders
  162. stock TC wont unlock??
  163. Temp gauge ?'s
  164. 2 -> 1 shift...
  165. Battery
  166. Trans Help
  167. need convertor size help please
  168. lock up converter not locking up
  169. Did I get the Right Tranny Fluid? Picture Inside!
  170. auto having trouble shifting
  171. RPM and Yank get me all fixed up
  172. 4l60e to th400 conversion
  173. Calling all TH350/TH400 Street guys
  174. 700r4 in a 65 pickup?
  175. Trnasmision from 2wd to awd
  176. tranny problems
  177. ss3600 highway rpm ?
  178. Torque converter allignment help!
  179. Built tranny before Torquer v2 install?
  180. Solve My 2-3 Shift Problem And I will Send You $50
  181. Ss3500/obd1
  182. 4L80E woe problems.
  183. Power Glide
  184. Tanmission or Converter?? Help
  185. 4l60e to th400 conversion into 94 formula
  186. Tranny coolers
  187. where?
  188. 4l60 torque specifications
  189. Is my fuddle on borrowed time?
  190. need help figuring out stall problem
  191. 4l60e Problems
  192. installing shift linkage.....
  193. What are you A4 guys getting for gas mileage??
  194. Auto Trans Help!!!! Tinging when shifting into Reverse and then to Drive...
  195. transmission interchangeability
  196. TH400 with Transbrake on a Daily Driver
  197. Stall???
  198. T/C Not locking...Help
  199. Wierd tranny problem
  200. park neutral saftey switch
  201. Built 4L60E
  202. turning up pressure????HELP!
  203. Noise comming from transmission
  204. what and where converter question
  205. TH350 guys in here please.
  206. VSS wires for SUX2BU Speedo for TH400???
  207. Original converter is back in, SSF3500 is out...
  208. Write up for tranny install?
  209. 2800 stall...
  210. What size Converter??
  211. Need new tranny
  212. Torque Converter Questions
  213. Yank PT4000 on the way, any other thoughts?
  214. 4k stall really only 3k
  215. Just another 4l60e P.O.S.
  216. Need to get car out of limp mode
  217. Need help on understanding TQ Converters
  218. 3400 to 3000 stall ???
  219. Bell Housing Bolts?
  220. B&M shifter install
  221. M6 to TH400 Swap - What happens to Rev Limiter?
  222. New Tranny question!!
  223. New Dexron Mercon Vi : Users
  224. Problem with 2 to 3 shift
  225. PerformaBuilt SALE! LS1TECH ONLY DISCOUNT
  226. Yank or ATI TC for TH350
  227. 200 shot on SS4000 YANK
  228. Harsher shifts on cold engine?
  229. Tranny problems need advice...
  230. Lockup or Non-Lockup? Hear My Story! (Mild)
  231. B&M Trans Cooler PN 70264 or PN 70266
  232. Flexplate Cracked???
  233. 2nd Gear Slipping
  234. $2600 to rebuilt my a4 transmission
  235. driveshaft? LS1 for LT1?
  236. cooler question
  237. How do A4 cars dyno without downshifting, etc
  238. Shift Kit
  239. LSx + 700r4 info. and ???
  240. th350 convertor
  241. Rebuilt trans help
  242. 4l60
  243. th4oo swap this weekend
  244. What has more potential to be quicker? auto or manual?
  245. Tranny Issue??!!
  246. 3200 vig, pt4000 or ss4000 which one?
  247. Performabuilt 4,000 stall installed
  248. The Fuddle worked...
  249. what trans to go with
  250. Auto Help
