- Torque Converter/Gears for a mild 383 street driven Vette?
- shakeing?
- Yank SS Series
- Going to a TH350?
- problems getting the stater into the housing
- trans not shifting right
- 4L60-E removal questions - already searched
- Valve Body question?
- Help needed....did search
- Any A3 guys got their neutral safety switch working
- How are these numbers for a TCI SSF 3500 stalled 2002 WS6??
- What stall do i have?
- Which Tranny Would You Choose?
- Does Chuck Johnson still works at FLP?
- new tranny
- whining/deceleration
- Who do you talk to at TCI about converters?
- what do you guys think about this rebuild kit for 4l60e's
- vibration
- Transmission Cooler Fan?
- OD servo, int. servo, boost vlave info. request
- Is this normal for a TCI SSF3500?
- TCI SSF3500 review inside
- th400/manual valve body guys - ?????
- 4l80 Conversion Company...
- Tail-Housing Replacement
- torque converter suggestions for just a bolt on car
- DS and dipstick info needed.
- Anyone modify the A4 console and use a A3 shifter
- th-400 whining?
- good article on 6L80E in Nov 05 Hot Rod
- n00b auto tranny Q's, need help!
- Stall advice for 408 stroker?
- What are you base pressures at?
- fuddle stall
- Art Carr 4500 stall
- sfi sheild for the 4l60
- A4 shifter consol makes lots of noise!!!!!!!
- Rebuild kit, what should it have in it
- anyone build sick 4L60Es?
- yank ss3600 owners please help
- Fuddle VS Yank
- Newbie Question:I need to know about Torque Converters
- guys who converted to th-400-speedo?
- SES light after installing stall and shift kit
- Is A4 strong enough?
- LS1 Converter fit an LT1 Car?
- After market shift kit?????
- Uh oh symptoms....
- i wanna churp em...
- Yank 6-lug converter + TCI Flexplate?
- Aftermarket converter question?
- SS3800 and pro built shift kit is in!
- Converter won't stay locked up on interstate!
- Which Converter
- B&M Shift Plus???
- A Stall $$$$ ?
- 4L60E power range?
- What all does the car do in fail safe mode?
- Head is spinning after reading line pressure sticky
- What's The Trick? 4L60E Oil Line Connector Clips?
- need a good stall for ls1 silverado
- 2nd to 3rd pre shift quirk
- Does a lower STR also mean a converter is tighter?
- Transgo with my SSF3500?
- After market torque converter sounds
- TH350 Conversion need info...
- Trouble adjusting A4 shifter after converter install
- Temp sending unit 4L60E?
- loose tq arm, now loud banging?
- toasted tranny, need advice on new
- Tranny guys...
- I will buy TransGo shift kit towmorow. Do u agree?
- No TC lockup...?mechanical problems
- ROCK-ON Tranny,
- info on this tranny
- Post Your Stall Size And Manufacture.
- 4L60E vent tube??
- time for a stall??
- converter flash n/a vs spray?
- Grinding noise when put in reverse and more...
- 700r4l60e.com
- Vigilante 3200
- Looks like I will be joining the ranks of the A3 club!
- TCI converter problem...
- A4 Trouble please help..
- Anyone know about a neutral safety switch!
- Loud "POP" sound...
- 2-3 shift
- Dropped tranny pan. Is this normal? (pics)
- 4l60e in a 74 nova
- TCI 3800 stall vs. Yank 4000 stall
- Yank SS4000E, Bigger than 245 tires?
- What is it worth?
- Any Daily-Driver NOT happy after TC installed
- Where is the VSS sensor (4L60E)
- Will a TH400 bolt directly to a '98 WS6?
- v6 and v8 crossmember the same?
- very bad vibration
- Will a 400 bolt up to my tranny?
- What all does it take to convert to TH400?
- slipping after putting on 315's
- stall & cooler question
- Will my 700 R4 bolt to LQ4?
- Bad rattle ofter TC install
- Hitting OD in the 1/4 mile
- Tranny temp guage
- MegaMax Transmissions
- No more Rock On 4l60e for me
- Does a Yank SS3200, with 3.15 gears, feel looser than stock?
- Fuddle STR?
- Question on JW Ultrabell
- Which stall?
- stock tranny problems
- Please Help...broken Tailshaft Housing...please Help
- Forward sprag question
- Does the converter lock w/stock settings @ WOT?
- trans tuning after stall?
- Line pressure problems!
- Fuddle Track Results
- Stalling/idle problems with aftermarket converter?
- convertor question
- stupid question how does a stall work and
- stall locked and unlocked
- Yank 4000 stall results =)
- why can i stall higher in second?
- Who cracked their flywheel.. should i upgrade..
- Stall recommendation Please??
- Please help....swapping to an A4...questions
- Where to order tranny parts from???
- Vaccum modulation?'s
- Stock Converter
- Blew my tranny
- Stock trans, stock 10 bolt, 11's no problem.
- Question /Help with 3200 Stall
- Should I get a bigger stall?
- stock trans with stall
- MAy sound like an idiot but....
- Those with BMR or Yank TH400 transmembers.
- Gear Vendors OD Unit
- Two Fuddles in under 5hrs, very happy x2!
- When do i upgrade, and what to?
- A4 kicks out of gear?
- ratchet shifter ????
- Need some info on a converter plz help
- How Do You R & R A 4L60E Transmission Filter...?
- Strange noise
- Steps to r/p the sun or reaction shell - 4l60e
- Wont shift out of first
- Trans Mount Crossmember Stud-Torque Spec?
- Will it work???
- Th400 RMVB Questions
- 4l60e/3500 stall? will it hold?
- TH400 RMVB Questions
- ordered a 3800 stall with 2.2 str feels like stock
- Please help! Need advice on 4-speed
- 2->3 and 3->4 won't shift hard
- need a good stall
- What is a good Trans Filter?
- Hitting rev limiter
- my english paper on removing a 4l60e from a fbody
- Tranny rolls forward in reverse, no mph, but revs, in neutral doesnt roll back......
- Please help, looking for street/strip 4 speed
- 4l60e...will an '05 fit a '96 blazer?
- A4 guys.....come in
- TC bolts loose..TC knocked the rear main
- ShiftKit and TC install
- Front pump seal leak..need help..
- loud banging when going into gear.
- TH350 3rd gear problems - diagnosis
- Help reading Trans Fluid Level
- help me please
- Bulletproof transmision needed
- Transmission pan leak
- $l60E problems....
- Car "hanging" on 2-3 shift
- Is this normal? / Look OK?
- A4 vibration, 3rd gear only
- Loose noises after Spohn TA and Moser Rear
- Are C5 and F-Bod converters interchangeable?
- Trans fluid suggestions
- I think my A4 is going out
- How much can the 4L60E take ?
- 74 TH350 tailshaft bushing problem maybe?
- tuning 4l60?
- Non-drag Daily Driver: Stall or Gears? A4 2.73's...
- what type of th400 u guys run
- Need Help ASAP!!!!!!!!!
- trans temp high?
- Wheel hop at track... broke rear and tranny
- HELP: Auto tranny rebuild opinion
- poll.. what stall speed n/a f14 cam only ls1
- What's your best 60' with your aftermarket torque converter & REGULAR street tires?
- Fuddle owners?
- LT1/LS1 trannys'
- Torque managment ??
- 700R lost upshift.Help??
- Got a rear end transmission question?
- Does this Fit?
- How long does it take to install a converter?
- Stock trans cooler temps.
- Another Fuddle Review!!!
- Which A3 works with M6 Drive Shaft?
- Is tuning required after upgrading converter?
- WTF did I do?
- What's the most efficient converter that will work well with regular street tires?
- tranny warranty
- Help me pick a converter
- 4l60e s10 tranny lines
- 4l60e Experts Help!
- Hurst pistol grip (Th400) M6 console fit?
- tranny rebuild price?
- what converter to go with
- Stall question
- how much for 4l60e
- Dexron VI has made it to (some) dealers...
- fuddle owners-what mph do you lock-up?
- fuddle racing converter + drag radial = 1.4 60'!!!
- a4 vs. m6
- 4L80E Converters...
- Tranny won't down shift at WOT
- Weird slipping..
- Track Resutls of My Fuddle 4000 TC
- 700R4 to 4L60E
- Ideal operating temp
- Aftermarket A4 shifter
- what will kill my tranny faster?
- 1st gear in a 2000+year?
- help... something just happened to my tranny :(
- Rock on 4l60e made 10 passes today
- stall ?
- Yank PYE3600 WONT GO ON!
- Cam and Sprayed guys with stalls look!!!!
- Need Quick Help !!!
- Need part numbers for replacement seals
- AN fittings on a trans cooler overkill?
- Ordered Fuddle Converter today
- F type trans fluid swap
- Automatic vs 6 speed Standard
- TH400 Converters...
- how do you tell if a converter is good or not? this should puzzle quite a few of you
- Why is manual shifting bad????
- 4L80E hold 1,000+ rwhp?
- do i need to worry?
- 4L60E torque converter bolt torque specs
- '94 Z28 Auto Trans Trouble
- Again With The Noises!!!
- Where to get manifold vacuum for TH350 vac modulator?
- Add Horsepower
- need help.4th gear acting weird
