- MegaMax Transmissions
- No more Rock On 4l60e for me
- Does a Yank SS3200, with 3.15 gears, feel looser than stock?
- Fuddle STR?
- Question on JW Ultrabell
- Which stall?
- stock tranny problems
- Please Help...broken Tailshaft Housing...please Help
- Forward sprag question
- Does the converter lock w/stock settings @ WOT?
- trans tuning after stall?
- Line pressure problems!
- Fuddle Track Results
- Stalling/idle problems with aftermarket converter?
- convertor question
- stupid question how does a stall work and
- stall locked and unlocked
- Yank 4000 stall results =)
- why can i stall higher in second?
- Who cracked their flywheel.. should i upgrade..
- Stall recommendation Please??
- Please help....swapping to an A4...questions
- Where to order tranny parts from???
- Vaccum modulation?'s
- Stock Converter
- Blew my tranny
- Stock trans, stock 10 bolt, 11's no problem.
- Question /Help with 3200 Stall
- Should I get a bigger stall?
- stock trans with stall
- MAy sound like an idiot but....
- Those with BMR or Yank TH400 transmembers.
- Gear Vendors OD Unit
- Two Fuddles in under 5hrs, very happy x2!
- When do i upgrade, and what to?
- A4 kicks out of gear?
- ratchet shifter ????
- Need some info on a converter plz help
- How Do You R & R A 4L60E Transmission Filter...?
- Strange noise
- Steps to r/p the sun or reaction shell - 4l60e
- Wont shift out of first
- Trans Mount Crossmember Stud-Torque Spec?
- Will it work???
- Th400 RMVB Questions
- 4l60e/3500 stall? will it hold?
- TH400 RMVB Questions
- ordered a 3800 stall with 2.2 str feels like stock
- Please help! Need advice on 4-speed
- 2->3 and 3->4 won't shift hard
- need a good stall
- What is a good Trans Filter?
- Hitting rev limiter
- my english paper on removing a 4l60e from a fbody
- Tranny rolls forward in reverse, no mph, but revs, in neutral doesnt roll back......
- Please help, looking for street/strip 4 speed
- 4l60e...will an '05 fit a '96 blazer?
- A4 guys.....come in
- TC bolts loose..TC knocked the rear main
- ShiftKit and TC install
- Front pump seal leak..need help..
- loud banging when going into gear.
- TH350 3rd gear problems - diagnosis
- Help reading Trans Fluid Level
- help me please
- Bulletproof transmision needed
- Transmission pan leak
- $l60E problems....
- Car "hanging" on 2-3 shift
- Is this normal? / Look OK?
- A4 vibration, 3rd gear only
- Loose noises after Spohn TA and Moser Rear
- Are C5 and F-Bod converters interchangeable?
- Trans fluid suggestions
- I think my A4 is going out
- How much can the 4L60E take ?
- 74 TH350 tailshaft bushing problem maybe?
- tuning 4l60?
- Non-drag Daily Driver: Stall or Gears? A4 2.73's...
- what type of th400 u guys run
- Need Help ASAP!!!!!!!!!
- trans temp high?
- Wheel hop at track... broke rear and tranny
- HELP: Auto tranny rebuild opinion
- poll.. what stall speed n/a f14 cam only ls1
- What's your best 60' with your aftermarket torque converter & REGULAR street tires?
- Fuddle owners?
- LT1/LS1 trannys'
- Torque managment ??
- 700R lost upshift.Help??
- Got a rear end transmission question?
- Does this Fit?
- How long does it take to install a converter?
- Stock trans cooler temps.
- Another Fuddle Review!!!
- Which A3 works with M6 Drive Shaft?
- Is tuning required after upgrading converter?
- WTF did I do?
- What's the most efficient converter that will work well with regular street tires?
- tranny warranty
- Help me pick a converter
- 4l60e s10 tranny lines
- 4l60e Experts Help!
- Hurst pistol grip (Th400) M6 console fit?
- tranny rebuild price?
- what converter to go with
- Stall question
- how much for 4l60e
- Dexron VI has made it to (some) dealers...
- fuddle owners-what mph do you lock-up?
- fuddle racing converter + drag radial = 1.4 60'!!!
- a4 vs. m6
- 4L80E Converters...
- Tranny won't down shift at WOT
- Weird slipping..
- Track Resutls of My Fuddle 4000 TC
- 700R4 to 4L60E
- Ideal operating temp
- Aftermarket A4 shifter
- what will kill my tranny faster?
- 1st gear in a 2000+year?
- help... something just happened to my tranny :(
- Rock on 4l60e made 10 passes today
- stall ?
- Yank PYE3600 WONT GO ON!
- Cam and Sprayed guys with stalls look!!!!
- Need Quick Help !!!
- Need part numbers for replacement seals
- AN fittings on a trans cooler overkill?
- Ordered Fuddle Converter today
- F type trans fluid swap
- Automatic vs 6 speed Standard
- TH400 Converters...
- how do you tell if a converter is good or not? this should puzzle quite a few of you
- Why is manual shifting bad????
- 4L80E hold 1,000+ rwhp?
- do i need to worry?
- 4L60E torque converter bolt torque specs
- '94 Z28 Auto Trans Trouble
- Again With The Noises!!!
- Where to get manifold vacuum for TH350 vac modulator?
- Add Horsepower
- need help.4th gear acting weird
- besides the th350 and stall what else do i need swap in for my 4l60e
- 4T65E Help
- Overfilled trans! Easy way to drain some off?
- Somebody help....
- how much did u guys drop after tc
- HELP! how could I fry another??
- I Need Overdrive
- Trans broke. Does this sound about right?
- Is a B&M 24k GVW cooler enough for a 5000 stall converter?
- Anyone done a 4L80E in a turbo F-body?
- help!!!
- help please!
- str
- what parts do I need for a 4L80E rebuild to handle 600ft/lb of torque??
- dirty work...any tips
- torque converter
- Torque Converter
- Good idea or waste of $$
- Trans not downshifting
- Drivetrain warranty
- Life expectancy of stock trans...
- Best choice torque converter for this?
- Stall / How to launch
- HELP: What am I doing wrong (stall/gear swap related)???
- What Tranny to hold 600-1350 RWHP??
- Dyno Graph
- Rebuild/New Tranny?
- major trans issues
- Th 350, B&M rebuild tolerance problem
- 4L60E Transmission Wont Go Into Gear
- What to tune on an automatic car
- P1870 DTC Sanity Check
- P0748 Code/Sanity Check
- serious th2004r inquiry
- i want a tranny that can hold 600hp and 650+TQ
- How will I know if I lost 2nd gear?
- Ordered new Fuddle Racing Converter...
- Th400 : short tailshaft...swap it?
- New Transmission Mount Can't be Found
- what do u think of the flaxplate for 4l60e
- 2, d, od to 1, 2, d, od...HELP!!!!!
- Stock trans and transgo shift kit, need opinions on performance
- 4L60E transmission filter oring seal on my 98 Z28
- TH350 Info Needed All Help Appreciated!
- TH350 parts
- Launching An Auto
- Tranny cooler 'kits' with cooler, fan, thermostat....
- PATC Need Feedback!
- Non-LS1 Transmission Problem... Need suggestions
- 4L60E Trannies...How Much Horsepower Do They Use?
- Stupid tranny cooler lines are leaking
- What rear end gear do I have?
- ok think I F'ed up, tranny/verter install question
- aftermarket shifters
- People with Modulated 4l60e's does your car throw a code for the e/modulator?
- what tc to get?
- Problems after Prostars installed, (trans)
- NEED Auto tranny swap this week, HELP
- testing waters: paddle shift kit for 4th gen camaros
- Shift problem
- Major shifting issues after cam and tune. Please Advise.
- Big nitrous users and 3speed guys in here
- Yank SS4000 is in!!
- Converter Selection help!
- How much converter run out is acceptable?
- How much does a 4L60E weigh?
- Question about driveablity and gas mileage
- Evil Transmissions???
- slapshifter/shift kit for 2002 auto z28
- 700 plus HP and I want a 4 speed auto - what tranny to get?
- Auto Tranny
- a4 + tc + gears
- Question on slipping TCI
- Quick ??, should it feel this way
- V6 & V8 Tranny are 4L60E's?
- What tranny comes in a lt1 trans am
- Would this be an interesting product?
- Fuddle Convertor questions and my broken TCI convertor
- What trans fluid for A4?
- Is This Normal
- tranny slipping into neutral, comp. problem?
- I think my Transmission is slippin?
- check out my upgraded fuddle
- how much can my auto take
- Tranny rebuild help
- What color wires for the 2 shift solenoids
- TH400? how to hook up speedometer?
- trans cooler question
- Is my car a dog, or do I have sticky tires?
- No 3-4 Accumulator Spring in 2000 T/A
- Quick Question Help
- Th 350/400 ?
- partial tranny failure...possibly stall converter related
- H.P. Street Fuddle 3600stall / 2.2str
- how much hp can a a4 hold
- Th400 slipping at the track (question)
- 4l60e
- hard shifting ws6 -00
- Yank Torque Converters
- Is it better to lock up the converter in 3rd or 4th gear?
- TH350 vs 4L60E
- A3 in!!! one question
- Higher Stall add Stress?
- 3rd??
- Good 4L60E
- trans doesn't not shift into 4th at WOT
- trans info requested...
