View Full Version : Automatic Transmission
  1. going from t56 to t400????????
  2. What kind of power can a stock 4L80E hold?
  3. TCI Stall ??
  4. Bad Vibration at 40MPH TCI 3500
  5. Tranny Shop
  6. No Reverse?
  7. trans coolant line questions
  8. Harsh 1-2 shift under light throttle after Transgo & Servo install
  9. TCI SFI Flexplate TC Bolt Holes Too Large!?
  10. Car feels like it drops into neutral at hard throttle...
  11. 4l80e swap details please
  12. anyoen have a link for a th350 swap
  13. Trans problems?
  14. 200r4 swap
  15. Gains on torque converter
  16. how many of u guys have a th350 that is dd?
  17. Need some gurus. What do I need to do a M6 to A3 swap.
  18. Another 4L60E problem...
  19. What converter
  20. Weird metal-to-metal sound when shifting gears?
  21. Art Carr Stall?
  22. remote trans filter
  23. 2004r conversion write up
  24. Which B&M kit should I buy?
  25. Torque converter hub bushing
  26. Harsh enough?
  27. I will install B&M shift kit but?????
  28. Torque Converter Noise
  29. Am i losing the tranny or is it tuning?
  30. How Many Washers?
  31. wiring harness m6 to A4
  32. TC unlocking erratically
  33. Not shifting to 3rd at WOT
  34. Stall, Shift Kit and Cooler Install
  35. Tci 3500
  36. Stall question on the highway
  37. finally made a few passes with the transbrake and fuddle converter
  38. Truck P/N switch
  39. Question regarding flexplate...
  40. Popping Noise Under Console..Please Help
  41. What torque converter??
  42. My Fuddle Experiance
  43. Slipping In 4th
  44. Do deep transmission pans reduce ground clearance?
  45. What Size Bolts To Use with Yank PY3600E?
  46. Removing the dust covers/bellhousing covers?
  47. New Converter INSTALL TIPS so far..
  48. 4L60E wont go into any gear but park
  49. Transmission Cooler
  50. Transgo Shift Kit
  51. EPC modification
  52. new radiator or tranny cooler?
  53. Newbe converter thread.....
  54. Installed B&M Trans Cooler
  55. 700R4 shift point change question?
  56. $505 for converter, gears, and cooler install, sound right?
  57. vacuum modulation with forced induction
  58. Curious which stage to pick
  59. 2600 bucks for trany rebuild?
  60. '05 escalade with turbo
  61. Going to race my buddy in his A4.
  62. valve body
  63. Tranny's sick
  64. shift kit
  65. Replacing Torque Converter??
  66. wat to do for a 4l60e to hold power?
  67. Performance Rebuild Kit/Components?
  68. 4L60E Tow Haul through PCM?
  69. 4l60e problem
  70. Why do people discredit unlocked torque numbers?
  71. '00 4L60E into a '99
  72. Whats wrong with my trans?
  73. 93 Camaro what tranny ?
  74. tranny cooler big enough?
  75. Torque Converters???
  76. Stupid newbie question: 1-2 shift
  77. Driveline cause any other problems?
  78. Sick and tired of cooler hoses!!
  79. i need help..
  80. LT1 converter question
  81. 4l60 to th350
  82. Flexplate bolts, what TQ specs for standard bolts?
  83. Having to manually shift my A4
  84. understanding my tranny.....
  85. help with major ?'s on convertor decision
  86. shifter ???
  87. what could be wrong?
  88. how much trans fluid to do i put in.....
  89. Shift kit or not?
  90. Won't move until 3,000 rpms
  91. A4 throwing code, advice please
  92. 1/4 times in a stock A4 ls1
  93. Built 4L60e - in 3 weeks
  94. Yank ST/SP/YPE/SS, what's the difference?
  95. Transmission cooler bypass stock radiator?
  96. Converters?
  97. trans cooler (4L60E)?
  98. Trans Temp. gauge?
  99. 2wd Shaft Removal
  100. cooler line E cips
  101. transgo vacuum mod
  102. Who used VSS to make speedo work in TH400
  103. factory tanny cooler?
  104. TCI SSF3500 will not lock
  105. ???? I just put in a poly tranny mount in now i have a vibration.Help.
  106. How is Racing from a Roll compared to stock with a 3500 stall or better?
  107. trans started leaking.....
  108. Sharing my Trans Am (temporarily)
  109. TCC lock/unlock/lock/unlock - Mechanical Issue?
  110. Can some one tell me what to expect?
  111. Can someone tell me how my converter will be?
  112. 4L60E...I'm done with it
  113. Stall Converter Q..
  114. wierd trans problem, any suggestions?
  115. why is it bad to turn off TM?
  116. Tranny bolts..,
  117. tanny flush bad?
  118. re-flash with LS1 edit after M6 to A4 swap?
  119. Converters in different trans
  120. Gears OR Stall?
  121. 2nd and 3rd Gears?
  122. 2 tranny coolers y\n?
  123. Question about 3500 stall Torque Converter Drivability????
  124. M6 louder than A4?
  125. 350 turbo pic please!!!!!
  126. tranny builders..help please solenoid
  127. Rock On tranny quit handling 700rwhp
  128. what the best rebuild kit for 4l60e ?
  129. For anyone with a street driven manual valvebody trans
  130. Derale Pan w/Cooling Tubes Works
  131. Century
  132. Transmission Break In Period ?
  133. Best 60 footers with SS3600/SS4000
  134. what do you think?
  135. Shift Kit
  136. Vig 2800 & 3200 STR?
  137. OT: 4T60-E downshift problem
  138. BMR LT1 Torque Arm Crossmembers now available!
  139. Problems with 2nd gear- Please Help!!!!!
  140. Tranny Help Plz!
  141. Stock TC Bolt Removal
  142. Question for the experts: Transmission Flushes: Good or Bad?
  143. Question for H/C A4s with vacuum modulation?
  144. Yank SS 3200 vs.TCI 3500
  145. anyone done the ford AOD in Fbody swap yet?
  146. need a torque converter
  147. locking problem
  148. How much power can a 4l80e handle?
  149. Non-electrical transmissions
  150. Torque converter
  151. funny acting trans
  152. Thinking of rebuilding 700r4 my self. What tools do i need?
  153. Highest stall the computer will tolerate?
  154. Car doesn't shift smooth with AC on ?
  155. shifting an automatic
  156. Tranny and rear end gears??
  157. I want to make a new 4L60E for my car HELP ME
  158. TCI3500SSF is in! First Impressions
  159. TH400 and 4L80E mounts the same?
  160. TH350 Trans mount
  161. Transmission Cooler Mounting
  162. Cracked Flywheel
  163. Anyone ever have there Stall Converter out to be refreshed....? How much?
  164. NSBU Switch???
  165. Traction Control??
  166. No 4th gear lock up
  167. adding gears to a th400?
  168. stage 2 or 3 4l60e?
  169. Any one ever tried a Ford or Dodge VSS?
  170. Why did my Overrun clutches fry??
  171. Help tranny doing weird stuff help
  172. Yank Converter Gains
  173. Poly Mount vibrations....yes I searched...
  174. Need help fast on 60e problem after rebuild...
  175. What does it take to go th350
  176. Can I do it?
  177. Torque Converter
  178. 4l60e 94 to 95 tranny swap
  179. Whats the max HP a 2002 Z28 A4 stock tranny can safely handle?
  180. how much of a power loss with th400
  181. stall for stock cammed LT1
  182. Shift points...
  183. Th400: Trans brake questions
  184. 4L60E converter/flywheel - 4 or 6 bolts?
  185. built 4l60E & TC problem need advice
  186. How should I cool my new tranny? (Tech guys inside please)
  187. 4L60E install problems
  188. TH400 in 3rd gen, what do i need?
  189. 4l80 spacer
  190. cooler size for car without oem cooler
  191. Lets get this ball rolling.....TC1 4000 vs. Yank SS4000
  192. How does this set-up sound?
  193. help with locking converter
  194. Strange shifting on 87 GTA
  195. What stall do I have??
  196. What stall to choose?
  197. trans swap
  198. 4L60E trouble....HELP!!!!
  199. broken bolts in flywheel
  200. What would be considered inefficient on high stall converters?
  201. 4wd tranny
  202. Cost of Installing a Torque Converter
  203. Trans Temps
  204. jerking when puting into drive
  205. Why would a shift kit cause any problems?
  206. when all will a stall help me?
  207. Why the stall?
  208. Making the speedo work in a TH350.
  209. Trans go piece?
  210. Yank Converter/FLP Transmission Help
  211. $255 for TC install alot?
  212. Info. on a Transgo
  213. R/R trans
  214. How Much Stall/Convertor do I need?
  215. stall installed with pics
  216. will it hurt my transmission
  217. Transgo issue
  218. Best Tranny Cooler?
  219. what should I restall to ??? (vig)
  220. STR and Single/Multi Disk on a TC?
  221. 4L60E P1870 code and Shift Kit HELP!
  222. camaro trans in a trans am
  223. quick question help
  224. Rebuilt 4L60 price??????
  225. A B&M Ratchet killed my TH400?
  226. HPTuners: Converter log
  227. what tranny do i have?
  228. Tranny going out? Need help!
  229. Not shifting into 2nd
  230. I broke my flexplate could it have damaged anything else??
  231. whats wrong with my tranny/TC?
  232. Shifters
  233. Tranny won't shift
  234. Biggest tranny pan without clearance issues?
  235. Help with this mod!
  236. Any One In Chicago Area!!
  237. Th400 into a LS1 parts list, Please!
  238. HIGH rpm nitrous th400 stall...who?
  239. Dayco Stall??
  240. Shifting problems in a a4
  241. A4 Stock shift points
  242. Finally ran her at 7psi
  243. what convertors interchange?
  244. stock rearend question
  245. 4L60E - Who Does It Best? Who can prove it?
  246. Does the shift kit have bad influence on the Trans?
  247. Upgrading trans lines with t-400?
  248. 4l80e??????????
  249. initial impressions....Fuddle Racing 4500
  250. please help vig 3600 w/ 150 shot
