PDA
View Full Version : Automatic Transmission
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. 6.0L and 700r4 question!
  2. 4l60e to 4l80e swap
  3. 4L60E - reverse drum binding
  4. Excessive Converter to Flexplate Clearance
  5. No 3rd or 4th after "Rebuild"
  6. Junkyard turbo 5.3.. What converter?
  7. 4l80E low gear
  8. North Texas Converter
  9. TH400 Billet valve body
  10. New built strenghtened 4L60E trouble shifting into 3rd under WOT
  11. 4l60e O Ring identification?
  12. Decode this 4L60e "4cfd020"
  13. 4l80e problems after rebuild no reverse
  14. Trans go hd2 shift kit
  15. Range selector wiring for a 4l80E 03 dbw harness that had a 4l60E
  16. Shifter cable questions, picture inside
  17. 4l80e
  18. Stall too small?
  19. Mid to high powered Th400 users....hardware question
  20. 4l60e Issue after swap
  21. Vjcx converter longevity in trans am daily driver
  22. th350 hughes style adapter
  23. What is the right Performance rebuild? 4L60E
  24. M6 vs high stall A4 question.
  25. 408w/FLT5 4L60E Yank3600-Need Trans Tune Advise and on TCC & Slip good or bad why?
  26. little help with 4l65 in a c6 zo6
  27. How much power can a 4l80 survive under?
  28. *NEED HELP* flexplate to th400 needed vendors welcome..
  29. 4L75-E, any info?
  30. 4L60E Cold Slip
  31. 4L80e upgrades
  32. TH350 vs. TH400 Case/Interchangeability?
  33. Slow shift at wot 2-3
  34. 2001 z28 4l60e questions
  35. 4L80e trans question; one better than other?
  36. 4L60E will not engage (S10 5.3)
  37. Cricle d stall problem
  38. 4L60E "sometimes" shifts to 3-4?
  39. 4l65e 1-2-R only
  40. Dex 6 in th400 fti
  41. Restall to a CircleD 4C? or SS3600?
  42. 4L60E Manually shifting to 1st
  43. 4L60e Reverse Drum Clearance Question
  44. 210* trans temp with cooler
  45. E38 & T42 Compatibility
  46. Need some converter advice
  47. What did I do???? 4L60E not shifting
  48. 2nd gear lockup
  49. 4L65E computer flash
  50. Th350 guys help out
  51. 4l60
  52. What torque converter stall?
  53. 4L60E 2nd rebuild, no 3rd-4th. Full rebuld or just 3-4 pack
  54. New Member/ Help Needed with trans
  55. Costs to do an t56 to auto swap
  56. 4l80e id help
  57. What's involved in swapping over a pre 97 4l80 4wd to 2wd
  58. Fresh 4L60e Blues. Need Help Please
  59. 4L60E Shifting Issue When Warm?
  60. 4L60e No Reverse After Install
  61. How to build a cool shift diagnostic device
  62. 4L60e Reaction Planetary Differences?
  63. 4l85e - 07 for fbody
  64. Circle D vs Revmax Converter
  65. 6l80i issues before/after rebuild!!!
  66. Aftermarket trans cooler with all 8 An hoses and fittings. Bad idea??
  67. Trans cooler hose question
  68. 4l60e vs 4l80e
  69. TH400 failed...
  70. Reviews on Boss Hog Converters
  71. M6 to auto swap guys chime in please
  72. Trans question
  73. Shift Lights
  74. 4l80e swap 2nd gear start issues
  75. patc 6 pinion planetary
  76. What converter would fit me best
  77. 4L70E Stator Support Shaft removal from Pump Housing?
  78. Sonnax smart tech drum loaded
  79. 09 4l60E internal interchangeably
  80. Need some help please
  81. 2002 f-body 4l80e swap and NO VIBRATIONS
  82. after rebuild + tc
  83. New SFI flexplate and looks like it's got alittle wobble.
  84. 4L60E Automatic Transmission to NP2 Manual Transfer Case Connection
  85. Will a Corvette C5 Differential Fit a 700R4
  86. Easiest way to wire up a transbrake button
  87. m6 to turbo 350/400
  88. Th400 rebuild reverse issues
  89. 4L60E converter question
  90. ISO Complete TH400 kit for F-body
  91. McLeod Racing Automatic Performance Transmission Rebuild Kits
  92. Shifting from Park to Drive Issues on 4L60E
  93. 700R4 TV Cable Hook Up
  94. 4l80e stalls when in gear like converter locked
  95. 6L80E into 2001 Yukon?
  96. Speedo
  97. Stall for 4l60
  98. No reverse in 4l80E
  99. Live level 3 assembly at PerformaBuilt for Chevy High Performance
  100. Transmission trouble
  101. T42 / 4L80E limp mode - how to troublshoot?
  102. can't feel stall converter
  103. Flexplate to crank bolts backed out is it garbage?
  104. BUDGET build question
  105. 4l80e rebuild
  106. Suspect Failing Torque Converter
  107. New 4L70E went soft
  108. Th400 1st gear only works when trans brake engaged
  109. New to 4l80 Temp Question
  110. 2000 Camaro Z28 Tranmission Questions
  111. Unusual 4L60E Swap Project
  112. 245mm vs 258mm Triple Disk Converter
  113. Th400 is complete....ran through gears today.
  114. 1998 Auto concerns
  115. HELP 4l60e trouble
  116. 4L60E Rebuild after 3-4 Clutch Failure, still failing
  117. First time rebuilding a 4L60E, worth the risk?
  118. reuse this input drum?
  119. 4l60 problem
  120. I messed up and over filled my 4L60e.
  121. 4l60e torque converter won't unlock
  122. 4l60e question
  123. Trans temp gauge
  124. 4L60E no reverse
  125. Vortec PNP Switch Wiring With No BCM
  126. Shifting A4 manually? RPM Level V questions
  127. Advice on m6-a4 swap
  128. Converter won't build rpm at the line like it used to. O-ring? Converter going bad?
  129. 4l80e internal harness
  130. Dana Probuilt
  131. Stall converters
  132. TCI StreetFighter Torque Converters 242931
  133. 4l80e power ?s
  134. Th350 end of truck cutoff
  135. 80e rebuilders, do you want or need this stuff...
  136. 4l60e slip yoke barrel diameter
  137. Best Flexplate
  138. 4l60e falling in amd out of 3rd gear
  139. 4l60e pump torrington?
  140. lockup problem
  141. 200 4R with out lock up converter gurus come in
  142. What should I do? 4l80e swap wires 60e or 80e segment
  143. 4l80e Fixed Yoke
  144. building a 4l60e or get new tranny?????? HELP
  145. M6 to Th400 swap (already checked sticky)
  146. Th400 factory deep pan depth
  147. Live assembly of black edition
  148. weight stock torque converter ?
  149. Performabuilt black edition specs
  150. Help me diagnose my 4L60E overheating issue
  151. Need help powerglide to LS?????
  152. im about to fix code p1870 1-2 hard shifts . I need some advice!
  153. Converter hits flexplate bolts
  154. At last....
  155. 4L60E question from a first timer
  156. Purchasers of FTI 3200 street brawler enter.
  157. threadlock
  158. Which Trans. 4 '50 Truck
  159. Swap Trans issues
  160. TCI Converter Tightness
  161. Question about Circle-D higher stall and towing.
  162. poly torque arm bushing
  163. 98 A4 4l60e no 4th or tcc lockup
  164. Mad man dipstick
  165. lockup and racing?
  166. Bought 3200ls FTI stall for a bolt on car, what should I expect?
  167. Doing a live assembly of corvette 4l60e
  168. Has anyone swapped a yank for an FTI?
  169. 2000 4l60 Luggs in lockup.
  170. installing yank ss4000 what would you replace while trans is apart?
  171. Help me pick a converter for my cammed 94 LT1!
  172. Ordered a LS 4L80E Trans what would you expect to get?
  173. dipstick bolt
  174. Th350 bop adapter
  175. Tci Th400 transbrake help
  176. Link inside, will this stall fit my 2000 SS?
  177. 4l60e
  178. 4l80e leak front seal?
  179. 4L60e Won't Stay in OD or Downshift from 3rd While Moving
  180. Parts for rebuilding a 4l60E
  181. th400 swap questions
  182. Who to spec a converter
  183. Converter identification help
  184. 4L60E Boost Valve replacing on 2007 GMC
  185. 1998 Camaro SS Transmission Issue: Help!
  186. convertor stall?
  187. Th400 snap rings
  188. 4L80 shift issue
  189. What would have caused this?
  190. v6 converter with 4l70e trans
  191. 1998 firebird slow to shift
  192. GMPP TPS and VSS signals from ECM Bulkhead connector
  193. Stall help!
  194. F250 trans cooler in Fbody
  195. 4l60e 4th gear problem
  196. No 1st gear from a dig
  197. TH400 lost reverse but backs up when engaging transbrake in neutral.
  198. Help 4L60E issues. 3-4 gears
  199. High performance atf
  200. 4l65E - have an overflow?
  201. 4l60e question
  202. T56 to TH400 swap help!
  203. 2003 ext cab 1500 4l80e swap HELP
  204. 6L80E into a 4th gen swaps
  205. 4L60E "Shift Kit" Advice Needed
  206. 4L80E fluid leak
  207. 4l60e to a 4l80e swap in a Silverado?
  208. fbody th 400 ford8.8 driveshaft question
  209. best rebuild kit for 4l60e 550hp
  210. Help!
  211. 4l80e shift kit
  212. 4L60E fluid out the top vent!
  213. Silly question but I have to ask
  214. 4l80 dipstick
  215. Built transmissions
  216. 2016 Camaro 8L90E Converter install
  217. 94 4l60 to 5.3 help
  218. Point me to the correct rebuild kit
  219. 4l80e silenoid problem
  220. 2 step turbo question
  221. 4l60e stock possible issues
  222. Trying to ID Torque Converter
  223. Absolutely Stump'd
  224. New guy, 1st post, 4l80e, pics
  225. Hughes Adapter with TH350 issues
  226. 4L60E Help
  227. Trans Cooler options. JEGS 60345 or B&M 70274
  228. 4l80E late MLP with early harness?
  229. Converter rated by HP not Stall
  230. 98 Trans Am/Firebird A4 Not Downshifting?
  231. 4L-Sh!t
  232. 4L60e weirdness
  233. For those doing their first transmission...don't do this.
  234. Is the Park Prawl controlled hydraulically or mechanically
  235. Th400 direct drum Transbrake Springs = bent retainer??
  236. Is this a 2-3 shift valve?
  237. Th400
  238. 2000 4l60 no lockup in 3rd?
  239. 4l80e swap help
  240. Rebuilt 4L80E 2nd and R only. Think it's the vehicle wiring
  241. Transbrake w/ stock ecm
  242. Th400 and trans shield questions on 4th gen
  243. Th400 forward drum inner seal
  244. Reman 4L60E Leaking
  245. Safe fluid level for 4L80E dry start up
  246. Convert 4wd 4l65e into 2wd for swap
  247. 4L70E: adding stall and corvette servo. Need anything else?
  248. 4l60 Solenoid Kit Master
  249. 4L60E no part throttle power - sluggish
  250. Need help with 4l60E 2002 LT1 4.3, to 2002 LS1 4.3
