View Full Version : Generation IV External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17
  1. Torquing balancer bolt on an auto trans car
  2. Looking for LQ9 Heads Flow Numbers
  3. LS2 oil pan on an LS1?
  4. Bolt ons to get the most power out of LS2s
  5. how big of a bore on LSX block
  6. How much is my LS6 intake gonna limit me?
  7. Ls7 Manifold Height??
  8. C6 Gear Change??`
  9. LSX 6 bolt head
  10. Lsx 454
  11. Abear's Winged Fuel Rails
  12. Anyone running a Beck SM on a C5?
  13. LS3 swap. Need advice
  14. what heads and intake for ls3 418 stroker
  15. help please! will l92 heads work with lq4 block
  16. 427 gto buildup questions
  17. how do you tell the differance ls1 and ls2?
  18. L92/LS1 fuel rail differences?
  19. ls1 to LS2 knock sensor conversions?
  20. C6 LS3 and Z06 LS7 question for a friend
  21. Alternator for L92??
  22. Upgraded L92 rockers
  23. opinions on winter mods
  24. spacer intake
  25. LS2 engine run with on oil
  26. new motor running hot?
  27. ummm little help
  28. Where to get a 95mm drive by wire TB???
  29. Safe to run stock headers + y pipe cut off at i pipe?
  30. LS3 Corvette coupe MN6, stock, what now?
  31. Nipples! Hooking Up the LS7
  32. Intake Manifold Choice
  33. pacesetter LTs?
  34. how to check ls2 coil?
  35. some noob questions
  36. Problem with a Meziere Electric WP on a LS2 GTO
  37. Problems finding parts
  38. Can the blower style intake be used on a LS-3 motor
  39. anyone using a breather oil cap?
  40. Where can I get ARH for 08 G8???
  41. Obtainable power goal???
  42. ls1 timing chain in ls7 block.
  43. What cam to install in ls7 build
  44. distributor questions
  45. Carb style throttle body
  46. Which heads and intake for an LS7 440
  47. Quick question:
  48. TSP 00 F-body headers and LS2
  49. C6 Kooks installed with a few pics
  50. lsx in a third gen
  51. Sponsors HELP! Need fuel rail kit!
  52. Need a LS3 MAP sensor part number
  53. LS3 Sparkplug Gaping?
  54. will 1 7/8 headers from an f body fit a l92 stroker silverado?
  55. Trickflow Heads: Questions
  56. UPS delivers my C6 1 7/8 Kooks!
  57. Thoughts on Super Vic on 416CI L92 v. FAST 90
  58. 243 heads on a 6 liter whats the the chamber CC stock
  59. Trickflow 225 heads and only come with .600 lift springs WTF
  60. LS7 Oil Lines too long
  61. Compression?? L-92 heads
  62. 6.0 truck engine
  63. Just to make sure...
  64. ls1 to ls7 conversion package
  65. ARH 1 7/8" on a 408 with
  66. ~TSP~ Nice!
  67. TBSS LS2 Question.
  68. WTB Holley 90mm LS2 TB
  69. Replacing the LY2's controller with the LMF Unit = Flex fuel LY2 ?
  70. Bolting LS6 manifold back on after race headers???
  71. which harmonic balancer for Ls3 w camaro pulleys
  72. LS7 intake vs LS3 intake
  73. LS3 or L92....how do I tell?
  74. Where to tap LS2 water pump for gauge?
  75. Ls2 and 1998 Z28?
  76. LS1 PCV system to a LS3/7 style....how to route it?????
  77. What gains have you seen porting LS7 intake?
  78. L92 Shortblock to race ???????????
  79. HP limit of the stock L76 fuel rails?
  80. Stock LS3 shopping list
  81. ls3 intakes on ebay
  82. people with L76 intake.....vaccum line?
  83. no cats and header install on Z06, now hellacious backfire
  84. LS7 oil
  85. 4in mufflers
  86. Dry stump oil pump?
  87. patriot heads 2033
  88. Gmpp ????
  89. Pics of my new accu fab TB
  90. 454 LSX cooling
  91. so i got a exhaust prob need opinons
  92. What size headers to get?
  93. where to put knock sensors?
  94. Budget build Lq9 block, L76 Intake and L92 heads
  95. Z069 Vette Build...Fuel Regulator question..
  96. light weight vibration balancer?
  97. AEM Pencil coil on LS engines
  98. Exaust
  99. mass air question....85mm?
  100. what would make the car run better w/o a hood ? then with it ?
  101. TSP 1 7/8 header fit perfect on G body car
  102. For everyone running a stock water pump.
  103. Help Problems with 402cid Cam positioning sensor "CPS" harness , not reading RPMS !!
  104. ZR1 intake manifold on LS7?
  105. LS1 Oil pan on LS3? All pans the same?
  106. Good exhaust for power & not too loud?
  107. No oil pressure on 408 first start
  108. WTB C6 Z06 Oil Cooler
  109. 2008 Corvette LS3, Manual Trans - NEEDED - easy $500 for you
  110. Kooks Revised F-body Header
  111. LS2 Crankshaft, Flywheel Dowel, do I need one opinions?
  112. What TB for LS7 Manifold
  113. could i use my fast90 w/ l92 heads?
  114. LS2 2 piece timing cover needed
  115. Timing question?
  116. LSX Block running hot
  117. update on 454 problems!!!
  118. XS Headers
  119. What spark PLugs to use on a 402cid
  120. look at this intake
  121. With true duals, how much does the location of the X pipe matter?
  122. head plate?
  123. exhaust debate.. im having trouble whic route to go
  124. Buddy is looking for l76 intake w/ all the stuff that comes with. Where to buy?
  125. Livernois stage 2 on LS 2 help?
  126. LS2 intake...injectors slanted into the heads???
  127. LS2 Ported Intake Manifold
  128. 98 ported tb???
  129. TB idle air Hole size?
  130. Exhaust twin 2.5" or 3" ??
  131. Crankshaft/ Flywheel stud
  132. What do I need for LS7 injectors on FAST 92mm Intake?
  133. PS cooler and remote reservoir installed
  134. LS&/LSX "tall" decks......
  135. LS7 bore size......
  136. LS7 stroker clearance.....
  137. What MAF to use with 402cid and what Spark plugs ?
  138. performance difference between holley 90 and fast 92 t/b for my 427.
  139. '05 SSR LS2 accessories
  140. Stock displacement LS2 with TFS 225
  141. what kind of power to the Flywheel v/s Rear wheels
  142. cylinder head coolant cross over
  143. New billet belt tensioner color available
  144. LSX help
  145. LS2 TB onto the 408 and now problems, help?
  146. June Intake and TB Porting Special
  147. Just talked to Weiand about there NEW INTAKE
  148. Which heads/intake on a TBSS
  149. Going to a LSX Block
  150. excessive oil consumption LS3 427 stroker??
  151. no start 408, crank position sensor help
  152. L92 Heads w/LT headers (Gaskets????)
  153. will my nasty performance fuel rails from a ls1 fit a ls3 intake manifold
  154. Vic Jr and hood clearance?
  155. Fast for L92 heads
  156. 408/ Ported L92...Beck or single plane?
  157. 380hp Denali L92 vs 403hp Escalade L92
  158. Hey Weiand/starr I Think Its Time We Heard Something?
  159. Exhaust question... how restrictive are the stock 2.5 inch pipes?
  160. loudmouth or corsa
  161. fast 33lb 58psi injectors should be ok for a 402cid
  162. Fel Pro Part # L92
  163. Stock MAF/Throttle Body sizes on the different ls2, ls3, and ls7?
  164. What headers and y pipe or x pipe true duel kit for LS2 402cid ?
  165. Running 402cid TSP engine with PATRIOT stg 3 heads what injectors for LS2 intake ?
  166. will part # FELMS92438 flepro intake manifold gaskets work for LS2 intake
  167. Need Help Underdrive pulley
  168. Exhaust cutout on big motor
  169. Need help..LS2 injectors
  170. best 4 barrel TB for GMPP L92 intake
  171. Question about L76 (G8 GT) exhaust manifolds
  172. Holley 90mm Throttle body, need a quick measurement
  173. LS7 Wiring Harness/Doubts
  174. 408 + Borlamouth
  175. Aftermarket oil pressure gauge hook up?
  176. where do you put O2 bung for LM1 ?
  177. LS2 with LS6 parts - many engine codes
  178. Have you ever wondered how GM's LS2 V8 fits together?
  179. would a L92 VVT w/6 spd work with a CTS-V tune
  180. L92 info
  181. bought an ls2 water pump w/ no t-stat housing.. what do i do?
  182. **Video** GOAT Run
  183. GMPP L92 intake manifold
  184. Stock 90mm cfm??
  185. What headers for a 402 Stroker ls2? (in an Camaro)
  186. ARP head stud kit for ls2 with l92 heads?
  187. Ported fast 90/90 swap...*Results*
  188. Relocated coils - spark plug wires and MAF question
  189. LS7 headers
  190. rear main seal install
  191. What heads for my cam?
  192. corsa on a 408
  193. will a LS1 Camaro AC compressor work with my LS2 corvette engine
  194. What is the chamber size of the stock heads on Vortec 6.0 Engines?
  195. LS2 head gasket
  196. L92 basic questions
  197. Will stock ls1 exhaust manifolds work on ls2??
  198. Used LS7: what should I go through
  199. In a bind, need some LS2 Info
  200. Stock L92 shortblock?
  201. Installing "Race headers" NEED help!
  202. another 408 l92 setup is alive!
  203. coolant pressure limits on LS3 combo
  204. Advise on springs for Gt 1-1 cam
  205. Custom plug wires assembly help
  206. what intake on LS7 Heads
  207. OK, don't laugh, I'm just wanting to be *sure* before I spend some $...
  208. Building a 440
  209. tried to start the 408 today
  210. Introducing The All New 1 7/8" TSP Long Tubes!!
  211. Does anyone know if the LS7 carb intake ports will match up to a C5R head
  212. bluemaxx 90 mm or Fast 92mm throttlebody
  213. Anyone used one of these intakes?
  214. orings for l76 intake
  215. Someone has to know what exact size the L92 injectors are from the Caddys?
  216. Intakes Stock ported ls2 90mm or BBK 85mm
  217. Exhaust sizing for l92 strokers?
  218. LS3 Starter???
  219. FAST 92mm Opened up to 100mm by Vengeance Racing
  220. L76/92 stroker guys
  221. ls2 swapped z28 with coolant temp being sparatic at times.
  222. Stock LS3 Dyno sheet..
  223. L76 on L92..need advice
  224. L92 swap into Fbody, Pops when trying to start and no throttle response
  225. sounds clips of stroker set ups
  226. valve cover ?, pcv ? and more
  227. bought some l92 headgaskets
  228. "Check guages" everythings going nuts
  229. DMH Low Profile Cutouts added with Z06 Ti Exhaust
  230. L76 intake fueling questions
  231. 90mm GM cable driven throttle body?
  232. FAST 92mm L92/LS3 Intake: When? Who would buy one?
  233. Ls2 carb and front Distributor
  234. Any TBSS owners?
  235. lq9 72 corvette?
  236. L92 Short block?
  237. anyone try the gm singleplane intake on the L92's?
  238. WHat kind of intake with LS2 364 cid engine with patrito stg 3 heads and 600 lift cam
  239. Should I upgrade my headers?
  240. L92 accesory drive???
  241. LS3 Hollow Stem Intake Valve PN?
  242. Forged LS3 already built with L92 Heads. What heads/intake can I change to?
  243. Cam PTV clearance
  244. Aftermarket intakes for L92's??
  245. New 46lb/hr Pico Injectors for LS7, L92, L76, LS4
  246. What Heads To Buy???
  247. 06 Lq4 Engine Really Important ?
  248. L76/LS2/3/7 intake porting
  249. question on 243 heads
  250. who else ports the L76 besides LS2portworks?
