View Full Version : Generation IV External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17
  1. what intake on LS7 Heads
  2. OK, don't laugh, I'm just wanting to be *sure* before I spend some $...
  3. Building a 440
  4. tried to start the 408 today
  5. Introducing The All New 1 7/8" TSP Long Tubes!!
  6. Does anyone know if the LS7 carb intake ports will match up to a C5R head
  7. bluemaxx 90 mm or Fast 92mm throttlebody
  8. Anyone used one of these intakes?
  9. orings for l76 intake
  10. Someone has to know what exact size the L92 injectors are from the Caddys?
  11. Intakes Stock ported ls2 90mm or BBK 85mm
  12. Exhaust sizing for l92 strokers?
  13. LS3 Starter???
  14. FAST 92mm Opened up to 100mm by Vengeance Racing
  15. L76/92 stroker guys
  16. ls2 swapped z28 with coolant temp being sparatic at times.
  17. Stock LS3 Dyno sheet..
  18. L76 on L92..need advice
  19. L92 swap into Fbody, Pops when trying to start and no throttle response
  20. sounds clips of stroker set ups
  21. valve cover ?, pcv ? and more
  22. bought some l92 headgaskets
  23. "Check guages" everythings going nuts
  24. DMH Low Profile Cutouts added with Z06 Ti Exhaust
  25. L76 intake fueling questions
  26. 90mm GM cable driven throttle body?
  27. FAST 92mm L92/LS3 Intake: When? Who would buy one?
  28. Ls2 carb and front Distributor
  29. Any TBSS owners?
  30. lq9 72 corvette?
  31. L92 Short block?
  32. anyone try the gm singleplane intake on the L92's?
  33. WHat kind of intake with LS2 364 cid engine with patrito stg 3 heads and 600 lift cam
  34. Should I upgrade my headers?
  35. L92 accesory drive???
  36. LS3 Hollow Stem Intake Valve PN?
  37. Forged LS3 already built with L92 Heads. What heads/intake can I change to?
  38. Cam PTV clearance
  39. Aftermarket intakes for L92's??
  40. New 46lb/hr Pico Injectors for LS7, L92, L76, LS4
  41. What Heads To Buy???
  42. 06 Lq4 Engine Really Important ?
  43. L76/LS2/3/7 intake porting
  44. question on 243 heads
  45. who else ports the L76 besides LS2portworks?
  46. cost of 427 block
  47. looking for dyno results and rockers
  48. L92 car intake
  49. anyone know where to get this????
  50. ls7 engine onto 2002 t56
  51. does anyone know if..
  52. Advise on heads.
  53. can u port ls2 rails????
  54. ssr tb porting
  55. Z06 LS7 engine install pics
  56. Best motor mounts for a l92
  57. TBSS throttle body compatability??
  58. ls6 coolant lines
  59. GTO power steering pump
  60. LS1 to LS2 conversion, not a success! coolant leak.
  61. LS1 to LS2 conversion; finally SUCCESS!
  62. L76 Able To Make Power Till 6700rpm?!?!
  63. water pump for ls3
  64. Ls2 Cold Air Lid
  65. Quieted down my exhaust today
  66. Loudmouth Question on an LS3 Vette...
  67. "TSP 100mm Maf" Anyone have the MAF tables for the sensor?
  68. ls3/l92 ??s
  69. Power Steering Pump ?'s
  70. Is anyone installing a Crank Pulley on C6 LS2?
  71. Next batch is in!
  72. need help with 05 C6!
  73. LS2 C6 Oil Pan Question
  74. need to know some thing
  75. ls1 to ls2 swap.vac port.
  76. any more results on ported L76 intakes?
  77. Need pics of newer style water pump ASAP
  78. Vacuum pump installed!!!
  79. Fast 90 installed on LS2 *pics*
  80. Quad exhaust on GTO (photoshop)
  81. New LS7 intake arrived Pics
  82. Where Are These Billet Fuel Rails?
  83. Need a part number...
  84. Need to find
  85. Harness
  86. ETP Heads and LS2 issues
  87. 416 L92 engine swap ?s
  88. ET ls7 heads on 402 will it kill low end power and mid
  89. LS2 will crank but not start
  90. .631"/.644" PTV issues?
  91. Cylinder head suggestions(LS2 SUV)
  92. Cold Air
  93. Home porting LS2 Intake
  94. Looking for CFM of fast 92 and ls7 intake/hp cars there on
  95. GMPP l92 carb style intake
  96. Looking for ideas for my new engine thinking 402 ls2
  97. l76 intake repairable?
  98. Any one have their PCV sys w/just hoses hanging down?
  99. LS7 balancer same as LS1?
  100. Needing a better radiator..
  101. Powder coated RevX Catch cans!!!!!
  102. Where can I find a good deal on a LS2 oil pan kit?
  103. What fuel rails for LS7 carb intake?
  104. FAST 90mm Intakes - DISCONTINUED
  105. TSP 100mm MAF !
  106. new LS376/480 ls3 Im new to this and need to know what to get
  107. ls6 intake on ls2 engine
  108. best cam for ls2
  109. 2006 GTO ls2 pinouts
  110. Which cam?
  111. Harmonic balancer question, help please.
  112. who can port 241 heads? cheaper?
  113. FAST 92mm Intake/Throttlebody Pictures inside
  114. Which Valve covers
  115. Will I lose much HP
  116. Would I benefit from a.......
  117. LS2 GTO Oil pan.???
  118. 2000 ta ls3 build?
  119. What size Carb?
  120. spun rod bearing, time for L92 408.
  121. cam position sensor
  122. Cats or X-Pipe.. Alot of HPDE use.
  123. 454 lsx
  124. LS7X flow numbers
  125. LS7 exhaust manifold part number?
  126. Pully ratios
  127. LS7 Spark Plug Wires, Suggestions?
  128. WHAT BOLT ONS and cam FOR LS3 A6
  129. Difference between L92 engine and Ls3 engine
  130. Ideal 402 stroker Heads
  131. '88 Camaro runnin a LS2
  132. Aftermarket LS7 Throttle Body Available?
  133. looking for new intake and heads need help picking ls7 headand intake maybe
  134. L92 throttle either DBW or cable
  135. Anyone with 4" catback/ mufflex/spintech?
  136. best cam for l92 heads?
  137. What head gaskets to use!
  138. Dart 225s on 408 and Vic Jr
  139. ls3 in silverado
  140. L92 head question.
  141. LS2/GTO steering pump output size
  142. Looking at LSX
  143. Head options for max power TBSS Build
  144. L92 cam sensor
  145. L92 knock sensors
  146. Need Help Choosing Good Cylinder Heads
  147. New FAST Intake for LS7 or L92 Heads
  148. Billet High Fow Fuel Rails
  149. Installing roller rockers?
  150. LS2 starter bolts
  151. manifold for a 454ci
  152. Replacing ls1 w/ls2
  153. Which will be cheaper and easier? (LT1 to LS2)
  154. Will LS7 exhasut manifiold gaskets work with C5R heads?
  155. 402 w/ factory catback/airlid=how much to be gained?
  156. Carbed LS376/520hp costs more than LS3?
  157. Best plugs for my 402?
  158. Valve cover question
  159. ATI damper question.
  160. Openions on exaust for my 402!
  161. LS7 intake bolts question
  162. 1 quart baffeled catch cans, $49.95!!
  163. Texas Speed 100mm MAF: Pre-Order Now!!!
  164. Why wide space durations splits?
  165. WB O2 Bung Install Price?
  166. GMPP LSX 454 Crate motor?
  167. zr1 is back!
  168. Will LS7 exhaust mani/h-pipe/catback work on LS3 (08 Corvette)
  169. GMPP carb intake Map & power brake booster
  170. 08 Sierra Denali - any mods?
  171. MAF wont fit inside my volant
  172. LS2 fuel rail on a L76 intake--will it work
  173. injectors and rails for L92 carb intake ?
  174. Cam install.
  175. L92/L76 and cam questions
  176. Borla catback makes banging noise.
  177. 416" L92...GMPP Carb intake or FAST L92??
  178. GM Performance LS Engine Control Harness Video
  179. L92 carb/efi intake, what fuel rails??
  180. Pics of my GMPP l92 intake setup
  181. L92 truck Intake--Fuel Rail P/N Needed
  182. l76 fuel rail no regulator what now???
  183. fly by wire throttle body
  184. 90,95,&100mm Billet throttle bodies.
  185. How much rwhp are you ls7 NA guys making these days
  186. 418 motor
  187. '08 LS3 Belt Tensioner Pulley - High Lip?
  188. How Much Can You Bore An Aluminum 6.0
  189. What to do with LS2 valley plate tube?
  190. Help fast intake doesnt fit my c6!!!
  191. cats vs offroad Y-pipe
  192. Exhaust port, mounting and angle difference between LS1/LS2 and LS7 Heads
  193. Hooker LT's and LS6 Intake
  194. Cam for 6.2l Denali
  195. Lifting L92 Heads
  196. ZO6 engine!
  197. 440ci
  198. stage 2.5 ls6 heads on stock ls2 intake?
  199. LS6 Ports
  200. Abear Motorsports now offering Award Winning rocker covers!
  201. Can someone confirm me that those are ls2 coils please
  202. Has anyone flowed their L92's?
  203. I got a problem with Knock sensors in my LS2 conversion
  204. l76 intake on f body question
  205. Can I used LS1 heads on an L92?
  206. Heads for a forged 6.0L FI build...ET 245, CNC L92, TFS 235???
  207. LS7 coil pack question???
  208. What plugs for my Z06
  209. headers for 402 with a big shot
  210. LS6 Heads on LS3/L92 Block
  211. price of trickflow ls2 heads bare?
  212. L92/L76 Parts listing needed
  213. L92 Heads or AFR 205, 215's
  214. How much would I gan from L92 Heads
  215. LS2 alternator relocation bracket?
  216. L76 manifold on LQ4 how to?
  217. ls7 valvesprings fit ls1's?
  218. good setup? and suggest trans. super gas rx7
  219. Accusump without shut off valve
  220. ls2 v ls1/ls6 valley cover?
  221. LS7 exhaust system on an LS2 = 30 hp
  222. kooks lsx shootout at atco
  223. Rotating the throttle body, LS7
  224. Which TB......454ci, ETP LS7 heads, carb style GM intake, 90* elbow.....
  225. Big Cubes = American Racing Headers!
  226. cant decide...ported 243's or L92's
  227. T56 Differences; ls2/ls1
  228. Merry Christmas and a Happy Holiday Season
  229. How to ID engine date?
  230. GM says LS7 heads require a minimum 4.100 bore, anyone tried them on a 4.080 bore?
  231. ??s about a LS7 install
  232. Ford style TB cable????
  233. What makes a gen IV engine not a gen III?
  234. Will A Holley 90 Mm Throttle Body Work With An Ls6 Intake
  235. LSX block weight
  236. LS7 intake vs carb style.which flows better?
  237. are LS7 valve covers different?
  238. Quick question on LQ4 powa.
  239. 408, L92 heads, what intake?
  240. Lq4
  241. MAF/Aftermarket Sensor Swaps
  242. Anyone else have to cut dipstick tube??
  243. ls1 to ls2
  244. LM1 / 408 .. anyone?
  245. TSP 100mm Prototype MAF Results!!
  246. 6.0L heads
  247. thoughts on new setup. i need your help!
  248. Modifying C6 Z06
  249. LSX 454 question
  250. LS7 Intake Manifold Options
