View Full Version : Generation IV External Engine
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17
  1. oil dip stick ???
  2. Best Price & Place to buy Adaptors & Ext. Harness for LS3 into 2001 F-Body -Need ASAP
  3. 416 build, head and intake ?
  4. LS6 Cam Vs. the LS3 Cam
  5. has anybody bought from this ebayer - ls7 ebay heads
  6. What couplings are you guys with 102's?
  7. Which 102mm TB to go with?
  8. L92 heads on LQ9
  9. LS1 Heads vs LS3
  10. T/A to firebird exhaust
  11. Is it worth adding cutouts if u run true duals?
  12. l92 #823 ?
  13. ls1 map on a ls3 intake
  14. Quick FAST 102 install Q???
  15. LS2 fuel rail covers on LY6
  16. Part# for the throttle cable for a accufab 4150
  17. Throttle Cable Adjustment
  18. LS2 GTO and vette block diff. Will it still work?
  19. FLT or Tick ?
  20. LS3 intake on L92 heads?
  21. After market mini alternator
  22. Coolant Air Bleed System LS3 Heads
  23. LS3 Engine covers?
  24. ls3 intake bolts
  25. How much louder with a cutout?
  26. ex valve ptv clearance LS3
  27. New GM LSX LS7 Heads
  28. balancer seating
  29. Flexplate Question
  30. Need Help with Crank Sensor
  31. V8 LS2 350z!... critique my build!- my 500+hp NA goal
  32. laser cut exhaust flange for carys killer heads
  33. OK, ready to get hammered for even asking the ?, but can you reuse intake/tb gaskets?
  34. accessory drive help?
  35. LS7 INJECTOR o Rings....
  36. help with ls3 stock shortblock prices
  37. Oil pressure
  38. Throttle body porting--who's done it, and what HP gain did you see?
  39. pcv ques....
  40. Vic Jr Intake Installs, Pics, Results, Pro's, Cons, On L92/LS3 Heads.
  41. LS6 intake compatable?
  42. Fuel system for N/A 408
  43. Oil Pan Baffles?
  44. Sheetmetal intakes - runners extending into plenum?
  45. L92 street engine,66 chevyII
  46. Coolant seeping from water pump bolts
  47. LS7 427 header size?
  48. L92 Head Porting
  49. Help With Header Selection
  50. 04 GTO power steering pulley help.
  51. Gen IV 5.3 Cable throttle conversion?
  52. Ls2 sensor issue... cam sensor harness wont mate with engine harness
  53. what head bolts do i use? 6L w/ ls3 heads
  54. Is There difference in power level (480 ~ 500 RWHP) between 2.5" & 3" catback....
  55. (quick response please)tb 95mm vs 92mm cable 4bolt
  56. Intake question for L92 into a 98 Camaro
  57. 427 Build Questions
  58. Stepped headers or just 1 7/8ths?????
  59. 32v ls heads?!?!
  60. Newb question here!
  61. What Power Steering Hoses or Hose ends
  62. Need help--Plz post pics of junkyard engine crank/rod condition when pan off
  63. Anyone see an improvement?
  64. Horsepower Gained Mods??
  65. which heads to use on my 427
  66. Quick Advice Please!!!! LH8 oil pan
  67. why wont my ls2 cam sensor harness plug into my ls2 gto harness?
  68. edelbrock throttle body
  69. Thinking about sell my LY6 intake
  70. Edelbrock Pro Flo intake for L92 heads?
  71. Auto meter adapters for oil pressure
  72. Auto meter adapters
  73. Water pump spacing using motor plates
  74. 2.5" or 3" exhaust?
  75. Differences in Wiring Harnesses
  76. im swapin my ls1 top end to a ls3 top end, few questions
  77. what arp head bolt kit for 6.0l and l92 heads
  78. intake opinion
  79. fuel rail covers for l92
  80. which water pump?
  81. Talk to me about LS heads
  82. l92/ls3 heads wanted.
  83. Kenne Bell BAP 20amp where to ref 12v with Racetronix rewire
  84. Ls6 intake or headers first
  85. L92 Pullout question
  86. I need Sensors for new engine
  87. Ls2 90mm throttle body question
  88. ls2 swap injector question
  89. LS3 and LS7 Head question
  90. 100mm MAFs, whats the scoop?
  91. LS2 Cylinder Head Plate template?
  92. please delete
  93. Help identify TB
  94. l92/ls3 head differences..
  95. oil pump pick up tube mounting ring??
  96. pro comp ls heads
  97. Does anyone know the stock injector size?
  98. Opinions please way in: Thinking outside the box (Super Vic & Accufab 4150)
  99. Tall Deck LSX in 98-02 F-body
  100. Full Exhaust for 99 camaro with ????????
  101. LS3 block /casting codes
  102. Headers Trailblazer SS
  103. cnc'd l92/ls3's
  104. LS2 swap questions
  105. FAST LSX-R 102mm Gains Or Loses Results
  106. 4.8 to 6.2 swap help asap
  107. Converting Cable Tbody to Fly-By???
  108. TSP 1 7/8's Header Ground Clearance on Lowered Car
  109. Best Cathedral Port Intake setup discussion
  110. Professional Products damper
  111. headers or pipe?
  112. ~LS6 Valley cover PCV system adequate for 427?
  113. Fuel Regulator
  114. These are kinda cool
  115. Ls3 stroker starts but does not stay running
  116. TSP 100mm MAF wire harness
  117. lq9 in 84 c10 mounts and headers
  118. New to the board - Quick cam question
  119. Wilson 471105 Throttle Body Question
  120. new exhaust took my torque
  121. Obx headers
  122. mounts and headers for an 84 c10
  123. Car not starting
  124. Any word on these LS7 heads?
  125. Has Edelbrock discontinue the Victor series drag race headers?
  126. Are Dynatech LT Headers any good?
  127. Best Heads for ls3 427 for around 2500.
  128. LS6 intake upgrade
  129. LSX 376 Knock Sensor
  130. New dynamax vt muffler
  131. Will my L92 WCCH Stg2 be enuff head for....
  132. Got my new GM LSX-LS7 Heads today!! Tons of Pics
  133. LQ4 L92 questions
  134. LS7 crate, accessory drive options?
  135. c6 z06 axleback on 09+ LS3
  136. help with long tube headers O2 senor codes P0134 P0154 PO174
  137. LS3 427 stroker & FI??
  138. New member of the American Racing Header crew!
  139. What is correct alternator voltage
  140. L92 rough cast
  141. how to make a 5.3 fast????
  142. lq4 in 84c10/ headers, alternator, mounts
  143. Why doesn't someone make a turbo header for a SBC?
  144. Which TB for LS3 crate engine
  145. intake manifold advice?
  146. F.A.S.T intake repair HELP!!!
  147. ls3 427 max effort predictions
  148. LS3 swap into LS6 CTS-V ????
  149. ls7 header?
  150. Innovators West vs ATI damper
  151. Progressive throttle bodies
  152. Stick with ported L92's or go small bored LS7?
  153. white goo in valve cover
  154. to david
  155. TR6's plug gap on a procharged G8 (575rwhp @11psi of boost)
  156. Do I need a new throttle body ??
  157. 2007 LS2 crate motor
  158. Gasket Matching an L76 intake
  159. FAST 102 or Vic Jr For 408 FI
  160. ls3 top end on a 98 f body.. help?
  161. muffler replacement for slp lm
  162. ls1 to ls3
  163. 418 LS3 top end?
  164. ProComp LS3 Head
  165. livernois or TEA stage 3
  166. Holley Intakes for L92/LS3 Heads
  167. Few Questions about converting a TBSS motor
  168. Cam question for 5.3L LMG
  169. sheetmetal intake
  170. Serpentine belt systems
  171. 102mm PTM Throttle Body issue
  172. Patriot 225/229 cam in a 5.3
  173. Can anyone tell what it means (pic inc.)
  174. How can i post something for sale on this forum? - LS2 Intake Manifold - NEED HELP
  175. 500rwhp on a stock bottom LS2 GTO
  176. L92 head People! Quick Question
  177. What engine oil are you running in your SDPC LS2 402 or other crate engine?
  178. Fuel rail hold downs
  179. exhaust
  180. How much HP gain possible for LY6 w/just headers & tune?
  181. Need help with LS7 installing crank damper
  182. Ported LS2 head enough?
  183. 5.3 lt ly5 truck engine
  184. Recommend good Starter?
  185. 90 Degree Coil Boots
  186. Who makes waterpump spacers?
  187. help scoggin dickey(or anyone else who might know)
  188. thinking about going LQ9...looking for advice
  189. Any alternative to Meziere water pump?
  190. Doing some R&R underhood
  191. Vette front accessories on a ly6??
  192. Square port truck intake problem (Need help ASAP - thanks guys)
  193. AFR 230 V2 - worth the upgrade for my 402?
  194. CrN Coated Ti Valves
  195. 2" primary headers on a 416 anybody done it?
  196. L92 in 2001 swap questions
  197. Need Throttle Body Help.
  198. Kooks 1 7/8 headers and relocated knock sensors
  199. How to make headers quiet?
  200. Mods for Stock car
  201. Twin throttle carbon fiber intake manifold
  202. Which headers to get.
  203. programmer and intake suggestions 06 c6
  204. dbw throttle body question
  205. when was the ls7 introduced?
  206. Newbie intake questions
  207. LS1 to LSX? Rebuild or Swap?
  208. LS1 to LS3
  209. LS3 + Hollow Valves: Intake Pushrods different than exhaust?
  210. stock starter
  211. Ls1,2,3,6,7??
  212. Shaved valve covers
  213. PROCOMP l92 heads.. anyone run them?
  214. Are the fuel rails the same?
  215. C6 manifolds fit LSX block/heads.
  216. Which heads would you use
  217. Will a y-pipe w/3in cutout hurt my hp numbers?
  218. LSX454R 13:1 compression 11 degree heads
  219. Which crank pulley?
  220. L92 truck intake VS LS3 intake
  221. Budget Build
  222. Is over buying on the fuel system a bad thing?
  223. Best fitting y pipe with pacesetter LT's
  224. Heads
  225. Carbureted 5.3
  226. LS Engine
  227. C6Z with the New Style NW 102
  228. Who sells combo lid, maf and bellows for my fast 102
  229. need help with a 408
  230. Crank sensor reluctor wheel gap?
  231. TBSS LTs??
  232. Engine build
  233. LS2 crank sensor voltage???
  234. Heads/Cam CTS-V Runs like crap 1 day after install
  235. waterpump hitting front cover help
  236. LS3 vs LS7 intake
  237. Where to get MAF honeycomb, not stock - anywhere besides saxonpc?
  238. L99 LS3 tensioner pulley dimensions?
  239. Help wiht LS2 intake swap onto truck engine
  240. In case something WEIRD happens to your SLP Radiator ...
  241. TEA Stage 1 LS3 CNC Heads - Pics Inside
  242. Need recommedation for serpentine belt, a/c and pwr steering delete
  243. Help me find LS block hugger headers with at least 1-7/8" primaries.
  244. Accel Pedal: Camaro LS3 VS G8
  245. Please help
  246. Does anyone have any experience w/ this intake elbow?
  247. Who's Running After Market Oil Pans On LQ9 Strokers???
  248. deleting air inj. on my 402 ?
  249. Sheet Metal Intake Manifold Torque for Boost
  250. Which 7 Qt. Oil Pan For Lq9 LME 408?
