View Full Version : Parts Classifieds
  1. New LS1 Cats 2001
  2. PRO 5.0 T56 Shifter with Hurst Pistol Grip
  3. 9 Second LT1 WS6 Partout - LOTS of Stuff
  4. Engine parts/accessories/exhaust and more
  5. 2001 Ls1 short block, 1998 Ls1 shortblock, Ls1 intake!!!
  6. Various F+Y Body Parts
  7. Stock 16" 01' base trans am wheels and tires
  8. leftover parts
  9. FS: Fast Big Mouth 102mm throttle-body
  10. FS: Fast LSXR 102mm intake manifold and 85 lb-hr injectors
  11. 750 holley, msd ignition, 2.5" x pipe,
  12. FS: AFR 230cc V2 cylinder heads!
  13. Shifter Knob
  14. FS: Forged 383ci turbo short-block
  15. Ls 6 intake ~ stock 243 heads~ complete 01' rear
  16. Tons of parts
  17. Ls1 engine parts
  18. ERL 441 cu in short block assembly-brand new
  19. Faceplated T56 **SOLD**
  20. T6 S85 race turbo(pics added)
  21. Stage 3 CNC Ported 853 LS1/LS6 Heads w/PRC Extreme Valve Springs ($700 Shipped)
  22. Factory 12 disk changer
  23. Fs- sportlines
  24. Rossler TH210XHD NEW
  25. Trailer World Aluminum flat bed trailer 19.5'
  26. LT1 Performance Parts, Wheels, Stereo, Misc 3rd and 4th gen parts
  27. Shift Knobs for sale
  28. Nearly new 36lbs FAST injectors
  29. WTB: 4l80e
  30. 370 C.U LS1 93 octane badass!
  31. Yank SC3000-4L80e converter, fresh rebuild
  32. vortech race bov
  33. gtp ported heads, ls2 rods pistons,comp cam, iron block
  34. 98-02 camaro console
  35. Kooks 3" y pipe with cut outs
  36. Gto owners............diff parts
  37. Nitrous parts!!
  38. Convo Pros
  39. hood
  40. 19" Hp evo wheels with Great tires
  41. forged ls1
  42. LSX steel crank stock stroke.
  43. MSD timing control
  44. Jessel shaft mount rockers 1.7
  45. WTT level 3 4l60e (4l65e) for built t56
  46. Nitrous accessories for sale...
  47. maggie 112
  48. bnib eps comp cam, 2.5 mandrel bend pipes
  49. 2005 4L60 for sale
  50. 30lb SVOs 5k miles - $120 shipped
  51. Enkei Wins - any interest
  52. LS7 exhaust valves
  53. Feeler: WTT/WTS MWC Fabbed 9" Rear End
  54. Rip shifter race version
  55. sun visor spring & black triangle mount
  56. Morel Lifters
  57. 01 Trans Am WS6 body hull w/title
  58. 4 channel rear with backing plates,stock aluminum driveshaft "WITH PICS"
  59. Injector dynamics id 850
  60. FS/FT ls1 shortblocks, and other parts///
  61. RaceCraft Kirkey Bolt in Seat Brackets
  62. four 275/35/18 dunlops
  63. gargae sale
  64. New half filled lsx tall deck block 1500
  65. 232/238 cam
  66. Fast 90mm Throttle Body - Sold
  67. Over the axle true duals fs
  68. Tubular PHB and LT1 stuff
  69. WTB: In desperate need of 35th LE wheels
  70. New!! Weldon 600A Fuel Pump/Weldon A2040 bypass Regulator
  71. Engine & Transmission Harness & PCM w/Base Tune (2004 Silverado HD, DBW, 2wd, 80e)
  72. LS1 coils with remote mount and wires
  73. Fre 91mm billet throttle body and monster stage 3 clutch SOUTH JERSEY
  74. Ls3 416 stroker short block rebuildable south jersey
  75. New Stainless Steel Exhaust Manifolds
  76. LQ4 and LQ9 connecting rods/pistons
  77. weldon pump and regulator (brand new)
  78. FS: Refreshed Performabuilt 4L60e Level 2 ***SOLD***
  79. WTS: Stock pistons and connecting rods
  80. Strange 12-bolt
  81. Stock T56 out of 99 WS6
  82. Borla Catback with QTP e-cutout
  83. WTS: 330-2802 ARP Flywheel bolt kit 11mm
  84. T/A, Trans Am, Firebird Headlamps
  85. FS: PRC 215 LSX Heads with .700 lift Dual Spring Kit (Pics)!
  86. Vigilante Stall
  87. FS: LSx Race/Stock part out
  88. (2) Damaged factory SS 17x9 ZR1s
  89. (1) 275/40/17 Nitto 555R
  90. LSx Cam
  91. Turbo Timer *price reduced*
  92. 2001 LS1 valley cover, knock sensors, harness and MAF
  93. wtb gto stuff
  94. ls1 97-98 corvette fuel rail
  95. Comp Dual valve Springs & BBK TB + SSI Intake Manifold (Trade)
  96. Garage cleaning sale
  97. nitrous kit
  98. Tuned PCM For LS1/LS6!
  99. TH400 tranny JW bell with a brake FRESH NOT A RUN ON IT $1300
  100. meziere ewp ch, belt tensioner, vac pump breather, oil filter cap
  101. Ceramic Coated Dynatech LT headers
  102. WTB: ARP head and main studs, 799/243 heads, ZR1 gaskets, dual valve springs
  103. 255lph Walbro pump/hotwire kit
  104. 00-02 oe ls1 m/t pcm stock
  105. Ported and Powdercoated intake manifolds by Fasterproms
  106. *SOLD* OBD1 PCM x2
  107. GTO Spool
  108. ams1000
  109. Harwood Fiberglass WS6 Hood: Black (98-02) $325
  110. FRESH L92 heads with patriot golds and trunion upgrade!!!
  111. sold
  112. Auto Meter Ultra-Lite Oil Temp. Gauge 4347
  113. 17x9.5 C5 Deep dish wheels and tires for sale or trade, basically brand new
  114. Dailey Engineering billet dry sump setup
  115. LS1 LT1 aluminum driveshaft
  116. Custom FBody Trunk Sub Box Memphis 12's and amp. Still use your t-tops and have Subs!
  117. ms3 cam
  118. SLP H.O RamAir Hood
  119. 3 SS 10 spokes
  120. Stock LS2 crank and rods
  121. (1) 15x10 Prostar priced for quick sale 50$!!
  122. Ws.6 Speedline wheels
  123. FS: 01/02 Ws6 Speedline wheels all 4!
  124. 6.0 parts
  125. FAST fuel rails, Racetronix 42 lb injectors *sold*
  126. fs; 5.3 heads
  127. Built T56 Transmission
  128. stock lid, bellow
  129. Bullseyepower S362 T4 .88 turbo w/race cover for sale, mint condition $670 shipped
  130. rear ws6 wheels with mt et streets
  131. 98-02 ls1 F-body y-pipe, washer fluid reservoir
  132. WTT: 78mm plate for 90mm plate
  133. WTT: Turbonetics TC76 turbo
  134. Need to get rid of some parts
  135. TC78 and Boost cam for sale,Chicago or ship!!
  136. FS: Standalone harness/pcm/throttle body/MAF - CHEAP
  137. LT1/T56 Combo
  138. BMR Front Shock Spacers
  139. Spohn Rear Sway Bar Relocation Brackets
  140. OEM GM Alternator
  141. 853 heads in really nice shape
  142. LS2 water pump. ADM 100mm maf housing. w/pic
  143. Ported FAST, TFS Heads, Valvetrain, Oiling, Interior, 93 Z28 Partout, + Lab Surplus
  144. Craigslist Alert LS1 Trans Am
  145. Stuff in the Garage
  146. ls6 comp cam
  147. Melling High pressure oil pump p/n 10295
  148. Holley 750 DP, flows790 cfm, perfect for street/strip LS motors etc. Last wk on here!
  149. GM Performance L92 carb intake (like new, 20 miles on it!) Like new /clean!
  150. Dynatech Fox body stang LS swap headers 79-93 (updated version) Last week on here!
  151. Ss hood nice 550 obo
  152. FS: Stock LS2 Injectors
  153. 96-97 LT1 Stock Exhaust
  154. FS. Mecham Design 4-Port Extractor / Ram Air HOOD for 1998-2002 CAMARO
  155. LS6/LS1 partout LS6 Cam
  156. LT1 Trans Am Ram Air Hood
  157. 1999 Trans am Part out - LS1 w/ 16,000 miles
  158. WTB - Strange or QA1 Adj Coilovers for 98-02 F-Body
  159. (4) bridgestone potenza re050a tires (255/35zr19 & 285/30zr19)
  160. Fox Body Performance Parts,hurst ratchet shifter, etc. NW INDIANA, Last week on here!
  161. Disassembled LS1, LQ4 wiring harness
  162. 83 lb and hour injectors LS1
  163. 18' beyern five chrome wheels & tires
  164. Weisco 4.125 bore pistons
  165. Weisco custom pistons 4.135 bore
  166. Meling High volume oil pump 295
  167. Patroit extreme dual gold valve springs
  168. Callies compstar H beam rods
  169. Callies Compstar 4 inch stroker crank
  170. 94 camaro z28 complete part out
  171. FS: TSP LS7R cam CHEAP!!!!
  172. LS1 Edit Unlimited License/Cable
  173. Sold
  174. stock aluminum DS w/ spicer u-joints
  175. ebc red stuff brake pads corvette gto
  176. Harris nitous stand alone fuel cell/pump/regulator/filter
  177. 102mm TB
  178. FS: MSD Wires, Misc
  179. 4 c6 z06 OEM wheels
  180. L92 heads new, ls3 intake fuel rail injectors, and new 90mm eldabrock tb cable
  181. LS7 Intake and Fuel Rail $245 (Sold)
  182. Ls3 Valley Cover-Non Pvc Type (SOLD)
  183. Lsx Truck Oil Pan P/N 12619776
  184. Ls3 Rotating Assembly (Stock) SOLD
  185. lt1 shortblock fs
  186. FS Chrome 10 Spoke SS Wheels
  187. Ebony interior parts
  188. Brand new Ford Red Top Injectors
  189. ls1 "The timing tuner" timing and nitrous controller
  190. FS: 8 ID2000 injectors (2200cc/min+ high impedance!!)
  191. Advanced Induction 200 cc heads and cam
  192. Ended
  193. 98-02 Ebony A4 Console
  194. SOLD-Damaged LS1 T56-$275.00, Bell Housing and Used RAM VDS Clutch/Flywheel FS
  195. 226/229 cam for sale
  196. set of 4 rear (18x10.5) c5z06 speedlines w/ R888s
  197. 1999-02 A4 Wiring Harness
  198. MWC 9" aluminum center section 3.50 gears 35 spline Moser Wavetrac
  199. 2003 Z06 LS6 Intake/LS6 Clutch
  200. 92-94 GM optispark brand new
  201. WTB Sweet Thunder Bullets
  202. 93-02 Camaro rear lettering
  203. Some parts off my turbo setup
  204. Lunati LS1 camshaft FS
  205. 243 Cylinder Heads
  206. Metco Motorsports control arms and parts!
  207. lt1 383 short block
  208. LQ9 short block
  209. Camaro RS-Z28-SS OEM BodyKit
  210. PCM serv #12576106/ hdw# 12570558
  211. Custom grind cam (very similar to G5X4), Knock Sensor, a/c condensor
  212. GM LS3 rockers set with Comp Cams trunion kit installed
  213. UMI Pan Hard Bar off of 2001 Trans Am
  214. LS2 96mm throttle body by Professional Performance
  215. Virginia Speed custom LS3 cam
  216. nano 3000 universal kit fs / ft.
  217. Parting out 98 Camaro Z28.
  218. 4l80e Trans and Vigilante Converter
  219. Manley dual valve springs, seats and ti locks
  220. *SOLD*Ebony door panel Trans Am/Firebird No Crack
  221. GI- LS6 intake
  222. FS:Saikou Michi dual CatchCan
  223. ARP Head Bolts 04-
  224. Ebony A4 Console Top - New in GM Box
  225. Texas speed 408 and supercharger
  226. tail lights
  227. LS1 Engine - Long Block, Low Mileage
  228. 98-02 brand new kooks y pipe with custom cut outs
  229. ls1 conversion parts
  230. Complete A/C
  231. Valves, springs, retainers, locks.
  232. 441 ls7
  233. Pcm/ecm holder/bracket
  234. Power antenna
  235. F-Body Subwoofer Box
  236. Jesel Shaft System for All Pro LSW 12 degree head
  237. holeshot holestar wheels mickey sportsman fronts nitto rears
  238. SLP HD Oil pump(>2k miles). 130$shipped.
  239. rocker stands,gto springs, drag brags, o2sensors
  240. magnaflow muffler
  241. Shaved and powder coated calipers and brackets for exchange program
  242. Vengeance Racing 440 Cubic Inch FORGED LS7 Longblock
  243. Bare LS2 block
  244. borla non adjustable WITH tsp ofy pipe need gone asap
  245. Monster Level 3 Clutch Package
  246. Lots of different parts
  247. Air to water IC
  248. 6.0 truck manifolds
  249. LS Swap headers for foxbody
  250. O2 Sensors
