View Full Version : Parts Classifieds
  1. alpine plv-7 sub/amp combo box all in one!
  2. lt1 heads and throttle body
  3. 98 ls1 stock cam
  4. Walbro 255 & install kit
  5. 93-02 Magnaflow Muffler $80
  6. 2 eibach lowering springs
  7. Precision 65 lb injectors
  8. LS6 Intake & Throttle Body w/ 80mm TB, Corvette C5 ZO6 FRC's
  9. Fs: 243's
  10. GTO Stainless Works 3 inch Exhaust
  11. Optima red top, brand new in box...1000 cranking amps.
  12. crank pin kit
  13. Direct Port Fast 90 setup,FJO controller,42LB injectors,LS2 TB
  14. FLT lvl 6 4l60E/4L65E
  15. WTB LS1 Coolant Crossover
  16. 04-06 GTO Rear Seats and F&R Door Panels
  17. Injectors, Ford 9 3.00 gears, interior, Coils, TA mirror, Hatch weatherstrip, Shades
  18. 1999 Formula Partout
  19. monsoon, driver side trans am mirror, stock converter, stock plug wires
  20. Complete 4l60e swap (going with t-56)
  21. FS:LS6 intake, TR 7.4 PRs, SLP STB, 3" DMH e-cutout, stock TB, stock cams, +more.
  22. FS: Lucas 36lb flow matched injectors! (SHIPPED!)
  23. FS: OEM SLP "Blackwing" LID with base, hose, and bello/boot.
  24. FS: hp tuners vcm suite version 1.2.0.
  25. Steering wheel with airbag and clock spring
  26. T56 Transmission & Harness Complete Swap
  27. 2000 SS T56, Wiring Harness, Front Accesories, Oil pan
  28. Stock MAF, Ported MAF ends, stock bellows, knock sensor wiring harness
  29. Ls1 parts F/S Cam, LM1 Catback,Fast 36lb injectors, much more....
  30. LT1 carbed 383 partout, FS or trade for LS and turbo parts.
  31. F body Mid Plate
  32. Wolf crotch strap bracket
  33. Wilwood rear brake kit
  34. TH350/Glide Fbody trans crossmember
  35. Spohn Adj lower control arms price drop
  36. LS 1 Intake w/ Fuel supply
  37. Borla Stinger Catback '97-'04 C5 Corvette
  38. Vigilante billet 3 disc 4000 stall converter
  39. 15X10 Centerline Convo Pros W/tires
  40. Stock Ls1 MAF sensor
  41. Cleaned & Flowmatched GTP 36lb (41lb @ 4bar) Injectors
  42. Misc 4l60 parts and MLS 6.0l head gaskets
  43. 18" C6 Z06 Wheels
  44. 1050 K B carb
  45. Solid Roller valvetrain (New and Used)
  46. NIB Chance Nitrous Converter TH400
  47. C5 Z06 wheel true speedline wheel
  48. SLP lowering springs
  49. SubThump 10" stealth boxes & Amp rack for sale
  50. Welds with Hoosiers
  51. FS: OEM C5 Corvette Pewter front bumper in great shape
  52. WTT: 160* Thermostat
  53. 4 summit/jegs 5 spoke wheels
  54. T56
  55. Used aftermarket tyc brand headlights
  56. 98-02 Eibach Pro Kit FS
  57. Arp 8740 rod bolts
  58. 2007 LQ4 Computer reflashed for stand alone use
  59. WTT 2000 Corvette Wheels Y2Ks 17/18 Chrome Great Shape
  60. 2 x 2.5 inch borla xr-1 bullets
  61. 98-02 key fob
  62. 2000 Ls1/T56 pull out
  63. Like New Mallory Ignition 685
  64. kyb gas-a-just rear shocks
  65. 90mm Nitrous Outlet Plate
  66. 2004 Z06 LS6 cam
  67. Cloyes LS1/LS6 hex-adjustable Timing Chain. 2,500 miles
  68. SOLD! Comp Cam 216/220 .525/.532 114
  69. 2004 GTO exhaust manifolds
  70. GI Stainless works 3 inch 64-65 style exhaust
  71. LS6 intake & tb
  72. C6 Rims Nittos Centerbolt valve covers
  73. BNIB 3:73 gears/install kit for fbody & 03/04 cobra CAI & SCT tuner + misc stuff
  74. LOW milage LQ9 shortblock
  75. WTT: A4 Trans for M6 or??
  76. steel main caps ls1
  77. LS9 / LSA Valve Covers (pair)
  78. Sold
  79. 06-11 OEM corvette zo6 carbon fiber fender,left side driver
  80. 2000 Camaro Part Out - Ebony Interior - Black Exterior
  81. Turbosmart Ultragate 38mm
  82. LS6 O2 Extensions
  83. Stock LS6 fuel rail
  84. MSD 8.5 MM plug wires with CoolSox covers
  85. Zex Wet Nitrous Kit
  86. Ls1 4l60e bellhousing for sale or trade for t56 bellhousing
  87. strange 9"S case with detroit locker and moser axles or trade for PG/Parts
  88. BBK LT HEADERS NIB$360 shipped!Aeroquip Race hose/ NGK plugs
  89. FS recXtreme catch can 35 bucks shhipped
  90. B&M Holeshot 3000 stall for TH-400 trans
  91. Qa1 front f series shocks and 300lb springs
  92. brand new complete spring kit ls3, 570 lift spring
  93. torque arm,LCA,and drag shocks
  94. Misc parts
  95. Some Stock LT1 Parts
  96. ls1 Calipers (front and back) :::SOLD:::
  97. New Cam, pushrods, flywheel and other items F/S
  98. Fresh Built complete turbo motor F.S.
  99. Yank 3000 Stall for LT1
  100. (SOLD) 5-Point Racing Harness Seat Belts - RJS (RED) - Lowered Price!!
  101. 4 Falken Azenis RT615 Tires 315/30-18 - SOLD!!!
  102. FS: Factory C6 Z06 silver Speedlines w/ TPMS and Michelin PS2 tires
  103. FS: OEM 2005 Silver C6 wheels, sensors
  104. HRE 547 18x9.5/18x10.5 w/BFG KDWII's
  105. BMR ADJ Panhard Bar - SOLD
  106. wtb ls1
  107. Chrome C5 wheels with tires
  108. Kooks Stepped Style Headers (1 3/4 - 1 7/8), TSP Y-Pipe, SLP LM2 - SOLD
  109. SVO 42lb, MS4 Cam, 243 Heads, Eibach, Etc.
  110. New grey Noah 2001- 2004 Z06 covette cover
  111. 853 heads with 650 lift springs
  112. Zex bottle gauge
  113. Feeler on selling built LT1
  114. ***WTB*** LM7, LQ4, or LQ9 Swap
  115. 4l80 converter
  116. GTO spares, 17" skinnies!
  117. 02 Camaro ss hood sold
  118. Misc. LS1 parts. other
  119. Lt1 643 Heads, Intake plug and play! need gone ASAP
  120. 6.0L iron block !!! Magnacharged!!!
  121. Valvetrain Parts
  122. Brand New LS1 Water pump and valley cover
  123. Diamond Pistons 4.10 bore
  124. Vortech Super Charger V9 98-02 LS1 Fbody + Extras!!
  125. GM 36lb injector 12594512
  126. Ls2 413 Stroker Shortblock-SOLD!
  127. FS: Precision PT2000 Intercooler
  128. Kooks Long tubes and Kooks Y pipe SOLD
  129. AFR 205's SOLD
  130. abandoned 6.0/L92 build
  131. FS:LS1 stuff and F body aftermarket parts
  132. ls1 coils
  133. Sumitomo Tires 5k miles!
  134. just throwin this out there 5.3 intake manifold f/s
  135. NEW Rossler TH350 RMVB, ATI 8" Treemaster Stall
  136. Sold - Volant cold air intake camaro/trans am ls1 98-02
  137. Throwout and Pilot bearings
  138. Lokar oil dipstick LS6 coolant crossover
  139. SBC Milodon steel splayed main caps
  140. 2002 z28 exhaust manifolds to tips compelete
  141. NX kit with standalone fuel system msd timing twister and more
  142. 1997 LT1 t-56
  143. Ls6 intake manifold
  144. REV Valves, 317 heads, Aftermarket Fuel Rails, Stock 5.3
  145. Cometic .40 mls Headgaskets thinkness 4.030 bore *BRAND NEW*
  146. 317 heads, LQ9 cam
  147. Zex Wet Nitrous kit with BRAND NEW window switch. $325 SHIPPED!!!
  148. LS1 EGR intake & AIR
  149. SOLD* FLP Longtube headers with cats/Off-road pipes and y-pipe
  150. FS: 93-02 Firebird Monsoon CD Player
  151. LS2 Shortblock - needs rebuild
  152. Ractive Exhaust Tips (Wide Oval) SOLD!
  153. 07 Vett LS2
  154. LS1/LS6/LQ9/LM7 parts for sale, head gaskets, ARP pulley bolt, rod bearings.
  155. procharger stock and aftermarket parts
  156. Magnuson LS6 Valley Cover
  157. Custom Procharger kit for LS powered 2nd Gen Camaro
  158. Spohn Extreme Duty Drive Shaft
  159. FAST 65# Injectors
  160. center bolt valve covers w/ bolts
  161. 04 GTO black leather seats
  162. LS6 Intake and fuel rail
  163. C6 exhaust manifolds
  164. Sparco torino 2 race seats
  165. 243s with springs, retainers, seats, locks, also rocker arms for sale! Free shipping!
  166. One WS.6 Rim
  167. Mufflex/Y-Pipe/4inch Exhaust
  168. Wanted Trickflow 225cc heads
  169. Circle D HP 4L60E LS Torque Converter
  170. One-off 17" black Billet Specialties street lite wheels
  171. S475 Brand New!!!
  172. WTT or SALE 18" Z06 wheels for HPTuners
  173. Katech LSx Billet Oil Cooler Adapter
  174. FS:96mm Typhoon intake
  175. 6.0L shortblock and 6.2L heads for sale
  176. ls1 mustang swap headers/custom vortech kit
  177. strange u1667 chromoly transmission slip yoke
  178. 317 Heads w/Patriot Duals - Cleaned, Milled, Valve Job
  179. 2x 97-01 WS6 Wheels $80
  180. Sweet center console M6
  181. steering column and key (from a 1998 Z28)
  182. "Z28" emboidered floor mats, black with red stitching
  183. prc .675 valve springs
  184. 2002 - 2007 LQ4 Drive by wire setup and reflashed computer
  185. Stock LS rockers
  186. Ported LS6 intake
  187. F.S. - HP Tuners MPVI Pro - SOLD!!!!
  188. ls2/3 parts for sale!!!
  189. New G.M L-92 pistons
  190. 60# siemens/mototron injectors
  191. blown ls1 shortblock,mti 5.3 heads/cam
  192. IROC/LS1 header back exhaust, grant wheel, fancy SBC valve covers
  193. Superchips Cortex 2950 Tuner
  194. UPDATE centerline split spoke street/strip wheels
  195. LS2 Intake Manifold and fuel rail
  196. Aluminum 5.3 block for sale
  197. Stock Springs
  198. WS6 stock shocks and springs
  199. FS: Mostly-complete ’98 LS1 with PCM
  200. SBC Trick Flow heads
  201. LT1/LS1 Parts - Forged Rods,ECM,Injectors, and more!
  202. LS Valley Pan Knock Sensor Grommets FS
  203. Manley .650 lift Springs
  204. Stock and Aftermarket Parts for sale, something for everyone
  205. 2002 Camaro SS 241 heads
  206. Scat H-Beam rods with arp2000 bolts
  207. Ly6 cam
  208. FS: Stock LS1 (2000) Engine Wirning Harness
  209. Brand New OEM Jaguar Trunk Emblem/Badge (XJR XJS XJ8 XJ6 VDP)
  210. Pilot style motorcycle/scooter helmets
  211. New "Leaper" Gas Cap - Jaguar XJ6,XJ8,XJ12,XK8,XJR,XKR
  212. walbro 255L in-tank pump with sending unit
  213. Pro 5.0 shifter
  214. MTI Stealth Cam II
  215. DMH 3.5'' Electric Cutout
  216. 98 m6 camaro COMPLETE PART OUT, Clean Bare Chassis F/S
  217. Ls3 intake, NX nitrous kit, ls6 springs, c6 z06 stock air intake, ls3 crank pully
  218. lt1 Parts for sale, TPIS HEADS, LONGTUBES, INTAKE, INJECTORS- GO FAST PARTS
  219. Mass Air Flow
  220. 4l60 trans an converter
  221. Fuel Rails - FAST & Professional Products
  222. 317 Heads off 2004 Escalade $200 shipped
  223. Vig 3600 and 4L60E, BMR LCA's, Adj Panhard, TSP 100MM MAF, Hubs with Studs
  224. ls6 Intake
  225. SOLD!! valve covers carbon fiber hydro dipped
  226. New 80lb Motron fuel injectors
  227. New LS9 ZR1 Engine Complete $18K
  228. lt1: heads, cc502,other valvetrain parts *lowered prices*
  229. ms3 112lsa
  230. 02 gm "ss" hood
  231. FS: TR-6060 08 Z06 Good condition!
  232. 241 heads
  233. 31 spline spool for Ford 9"
  234. Rebuilt Ls1 longblock w/ upgrades
  235. 2002 Camaro 4L60e, 8000 mi. w/extras. SOLD
  236. 2002 Camaro stock 16" aluminum rims w/ tires Low miles
  237. 2002 Camaro Passenger airbag
  238. harris speed works nitrous kit,tial 50mm bov,alky control kit,strut tower brace
  239. FS: c6 z06 OEM Intake + Filter
  240. FS: c6 z-06 Exhaust Manifold - Great Condition
  241. New LS1, LS6, LS2, LS3, LS7 and SBC Morel Lifters
  242. SLP UDP, LS6 Clutch, Stock Valvetrain, etc..
  243. LS1 Rocker Arms and schtuff - cheap
  244. pa racing lca's
  245. L33 intake
  246. Ram Powergrip HD Clutch, Intake, Lid, etc.
  247. K&n oil filters
  248. NEW Comp Cams "r" series hydraulic roller lifters
  249. 99 ta oem black non-ram air hood
  250. ls1 block, crank, manley rods, and CP pistons
