View Full Version : Parts Classifieds
  1. NIB VRX5 Cam, 42lb Green Tops, C5 Headers, 75lb injectors
  2. Wanted!ls3 heads and valves
  3. CTS V Manifolds, Cats, and O2 Sensors.
  4. 2013 Camaro SS Engine/Transmission parts
  5. LS AC Compressor/brackets/idler/bolts
  6. Sold
  7. LQ4 Rods, Pistons, ARP, Bearings, Rings (Trades Welcome)
  8. BMR F-Body Xtreme Strut Tower Brace NEW
  9. Throttle Body Adapter, Fuel Rail, MAF & More!
  10. 2008 c6 corvette parts 12K MILES!!
  11. FS: 05 GTO 17's like new
  12. 44mm wastegate
  13. 16 snowflake rims with new kumho tires.
  14. LOW MILES ceramic ball bearing TC78 1.15 AR
  15. 2 cams/Pac 1209x springs/l92-ls3 yellaterra adj./lunati solid lifters/katechchain etc
  16. 1994 4l60e camaro z28 transmission
  17. TH400 with brake and PTC Converter $1500 Fresh
  18. RPM LVL. 5 4L65E & FTI Converter
  19. 120 lb high impendence fuel injectors $375 shipped NEW
  20. Turbo car parts, ST-80, BMR Turbo K-member
  21. 4 Lug Fox Bogarts *Trade for LSX Parts*
  22. Bazooka DVC 6.5" Subs + Kicker 15"
  23. Sold!
  24. FS: AutoMeter Sport Comp 5" tach with shift light
  25. stock ls1 bolts from all over the engine; water pump, intake, tb, etc...
  26. A1000 and quick release fittings
  27. ASP UD Pulley,LS2 Timing Chain,Oil Pump,Water Pump
  28. FS: like new Precision PT88 turbo
  29. Factory Aluminum Driveshaft - $75
  30. 99-02 f body racetronix FUEL PUMP
  31. 1996 z28 ecu
  32. Lund Black out tail light covers for trans am
  33. FS:interior parts, 243's, PP 96mm intake and 102TB more
  34. weld draglite rims...$400!!!!
  35. Stock stuff I'm not going to use...Updated 3/16
  36. Brand New Nitrous Outlet Stuff
  37. Sold
  38. 90mm Trail Blazer SS LS2 Complete Intake Manifold
  39. LS1 Intake....SOLD
  40. 60k Mile 4l60e + Transgo HD-2 Shift Kit *NEW IN BOX*
  41. Truck Manifold, Truck Rails/Injectors, Truck Coils, LS1 cam
  42. 90 mm Holley TB
  43. EFI LS1 Vic Jr 325$
  44. YANK Performance SS 3600 converter-4L60E
  45. Precision 6766 Ball Bearing CEA Turbo T4
  46. Hoosier rear tires w rims and front skinnys
  47. SOLD! LQ9 with 317's for sale
  48. Cog YSI T/A PART OUT! 9" rear T56, Fuel system LOTS OF STUFF!
  49. Ls3 heads and valves
  50. Mcintosh MX406 and Arc Audio KS300.4 SQ goodies
  51. FS/FT 16in CCW Classics, Drag Pack
  52. Painted 35th anniversay Camaro ss lid and frc's
  53. Ebay gt45 turbos
  54. Awesome aftermarket sale - custom Fbody audio, C5 Z06 rims, bolt ons, suspension more
  55. Siemens Deka 60lb Injectors, Clevite 77 "P" Main/Rod Bearings
  56. LS3/L92 Rocker Arms w/ Pedestals & bolts
  57. Moser 10 Bolt Axles & Triple Pod Gauge Pillar.
  58. NJ/PA - Forgeline- 1.5" Polished Lips / 8" Silver Barrels - 18"
  59. Decided not to build my Z. Parts for sale
  60. Cam-Solid lifters-l92/ls3 yella terra's/TH400 converter etc... Cheap
  61. Cam-solid lifters-l92/ls3 yella terra's-TH400 3600 stall
  62. new ever used borla s type ll cat back exhaust 2005+ corvette
  63. WTT/WTS Futral F13
  64. 2000 ls1 engine complete 62,000 ( SOLD )
  65. Mickey Thompson Sportsman Front Tires
  66. misc parts
  67. Holley ultra hp 750
  68. ARP LS1/LS6/6.0 ECT intake manifold 12pt bolt kit
  69. black sun visors 93-02
  70. Seimens Deka inj w/ adapters, L92 conversion FS
  71. gto oil pan, ls tb, manifolds, fuel cell
  72. PCM, HVAC Controls, NEW maf, other misc
  73. VERY healthy chevy 355 engine, under 2K miles on it
  74. Left over stuff i dont need selling cheap need it gone
  75. Boyd Shyster 17x9.5 wheels
  76. Water to Air Intercooler with Exchanger w/ fan
  77. Performabuilt Level 3 4L60E Trans & Converter
  78. bear front rotors
  79. FS: Diablo Predator U7193 Unlocked
  80. ARP Head Bolts *NEW*
  81. typhoon 85mm intake throttle body and rails
  82. SLP lid
  83. Firebird/Camaro power antenna brand new GM
  84. TPP/Nitro Daves 00011 nitrous dual stage rpm window switch
  85. flowmaster Super 10 Muffler
  86. 2002 LS1 pullout 105k
  87. (LT1) COMP 787-16 Retainers and COMP 648-16 Locks
  88. C6 Corvette Bogart Drag Setup
  89. Super Victor intake package
  90. Stock 2002 WS6 MAF sensor (40k mile car)
  91. ls7 & ls3 clutches
  92. parting out 04 GTO
  93. Like new Tick master
  94. ls2 pistons and rods,holley 750dp, c5 balancer's, much more...
  95. 2002 WS6 Part Out - Canada
  96. 99 Up Racetronix FP w/ Hotwire kit
  97. 93-97 Formula f+r bumper cover Body Parts + misc
  98. Fast 102 intake 146302,MS4, Yella Terras
  99. JGS 50mm Wastegate
  100. TNT F1 nitrous kit
  101. 416 Wiseco pistons
  102. Ls6 intake,fuel rails an regulator
  103. Mild LT1 Cam
  104. hsw n2o stand alone fuel cell
  105. New Billet 88 and Billet 91 turbo for sale
  106. ARP Head Studs & More
  107. FS RaceTronix 37lbs Injectors Flow Matched Set of 8
  108. Ls parts
  109. 2 ls1 intakes. exhaust manifolds for vette and trucks
  110. 2 wheels
  111. LS1 flexplate & bolts
  112. 98-02 4L60e LS1 Torque Converter Camaro Firebird
  113. 2005 5.3 Intake*Oil pan* Pulleys ect.+ F body manifolds
  114. RPM trans
  115. FS: TBSS OEM front bumper cover
  116. 2002 T56 bellhousing
  117. 05 GTO-Monaro Part Out
  118. Ported Super Vic With Nitrous outlet Spray bar
  119. Holley 0-80498-1 Carb 950cfm
  120. ls1 gto parts drag wheels
  121. ls stuff and some LT1
  122. Ls1 intake and tb
  123. 17x9.5 zr1
  124. Weld RTS wheels
  125. small stall circle D
  126. sold sold sold
  127. Hsw NItrous nozzle kit, bottle warmer, MSD digital window switch
  128. FS: Nitrous Outlet 93-02 F-Body Transmission Tunnel 10lb/15lb Nitrous Bottle Bracket
  129. Stock ls1 intake and maf and wet nitrous kit
  130. sold
  131. 2000 SS Camaro parts
  132. Fs: 4bbl 2000cfm tb with sensors
  133. wtt c5z repos black with machined lip
  134. oem c5 thinspokes 17/18 coated black
  135. SLP Long-Tube Header Package (2001-2002 Camaro & Firebird LS1) [BRAND NEW]
  136. lq4 block LS3 Heads painless harness ecu L76 intake
  137. Bogart fronts/ cam /yella-terra l92/FTI Th400-glide/lunati solid lifters
  138. Fikse fm5 wheels for fbody (17x10 & 17x11)
  139. Livernoise stage 2 heads. Complete
  140. New front slotted EBC Rotors, hawk pads, lines
  141. Nx nxl kit
  142. Prc stage 3 ported 317 heads with prc dual springs and Ferra stainless valves
  143. Ac delco intake gaskets
  144. Lq9 truck oil pan set up
  145. Bnib Callies compstar 6.125 rods
  146. Lq9 truck intake complete
  147. G5X3 Cam on 114 LG Motor Sports
  148. Trickflow 225 heads
  149. 6l80e transmission for parts
  150. Mint Hurst "H" leather shift knob
  151. Corvette Sport Seats & Stuff
  152. My lost your gain massive ls sell, injectors,ls2,ls3 valve train,diamond pistons
  153. FS: 2 C6 ZO6 wheels 18x9.5 gloss black
  154. TEA 5.3L ported/big valve heads
  155. Trick Flow, 5/16, 7.350 pushrods
  156. 1994 firebird formula PART OUT!!
  157. Hoosier rims and tires w front skinnys tires and rims
  158. SOLD - FRONT Leather Seats from 1999 HOSS Camaro FOR SALE - SOLD
  159. 02 SS OEM Hood NX Accufab
  160. Springs and retainers! Pics!
  161. Back to Factory sale
  162. OE ZR1 wheels and original tires
  163. 15lb nitrous bottle, 10lb nitrous bottle, nitrous opener
  164. LS1 AC system for sale SOLD!!!!
  165. solid roller cam, lifters, ls1 block, valve cover spacers, 806 heads
  166. 4L60e transmission cooler fluid lines
  167. 98-02 C/F LS1 Gas Tank Complete w/ pump
  168. eBay GT45 turbo
  169. Edge C5/LT1 torque converter 3600 stall - $380
  170. CSU Carb bonnet
  171. Isky boost cam. 5.3 up to 370. NIB 218/218 .570/.570 112LSA +2
  172. PORTED LS1 DART 225s
  173. QTP Cutout w/ controller
  174. F/S Forgeline 18" SOP3 3-piece wheels (Pics)
  175. stock ls1 cam, springs, pushrods, clamshell motor mounts, and few other misc things
  176. complete motor 4l80 trans and turbo kit for chevy truck everything to go run
  177. Hi-Perf Parts, turbo stuff, Fast 102mm LS7, Brakes
  178. NIB 228/230, .571/.573@112 cam
  179. F-Body QA1'S coilovers and rear drag shocks
  180. l92 victor jr fs/ft monster stage 3 67-69 camaro nova swap headers 1 7/8"
  181. 42lb Green top fuel injectors
  182. holley efi 5.7 lcd touchsceen brand new in box 590$ shipped
  183. 15x6 Pro Stars w/ good tires, 10 bolt, driveshaft, hood, MAF, starter
  184. FS - LS6 engine with extras
  185. BNIB nitrous psi gauge $125 shipped
  186. Truck exhaust manifolds for ls motor
  187. Truck Mani's
  188. LPW axle brace kit
  189. lt1 bmr
  190. ls1 hotcam
  191. complete brand new aps turbo kit w upgrades and lg turbos!
  192. 01 ls1 130k, ls6 intake etc., ebony dash
  193. ARP 234-2503 Harmonic Balancer Bolt
  194. FS: 4l60e with 0 miles (WITH PROSTICK)
  195. FS: 94-95 Full front suspension for LSx swap (TEAM Z MOTORSPORTS)
  196. 78mm Nitrous Outlet Nitrous Kit ###SOLD###
  197. FS: MONSTER CLUTCH stage 2 with 18lb billet steel flywheel
  198. complete tbss 3ss partout!!!!!!!
  199. Melling M295 oil pump SOLD
  200. Innovate LC-1 Blue Gauge (NEVER USED)
  201. New Nitto 555r on new fast fives
  202. Complete ls1 w/accessory drive
  203. LS1 Comp Cam and '99 Camaro Parts
  204. NX Gemini Nitrous Plate kit (Dual Stage capable of 250hp of N20) W/Solenoids
  205. Speed pro piston rings
  206. LT1 ecu and harness
  207. Fs: TTops, Fenders, Guages
  208. Brand new 39lb EV6 injectors
  209. Nitrous Bottle/Tachometer
  210. magnaflow f body cat back pics added
  211. wtt Race powerGlide for ls 4l80e!!!!!
  212. Jounce bumpers
  213. Sold
  214. Some parts for sale
  215. 245/250 .629/.612 114+4 LSA Cam, Coated Pacesetter Longtubes
  216. ES Poly trans mount and a 4L60e crossmember
  217. FS or FT headers/ypipe, fmic, stock rockers/injectors, innovate afr gauge
  218. Clevite H-Series Main and Rod bearings
  219. LS7 Lifters
  220. Precision Ported/Blueprinted M295 Oil Pump
  221. 99 camaro leather seats
  222. 33 lb/hr injectors
  223. 1998 Ls1 longblock COMPLETE- sensors/etc stock
  224. LS1,LT1,SBC performance parts
  225. 96mm Typhoon Intake LS1/LS6--P/P High Flow Fuel Rails
  226. LT1 Engine Parts
  227. Cleaning out the attic and garage sale!!!!!
  228. Nitrous Bottle, solenoids, nozzle
  229. McLeod RST Twin Disk Clutch
  230. LS3 Fuel Rail + spacer kit
  231. B&M 80834 8' Super Duty Race Shifter Cable
  232. Siemens/DEKA 60lb injectors
  233. GM Truck headers 4.8/5.3L -sold-
  234. Comp 850-16 lifters *NEW*
  235. Micreoedge Nitrous Controller
  236. Pace torque converter spacer/adapter.
  237. Custom built stainless Foxbody LS swap headers
  238. 30th edition camaro cloth seats
  239. sold the car sale...
  240. Assortment of torque wrenches, mostly snap on
  241. 6LE guage bezel overlay, stainless steel
  242. Nick Williams 92mm throttle body
  243. Edlebrock high flow water pump w/ 160* t-stat
  244. Ls6 intake
  245. performabuilt lvl 3, ls3 block and eagle crank 4.100
  246. Misc parts, Allstar oil catch can, t4 flanges, gauges, valve covers, etc
  247. 94-04 Mustang LSX Swap Headers
  248. LS2 447ci Long Block
  249. FS: SS Spoiler
  250. Camaro roller rollcage
