View Full Version : Parts Classifieds
  1. Garage Sale
  2. Cluster & Gauge Pods
  3. PA racing LS1 f-body chromoly turbo style K-member
  4. Ls1 t56
  5. turbo stuff
  6. Sell or Trade...LS3 MAF, Custom Billet Housing, Harness Adapter
  7. MSD Optispark Distributor
  8. LSX Parts for Sale Schaumburg, IL Priced to Sell
  9. F/S Nitrous outlet "DRY" Direct port setup
  10. Nitrous Express 92mm Dual Stage plate/dedicated/2 15lb bottles EXTRA'S!!!!
  11. 5.3 intake/TB and Corvette Exh. Manifolds
  12. ASA Scavenge only LS1 Dry Sump System
  13. Aerospace Front Brakes
  14. Lingenfelter 2-step,line lock, injectors
  15. KY turbo hotside and 78 mm turbonetics turbo
  16. 6.0L Iron Longblock w/ 317 heads
  17. Want to trade my built lt1 for
  18. (4) 16" chevy ralley wheels
  19. FS: Koni Yellows & Strano springs, tan leather Trans Am seats, interior, etc
  20. FS: Custom ”Trans Am” HVAC delete gauge/switch panel
  21. Kenwood DDX7015 Double din w/ navigation
  22. Rocker arm l92
  23. FS: Fast 90, SPDC 402, PRC heads
  24. Ford SVO 30# Injectors
  25. 295/50-16 et radials fs/ft for fbody go fast goodies
  26. Complete stock rocker set
  27. LS3 block (empty)
  28. Stock radiator fans, lid, fog lights, fuse box holders fs/ft for 317s
  29. 2gauge piller pod camaro firebird
  30. L92 6.2 complete Engine /6L80 Trans
  31. ws6 fiberglass hood
  32. 17 inch front 18 inch rear c5 rims
  33. LT1 style T56 w/ spec stage I clutch and short shifter
  34. FS: Edelbrock fuel rails/crossover
  35. Complete LS3 intake manifold minus throttle body
  36. 10 inch sub box for 4th gen
  37. Ls6 intake, 42# injectors, stock fuel rail, stock tb
  38. 1993-1997 camaro harwood cowl hood
  39. Windshield Wiper Motor & Hardware
  40. Set of C5 Y2K 2000-2005 Corvette Wheels 18/17" with tires (Chicago area)
  41. eagle crank..
  42. 99 Camaro aluminum driveshaft (auto)
  43. Complete LS1 with Fast 92/ARH 1x7/8"/239/247 110LSA cam oil pan to intake
  44. Turbo Camshaft-Comp Cams-284/280 235/231 .621/.617 115.0 LSA
  45. Springs, Retainer, Heads etc.
  46. Monster stage 3 clutch kit
  47. c6 MAM Exhaust + X pipe
  48. 17" dark chrome race star wheels
  49. f body parts
  50. procharger F1R standard rotation
  51. F.A.S.T 65lb Injectors
  52. LS1 241 Heads
  53. NW 102mm Cable Drive Throttle Body
  54. 82-92 camaro stahl 1-7/8 headers
  55. Corvette aluminum torque tube bushing
  56. UMI Adjustable Torque Arm and Stock Driveshaft PRICE REDUCED!!
  57. Complete Fuel System From Nasty Performance
  58. Parting my 8.5 LSX mustang build
  59. Prothane motor mounts LS1 F Body
  60. SLP Skip shift eliminator f-body nitrous mount
  61. HVCII coil
  62. sell or trade: ported tbss/nnbs intake
  63. BMR Weld in subframe connectors
  64. 99 Camaro PART OUT!
  65. Camaro body parts
  66. TH350/ powerglide Trans X member
  67. TH 400 Trans x member
  68. Berger Panel's
  69. LS1 241 heads and ls6 springs
  70. Turbonetics T-Series 7875 .96 a/r Brand New
  71. Pt76gts .81ar
  72. parting out 2001 camaro ss nbm
  73. 42 lb green top injectors
  74. New Afco Front DA Shocks and 275lb Springs
  75. SLP Eibach Springs...SOLD
  76. SLP,SS,Firehawk framed pics
  77. 241 heads, stock cam
  78. 17x4.5 Direct Drill Polished Race Star wheels
  79. B&M shifter for 98-02 fbody $100
  80. c6 zr1 wheels/tires camaro
  81. Nitrous Outlet kit, 2 drag radials and hood for sale
  82. SLP LM1 mufflers 2.5"
  83. Ls1 t56 bellhousing
  84. Pioneer DEH1600 HU, comes with everything needed.. 50$ shipped.
  85. New Walboro 255 fuel pump (broken)
  86. ss emblems,pics and price drop
  87. SLP LS3 L76 throttle bracket, sandblasted valve covers,SLP bellow
  88. hsw nitrous kit with nitrous controller
  89. F/S 275/40/17 Nitto NT05R
  90. GA New LS6 clutch kit with new flywheel
  91. Alpine IVA-D106
  92. Turbo Build Sale!!!!!!!!
  93. F/S Lingenfelter Launch controller
  94. black c5 z06 rims(oe concepts)
  95. Electric Cooling Fans 98' Z28
  96. (4) C6 Z06 Polished OEM Speed Lines with General Exclaim
  97. ARP Main Stud Kit
  98. boost a pump and billet TB
  99. Comp 7.4 .080 5/16'' pushrods
  100. Innovate LM-2 wideband
  101. LS7 Exhaust Manifold Pair $110 SHIPPED
  102. borla adjustable catback with duel intercooled tips pics added
  103. 98-02 firebird and camaro kooks true dual exhaust
  104. 6PT Jig Notched Cage. Wolfe Unit.
  105. EBC Red stuff pads for corvette/GTO and Roadsafe adjustable camer bushings for GTO
  106. 93-02 aftermarket LCA
  107. LS1 T-56 bellhousing
  108. FS 4L60e & seats
  109. Ls6 intake, ported throttle body and Maf
  110. Trick Flow 7.500" pushrods 5/16" BRAND NEW
  111. Ported & Bigger Valves LS1 Heads
  112. NEW Turbo Parts, PT80 hot Coated, Up and Forward LSX headers
  113. FS: DTE C6 manual Diff Brace
  114. GM Turbo 400 tranny and stall
  115. Comp HP8079 turbo...
  116. WTT: 16 inch CCW Front runners for 17 inch CCW Front runners
  117. FS: 72K mile LQ9!
  118. Installed (never used) NX 102mm dual plate nitrous kit. 650shipped.
  119. 2005 C6 Drivers and Passenger Airbags
  120. Yank 3600 stall
  121. SOLD!! SLP 25% Underdrive crank pulley, LS1
  122. Holley Hi Ram Blank Top plate
  123. 98-02 camaro taillights good shape pics added
  124. Siemens Deka 60lb fuel injectors
  125. Early Style LS1 ARP Head Bolts
  126. ls6 intake weiand intake 90mm headers etc
  127. LS6 valvesprings
  128. Anyone want to trade PCM's?
  129. Msd ls 2-step
  130. 317 heads lq9 truck intake and parts
  131. Performabuilt level 3 4l60 with circle d converter
  132. bilstein shocks/pro kit springs
  133. LS2 Corvette air filter assembly
  134. Lots of parts, Engine, Welder, Spal Fans, 5.0 Shifter, Eboost controller
  135. (0821) LS3 Heads Milled .30, w/PRC Dual Valve Springs, Manley Valves
  136. Ls2 camshaft
  137. LT1 Water pump off 1996 impala ss
  138. 2 slightly used toyo proxest1R tires
  139. SLP Dual Dual pipes / tips.
  140. 98-02 LS1 firebird/trans am rear lights
  141. Borla Adj Catback
  142. Misc Parts
  143. LS2 ENGINE 3500mi need a piston
  144. FS OEM 96-97 SS wing Non painted
  145. On3 Performance 50mm Blow off valve
  146. Random parts (ls1 pcm, door panels, console, ttops etc)
  147. Powder Pro Powdercoated Calipers, BFG KDW2 275/35/18, Stock A-Arms, and more
  148. comp lifters
  149. AJE ls1 swap motor mounts
  150. 7.400 hardened push rods
  151. WTT Vic Jr with elbow
  152. 317 valves and springs
  153. 10 spoke camaro SS gm wheels and tires wtt for pro stars
  154. Slp lid f/s
  155. Fs: two 57mm turbos polished
  156. Original 98-02 Camaro ss spoiler and hood great condition must sell cheap all oem
  157. LT1 parts*****
  158. TSP .675" spring kit NEW, Cloyes timing set, c5 ATI 25/10 udp,
  159. Camaro 4pc LLoyd Embroidered "SS" floor mats SOLD
  160. BRAND NEW-80lb Siemens deka flow matched set of 8.
  161. FS: Bunch of parts(interior, SLP, honeycomb taillights, headlights)
  162. truck coils(sold)
  163. Set of blk zr1s
  164. Oe SS hood and wing
  165. brand new Tial 38mm wategate
  166. ls6 longblock
  167. FS nitrous kit, hp tuners pro, microedge, timing tuner
  168. will trade pro stars
  169. Stock Clutch
  170. Comp lsr269
  171. McLeod RST Clutch with Flywheel
  172. Bogart,autometer ,abs module, ARP head studs
  173. Dual Outlet Exhaust Tips-Magnaflow and SLP
  174. 85mm Typhoon Intake With Fuel Rails
  175. SLP Quad Tip Exhaust Valence (no tips) NJ
  176. Custom remote mount turbo kit
  177. FS: Tall Valve Covers and Coil Brackets
  178. LS2 Intake Manifold 90mm
  179. fs/ft TransAm leather front seats
  180. FS/FT 1 - 18x10.5 Topline zo6 wheel
  181. Needed: EGR Tube For '98 Z28
  182. TCI SSF Coverter. PRICE DROPPED!!
  183. LSX Stainless Allen Head bolt Engine Kit Installed pics added
  184. Nitrous Bottles, Clutch, Turbo, LQ4, Fuel Rails, Strange, etc
  185. Autometer Gauges
  186. SLP Loudmouth -SOLD
  187. SLP 25% underdrive pulley
  188. Drive by Wire (DBW) Complete Package for Sale
  189. PTM 102mm Cable Driven Throttle Body
  190. LS1 intake and throttle body
  191. Wilwood Disc Brakes 12.88 Inch Rotor 4 Piston Red Caliper
  192. 82-02 F-Body UMI Panhard bar
  193. BNIB 235/243 cam
  194. Nos kit and kooks headers 1-3/4"
  195. new black pacesetter headers f body
  196. moser 9" package deal
  197. For sale - ls2 intake
  198. new 1le springs with tags........
  199. RotoFab CAI for G8 GT/GXP for Sale
  200. FS/FT Carb Swap Stuff - Holley, Aeromotive
  201. wtb: head bolts
  202. 6-Bolt head Large Bore MLS head gaskets
  203. LT1 / LS1 parts for sale Yank DynoTune Firehawk
  204. C5r lsx na grudge or all motor class worthy small block motor
  205. 15x10 weld pro stars 7.5bs
  206. New LS3 block, Compustar rods and more!!!
  207. 99 ss k member with rack
  208. walbro gss 340 intank pump
  209. New LS2 timing set
  210. Comp Cams Retro-Fit Rocker Arm Trunion Kit; All GM LS Engines
  211. LS7 Intake manifold F/S
  212. Trailblazer SS intake manifold 6.0 w/ injectors and rails
  213. BTR Extreme Valvesprings
  214. Magnaflow catback 1999-2008 Silverado #16742
  215. New Hoosier slicks mounted on Camaro salad shooters
  216. 1999 LS1 Complete Pullout
  217. Corvette motor mounts/bushings
  218. 230/230 custom cam
  219. Ls2 intake for sale
  220. Feeler: LS2 Engine (Nearly long block)
  221. BMR Turbo K-Member
  222. 99-02 LS1 engine mounts/brackets (f-body clamshells)
  223. VFN 4 inch sloped WS6 hood (bolt on)
  224. NIB GM LS1 Headbolts
  225. iForged Aeros + BFGoodrich T/A KDW 2
  226. Truck Coils & Valve Covers
  227. Yella Terra LS3/L92 Rockers
  228. FS LS2 Corvette Oil Pan
  229. LSX Parts For Sale Schaumburg,IL Must Go!
  230. fast 36lb.injectors
  231. LG Pro Headers (no AIR tubes) ceramic coated + off-road x-pipe (C5 fitment)
  232. Nitrous Fbody Accessories
  233. ProSystems 4150 E85 Carb, 1000hp Body - $550
  234. BNIB Motive Performance 3.73 10 bolt Series 2 Gears
  235. turbo kit
  236. NEW 17x4.5 Direct Drill Polished Race Star Pair!
  237. OEM Exhaust Tips Firebird Formula Trans Am Perfect Condition
  238. Custom LSx Camshafts - Detroit Area Only
  239. LSX Custom cam
  240. Innovate XD16, LM2
  241. Sold
  242. Turbo 350 setup for 4 th gen
  243. Precision 76mm Billet wheel
  244. 3500 stall, shift kit, cooler package deal!
  245. Calibrated Success DVDs
  246. vortech 8 rib 2.95 pulley, one dyno pull, $30 SHIPPED
  247. Texas Speed 233/239 and pushrods
  248. wtb 241 Head
  249. 4L70E out of AWD TBSS w/54k Price Drop!!!!
  250. LSx go fast parts garage sale Look inside ws6 airbox, lid, push rods, and much more!!
