View Full Version : Parts Classifieds
- Fs or trade yank th400 race transmission ls1 setup for t56
- stock 6.0 liter pistons and rods
- LS6 Intake and Ported T/B
- M&H 325/50/15 Drag radials 70% tread
- New OEM LS9 Throttle Body 90mm
- sold 5.3 Crate Oil Pan Take Off
- mtx 9500 woofers and kenwood stereo items
- SOLD LS Transmission Conversion Spacer
- misc stuff for sale
- All the little stuff the dealer charges too much for
- Billet throttle body tpis
- SOLD LS Engine Tools Comp Cam Crane Cam Kentmoore
- Used ls1 h2o pump
- T56 Transmission Six Speed LS1
- 1998 LS1 complete long block engine for sale motor Z28
- Ls1 head gasket
- OBD2 PCM off 96 z28 and BCM
- FS - LS3 42lbs injectors, L92 40lbs injectors
- Non TCS throttle cable
- F/S Spohn LSX Swap Motor Mounts
- F/S Kurt Urban Coolant Vapor Billet fittings, An fittings, and 1 hose
- 01 LS1 exhaust manifolds
- 3" Y-Pipe Bump Stop
- 30lb SVO & 55lb Siemens Injectors
- Mcleod RXT twin disc clutch kit
- GMPP single plain/direct port/eblow/fuel rails forsale
- Thunder Racing ported oil pump
- Cam and a few other parts
- Wtb pistons bigger than 4.00 stock or aftermarket
- nitrous express 10lb bottle brackets
- Vette motor mounts for sale
- LS1 Fbody exhaust
- corvette O2s, Fbody clamshell motor mounts, corvette motor mounts
- 93-96 firebird trans am center console, transmission perform switch
- MSD Ignition 7550 programer
- A/C Bracket & Tensioner, Idle Air Control Motor, TPS Sensor
- WTT/S: 2002 M6 swap parts for A4 swap parts
- ls2 bare block
- LS1 intake manifold for sale.
- PAC1218 valve springs & more FS
- F body P1SC Procharger 4.5" ic's
- Ported t/b and heads, udp and other parts
- tc76 turbo and older sytle 4l80e **SOLD**
- Brand new Comp 918 springs
- C5 Vette to 4th Gen F-Body Caliper Adapters
- 00-02 F-body Ported Throttle Body
- Stock and a few lt1 aftermarket parts
- **Silver smoked** corner lights for Trans Am
- Lifters and Lifter Trays
- Brand new OEM carpeting for 4th gen f-body.
- LS1 Parts (updated)
- FS-Pushrods-7.450, cometic gaskets
- Fs: Lt1 parts, 3 rocker sets, 2 cams, tb, and misc stuff
- 93-97 v1 vortech supercharger kit
- Motive 3.73 gears BRAND NEW
- Spring Cleaning LS/Fbody parts
- 315/35/17 Nitto NT05 tires *SOLD*
- C5 Light Oak Sport Seats with a twist
- Lt1 stock and aftermarket parts
- BRAND NEW AC Delco AFS74 Oxygen sensor O2
- NEW .660 dual valve springs, pushrods, ls3 cam
- FS:TSP giant cam
- WTT - 2004 DBW TB for 2002 DBW TB
- NEW threaded IAT, new cam sensor new tps
- Replica Z06 wheels
- Granatelli mass airflow sensor for lt1
- LS1 Altenator
- 35th Anniversary Camaro 10 Spoke Wheels
- Trick Flow Pushrods for LT1
- New Performabuilt Transmission For sale
- 230/234 .592/.592 111 LSA LT1 cam
- GMPP CAI (RARE), Trickflow Elbow, OBD1 PCM, Narrow Band Gauge,etc....
- 243 cast heads complete with rockers/stands
- 98-02 camaro black halo headlights $130,ultra z hood
- 03 mild built 6.0 an built 4l60e
- F body stuff for sale - Illinois
- fs/ft: 398 Twin turbo, drivetrain, fuel system...everything
- bad(not blown) LS7 rebuildable shortblock for sale in GA.
- procharger th-400
- FS-New Kooks catted-Y
- For sale: FAST 90 Throttle Body
- 8.1 injectors @ brand new 317 heads
- lt1 msd wires, like new. 96-97 stock coil with icm
- 2005 LS2 GTO Oil Pan/Windage Tray/Dip Stick/Pickup
- Billet High Mount Alternator and Bracket
- t56
- 2001 Pontiac Monsoon CD Head Unit
- Lots of stock and aftermarket parts
- HP Tuners Serial
- 2001 Chevy Camaro part out New prices 5/22!!!
- ls6 intake and tb also 2 stage nitrous plate
- Prothane Engine Mount inserts and Mounts
- Nitrous Express one piece Maf kit
- Trade like new FAST 90/90 for LS6 intake/tb plus cash
- Stock Y Pipe 00 z28
- FS: LS7 Crank, Pistons, and Ti Rods. (SOLD)
- Vortech t-trim for sale headunite and brackets
- Black and Yellow Custom seats
- F/S Corsa exhaust for 1993-95 Camaro Firebird
- F.S.-Custom ported/polished high volume LS oil pump
- Nos 90mm Plate 150 shipped obo
- Harland Sharp Adjustable LS1 Rockers - Part# SLS17A
- Camaro bumper cover, fender, headlights, and more....
- H/C/I LS1 longblock
- ls3 valves
- BMR K Member
- lot of 93-97 auto and t-56 camaro,t/a and formula parts
- SVO redtops, clear corners, ory pipe
- Corvette Polished Gumby Wheels & Tires, Houston area!!
- ls2 cam and lca relocation brackets
- Garage Cleanout! Ls6 injectors, Brass headlight kit, jacket/helmet, xm radio etc
- Cheetah scs shifter
- Autometer Monster Tach
- 2003 LQ4 complete intake to oil pan & other parts
- Vortech supercharger V9 super g-trim/ trade
- RK Sport 5 inch rear spoiler
- Lowerd price 410gm gears&minie kit
- LT1 FRCs
- MTI clear lid
- MS4 camshaft
- like new hallman boost controller
- 90mm Fast intake
- SOLD NEW FAST 4150 1375CFM Billet Four Barrel Throttle Body
- Driver's Door Glass and HPP3
- COMP R lifters
- LT1 Yank SS4000
- 1996-1996 OBDII LT1 PCM - $75 shipped
- WTT: 2002 m6 engine harness for a4 harness
- wts 3 truck coils with heatsinks
- Tremec TKO Tranny Crossmember for Camaro
- 00 Black Ws6 complete partout
- SLP 85 mm MAF
- NX Fogger trade 4 plate system
- FTP Fast Toys 85 mm Lid
- SLP Cold Air Induction Package "Flowpac" for LS1 F-Body's
- Super Vic Cathedral port FI, Head gaskets,cams
- 1999 ls1 long block
- 02 PCM 0411 and 98 PCM
- 17" tsw nogaro chrome rims & tires
- Crane spring compressor
- V6 Aftermarket stuff!
- LSx Oil cooler adatpters and oil thermostat
- LSX block 4.125 BORE 1800.00
- Oil Pan, Aftermarket intake cover, Stock Parts, Misc.
- SBC Turbo headers
- RPM Level 5 (transbrake) 4L65E w/ Circle D converter FS or Trade for heads...
- 93-02 camaro z28 hatch with struts
- new Ls6 yellow valve springs
- LS1 Long block
- Camaro trans am 93-02 t-tops awesome condition
- 2004 LS1 long block Corvette
- Camaro trans am t56 b@m ripper short thorw shifter
- DMS Lowering Springs
- 93-97 cross drilled slotted front rotors ceramic pads
- WTT: flowmaster catback without tips for LM or rumbler
- SLP CME Valance
- slp dual/dual muffler
- red rs ground effect kit, ls1 airbag, interior parts
- Used TC78 Turbo
- 93-97 camaro taillights fenders hood.headlight bar
- 4 channel rear end parts
- Comp 1.52 Rocker Arms 1417-16
- 17x9.5 tt2 wheel
- FS- Strange adjustable front shocks
- microedge progressive controller, msd timing twister
- LT1 MSD Coil
- complete money maker kit
- Custom LS1 Cam 226 222 116 lsa .584 lift
- STG 2 Ported LS1 Heads - Absolute Speed
- Aeromotive A1000
- LS6 Intake - Painted Sunset Orange Metallic / SOM
- Wilwood rear disk brake kit for late big bearing ford 9"
- Firehawk Decals!
- harness 99 up and pcm
- Brand New F-Body Oil Pan, Baffle, Windage Tray, and Pickup Tube - SOLD
- 93 to 02 TTops for Z28 Camaro
- Stock 2006 GTO Mufflers & 04 PBM Spoiler
- 18'' deep dish c6z wheels w/ mickey thompsons
- 98-01 ws6 wheels not speedlines
- FS: Alot of parts(Interior/Exterior/Wheels/Tires)**updated 5/10/10**
- 650 dual valve springs
- Improved Racing F-Body oil pan baffle
- Trans, shocks, cams for sale
- OEM TA Ws6 Ram Air Hood
- Yellow beehive springs and retainers
- 4th gen camaro tail light panel/berger panel
- edelbrock low profile elbow
- Lots of parts for sale..................................
- ls1 cam 238 int by 242 ext 112 lobe .610
- 2 mp turbo's for sale!!!!
- ZR1 wheels
- FS Fbody Oil pan
- engine stands..misc stock parts forsale
- 98-02 Dynomax Race Bullet Exhaust - Rear section and tips
- FS LS Truck DBW Harness PCM w/fusebox--SOLD--
- Engine Sensors, Skip Shift Eliminator
- LS6 intake & fuel rail
- Skip Shift Eliminator
- 1998 Camaro Harness Manual Trans
- crane cams powermax tuner
- Like new 17x10.5 & 17x9 Torque Thrust(anthracite)with tires. 100 miles on set
- TSP 233/239 112 lsa FS
- FS: Ram Adjustable master cylinder
- FS: Camshaft position sensor, Dome light and Pass. Door Bezel
- Nitrous Controller
- Yellow stock beehive springs and retainers
- lt1 ls1 tonneau convertable boot cover 3 piece
- afr 225 big bore heads to trade
- comp magnum roller rockers 1.6 3/8 1418-16
- 2002 drag radial roller/ ronnie dukes old ta
- 4 Black GM Zr1's 17x9.5
- BMR Chrome Moly Adjustable Torque Arm
- GM 410 GEARS w/ MINIE INSTALL KIT
- Body Control Module 97-2002 w/keyless BRAND NEW !!!
- FS or Trade: Weld Draglites & ET Streets
- Complete 5.3 , performance parts, and GTO pan
- C5 Starter Rebuilt New
- FS: 98-02 Trans Am Spoiler and mirrors
- FTP 104mm air lid
- NIB gmpp ls6 valve springs and tsp 7.450 chromoly pushrods
- stock parts for sale!!!
- 2007 Truck exhaust manifold w/ heat sheild
- 6.0 Iron Block & Moroso oil pan
- nx bottle opener
- Torquer V.3
- Lt1 centerbolt aluminum valve covers
- lsx ls3 valve set, hollow stem intake/sodium ex
- *New* Spartan/Cam Motion custom cam kit w/ pushrods
- ls3 flywheel and clutch
- stock 99 camaro ss camshaft(SOLD)
- Gto nitrous parts
- Auto Meter 3552 Trans temp gauge
- Firehawk ash tray badge *mint shape* SOLD
- Leftover A4 to M6 Parts
- 10 bolt 3.42
- LS Swap Turbo Headers (one time production run)
- Tons of stuff! Must sell!
- Autometer gauges, SLP underdrive, UMI stb, HIDs and more
- Ls1 semi long block FS
- 2002 coolant hose with coolant center for power steering. $50
- Fbody steering wheel w/ airbag and complete steering colum
- A4 transmission crossmember
- 2002 fbody engine wiring harness
- Slp air lid and bellow $70
- 02 SS Le sway bar 32mm $50
- 00' LS1 TA Parts, 3rd Gen parts, cams, springs AND MORE!
- MagnaFlow 14419 Stainless Muffler
- 228/236 .592/.592 110 LSA Custom Lloyd Elliot LT1 Camshaft
- Ls3 rockers w/ pedestals and bolts 700mi SOLD!!!
