View Full Version : Parts Classifieds
- 3.42 10 bolt
- comp cams adjustable rockers
- LS/LQ parts, and kent moore tool
- FOR SALE:LT1 heads and intake
- whisper Motorsports air lid $150
- Low Mile 2000 Z28 parts, LS1 Motor etc..
- Weiand Intake and more
- Hurst qtr stick/pistol grip Mounting plate/Cover kit
- F.S Corbeau harness pads
- procharger pulleys
- DBW Harness / TAC Module / Throttle Body and Other Misc Things
- Low mileage MS3 cam for sale!
- LS1 Aluminum Driveshaft
- 6l80 transmission complete
- ~*_~leather t/a lumbar front seats~_*~
- FS HSW 78mm wet kit, with purge, MSD digital window switch, bottle heater, HSW gauges
- SOLD-F.S.- LS6 Intake & Custom Ported TB Low Miles
- Post subject: ls1 , t-56 six speed drop out! OR COMP- $3999
- AFCO Dbl Adj Rear Shocks...
- moser 9 inch
- Custom Camotion cam 230/236 .611 .612 116 LSA! Ready to ship!
- LS6 cams
- LS1 Shortblock, 853 Heads
- ASA cam
- Flowmaster Catback for 98-02
- 01 WS6 Speedline wheels and tires
- LT1 K&N Intake, high flow cats, short stick w/ white 6speed knob
- SLP Lid, Bellows, 85mm MAF, Underhood ram air, lower air box, 02 SIMS
- NEW SLP Air Lid 98-02 Camaro Firebird
- L92 Long Block for sale
- s10 ls1 turbo kit
- wtb: Fbody accerssories &fbody oil pan
- Dash Pad
- Catalytic converters from my 02 conv. Z
- LS1 new Distributor Converison!!! Ls1 Old School GM Valve Covers!!! PICS!
- NOS 90mm plate
- 10 Pound Zex Nitrous Bottle - Like New $115 Shipped Price Dropped!
- Ported LS1/6 heads $900 OBO
- Corvette Glass Targo Top, 4l60e bellhousing, Electric Fans, couple other items.
- iSimple iPod/iPhone adapter, more parts will be added!!!
- maggie MP112 truck kit, 317 heads
- 2 ls1 short blocks 3 sets of heads
- Comp Cams Pro Mag 1.6 Rockers SA
- Whipple Kit 99-02 GM Truck complete bolt on and ride.
- AutoMeter Cobalt Nitrous Gauge
- Xenon Body Kit parts for Chevy Camaro 1998-2002
- Siemen Deka 60# Injectors
- 03 Z06 Vette NM12 T-56 T56 6 speed trans, 56k, out of bone stock one owner car!!
- Accel 44lb Injectors (8) EV1 Plug-N-Play
- G8 Vararam Intake
- ls2 tb pig tail/12574221 tac/derale adjusted fan controller
- Diablo Sport Tuner U7191 w/pc interface
- SLP 4th generation f-body car cover. Practically brand new.
- Brand new ProCharger (made by K&N) cone air filter for sale.
- Garage Cleanup, everything must go!
- 97-02 BCM (Body Control Module)
- 317 heads from 04 LQ4 motor
- SLP lightweight steel flywheel for LS1s. Brand new.
- LQ4 harness pcm flexplate intake oil pan
- 98 trans am steering wheel (radio controls)
- JBA shorty LS1 headers with ceramic coating for sale.
- Auto swap with built 4L60E, stock bird hood, rims and tires
- Brand new Chevy starter gen1 chev sm bl p/s pump etc..harm bal flex plat
- 236/240 Streetsweeper Cam!!!!
- New 9" f-body housing, carrier, gears, adjustable torque arm bracket complete
- pac 1218's springs for sale
- 2003 truck drive by wire pedal and harness
- F/s 2008 6.0
- Speed inc si6 cam patriot dual valve spring kit comp pushrods
- Pontiac Monsoon Head Unit
- LS1 & LT1 Parts, T56 conversion, Engine harness, PCM, SLP, and much more
- Stock Clutch Master Cylinder from 2002 WS6
- FAST 85lb Injectors PICO style. BRAND NEW!!!
- FS: Used Ram Twin disk clutch low miles
- Forged ls1 engine and build 4l60e
- Forged callies rods and mahle forges pistons
- 4l65 trans pan
- Comp 918 Valve Springs (retainers, locks & seats included)
- 4th Gen F-BODY 6 or 5 Point Crotch Strap Bracket
- Professional products ls1 intake with rails (nib)
- FS: F-Body LT Headers
- ati,tci,katech
- LQ4 heads, intake/ 98-99 emissions etc
- B&M Shifter
- Ac Delco Optispark
- Spohn solid motor mounts (black)
- FS: OEM Clutch Master Cylinder
- Ls1 pac 1218 / comp 918 beehive valve springs
- LS1 F-body Cruse control unit for sale
- LS1 F-body Stock Fan shroud w/fans
- Wanted:: MS3 CAM
- Torque thrust II rims/tan leather seats
- 6l80e transmission complete
- GMPP 4150 intake,Accfab,FAST Rails,Head Gaskets,Cams,Vette Rims,VFN WS6 Hood
- FS/FT Diamond Racing FI pistons for 4.030" bore
- Entire Direct Port 102mm Fast Intake Kit
- STAINLESS WORKS turbo headers
- Parts for sale
- BNIB QTP Cutout with 3inch Cutout
- Stock 5.3 short block,Chicago
- Power Seat Motors '93-'02 Trans Am / Camaro
- New Comp XE273HR and LS7 Clutch Disc FS
- FS: Fuel rail cover, ABS system, TCS motor, throttle cables and more
- Accel injectors for sale$$$$
- patriot gold dual valve springs
- LT1 Vig 3600 Stall 500 shipped!!!
- Garage clean out sale Stock LS1 exhaust, Intake and Misc
- FS: P-Trim .81 A/R housing and T76mm compressor housing
- NIB GM Hotcam kit FS
- WTS autometer fuel pressure gauge
- After Market Harmonic Balancer For Sale
- WTS 2 autometer water temp gauges
- WTS auto flex plate from 04 LS1
- garage clean out MAKE OFFERS. FIRE SALE
- 6.0 litre injectors
- LSA Valve springs
- Wolfe Race Craft 6 pt Bolt In Roll Bar
- new perfomabuilt th400 price drop
- Actron 9575 OBD scanner
- JE 4.125 Forged Pistons
- dbw parts cheap, valve covers
- Mezire, 96lb injectors, katech tensioner, wiring harness, etc....
- FS SBC aluminum water pump
- NEW TH350 ATI 8" Treemaster Stall Converter 4500
- FS 6.0 short block
- FS 6.0 Pistons and Rods
- F S PAC #1218 Springs
- K&N cold air intake for 94-97 LT1 camaro Z28 firebird formula
- Cam $140/ MAF translator $70 / Comp Pushrods $75 Shipped
- Center Caps Galore
- Madman Racing LT1 solid motor mounts
- 15 gal fuel cell, fuel pressure reg
- LS1 Alternator
- ls1/ls3 parts for sale, bolts, sensor, coolant tubes, etc...
- Ls1 stock catalytic converters 98-02
- LT1 Torque Converter
- Fs: comp cam , TCI tq 3k stall 4l60, coolinfans
- SLP Dual Tips
- Z06 knock offs with et streets.
- LS1 parts for sale
- WTS two procharger intercoolers
- 18 Inch Staggered Wheels with Tires
- 2000 frc black corvette motor covers
- GTO STS Turbo Kit
- WTT: MSD 8245 F-Body coils for MSD 8245 Vin=G coils for GTO
- FS: Mallory Hyfire Ignition Box
- (98-02) RS ground effect kit
- RAndom parts
- Fipk Series K&N Cold Air intake
- Stock camaro headlights (98-02)
- LS6 Intake
- Red Powdercoated LT1 Accessory Bracket
- LT1 BTE Flex Plate ARP bolts Cheap
- Reichard 8 Rib 3.2 Pulley or 4.0 6 rib procharger pulley for sale or trade SOLD
- Zex Nitrous Purge Kit - 4 AN New in the Box - $80 shipped
- Comp Cams 7.250 .080 wall Pushrods
- FS: compete dirrect port LS1 kit
- 3" to 4" Flowmaster Y Merge
- LS1 Rocker arm complete set
- Lots of LS1 performance parts and stock
- Ported, Polished and Powder coated Throttle Body SALE
- 60lb injector
- Maf translator for ls1/lt1
- complete lq9 swap fs
- LT1 Hooker Y pipe
- FS: monsoon tape player, rh headlight turn signal, z28 spoiler
- Manley 4.125" Bore Forged Pistons
- Trans am Tail light (driver side) ONLY $10 !!!
- 5.3 and ls2 parts...heads,wire harness etc....
- Autometer 5774, Hurst Line lock with wiring kit.
- Crate LS7 for sale with bad head gasket...<2k miles, 550whp...trade for 5.7 or 6.0
- Hp tuner price drop $375 shipped used once
- Pro 5.0 Shifter w/ Lou's Short stick and Wet N.O. 90mm Nitrous plate
- madman torque arm, brand new
- Stainless Works f body headers and ORY
- SLP Gutted cat pipe/ORY, smoked markers, quarter panel, interior, exterior, and more
- t56 and ls1 parts
- ls1 shortblock/lid/tbody/maf/nitrous
- Bw s475 turbo
- Fs:comp cam
- NEW GM LS2 LS6 243 Cylinder Heads
- '98 Ls1 Intake For Sale
- magnaflow muffler and tips, Mic. other stuff garage cleanout
- 2 LSX blocks 1 Brand new
- Brand New Diablosport Prediator Tuner
- 2 new Nitto NT01 (DRAG RADIALS) type tires for sale!
- FS: LY6/L92 intake manifold/fuel rail/Injectors
- 95 Camaro Z28 part out / LT1 / 700r4
- aluminum driveline
- bunch of things for sale, new,stock, performance
- F/S 25% underdrive crank pulley
- 4 channel 10 bolt
- UMI driveshaft safety loop, driveshaft
- LS dual springs , pistons, lifters, ls2 manifold...
- Complete LS1 engine, T56, and matching BMW M3!
- ZR1 Chrome Center Caps (2)SOLD!
- Ls1 heads, 40k miles
- hypertech power programer3 for sell 97-98ls
- Factory Coil Packs/Brackets and MSD Wires
- SVO Red Top Injectors FS
- TR6060 6spd, Excellent Condition, Shifter, Clutch, PP, Fly, and Throwout. $1,550.00
- SLP and Hooker Exhaust tips
- Powerbond/SLP Underdrive Pulley SOLD
- Comp Cam
- TSP 100mm MAF/Brand new - SOLD!!
- Air Filter Tray 1998-2002 LSx-Application
- FS: 4th Gen F-Body Convertable Top Cover
- Axle bearings and seals for Strange 12 bolt.
- 96 LT4 Vette Part-Out
- Like new LS1 coil brackets
- aluminum 6.0 short block ls2 style from gmc
- 9" Yukon third member/Detroit locker
- 2006 GTO cam (same duration/lift/LSA as '01 Z06)
- OEM SS hood *red*
- stg 3 monster clutch set
- SS Hood $100 Bucks!!
- comp cam for sale
- Stock 4L60e Converter
- smoked camaro tail lights
- Cam, Springs, CAI, TB, Fans. High perf. parts.
- Madman Racing SYA Bars
- Custom 3" Under The Axle True Duals
- Corsa stainless steel 3" catback exhaust (1998-02 fbdy)
- I Need your bad ignition coils....
- Eaton gear posi $50
- PRC valve springs
- tci 3000 4l60e
- lsx turbo 427 biult by lme
- ls1 turbo headers 321 ss
- LT1 handmade aluminum Billet Fab oil pan
- LT1 trick flow heads w/ beehives
- FS: o2 sims
- Procharger custom 12 rib 92-96 vette for F1R reverse rotation mounting kit
- Custom air to water intercooler new
- LTX OPTIs
- LT4-LT1 custom sheet metal intake
- afco aluminum radiator new in box 89-96
- Sonny Bryant Crank
- Zex LSX Wet Nitrous Kit "New" w/ Polished Bottle
- Stock manifold, cats and y pipe
- BRAND NEW 26x11.50x17 ET Street Tires on ZO6 Wheels
- K&N cone filter forsale...
- Gears, wheels, sub boxes, stock k member
- NEW!FORGED KB-718-030 383 STROKER PISTONS Keith Black/Icon +4.9cc
- FOR SALE Five firehawk rims w 4 like new tires wheels +tires
- PA Racing lower Adj A-Arms
- LS1 intake/ TB
- WTT SBC 23*racing parts/forLSX PArts.
- New Comp Solid Roller Lifters with Link bar #8956-16
- 98 z28/ss partout
