View Full Version : Parts Classifieds
- Moser Engineering Ford 9” Housing and 35 Spline Axles for Thirdgen Fbody
- 96 Z-28 M6 Cammed & Bolt Ons Partout.....
- Abruzzi Racing - 8" Torque Convertor
- 2000 Camaro SS rear axle w/ 3.73s
- Auto Meter Transmission Temp Gage
- 406 SBC and v8 s10 swap parts
- TH400 Trans Mount
- Holden VX Tail Lights & Wiring Harnesses
- sold
- sold
- Crane Fireball HI-6 ign box & fireball coil
- QTP 3 inch electric cutout and switch and wire to connect it up.
- Trickflow Cam
- Stage 8 Header Bolts, C5 Turn Signals & Air Dam, Exhaust Clamps, 98-02 FPR, AIR Tubes
- BMR Panhard Relocation Kit
- Skip shift elimnator
- Auto Meter gauges
- Parts for sale
- LT1 performance parts for sale
- LS1 Coils and Harness
- 6.0's for sale
- Trans Am GTA fog lights complete!
- Fast 78 with 80mm throttle body
- LT1 ETP heads, BRE turbo cam, supporting valvetrain components
- Mickey Thompson Drag radials (Cheap)
- yellow z06valve springs.NEW!
- Auburn Diff for 7.5" P/N 542058
- 5.3l pistons rods oil pan covers lifters tail cone
- comp 918s
- 319 heads, and 6.0L rotating assembly
- 65 lb. injectors NEW IN THE BOX ! 370.00$
- LS1 intake & Stock 4L60E converter
- Mcleod Adjustable Master Cylinder
- Brand new o2 extentions
- A/C compressor
- T56 blocker ring set
- Black SLP Driveshaft safety loop
- pro stars w/ newer tires trade for street set up
- strange 9" complete center section 600.00
- ls parts
- Billit Grill
- Firehawk wheels
- Meziere Wp-119 Race Water pump / 2.5" water pump block spacers
- Shop clean up. SFC, Turbo, A/C stuff, etc
- 17x9.5/17x11 Black ZR1 rims
- Built up T-56 LSX --SOLD----
- TSP Heads, Cam, Oil Pump, Lifters, Pushrods, More!!!
- Manual steering rack & pinion kit bmr/flaming rivers
- AFR225 Tony Mamo Ported Heads P/N 1630 w/ UPGRADES
- Morel Hydraulic Lifters P/N 4708
- C5Z06 rims (Sold)
- LS1 Coils and harnesses for coils
- Hurst Shift Knob
- Umi Driveshaft safety loop
- PRC 5.3l 2.5 59cc
- Baer DecelaRotors, Hawk HT-10 Track Pads, MSD Window, OEM Silver ZR1, C5 Motor Mounts
- Texas Speed MS4 Camshaft - $275 SHIPPED
- LE2 heads
- tsp 7.425 pushrod set
- 42lb injectors
- FS Fikse Rims with tires!
- crate 99 ls1 corvette engine
- factory monsoon amp
- 4L60E set up
- lt1 k&n cold air intake
- Comp 918 springs NIB
- HPTuners MPVI Pro FS/Trade for EFI Live FlashScan V2 -- SOLD!
- Garage cleaning!!!1
- FS: LS2 Throttle Body
- pioneer double din head unit.
- Yellow Z06 springs f/S
- OEM Black C5Z hood
- Prc 5.3 stage 2.5 heads/ Torquer v2 cam, Stock Rockers Trunion upgrade, and more...!!
- 4L60E Flex Plate
- FS: L92 heads assembled with PRC dual valve springs
- Misc Parts FS and WS6 fiberglass hood
- Innovate LC1 Wideband on ebay - $86 SHIPPED
- 317 heads with dual springs
- 317 Head Assembled w Rockers 30k on em
- WTT/WTS DD C5 wheels w/tires
- 427ci LS1 complete with extras
- Eagle 4.00 crank/ 4.030 Diamond boost pistons
- F/S or trade v-2 t trim/kooks/procharger valve
- Rear 15x10 Prostars with ET drags for sale
- DS Headlight/Window Switches
- LS1 intake (stock)
- Going SD? I got a coupler..
- NIB 918 springs and 7.4 pushrods
- Vengeance VRX4 Camshaft
- Oil return Pump and GTO auto crossmember
- used Ls6 clutch and flywheel Ohio
- LS6 intake/TB/fuel rail
- New SCAT CRANK $475 Shipped
- 9.5" PI 4L80E Converter
- LS1 single turbo setup for F-body
- Moroso CAI, 1LE Elbow, Z06 MAF, etc
- Aluminum driveshaft
- Ported 853 heads fresh from machine shop
- Crane Cams Valve Spring Compressor
- NOS progressive digital controller and MSD window switch
- Water pump and alternator
- Rebuilt LS1 Engine, Rebuilt 4l60e, Pacesetter Long Tube Headers
- Ls1 bolt ons
- Hp tuners
- MINT 02 Trans Am Steering wheel with Airbag
- FS: Silver DD ZR1s w/ tires WTT: for racestar ind. wheels
- EFI Live
- **APS*** Stage 2 Extreme kit (((SOLD)))
- Set of 16 McGard Splinedrive Lugnuts
- lt1 t56 swap
- WTT GM oem chrome zr1's
- 2002 camaro ss oem spoiler
- Complete ATI th400 set-up, 1400 hp capable
- FS - NEW 42lbs Injectors
- stock and aftermarket lt1 parts FS
- Pistons (2 sets)
- **Who needs seats?**
- WTT: OEM Y-pipe for off-road Y
- Random Parts!! (nitrous, O2 sensors, etc)
- FS: M/T ET Streets - $150 26x11.5x16
- Corvette T56 Transmission
- 6.0 Motor.
- t56, ls1 shorblock, driveshaft. etc.
- Midwest Chassis drive shaft saftey loop
- Ford 9" Auburn Differential 31 spline
- Engine Wiring Harness from 04 GTO
- cobalt 2.5 bar map with locking pigtail
- hp tuners fs
- LT1 K Member and A Arms
- Firehawk rims 17X9
- FMIC parts For Procharged cars
- Ls2 timing chain Ls1 cam gear 1800 miles 35.00
- FS: Russell braided fuel hose, LS1 fuel rail
- EFI Live Flashscan V2 $650 1 license left
- 6.0 Engine Harnesses $65 Shipped PCM $50 Shipped
- Salad Shooters (2), Valley Cover, Front Cover, Rear Cover
- z06 cam, 5.3 heads nos contoller, coil packs
- F/s...ported vic jr brand new never run
- New LS2 intake, rails & tb cable brkt
- LS1 stock motor 56000 mi out of 2002 M6 vert
- AFR Heads,NW 90mm,LS2 intake,ASPpulley
- NiB, blow thru carb.
- Ls style T56 6 speed trans swap NIB clutch, flywheel, etc...
- LS6 oil pump and lifters
- 1998 6spd ls1 pcm
- Stock Parts
- 862 heads,truck intake, stock 5.3 rods n pistons
- Complete 4th gen camaro part out, LOTS OF GOOD PARTS. look inside
- Wiseco 4.070" bore x 4.00" stroke E85 12:1 pistons
- Parting Out 2000 Camaro SS
- Lots of Stuff FS
- Performance and Aftermarket Parts Sale!
- Misc Parts
- Cam-LS1 longblock, Brand new billet specialties PRICE Drop
- HSW Nitrous Tunnel Mount
- a lil of everything
- LS1 parts FOR SALE off formy Ws6
- 2004 gto k&n fipk air induction system
- 2004-2006 pontiac gto aftermarket banshee hood
- Fs: 17" asa st4 chrome wheels
- fs: ls7 injectors
- FMS F14 Camshaft 232/234 .598/.598 112 LSA
- Jesel .937 Lifters
- PRICE DROP Stock LS1 assembled Heads and Cam
- LS1 241 heads (stock),, injectors,, cam
- Ls gm nib rocker arm bolts.
- Convo Pros and ET Streets FS or trade
- Factory LS1 Camaro Tail Lights
- F/s lt1 3800 tci stall in sc
- F.S. Aeromotive Fuel Pressure Reg w/bypass
- Complete part out 2000 NBM Z28
- Trade - 2002 LS1 accessory drive to C6
- 07 GM 5.3 Aluminum shortblock & 799 heads
- ta rearend girdle arp stud kit
- I will eat shipping/paypal if this sells today!!!
- Comp Cams Hi-Tech Pushrods 7.350"
- Worked Trick FLow 220 as cast heads
- Lots of stock LS2 GTO parts
- Sanderson Headers
- Msd 6010
- 07 5.3 Manifolds
- Chrome Ported and Polished Throttle Body
- BNIB Polyurethane Motor Mounts
- 2000 Camaro aluminum driveshaft - SOLD
- Bridgestone Turanza EL400-02(4)BRAND NEW!
- ***SOLD***Motive 4.10 gear set - 10 bolt
- Lots of ls performance parts
- Fast 90mm lsx intake manifold- ported
- BNIB ARP pro series rod bolts, used ls7 lifters
- LSX Tall Deck Block, Brand New
- 16" Z28 wheels/tires Stock PCM, clutch pack F/S
- Wiper motor, 85mm MAF, S&B Filter
- Cts-v t-56
- 6 qts of 10W-40 RP and RP filter 10-454
- Chrome Z06 wheels and tires
- Custom Comp Cam BRAND NEW
- 01 Z06 LS6 take offs, 9k: batwing, milodon pan, oil pump, timing chain, damper
- msd 6010 box
- procharger intercooler
- 12 bolt 3.73 gear
- MTI lid, 85 mm maf sensor, SLP SS grille, LS1 intake, & more!! Cheap!!
- part out leftovers
- one of a kind ! dual over the axle x pipe set up !
- 2002 Corvette MN6 6speed transmission
- WTB: PCM 2006 Trailblazer SS
- qtp 3in electric cutout one left !!! with controller
- SOLD!!!! SPOHN 82-02 Tubular Adjustable LCA's
- Lca Relocators, 2800-3k Stall.
- Meziere Electric Water Pump Street Edition
- Stock LS1 Ram Air Lid For Sale
- LS1 & 5.3 parts
- FS-Coil Packs/brackets
- Magnaflow Quad Tip Catback for sale
- 317 heads with valve job and 600 lift springs
- FS: FAST XFI and XIM modules plus LS2 harnesses
- 3 WS6 RAM AIR BOXS - CADILLAC CTS-V BREMBO CALIPERS and ROTORS
- Parting out Low Mile Trans Am WS6 - White
- 102 mm MAF Aluminium Billet housing
- TT2 17x11 & 17x9.5 w/ Tires
- LS1 Intake, Sensors, Stock Engine parts
- cleanout both speed/stock cheap.
- FS: 4L60E core from 99 TA
- LS6 2001 85mm maf
- tt2 17x9 17x11
- WTT 4L80E for T56
- GI/WTT Forged 347+ Performabuilt 4L60E for Stock
- mint condition stull billet grill with ss emblem
- Like new riken raptor tires with rims
- tsp carbon fiber airlid
- McLeod RXT twindisk clutch great price!
- Ls1 accsessoriesand engine parts
- FS or FT 55# siemens deka low imp injectors
- LS swap parts!
- FS: TB and PCM.....
- Brand new in box TSP pushrods 7.450
- chrome SS 10 spoke original gm
- FS: Wheels and Tires
- HID foglights
- COMP 675 lift springs retainers everything complete kit 320 shipped
- MTI cam and TSP pushrods
- LS1 T-56 Complete Swap
- complete stock LT1 Top end with 643 casting heads
- 3 channel ABS block, built 4L60E, auto swap parts etc.
- FS: Autometer 9117 Tach Driver
- TC76 Turbonetics Turbo for sale
- 408 Rods and Pistons
- SLP Strut Tower Brace
- AFR 225's 59cc COMPLETE MUST GO TODAY
- Alpine CDA-105 Head Unit with HUMount Trans Am WS6 Red LED
- LT1 Firehawk parts & OEM Firehawk red leather interior
