View Full Version : Parts Classifieds
- 2 rear qa1 single adj. shocks
- ls1 ls6 lunati forged stroker pistons/pins stock bore!
- ls1 wires
- WTS/WTT: 4.10 Ring and Pinion
- FT: 18" Gunmetal C6 Z06 Reps w/ tires
- AEM UEGO Wideband
- 2002 Z28 Stock wheels, gears & cam FS
- Ebony M6 upper console
- zex kit with purge and plugs
- HUGE LT1 Package Deal!!!EVERYTHING.
- lq4 rotating assembly and other parts
- LS1 water pump for sale
- Stock LS1/LS6 fuel rail
- FS: F body 8.8 rear end
- LS2 camshaft and valve train parts for sale
- FS: LS6 intake, Starter, K&N Filter, Poly Trans Mount
- New Corvette Crank Pulley off a ls6 crate motor
- T-42 tcm
- Eagle H-beam 6.125 LS rods, also have some pistons if interested
- JL Audio 10w6V2 in Stealth box
- flowmaster catback pretty much new
- Stock air lid and air filter holder
- Specialized stainless polished fuse box covers
- Camaro M6 upper console with boot
- Accel 44lb Injectors (8) Brand New - Plug-n-Play
- LS1 Valley cover
- Stock 2000 SS Camshaft, low miles
- Comp cams 244/244 .612/.612 112+4
- My entire LS Vega motor setup TB to Dry sump pan
- ls3 418 stroker, th400, yank 3600ss stall
- Howards racing converter
- Hypertech Power Programmer III
- *SOLD/SOLD* Spohn Adj. Tq Arm *Cheap-Excellent Condition*
- 65# fast injectors w/2k miles
- FS: Billet Fuel rails, Triple gauge pod, shift light
- LS1 comp cam
- Harland Sharps, LS2 chain, stock parts
- SOLD F.S.-6.0L non egr exhaust manifolds w/v-bands
- Tial wastegate 38mm and other misc LS covers, bolts ect ect
- 2 precision 6262 billet wheel turbos. New.
- lots of stock motor parts for sale!! ls1
- Big boys parts for sale, solid roller, crank etc.
- FS: 4 ZR1 17 x 9 silver rims
- Spohn Tubular Solid Motor Mounts
- ls1 ls6 PORTED 853 HEADS and CAM.. cam sold
- 2000 ws6 motor parts 35 k miles see
- 6.0L block lq4/lq9
- 6.0's and 6.0's Short blocks Cheap!!!! Burgers
- z28 exhaust tips
- Prototype 8.8 housing and axles for f-body
- New Shelby Series 1 Rims (they used a GM 5 on 4 3/4" pattern)
- 99 PCV System W/Valve
- NGK AFX Wideband
- F-Body 4L80E Conversion With Transbrake
- C5 Z06 rims/nitto555r*lots of pics*
- COMP 7.050 Pushrods
- Mpt70 turbo .96 a/r new
- Lunati 4.125 crankshaft
- (NC) LS1 and LQ9 parts Accy brackets
- Arp head stud set
- FS: LS1 Aluminum M6 driveshaft
- Tial 50mm BOV fs/ft
- Wiseco blower/turbo pistons---->> $450
- BMR Strut tower bar for sale $$$$$$$$$$$
- 2000 z28 for sale
- SLP lid and K&N filter for sale $$$$$$$$$
- 58mm BBK Throttle Body for Sale $$$$$ SOLD
- Dragon slayer crankshaft NEW
- Air Lift Air bag with hardware
- Parts
- ls1 ls6 cam
- Lowering Springs with struts
- L-92 pistons (brand new) with rings
- Kenne-Bell Boost-A-Pump
- T-TOP leather cases
- 2000 WS6 stock cats 110,000 miles
- Solid blower/turbo cam & lifters SOLD
- Magnaflow CB & front license plate holder
- A1000 and filter
- .....hjkjhj
- AC compressor
- B.G. 650cfm BlowThrough Carb(gasoline)
- car parts and car audio for sale
- CNC'd 243's w/ls6 valves LS6 intake
- new 243 heads
- built 4l60e with yank 3000 lock up stall
- WTT Mezeire STREET pump for RACE version
- 60lb Mototron injectors.
- WTT: LT1 T56 for LS1 T56
- lt1 stock stuff
- New PRC LS7x Cylinder Heads Assembled
- LT1 custom 2.5in X pipe setup
- speartech pully relocation bracket
- 07-newer truck water pump
- ls6 Engine parts never in car
- WTT:C5 Z06 LS6 Intake & TB for Fast 90/92 Intake & TB
- Alternator Reloc Bracket, Boost Gauge, CSR T Stat Housing
- Ported LS7 Intake with fuel rail.
- Strange front race brakes $600 shipped *** SOLD ***
- MN12 T56 gears, ready for face-plate
- SLP DYNOMOUTH CATBACK (loudmouth w/ dynomax muffler)
- 2000 Corvette Motor - Complete
- Hurst pistol grip shifter handle/Leather wrapped ball handle
- Meziere Fittings
- Turn key turbo 5.3 with all Acc.
- ls1 PS cooler and hoses new 100 miles on it
- FS: LS2 Block Only - From '06 GTO - 10K Miles
- Inovate Wide band O2 Gauge for sale
- Built 4L65 Trans,midwest 3500 stall,rev man,transgo shift kit
- BMR Battery Tray
- Hypertech Power Programmer 3 LS1 & LS6
- 98-02 Camaro T56
- 2006 GTO Wheels and Tires - 17 inch - Indiana
- 2800 pro tourque stall converter lt1 c5 f body 4l60e
- Stock LS2 Camshaft + valve train parts for sale
- LS1/LS6 fuel injectors for sale
- Billet Specialties wheels and tires F/S
- L92 heads
- NX Nozzle kit (w/ extras), NO ashtray switches
- 2 Sumitomo HTR-Z 315/35/17 Tires
- MSD Wires for coil relocate
- complete 2001 ls1
- Garage Clean Out - AEM, Vortech, FRCs, Bunch of Stock Parts
- few 2001 SS parts all stock
- AFR 225, Comp Lifters.
- LS2 Stock Intake Manifold - $125 shipped
- Spohn torque arm 93/02 f body
- BBK 58mm Throttle Body, OTVC MSD Wires, Camaro Steering Wheel
- LS2 Fuel Rail with Injectors (34lbs stock) - $130 shipped
- LS1 BBK 80mm Throttle Body
- 2000 ws6 gauge cluster 109k
- A4 Swap Parts For Sale
- Weld Draglites and brand new MT et streets..
- f/s slp TOTL muffler $275 shipped
- For sale 2 LSx rear covers and a truck balancer
- (2) 285/35/19 Goodyear Eagle F1 GS-2 EMT Runflats
- Heads, Heads, and more
- 17x9 and 17x10.5 American Racing TTM Black tire package
- Texas Speed ORY
- fs: ram hd clutch setup
- msd wires,shocks,silverstar headlights,
- F/s nib nx dedicated fuel system
- brand new eps cam in box
- 317 cnc heads,th400 tq arm,th400 alum driveshaftand more
- 396 Eagle Kit LT1
- Msd holley brodix jesel nos auto gage
- FS - GM Muscle Car Pan Kit New
- FS - NIB Crower Lifters 66278-16
- Fs nib nx dedicated fuel system
- FS/FT: Harland Sharp 1.8 Roller Rockers
- FS: Power Delete window switch plates, LT1 guage overlay, Stage 8 header bolts LS
- GTO Stuff F/S CAI 06 Tails
- 5 inch round, 3 inch inlet/outlet Magnaflow muffler
- 1300 hp n/a Drag Racing engine
- FS: Full set of used Comp 918 springs
- E-38 & T-42 for sale
- Low milage rocker arms for sale
- 2007 Corvette Black Leather Seats Chrome Wheels B &B Catback
- 2000 LS1 Engine Harness and PCM
- FS:LT1 race/street parts. EWP, 383, MSD!
- SS Embroidered Floor Mats, BRAND NEW
- Autometer Fuel Pressure Gauge - GS Series
- LM7 for sale! 57k clean and running! Hear it run in person. + ported heads + LS6 cam
- 10 bolt Partout, SLP 4.10 gears, 4 Channel Axles,4 Channel Backing Plates, LS6 Clutch
- Siemens DEKA 107962 60 lb Injectors (8)
- ATI COG kit & ATI Stage II bracket
- need cats. for stock exhaust
- CNC'd heads...$675 shipped!!
- 2004 6.0 parts 4sale
- FS:pair of K03 Turbos
- ls7 parts
- Brand New TSP Ported Oil Pump
- PI 9.5 3600 tripple disk 4l80e coverter
- LS1 block and parts
- LS1 Whisper LID, OTR Shroud, Alterstart 200a Alternator
- o2 SIMS FOR SALE
- 2002 Original Pontiac Firehawk Wheels
- ms4 cam
- 42lb injectors
- Siemens 83lb Injectors (#3105)
- 8 NOS foggers
- Nano Competition 15lb kit 4500psi
- GI: Fuddle 4400 TC
- FS: LS2 Oil Pan
- C5 Wagon Wheels - Black - Good rear tires
- ls6 intake off my 11sec. stock motor car !
- LT1 rear coolant crossover
- wtt built 4l60 ,pi 3600 for th400 setup
- LS/LFA Engine 6.0 Aluminum with 243 Heads
- lt1 performance and stock FS/FT
- LS1 & T56 Complete Take Out's (2)
- FAST 78mm Intake and SLP 85mm Throttle Body
- ! SOLD ! F.S. PORTED LT1 HEADS w/2.00/1.56 valves
- Custom Fiberglass 12" Subwoofer enclosure + Complete >$2000 Audio Setup
- Hypertech Flashpaq Tuner
- Custom grind cam and valve springs
- 98 LS1 A4 ECU/Harness
- Engine Acc's stock/aftermarket
- Stock ls1 2004 GTO MAF
- Heads cam package $900
- Truck Manifolds (use for turbo builds)
- Full NX setup, Carbon bottle, two stages
- LS6 Shortblock, HP tuners pro
- LS2 valve cover "covers" for sale
- Umi adjustable lca's
- FS: Fast 90 intake manifold for LS1 cathedral port heads...
- High Flowing Plastic mass air sensor ends, "Black" for sale
- RPM LVL 6 4L60 and Vig Converter
- Bare LT1 block, 4 bolt main, .030 over, stroker clearanced
- Livernois Stage 2r cam - TR 224/224 - C6 vararam
- FS: B&M Short throw shifter
- F/S: LS2 intake, fuel rail and injectors!!
- Lunati Pro Series 4'' stroke crank
- **SOLD**Aeromotive Fuel Pressure Regulator PN:13105
- PS pump, shift plates, Emblems
- Turbonetics T62 turbo
- Record Holding Cam only motor !!!
- FS: Edelbrock Vic Jr. Carb intake $220 s. mich :SOLD:
- Bright Red Camaro Fuel Rail Covers
- Turbo hotside parts FS
- Tune by frost ecu 1999
- ARP 234-4110 head studs, TR CheatR cam, 7.425 Pushrods, MSD Wires
- Speartech wiring harness retrofit package (LS3/L92)
- Parting out 1997 Z-28
- low mile TSP tqr V2
- Procharger 4.5 inch intercooler kit for sale!
- Trans Am part out (ls1, t-56, susp, complete a/c, interior)
- FS: TNT F2, 90mm Power Ring, 860 Bottle Bracket, NX Purge Etc
- Alpine, Audiobahn - Reciever, Speakers, Amp...
- BRAND NEW Dell Alienware M17X 3.33GHz Turbo/8M Cache/ATI CrossFireX Dual Video Card
- v2 cam 90mm plate kit 5.3 heads
- Weiand 90mm / NW 90mm TB
- LEFTOVER BUILD PARTS-vortech,autometer and lots more
- WTT - Comp 1.82RR/Procharger Airbox/headlights/Other Stuff
- LT1..Timing Cover..Delco Opti..Hub...Deal!!!!
- Clean up time
- Cleaning out the garages
- FS GM 3.42's for a 10 bolt 7.5
- FS 4.56 gears for a 12 bolt
- SLP Strub bar, 12"stealthbox,Monsoon HU, etc.
- 3 BAR MAP Sensor
- LT1 built 4l60e, nitrous and more
- Random stuff that has to go.
- LT1 parts
- UMI Chassis mount TA and On Car adjustable Panhard
- Corvette fuel rail covers, 98-02 fbody parts
- Alkycontrol Methanol Injection Kit
- Complete 1000+rwhp fuel system
- FAST 102 Truck(complete)
- Edelbrock Intake
