View Full Version : Parts Classifieds
- Truck flywheel -th300/400 swap. Truck manifiold
- TSP CAI 2010 Camaro
- 2000 complete pullout
- 2002 t56 rebuilt 8k miles ago
- LSX tall deck block
- Victor Jr Intake
- ls1 gto throttle body w/sensors SOLD
- 97-02 camaro A pillar gage pod speedhut
- zo6 wheels
- Fs Texas Speed MS4 cam, tsp chromemoly 7.4 pushrods
- 06 impala 5.3 engine wiring harness
- ls2 new front cover
- leftover GTO parts and spoiler
- UMI Torque Arm Mount (Tunnel Mount)
- FS: New Takeout LS3 42# injectors - 200 shipped
- Stereo System for SS
- Cammed ls1, FLT 4l60e, BMR, VIG 3200.......
- Holeshot beadlock drag wheel setup
- Ls6 intake with p&p t/b
- Adjustable Torque Arm and tunnel mount
- 05 GTO Stock Air Box
- draglites 15x10 with slicks
- Going back to stock sale!
- H/C LS1 engine part out.
- 08 ly6 engine parts F/S
- WTT LS1 motor for fast 90/90 or bigger
- PP 85mm intake manifold with fuel rails! and more!
- Bogart Bolted R/T's w/ Hoosiers
- 241 heads
- LS6 with T56 complete ready to run
- 4.8-6.0 truck intake....misc LS stuff. Edelbrock 24 tooth timing control module
- COMP Cams LS1 Rocker Arm Trunion Kit
- Complete ls1 and t56 for sale
- AFR 225 #1630 72cc CNC heads Brand New
- Dart LTX heads flow 332. Holley 58mm TB. Bob bishop brackets.
- For sale - Katech carbon fiber valve covers, relocation kit, and spark plug wires
- 315 3018
- Aje k member and struts
- LT1 Motor Part Out! Lots of Really Good Performance Parts!
- Misc. LS-2 GTO LS-1 f-body parts
- AEM Wideband O2 complete! Needs to go!
- LS 90 mm tb
- Auburn Pro posi,ring and pinoin plus install kit
- custom grind comp cam same as ms4 new in box
- TEA heads, lifters, fuel rails, push rods, cam
- Stant 186 thermostat brand new in box
- Pistons, crank, custom cam
- 94 Camaro Seats
- 93 Firebird Trans Am front clip
- 98 Longblocks, LS1 Aftermarket & Stock Stuff
- Timing Chain set only 1500 miles
- Billet 2800rpm converter for LT1 4l60e
- T56 Transmission LS1 Complete
- 2001 Z28 LS1 part out
- 100lb Injectors for Sale - $300
- bmr k member ls1 camaro parts
- 248/252 Comp Cam
- LS1 Parts for sale
- 93-02 garage cleanout
- Tires, gto rims, hooker aero chamber muffler,auto swap parts CHEAP!!!!
- Comp 7.425 pushrods for sale...sold
- ls1 AC pump bracket
- Borla Adj. Cat back, Spohn Torque arm, Injen Cold air intake
- Walbro 255
- Corvette Procharger D1SC A&A kit with extras !!
- ATS Tri-Y LS7 headers
- 5.3 parts
- F-body Truck manifold cross over kit- T6 flange 700 shipped
- Lt1 Moroso Cold Air and Trick Flow Ceramic Elbow
- Exhaust housings for 6262 Precision Turbo's
- Fs:2002 firebird 16" stock wheels
- WTT: Mustang Fox AJE for MM K-member
- 2001 camaro ss radio bezel
- t-56 clutch reservoir with tube
- sold
- Brand New Nitrous Kit And Accessories and Dual Gauge Pod CHEAP!!!
- #317 LQ4 heads complete
- Mid west chasis TQ arm ( for fab 9 rear)
- Monsoon cd with aux for your IPOD!
- Needed...comp brkt,stock coolant vapor pipes
- F-Body Mark Williams Brakes
- Trades..............
- O2 simulators
- plug wires,fans,pushrods,ud pulley,double roller timing chain
- Turbonetics TC78, JGS WG and BOV all new
- Misc Camaro Parts
- Misc Interior Parts, help me clean out the garage
- 94-95 LT1 Timing Cover and Timing Chain, 96-97 Opti, 94-97 Intake
- LCAs, e-cutout, FTRA, bezels, and more
- FS: GTO K&N 57 Series FIPK CAI
- Ls7 / ls1 part out.. Block / cranks / clutch / NEW PRICES
- 2001 trans am m6 engine harness
- ls1 and procharger parts for sale
- Camaro Bose Radio CD PLAYER
- 99 bare block w/ 3.903 bore: What's it worth?
- Maganaflow axel back
- LQ4 Bottom End
- FS, Factory Reworked injectors by FI Connection 42lbs
- ebay hot side turbo kit
- Black Billet Grill with SS Badge
- Lots of parts: Th400, Suspension, Headers, Cat back, 2 step, Oil pump...
- ls3 corvette heads
- LT1 Intake manifold
- Forged LQ9 370 shortblock
- sold!
- NIB HP Tuners Pro Kit
- ASP truck underdrive pulley with alt. pulley
- Monsoon Amp with wiring harness
- New 3.73 gear, Eaton Posi, Moser axles and more
- LS2 for sale (longblock, will separate if needed) SOLD
- TH350 built swap comes with everything! even bolts and pedals!!
- turbo 400 full manual valve body. brand new in box converter
- Seats from 97 Camaro
- Nitrous Outlet Stand Alone
- FS: OEM pewter ss spoiler
- Mickey Thompson 305/35-18 drag radials
- NIB Melling High Pressure Oil Pump
- NIB Precision Race Component EHT .675" Spring Kit
- 98 ls1 engine minus rods and pistons
- zr1 wheelsw and tires
- Centerforce Dual Friction 12" clutch
- Aeromotive Eliminator Fuel Pump
- stock ls1/ls6 parts FL
- lowering springs
- Spohn Adjustable Rear LCA's And Random Stock Parts
- MSD Plug wires *Red*
- Brand New Prothane LS1 Motor Mounts
- Strange DA rear shocks S5070
- WTB LS1 odds and ends...
- Set of 8 truck coils w/ brackets and harness
- HP Tuners Std. $300
- WTB: 93-93 Firebird/TA Dash
- F/s tsp torquer v2
- For sale c5 harmonic balancer
- 93-96 camaro LT1 gauge cluster bezel for aftermarket gauges
- Walbro 255 fuel pump w/Hobbs switch
- Ultra deep dish c5 replica wheels chrome!! with bfg kdw's
- FS: GM9-AUX Auxilirary Input Converter
- Nitrous Fill Station
- Brand New LS1 TEA Trickflow 220 HeadsSOLD
- lsx parts for sale!!
- Camaro ss keychains -get ya one!
- WTT for intake set up
- VERY high-end SUBWOOFERS *TRADE*
- Tremec TR6060 AKA T56 MAGNUM
- LS1 Camaro brake caliper decals
- LS/LT Wet Nitrous Kit
- LS6 Intake Manifold
- dry nitrous system, heater, digital gauge, RPM window switch
- motor mounts and stands, other parts to
- Complete '98 heads/truck headers/some turbo parts for sale
- vinc power programmer
- FS: Aeromotive A1000, RC 1 Gallon Tank.
- WTT: 6 speed ws6 center console grey
- FS:Corvette CCW Classics wheels with M and H dragmasters tires
- rear brembo rotors
- Brand New Racetronix Siemens/Mototron 60lb Fuel Injectors
- Afpr Fuel regulator aeromotive
- Tial 44mm Wastegate
- Mahle forged LS1 pistons
- F/S 60# Sieman Deka injectors
- 28.8lb lsx injectors
- FS: LS1 heads, fbody T-56 shifter, stock fbody cat back exhaust
- Camaro Bose Radio
- MP70 turbo
- HVH NX 50-300 hp 4150 plate
- HVAC Control Panel '99 Trans Am
- Shortblock parts for sale!!!!!!
- LS1 Valley Cover W/ Gasket
- ls1/ls6 lingenfelter weiand intake price drop 350 shipped
- Corsa Sport for 05-06 GTO
- innovators west, turbosmart, turbonetics, innovative
- SOLD! comp cam 230/238
- Goodies!
- Firebird and Camaro parts for sale - Wheels, Interior, Exhaust and More
- 2001 ss stereo molding whit the fog lights and asr switch 15 bucks exc cond
- Chrome ZR1's 17x9.5s and 17x11s with tires FOR SALE!!!
- Lt1: Holley 58, accel 300 375+ opti
- LY6 VVT set-up with covers 2500 miles
- Harland Sharp 1.7 rockers
- Alternator Bracket & P/S Bracket
- Huge Lt1/Tpi/SBC performance part sale(C4 vette parts, Wiseco, K1, Comp Cams & more)
- ls1/ls6/ls2 race flo manly valves
- FS: Turbo and Lifters
- FS: sbc timing gear drive set $40
- LT1 Trans Am Stainless Dual Exhaust Tips
- LG G2 Bilstein Coilovers
- Forged Hke ls2 engine 500hp 2.5k miles
- RPM T56 6 Speed for LSx
- Morel Lifters, Push Rods
- All SOLD
- P1SC Head Unit
- TPIS Long Tube Headers 97-04 corvette
- LS2 ENGINE COMPLETE, 30k miles, 24 tooth reluctor wheel
- Comp Cam 224/228, .581/.588, 114LSA +4
- Fast 92 intake 92TB SOLD!!! Ported Patriot LS6 Heads SOLD!!!!
- Powdercoated centerbolt valve covers
- Jantzer LS1 throttle body and stock LS1 throttle body
- 241 Heads, LS1 Coil Bracket, Coil Harness, Smooth Bellows
- COMP cam $320 231/239 617/624 lift 113+4
- **SOLD**hptuners vcm suite professional w/12 gm credits
- 42lb Injectors EV1 LS1 Very Low Miles - Plug-N-Play
- Black Cloth Door Panels '00 Z28
- ET Streets on Chrome 16" Wheels, Shifter Knob
- FS: 78mm Nitrous Outlet truck plate kit
- LT1 T56 for sale or trade
- a4 center console plate
- ~~~Flowmaster Catback~~~
- crome SLP firehawk wheel
- HP Tuners Pro
- Lucas 42.5lb injectors from Speed Inc. and spohn solid mounts
- ET Drags
- Totaled 99 WS6, couple of parts for sale
- LS7 Rockers, TSP LS7 7.750 pushrods, LS1 Shortblock, 2 Comp Cams
- LS1 F-Body Fuel Pump Hotwire Kit
- SLP Fan Switch
- HVAC Delete Plate
- Eastwood Fender Roller Tool
- Safecraft Halon Fire Supression Kit
- LS1 Crank, pistons, Spec 2 Clutch
- Suncoast creations WS6 Ram air kit with filter
- ls1 spec stage 3 plus clutch
- LS1 intake with throttle body
- ls2/ls3 valley cover new
- slp cold air system
- Boxed SLP control arms and LT1 custom intake elbow
- 2005 ctsv t56 complete
- Awesome deal on a really good system
- 105 amp truck alternator
- WTT: Used LS6 intake for LS6 intake with EGR
- C6 Gunmetal Wheels with Goodyear Eagle F1 GS-2 Run Flat
- Polished stock LT1 Throttle Body 48mm
- 90 mm dbw throttle body
- ASP pulley with belts and ARP bolt (new) LS1
- FS: DashHawk (PN 13100)
- MSD 2350 Boost-A-Pump $200 Shipped
- garage cleanout!
- Several Parts for Sell
- LT1 Stuff- Stock Stuff
- Brand New full BMR Tubular Front Suspension Set-UP 98-02 Camaro/firebird LS1
- 98-02 Camaro Center Console A/T car
- 02 chrome Firehawk rims and like new BFG tires
- Je pistons #194884
- full set of LS1 coil packs
- Jones Cam Designs LSX roller cam
- Forged Low Comp LS1 Longblock SOLD!
- 78mm HSW wet plate w/ SLP bellow
- 4500 flange throttle body, fuel rails, injectors, etc....
- F.A.S.T. 78 MM Throttle Body For LSX Intake
