View Full Version : Parts Classifieds
- Chrome Hood Hinges and upper latch
- 94 4l60e
- T-Tops with Conversion, Muffler, Cutout, cherry bomb
- WTB LSX 3 Bar Map Sensor
- BRAND NEW lunati aluminum rods 5.7l
- ****bogart d6 15x3.5 - 15x10****
- FS: Coan th400 rmvb w/ transbrake
- NYC Full LS1 Camaro Exhaust system
- PP 85mm polished tb
- ATI Sumper damper, TREX v2, comp 918s, patriot dual golds, oem cats, merge collectors
- 2009 6.0 w/1k mi from Silverado w/wiring and computer
- FS: Industrial Injections 66mm performance turbo
- everything you need to make your ls conversion run
- FS: 02 Camaro stock rear posi with 273 gears with 14K miles
- Hurst Pistol Grip Quarter Stick Shifter*SOLD*
- ls6 intake
- G8 GT ShortBlock 12k miles
- 2001 OEM Corvette Z06 front 17 x 9.5 wheels
- FS: 42lb Green Top FMS Injectors
- VA Speed Blower / Forced Induction Cam
- Koni SA Shocks/Ground Control/Eibach Race Spring Kits
- Fast 92mm TB practically brand new!
- LS3 exhaust manifolds
- Complete LS3 top end FS 4.000+ bore guys come in!
- FS: Patroit Performance LS6 Stage 2 Heads SOLD!!!!!
- Exhaust manifolds / valley cover
- AEM 30-1220 LS1 Engine Management.....
- FS/FT C5 Z06 style 17" rims Chrome 9.5"
- Complete L92 heads
- FS: BRAND NEW FAST 78mm Intake and Fast 78mm Throttle Body
- Ported 243's GMPP p/n 88958622
- FAST 102mm Intake with PTM 102mm TB and Needed Fuel Rail SOLD!
- MTI S1 CAM 244/244 Dur, .612/.612 Lift 112 LSA SOLD!!!
- h3 oil pan
- brand new custom s480 turbo, coated inside and out
- Cleaning out the garage sale ...
- Weld 15x10 draglites, 5.5" B/S, dual bolt pattern
- Innovative LM-1,Percys dual Egt meter
- Brand new futral cam
- MSD Boost Controller 7562 - MSD Programmable Turbo Launch Controller
- T56 Swap Parts/shaft-mounts-clutch
- The good ten bolt posi unit. LOW miles !
- Fikse Mag wheels & a set of Michelin Pilot Sport Cup tires (275/40/17 & 295/30/18)
- Garage Cleanout - Misc LS Stuff Stock & Aftermarket
- Diablo Predator $160
- LT1 and misc. f-body parts
- C5 Z06 wheel/tire combo
- finished 357,stock+perfomance stuff
- fox body lsx swap pices brand new
- 6.0 L92 with LS3 Intake Complete Engine with Accesorires
- disassembled l92 all there
- nib bmr alternator relocation, used delphi 42# injectors,
- wtb:heads,fuel injector.
- F/S C6 rim, Nitto NTO5R drag radials
- camaro tail light panel/ berger panel
- 1997 TA hood
- 93-96 style camaro tails
- new circle-d pro 4k stall
- cheap nitrous kit, edlebrock performer intake
- 50 lb/hr Delphi High-Z Fuel Injectors SOLD!!!!
- (8) Lucas 42lb Injectors 440cc Flow Matched EV1
- stock ls1 rods and pistons x7
- hood 98 transam black
- 98-02 FBody Front Calipers
- Used LS3 main caps
- Th350
- LPE Trigger reluctor conversion module, LS3 valley cover, Ajustable Timing set
- Wtb ls2 or lq9 pistons and rods
- Sx performance Fuel pump & aeromotive filter
- FS: Corbeau CR1 Black Leather Seats
- TTMs - SOLD
- BARELY USED Comp Hardened 7.350 Pushrods ($75 SHIPPED or best offer)
- WTB: 3.622 stroke forged pistons/rods for turbo build
- new boyds chrome vent rings for trans am plus cup holder rings new price $55
- SOLD! Nick Williams 102mm TB - Cable Driven & NEW IN BOX!
- 42# Lucas Injectors High Imp
- not for sale anymore
- BF Goodrich 275/50/15 Drag radials...cheap!!!
- WTS: LS1 block engine minus rods and pistons
- Stock Manifolds, cats, y-pipe
- SLP Dual Dual 335/345hp catback
- AJE TH400 crossmember
- feeler: 454 long block
- ls6 intake
- 225/35/r20 Yokohama S.Drive Tires
- Callies Compstar 4.000" stroke crankshaft $799.99
- Non-Z06 Valley Cover
- cleaning garage must go lt1/ls1 parts
- 6.0 iron block
- Nitrous stuff and magnaflow
- AFCO radiator, 243 heads
- Big HP Fuel parts
- Bright red 99 ws6 hood for trade maybe sale
- LS6 intake w/ported throttle body
- every thing must go to finish my project
- Silver SS 10 spoke wheels, 1 damaged
- 317 low comp heads with PRC dual springs and compcams 7.375 pushrods-450shipped
- ls1 block an parts
- sold...
- 76mm precision
- gm ss 10 spoke wheels and tires
- EFIlive V2 flashscan tuning software
- Wtb ls3 intake
- Sale or trade - Brand new KYB AGX rear shocks 93-02 - 8 way adjustable
- truck manifolds and extension pipes
- intake manifold complete injectors tb
- 99-04 corvette fuel filter kit, AC kit, Ecm
- USED Cloyes Hex-A-Just Timing Set ($65 SHIPPED Or Best Offer)
- Csr pg trans shield
- Brand-new McLeod Twin Disc clutch, Aluminum Flywheel
- N2O Outlet LSX Plate and Procharger J Bracket
- LS6 intake w/ 42# greentop injectors
- HP TUNERS PRO w/Master EFI tuner book
- 2004 GTO Harness + PCM's $300
- ls1 flywheel
- 5.3 oil pan and manifolds, steering wheel, carb braided throttle cable
- yank ss 4000 stall
- New ls2 / ls3 tb
- turbo kit
- New In Box Eaton Posi Limited Slip Differential Chevy Gm 7.5" 28 Spl # 19599-010
- parting out my 98 ss show car
- Msd ls1 blaster coils
- Precision PT88 and Eboost 2 Controller
- LS1 set up for boost - MI only, no shipping
- LS6 Fuel Rails
- 6.0 truck manifolds and flanges for your turbo build
- Corvette C5 chrome ten spoke wheels/Toyo tires for Camaro/Firebird
- 6.0
- Mototron 60 lb. injectors, Comp. Boost cam LS2, all like new!
- Howell lt1 & tuned port injection harness
- Green Top 42 lb. Injectors
- Borla adj. catback
- 4.8, 5.3 and 6.0 parts
- LS1 Longblock and other LS part
- le1 heads bnib 750 shipped
- Corbeau CR1
- MS4cam,Push rods,springs
- 3 speed Lenco CS1 with Quick Drive converter drive chevy and hemi bellhousing
- Precision GT4276
- LS1 4th gen F-body front motor plate
- Chiseled Performance 4000hp air to water intercooler and bolt on water tank
- BNIB Holley 770 Ultra Street Avenger
- Looking to buy LS1 corvette accessorys
- NEW Turbonetics TC76 Turbo - SOLD
- FS: MP70 with Garrett .81 T4 housing
- ARP LS1 Head studs, Main Studs and Cam bearings
- Jegs 4.10's for 10 bolt
- ls1 complete engine minus oil pan
- F/S: Used DeCarbon + coilover springs $25
- LS Foxbody swap headers/exhaust
- FS/FT Midwest Chassis Tunnel Mount Tq arm setup!
- Nitrous kit, heater, controller, etc...
- BRAND NEW 315/30/18 Falken Azenis Tires $300!
- Victory Red Ls2 FRC FS$$
- 8.5 28 Spline Eaton posi
- Pacesetter Off Road Y-Pipe....only 1,000 miles
- FS: Chrome Camaro Salad Shooters. Perfect condition
- FS:LS2 6.0L Block and Crank
- Autometer fuel pressure gauge 2 5/8 with chrome mounting cup
- MGW F-Body Shifter w/ Hurst 6spd ball....new
- FS: Tex 0Z700 and flywheel
- FS: Motron 60# Injectors
- Bmr mbk001
- LS1 comp cam
- K&N FIPK2 intake set up
- Fresh cammed LQ4 6.0/4l80e/harness
- custom 80mm BBK throttle body
- C5 topdown valet, high hp fuelpump,red valve covers,85m maf,crnk pin kit
- Parting out 98 Firebird 3.8 Automatic
- Fast 92 + Fogger kit..
- Part out
- Fast 92 intake/tb
- new master power mpt76 q trim 1.00 a/r SOLD
- M&H Drag Radials 275/50/17
- ****FS: Centerforce DF 12" Clutch $200.00!!!****
- HPTuner Pro, Tuning School for sale
- delete.
- old tin signs, oil cans, gas globes etc
- WS6 VFN hood/red fiberglass mint
- 98 Camaro Airbags driver and passenger
- PARTING OUT COMPLETE 362 CI 6.0L Nitrous Engine EVERYTHING MUST GO!!!
- ls7 clutch. PP and disk 4k miles like new
- SLP underdrive pulley,y pipe, ebony fuse cover,ls3 cover,firebrd license plate cover
- Feeler: WTT th400 for m6
- FS: C6 Corvette Kooks 1-7/8" headers & 3" OR-X-pipe
- Innovate LM-2
- Bogart RT's w/ 28 inch ET Drags
- wtb ls3 rocker arms
- Some Lt1 parts, cam, TC, Elbow
- 2wd 4l80E w/ convertor 67k miles
- SLP BlackWing Air Lid with Blackwing filter--SOLD----
- Mickey Thompson 28 x 11.5 x 15 ET Streets...like new!!
- Stock 2001 LS1 MAF--SOLD
- AMW Red Catch Can with Bracket--SOLD
- l33 5.3 motor part out
- Synergy 2-step with trans brake option, MINT !!! $275
- FS: Cold Fusion Wet Kit, GREAT CONDITION OBO
- Fluidampr Underdrive pulley
- Bogarts welded RTs
- F/S LT1, LS1, and SBC Parts
- FREE!! stock Z28 hood and spoiler
- c6 2009 jsb factory hood mint fs
- Billet Specialties breather and pcv
- ESCORT 8500 X50 Radar Detector
- moser 9 in 35 spline spool, cash plus ur stock
- AEM TRU-BOOST Boost contoller. 200shipped
- FAL 2500cfm PUSHER 16" fan. 100shipped
- high impedance 80 lb. injectors
- Stock & Aftermarket Parts for Sale
- Black 18/17 Z06 wheels with new front tires, awesome shape
- *SOLD* Mufflex Y-Pipe with 4" Flowmaster Merge
- gauges, microedge controller, MT ET Streets, etc
- ls1 geats,cats,cd changer!cheap make offers..
- WTB: LS1 t56
- few 6.0 lq4 parts crank,block,799 heads
- LT1 Holley Avenger TB NIB 52mm
- BNIB Hooker tips, LS3 yellow valvesprings, Slightly used 3.73 gears Lowered prices!
- 2004 DBW truck wiring harness and ECM
- Fidanza P/N 198571 Alumin 12.5 lb flywheel new, never used!
- 4L80-E Swap For Sale
- ls6 intake with fuel rails and ported throttle body
- built by proformance transmissions 4l60 with converter
- T56 parts... Bellhousing, front plate, etc...
- LS6 Intake With Ported/Polished TB **SOLD**
- wiring harness from a 2000 ss t56 with comp.
- FAST fuel injector spacers.
- Forged 370 nitrous motor, built T-56
- For Sale Metco Breather
- Aftermarket Raised Trans Am Hood-1997
- Cam/spring install tools
- Exile boost controller & Misc. stock parts
- New in box K&N filter
- 4150 nitrous kit turn key/parts
- New LS9 Valvesprings
- FS: ferrea valves 2.00" F6230
- Stock engine parts off 2000 Camaro SS
- LS1 LS6 Aluminum Intake Weiand Lingenfelter ed.
- Ford Racing/SVO 30lb Injectors Red Tops EV1 Bosch
- Sold
- valve cover spacers
- LS1 Shortblock *pick up only*
- SOLD!!!! POLISHED Front Bumper Support Cover
- GMMG catback for sale
- '99 LS1 heads/cam/valvetrain/oil pump For Sale
- RC Racing 71 lb injectors, 9" spool, pinion yoke, truck water pump
- Fastbird's Garage Clean Out -- OEM and Aftermarket
- ATI Balancer and Procharger 8 rib crank pulley for sale
- 93-97 Camaro/Firebird Stock Rear Woofer w/ Enclosure
- Nitto 555r Extreme Drags
- LS2 MAF With LS1 Wiring Adapter
