View Full Version : Parts Classifieds
- lt1 parts for sale
- 04 GTO Wiring harness $250 + shipping (WITH ECU'S)
- ZR1 17x9.5 17x11 Silver Wheels w/ tires
- good used heads
- 3" high flow cats cheap
- 2005/2006 Complete GTO Brakes
- Gtech Pro SS
- Camaro ss parts
- cheap nitrous kit
- BRR (81U) Factory Power Mirrors
- ls1 short block
- Rims&tires/ t56 short stick shifter assembley
- Prothane Tranny Mount (red) and Oxygen Sensors
- bunch of stick ls1 parts and some more 6.0 lq9
- lq9 parts from my 6.0 swap stock
- Emptying the garage. LOOK HERE!!
- 17" (4) OEM Chrome SS ZR-1 Wheels + Tires
- FS: Silver C6 Wheels/Tires/TPMS
- Futral cam 243/249, chromeoly pushrods, 2 nitrous feed lines, LS F-body coils/WP
- LS1 parts
- 6.0l iron block
- Ls engine cradle
- FS: GTO Fuel Rail Covers 05-06
- WTT: 17x9.5 black z06 Motorsports
- Level 4 RPM 4l60e
- AEM UEGO Gauge Display Black Bezel / White Face - PN 30-4123
- parting out ls1 shortblock
- Z06 race car part out - Trade for stock items + cash (Quaife rear, built motor, etc)
- EuroLight set with bulbs. New in box. (98-02 Birds)
- 1998 to 2009 GM cars and trucks service manuals dvd set $25
- HP Tuners for Sale
- Fs coolflex new (blue)
- Hooker Super Comp lt1 headers with y pipe $400 shipped ONe day sale
- LS6 Intake Manifold
- Alpine CDA-9855 and KCA-420i Ipod Adapter
- Rear strange drag brakes
- Nitto 305 35 18 Drag Radials FORSALE
- HUMount Trans AM WS-6 with Red LED
- LT1 / SBC Dynatech Ceramic Coated Headers
- HP Tuners VCM Suite Tuning Package with MPVI Pro Interface
- SLP Loud Mouth 2
- FS: Comp 918s - Price Reduced
- Mild cam
- LS6 Intake, ABS unit, brake master cylinder and booster.
- 36# red top injectors (30# @ 43.4 psi, 36# @ 58 psi)
- LS1 241 Casting Cylinder Heads - Springs & Valves Included
- Pair of new 11" wide 17 Inch SILVER ZR1 Wheels
- 93-97 combo switch, steering wheel, ignition swithc
- (2) Nitto 555
- nitrous kit
- SLP Strut Tower Brace Pewter Powdercoat
- LT1 Parts - Rims, Intake, etc...
- FS: AN awesome Monster Stg 4 Clutch
- Swap Dynatech offroad pipes for cats
- Vortec engine cover
- 6.0 exhaust manifolds NICE
- SLP panhard bar
- 2x 90mm TB, Manley Springs, 42lb Injectors, Wolfe LCAs, SLP Lid, Nitrous Parts, etc..
- OEM Z28 Emblems
- TFS Aftermarket castings
- 347 Shortblock/Longblock
- GI: Forged LS6 w/ turbo setup
- FS Int and Exh Valves for ETP or PRI Cylinder Heads
- mti x1 cam
- LS1 Fuel rail and coil packs
- FS PAC 1521 Valve Spring Kit
- Fs manton pushrods
- Ported&polished maf ends
- new champion beadlocks and tires
- 18" Chrome Z06 style wheels for fbody with nittos
- Hotchkis strut tower brace
- Stock and go-fast parts...
- Light Weight Hood Struts
- STS kit w/t67, meth, etc, 4L80E 3200 stall
- FS NEW Detroit Locker 31 spline
- WTT - SLP SS Grille for SLP Bowtie Grille
- 05-08 Corvette AC Compressor LS2 LS3 Complete AC setup
- FS: Stock camshaft, LS1 intake and TB, 2 Monsoon systems
- Koni's 4/3 Strano Springs
- competition nano 4500 psi kit
- HPtuners Standard
- PCM & wiring harness 04 GTO M12 (6spd)
- F.S. stock camaro parts
- LT1 RHS 235 heads, new never run **PICS**
- F2 Nitrous Solenoid,Blow Down Tube, 6an Bottle 80+ Shipping!
- MT et street radial 315/35/17's *REDUCED PRICE*
- 1997-2002 6spd Center Console Plate
- LS1 Engine Block and 2 Sets of LS1 Stock Heads
- 99 4L60E low miles.
- Pacesetter Headers and various parts
- NEW UMI Driveshaft safety loop
- Two LS2 AC Compressors
- FS: 30# SVO injectors
- 2010 Camaro LS3 Oil Pan
- ls1 parts centeral cali
- 3.5" aluminum driveshaft - T56 to 10b or 9"
- 15x10 weld prostars (2 sets)
- ZO6 6-speed Transmission 48k miles
- New FAST 90mm TB
- Nitrous Parts,HyFire window switch/timing retard,lt1 plate kit,AND MORE
- Eaton unit w/4.10 Gears, Lous Short Stick, Wolfe Rear Sway/Anti-roll Bar
- For sale ls3 intake/fuel rails/injectors
- Centerline Warriors with Dr's and 243 heads assembled F/S !!!!
- Green top Injectors 42#
- 56mm offset 17x11 Chrome ZR1 rears for trade
- Stock LS7 GM OEM Pushrods
- Howards 4l80e Converter 3800 stall
- Stock and granatelli maf for sale
- LS1 engine with spun rod bearing, wiring harness, 4l60E transmission
- Demod sale Heads, Cam ,Wheels, Prices
- Fs:C5 Sts turbo kit with upgraded gt32 turbo
- 2002 5.3 engine
- FS: Pavlock aluminum LCA's with mild steel rod ends -- SOLD
- Qa1 double adjustable shock package for the front and rear.
- LS6 intake manifod powdercoated Pewter
- LethalZ cam for sale!
- Trans Am WS6 17" Rims and Tires
- Hpe s2 cam
- FS Strange Drag Shocks Single adjustable
- PRICES REDUCED, Leather door panels, Ported TB, SS emblems, vents etc..
- 7.350 TSP Pushrods
- New PRW 1.7 Roller Rockers Fisrt $100
- LS2 Intake, Injectors, Rail and sensors. Less than 50miles!!!
- mcleod twin disc clutch kit used in great shape 4000-5000 miles
- Coil Packs, harness & Brackets less than 50miles!!!
- C6 Stock Exhaust
- Center Console 98-02 Camaro
- Backseat for a 98-02 Camaro
- F/S MSD Timing Twister
- new cam 244/242
- HSW 10lb Nitrous Bottle w/ -6 bottle Nut
- For Sale: FULLY POLISHED CME TIPS & 90* BENDS
- Raptor shift light for sale and drive safety loop cheap and brand new umi torque arm
- 03-04 steeda pully puller removal tool
- 03 mustang gt bbk chrome cold air induction
- nitrous outlet 10lb bottle
- 3600 stall, catback, TA dashpad,4l60e
- Trick Flow 220 as cast heads
- Strange Aluminum Center Section Ford 9"
- NEW SS SPOILER with brake light
- Harris Speed Works Stand Alone Fuel Cell, 10lb Nano fs
- Emblem Pro's Stainless Steel front bumper cover bird overlay/PONTIAC overlay
- TCI *NEW* Comp drag trans TH400
- Procharger P-1SC-1 from House of Boost kit
- 8.8 for f-body bolts in like stock...looks stock
- C5 EXhaust Manifolds
- f body 76mm kit tti $2400, hsw nitrous ,ls6 intake, gauge cluster and more cheap!
- Nitrous Kit Many Extra's good to go!
- F.S. Vigilante 3600
- Comp 7.5 pushrods, New
- EV1 to EV6 Injector Harnesses
- BMN Nitrous Controller NEW
- SLP Lid
- FS- SVO 30lb injectors
- Racestar Industries!!
- ASP C5/C6 Underdrive Pulley/ F-Body Hal Drag Springs
- Lloyd's Floor Mats, Brake Backing Plates, LS1 Water Pump
- 4th gen SS/WS6 stock exhaust tips
- << Proven Mid 10 sec lt1 Top End >>
- Wiesco Pistons with Rings for lsx
- Ported stock TB-28.8 injectors
- Racetronix in tank pump. NIB
- 3.89 lightened Gears for a Ford 9"
- 93-97 camaro driver side fender
- '00 T/A Stock Rear 27XXX "excellent"
- LT1 D1 procharger kit
- Dual QTP Electric cutouts, 3", 2 sets
- Accel Gen 7 Thruster DFI F/S
- Fbody Baer Big Brake Kit - 4301001 Brand New!!
- 9 inch moser housing and axles fbody 35 spline
- long tubes and turbo kit
- trans am steering wheel with air bag
- Nasty Performance Billet valve covers blems
- Carbon Fiber look LS2 rails
- Corsa sport 2004 GTO #14185
- Nitrous Outlet Halo Dry System GTO
- Racetronix 42lb injectors
- 408 short block has to go =(
- 98- 02 Firebird/Trans Am Driver Side Headlight Assembly
- Jegs Sport Mags and Tires
- WTT: OEM SS Hood silver
- Built 4L60E for a T56 ? 100 miles on this trans guys
- Camaro SS hood
- Lnc-002
- corbeau seat brackets with sliders 2" rise universal/s10-s15
- Raptor Shift Light (yellow)
- SBC Parts, Racing Parts, Wheels, Tires
- Complete 12" Subwoofer system with Sub, Amp, Enclosure, and Capacitor
- 3 Z06 Style Emblems from Emblempros.com
- new cam motion custom grind like ms3 238/242 113
- Thunder Racing TReX V.4 Camshaft
- T/A Girdle for 7.5" 10 bolt
- 355 lt1, heads, intake, K&N CAI
- eagle h beam rods
- Koni front struts single adjustment "Koni yellows"
- MSD 8969 digital window switch for sale
- 35 spline Detroit Locker for 9" ford
- STOCKER ROCKERS, MOUNTS, LIFTERS, CENTER BOLT VALVE COVERS, LS1 oil pan 24k
- Front Mount Intercooler - 2.5" Aluminum Piping Kit
- FS NIB suspension/ss wing/berger panel
- turbo/parts
- 42lb greentop injectors need gone asap $140 shipped
- Sold
- Leather LS1 Trans Am Back seats F/S
- used 2800 stall converter for C5 vette
- 2 sets of D585 type GM LS based Coils FOR SALE--ACCEL
- N2O filling pump and attachments
- FS: TA WS6 Wheels/tires, 18x9.5 Z06 wheels/tires and 1 new 19" Nitto Invo, 16" ZR1's
- LE3 Heads, LE3 Cam, LE Ported Intake Package
- complete 243 heads package!!!
- Brand New NVR Mounted Wings West Lip Spoiler F/S
- 40 Amp Adjustable Kenne Bell Boost-a-Pump w/Adjustment Knob
- ls1 wiring harness & ecu
- HOOKER super comp headers LS1
- C5 z06 wheels
- LSX 454 w/106mm Turbo Big Stuff 3
- F/S: 918 valve springs, AMW catch can, Spohn torque arm
- 3.91 gto diff--sold
- 16x5-3/4x8-3/4 Tube and Fin Intercooler
- 19x3x7-3/4 Tube and Fin Intercooler
- SCT Handheld Tuner!!! GM Xcalibrater2,!!!!!150OBO!!!!!
- MagnaVolt Voltage Booster and Turbonetics T4 Housing MAKE OFFER!
- GMPP Intake With Dry Directport.
- F/S: Michelin Pilot Sport 345/30R19
- Fel-Pro LT1 Throttle Body Gasket
- F/S: C5 Corvette Short Throw Shifter
- Alcohol Injection Systems Fender Mount Alky Kit
- Turbonetics T78 BB turbo
- F/S: Billet Aluminum Z-28 Shifter Knob
- Anyone want a brand new driver side fender liner?
- 80 lb/hr FMS injectors new!
- LT1 non engine parts for sale
- Stock Z28 Hood Red
- eibach pro kit
- nitrous express maf plate with gm maf
- big vertical flow intercooler 3" inlet outlet
- LS1 Plate Style Nitrous Express Setup
- FTP 104mm lid and 100 TSP MAF w/ breather KIT
- LS6 Intake Manifold - ported
- MSD 8876 Adapter
- WTB Ls3 motor
- A/W Intercooler,Ice Water Tank, Transmission Cooler Ice Tank
- Corsa Xtreme for C6 WTT for Touring or Sport
- Polished C5 corvette bolt on tips
- Lt1 racing parts(y-pipe)
- MTI Airlid
- Brand New Ported L76 Intake
- 02 camaro hood
- comp cams sigle bolt ls3 cam fs
- Mickey Thompson ET Drag 28/10.5/15S
