View Full Version : Parts Classifieds
- Gray Interior Parts 98+ Trans Am
- Nitrous Outlet 92mm plate, Wilson single nozzle kit,10lb bottle & more-CHEAP w/PICS!
- Harland sharp LS Rockers
- Fast 92 Intake for sale
- 1 Black & 1 Silver LS1/Silver C5 Ported and Polished Throttle body FS
- race car part out
- MTI Lid for 98-02 LS1 (Does not have AIR port)
- ***Nano Nitrous Kit W/Bottle FOR SALE***
- 1997 camaro gauge cluster 150 mph
- ported edelbrock vic jr with arrons elbow
- LS6 Xhaust Manifold gaskets
- Ls1 block, heads, Hooker, Volant, Crane and more!
- McLeod Clutch Adjustable Master
- For sale motive 342 gears
- McLeod Bellhousing New
- SPEC Billet Flywheel
- SPEC 3 Clutch Used in good condition
- ***Lonnies Performance Double Pumper Kit FOR SALE***
- OFI Turbo Headers
- 5.3 complete intake to oil pan
- Firebird Hatch Red w/ tint!
- 93-95 lt1 o2 sensor extensions (flat connector) driver and pass side
- 05 silverado part out!!!
- LSX and SBC garage clean out
- K&N Air Filter
- Fuddle 3600 Stall, 4l60e, a4 harness and computer
- MTI Air Lid
- 799 heads
- ls1 coolant pipe stock
- Walbro GSS340
- FS; LSX Tall Deck Block Brand New
- C5 LS6 / LS1 Ported Throttle Body
- C6 Z06 Exhaust Manifolds, Mid Pipe's and Cats
- FS: SQ Audio system, more than complete for f-body
- Stock LS1 Parts For Sale
- T6 Truck Manifold Turbo Kit
- Harland Sharp LS1 rocker arms
- 01 Trans Am Steering Column
- WTT: My hotcam for your ASA
- Pioneer/Jegs Keyed Crankshaft Hub for 92-95 LT1
- LS3/LS7 42lb/hr Injectors 5500 miles
- Ms4 for sale
- LT1 Fuel injector retaining clips
- Ls1 Fuel injector retaining clips
- WTT SI6 cam for TR224/springs
- Fast90/90/HSW stand alone/NXL fogger/Longtubes/Nitrous/4l80e swap/A2w ice tank Fbody
- 02 WS6 body parts
- Tons of parts! Nitrous/STB/walbro/FTRA/rims/battery rel./etc etc
- rockers, PCM
- 5.3 truck oil pan, valley tray, pick up, and gasket
- WTT: 3k mile MS4 Cam for your smaller cam
- Rossler 4L80E transbrake and B&M pan
- ARP head bolts 97-03
- Pair of 15x8 Weld Drag Lites 4.5 bs 4.75 bolt pattern & 2 3" stainless Borla Mufflers
- ls1 throttle body, tps sensor, iac sensor
- Ls3 l99 l92 rocker arms with harland sharp bearing mod
- touched up CNC TFS 215cc LS1 heads
- OEM A4 Radiator
- 7.400 comp cam pushrods and new mls headgaskets
- ls1 shortblock
- Slp ram air kit
- Diamond pistons for 370ci w/pictures
- MSD Timing Retard Box
- Snow Methanol Stg.2 MAF kit / aluminum valve covers
- ls1 short block
- Summit (Eibach) LS1 F-body lowering springs
- FS: Magnaflow Exhaust for C5 Corvette #15660
- FS: Dynamat xtreme and 02 extensions
- 2 LY6 long blocks 5,200 and 16K miles (iron 6.0L with L92 heads)
- New Simens Deka Injectors
- Autotap AT1 with Usb Adapter and case
- Brand new Sealed Power ls1 piston rings.
- FS: C5 Sport Seats---Black
- FS: LS6 Intake, Ported/Polished/Powdercoated TB, Intake Gaskets
- 2000 SS M6 ECM - Tuned for boltons
- TNT F2 kit + extras w/2 bottles
- Magnaflow, ARH, misc NIB
- FS/FT thunder 7.4 pr's for 7.425
- Ebony Leather Seats - 02 Camaro
- 98 Shortblock, Brand new Ls6 cam&springs, Ls6 Caddy pan, Gauges, ect....
- LPP Longtubes & Y pipe
- Turbonetics 72mm Turbo NEW
- Please delete
- NOS super powershot, fogger nozzle, remote opener, full 20lb bottle
- F/S Flowmaster muffler with polished tailpipes SOLD ITEM!!
- 6.0l, swap mount adapters, alt relocate bracket, 4L80E
- Built Tremec T56 - LS1 Style (New Haven CT Area)
- $10 parts!
- 99 z28 stainless steal exhaust manifolds
- Hoosier Road Racing Dry & Wet Slicks
- Garage Sale
- For sale: Comp Cam
- Fs: Trans Am Door Badges
- 3.70 gears for sale
- LS1 electric fans for a 1998-2002 Fbody & LS2 Water Pump
- FS: Front Bumper Support
- RAM adjustable master
- 1999 Camaro z28 or SS Cluster
- Brand new MSD coils in the box
- Loaded Stealth Boxes, Pacesetter Shorties, and a few stock parts
- Fs: Fog Lights
- B & M z-gate shifter and METH kit
- comp camps XER281HR ls1/ls6
- CME tips and bends (re-list)
- l92 heads
- Fbody Turbo kit
- Set of mickey stickeys (four passes)/NIB lowering springs
- BFGoodrich G-force R1 315
- 02 Camaro SS Cats
- 10 SEC N/A 383 SBC For Sale
- Gauge cluster with white face gauges
- Autometer Gauges, Almost new
- *Like New* 97-02 Camaro Gauge Bezel w/lens
- stock ls1 parts
- ls1 longblock FS and added more parts!!!
- ls6 oil pump
- Valley Cover Gasket
- Corvette Trim Plate
- LT1 Cam Swap Parts
- Valve Cover Gaskets
- T56 Bell Housing for Fbody
- WTS: MSD digi retard box, window switch, tach, oil temp.
- TA Performance 12 Bolt Cover
- VIG 3600 Stall Converter (4L60E)
- *Used* LS1 Hypertech Power Programmer #30015
- FS: manley 7* steel retainers & locks
- Complete running LT1
- 317 Heads
- ls1 front rotors calipers brackets and pads
- LS9 / ZR1 injectors set of 8 new
- FS: LS1 engine
- PT88 Precision turbo .96 t4 $900 shipped
- MSD Programmable 6AL-2
- Titanium exhaust with polished tips off of an '03Z06
- Halo hidden dry Nitrous setup for 98-02
- oem and arp crank balancer bolts new
- FS: ~100 stock lugs, ~10 chrome caps, 19 black caps, $50shipped obo
- 4k Stall TCI LS1-Th400 converter
- 5.3
- 2005 5.3 706 heads
- LS1 Crank, & Rods
- Bmr rear lowering springs.
- ls6 intake and throttle body, 42# injectors
- Forged 370 FS
- Stock Monsoon Speakers
- AEM 30-1220 Plug and Play ECM
- LS FAST 90 With Direct Port Kit
- SOLD LS3 stageII intake with 90fast
- Fuel system
- FS: FAST Wideband - SOLD!!!
- FS: LM-2 Basic Wideband - SOLD!!!
- hooker cat back and pacesetter ory
- SLP catback
- Magnaflow Dual/Dual Tips. NEW
- Wtt torque arm mount.
- Coil Packs w/Harnesses and Brackets
- Center Bolt Valve Covers w/Bolts & Gaskets
- 2002 lq4 shortblock w/ covers, pan and pumps
- Nitrous for sell going F.I
- LS1/T56 pull out from 2000TA
- ARP head studs
- halltech
- FS: C5 Halltech Stinger intake
- fast 102mm cathedral port intake manifold PTM 102mm throttle body
- Holley 950 HP Carb Pt# 80496
- Untouched 5.3 heads
- FS: Koni Standard Adjustable Strut -New
- 2006 pontiac GTO / LS2 misc parts
- M/T 255/50/16's w/wheels
- Weld Draglites for Fbody
- Racetronix 32#(36# at LS1 pressure)Injectors NIB, FLP Headers and Catted Y
- Trans am badges
- *FS* NIB ECS Dual nozzle alky kit
- engine harness with pcm from 97 camaro ss m6 lt1
- Sbc lt1 lt4 tpi edelbrock roller cam kit comp lifters & pushrods
- Nitrous kit, window switch, NANO, New Bottle, ect..
- SLP 85mm MAF
- Z06 wheels
- HPE Megadeath cam
- vararam power duct, crane cam tunner
- LS6 intake pictures added.
- LT1 Dephi O2's, Strut Brace Fuel Noid
- LS1 Oil Pan, LS1 Coils W/ Brackets, New Camaro Fogs, Poly Engine Mounts, O2's, etc...
- Moser 9" Rear end 8,000 miles
- Throttle Body
- Polished 17x9/17x11 ZR1s
- Autometer Phantom Tranny Temp 2 1/16" Guage BOTH SOLD
- Ebony A4 Center Console Ls1
- "NOS" Nitrous kit for LS1 Engines with 15# Unused Bottle!!!!
- FAST bolts,spring perches,ly6 flywheel,more...
- 98-02 firebird trans am RAPTOR HOOD,brand new in box!!
- APS twin turbo kit
- NX style Nitrous jets for Direct Port
- Firebird/ta eurolights conversion w/fogs new
- Lt1 30lb injectors
- 15x8 Prostars w/MT ET Streets
- Arp studs (lt1)
- 90mm Nick Williams Throttle Body-SOLD
- *MINT* 97-02 Radio Bezel
- FS - Manley Pro Flow LS7 Valves
- Autometer Ultralite 2 5/8 fuel level gauge CHEAP!!!
- Stock LS2 injectors 33lb/hr
- Vararam CAI C6 Vette LS3 or LS7
- Leather C6 bra
- (2) black ZR1'S with tires 100 bucks
- Callies Racemaster forged LS stroker crank
- LS2 bare block for sale
- Comp 7.375" hardened pushrods
- Turbo headers, mandrel bends
- whisper Lid
- LS7 Lifters (500 miles on them)
- Brand New Bilstein Shocks
- New throwout bearing 17$ shipped
- 1999 rolling chassis and some parts
- Parting out my LTx 79 TA
- Factory parts
- For sale...again. FAST 90 - comes with 32lb injectors
- <<WTB>> aftermarket valve covers for L92's
- 4L60e Swap and C6 Z06 Wheels OEM
- Strange Front Drag Brakes & QA1 "R" Front Shocks
- bunch of SLP stuff NIB
- 450 RWHP LS1 Longblock
- Two vette Y2K 18 inch rims for sale
- MTX fbody thunderfoam sub
- FS- LS1 Intake Manifold, MAP sensor, EGR Plug
- tnt f1 nitrous kit $400 shipped
- B&M 70420Tork Master Torque Converter
- C6 mufflers and tips
- FS: 3in DMH E cutou
- Truck Oil Pan and Balancer
- Misc. Parts For Sale........
- PatrickG Custom Cam
- LT1 parts
- Factory fuel rail with return line.
- WTS: LQ9 Truck manifold, DWB throtle body, PCM
- BW s400 Turbo, Katech valvecovers, EV Carb hat, T6 Turbo merge
- Brand New SLP Bow-Tie Replacement Grille Matte Finish - 1998-2002 Camaro
- Crane Cams 144984-1 Double Row, Roller Timing Chain Set for LS1
- Comp Cams Gen III/LS1/LS6 RPM Valvetrain Upgrade Kit 54100
- FS: New LS7 flywheel
- SLP Smooth Bellow
- Granatelli 85mm MAF Sensor
- Racetronix Fuel Pump & Harness & Entire Sending Unit (Bucket)
- 17" Black Wheels/Tires, TA Spoiler, Stock 16" 5 Spokes REDUCED
- SS 10 Spokes Silver W/Tires Houston, TX
- 2000 ls1 ecu/wiring harness [6 speed]
- 95 LT1 ecm and engine harness
- FS/FT 4l60e built with 3000 vigilante stall,trade for t56
- FS: Nitto 555R 275/40/17 drag radials on C5 thin spoke rims
- BBK Underdrive Pulley & Belt
