View Full Version : Parts Classifieds
  1. Stock tan leather seats for trade
  2. FS/FT: 17x9.5 Chrome ZR1w/ 275/40 NT05R
  3. Turbo 400 trans
  4. Black 17" FM5's
  5. FS: T-top shades 97 98 99 gray
  6. Rims corvette 18 inch thin spokes
  7. 4L80E 2wd for sale
  8. FS LS1 25% UD balancer & belt
  9. For Sale: Stock LS2 Cam
  10. 2001 LS1 T56 Drivetrain
  11. FS: 22" wheels/tires for Trailblazer
  12. gto aps twin turbo kit
  13. procharger bracket
  14. GTO SLP Longtubes
  15. SLP LS1 ram air kit
  16. Nitrous Parts
  17. Aeromotive Eliminator Fuel Pump with fittings
  18. KOOKS stainless headers 1 7/8 -3"
  19. Victor JR w Fogger set up
  20. NEW Wegner front drive set up w msd distributor
  21. F1R Procharger system/cog drive
  22. New aeromotive fuel pressure regulator
  23. Set of Bogart D10 15" wheels with tires -- sale or trade
  24. Audio Equipment: Amp, Stealthbox, Flip out DVD and more
  25. 85mm descreened maf, ported 90mm fb tb
  26. LOWERED PRICE - GM 85mm 25168491 MAF Sensors, Truck Coils, Brackets & Harnesses :)
  27. siemens 60lb injectors
  28. New PAC 1518 springs. .650 lift
  29. New LT1 Crankshaft & New 4340 Scat Rods
  30. need to sell 2004 gto parts
  31. ls1 engine and tranny
  32. NIB hotchkis springs and panhard
  33. Camaro headlight mounting brackets
  34. Ported LS6 intake and TB **SOLD**
  35. FS: Yank PT4400 LS1/4L60E converter
  36. 18" c6 replicas w/tires SOLD!!
  37. BMR turbo K member, Meziere race pump, 317 heads
  38. C5r lsx na grudge or all motor class worthy small block motor
  39. DBW LS3 throttle body F/S
  40. Centerforce Dual Friction Clutch, LS3 Intake Manifold
  41. intake manifold from 99 gmc 2500
  42. 02+ LS6 5308 cam
  43. nitrous,TB,Fuel rails,valve covers
  44. hardened pushrods .080 7.750 new in box
  45. LT1 parts, Igntion parts, 60# injectors
  46. fast 92mm intake and fast 92mm throttlebody
  47. F1A Procharger w/pulleys (Crank and blower) Aster bracket and HD Belt
  48. wall 7.400 .080 harden push rods
  49. Mallory HyFire Box
  50. Wtt balanced 6.0 rotating assembly scat h beam,mahle
  51. ATI Damper Hub 916033
  52. ***OEM Firehawk hood*** with grilles, latches, hinges
  53. LS9 Valve Covers
  54. ls1 camaro throttle body
  55. f/s ls1 intake
  56. F/S like new walbro 255 intank fuel pump
  57. 4l60e core
  58. Truck manifolds, 6LE side splitters and rear splash guard planes
  59. FS: 35th Anniversary LE mats and more!!!!
  60. MT ET drag stiff wall 28x10.50 x15
  61. Turbo cam, springs, and HS roller rockers
  62. FAST injectors LS1 intake GTO oil pan 4.8 lsx motor
  63. NGK TR55GP plugs
  64. 6.0 Truck pans
  65. 98-02 camaro and firebird air filter
  66. Thunder Stroker V.3 camshaft
  67. Crane Cams valve spring tool
  68. FAST 90/NW90 W/42lb injectors&rail
  69. Track wheels, Cargo cover 4th gen and 3rd.
  70. T&D 20042 shaft mount 1.7 rockers, lightened
  71. brand new autometer digital tach shift light level 2
  72. Fresh HPS ported LS7 heads, SS valves, springs, as new ready to install
  73. LS1 Crank
  74. Slp lid and summitt ls1 roller rockers
  75. Factory WS6 Air Lid *MINT* W/ Lower Airbox and Tray
  76. LS1 MAF ends
  77. zo6 style wheels fs
  78. 4 18 x 12 CCW Classics for Corvette with DOT race Hoosiers
  79. 59cc Patriot stage 2 243's
  80. LS1 brakes Powdercoated orange/ hammertone black
  81. FS: Stage 4 Monster Clutch w/ 18 lb Billet flywheel
  82. Brand New in box Poly Motor Mounts
  83. SLP "smooth bellow"
  84. Coils and brackets
  85. Lq9 block pick up only
  86. M6 to A4 Swap Parts
  87. C5 z06 wheels for your.....
  88. Fs: 408 ls
  89. New AEM Wideband Air/Fuel UEGO Gauge Kit $175
  90. JE forged pistons
  91. Magnacharger TVS pulleys, RIP, COGS, 8 RIB, 6 RIB,
  92. Brush research flex hone
  93. PRC 243 heads and LS6 intake
  94. 06' C6 Cam
  95. Pfadt Carbon Fiber drive shaft FS - NIB
  96. Misc Parts
  97. 98-02 Thin WS6 Wheels and Tires
  98. NEW LE2 heads for sale
  99. LIQUIDATION! Mildly Built LS1/ Viper Spec T56/ Misc parts
  100. Stock ported t/b with tps
  101. WTB: Camaro Medium Grey Door Handle Bezels
  102. Egr and air system
  103. Airaid CAI for C6Z06
  104. 8.100 pushrods
  105. C6 wheels f/s or trade
  106. rebuilt lt1 7489 miles complete all accessories
  107. Autotap Scanner USB version
  108. WTB Skip Shift Pigtail
  109. LS2 Intake, Brand New LS3/LS6 Valve Springs
  110. Harland Sharp roller rockers 1.7 ratio & trick flow 5/16 chromoly push rods
  111. L92 heads for $500
  112. Go fast and stock parts
  113. LS3 Ported Intake!!!!!!!!
  114. diamond 661s, black wrinkle covers, kooks gaskets, rockers, oil pump, truck coils
  115. Cam motion nitrous cam
  116. 98-02 F-Body Hooker Headers w Y-pipe
  117. 2000 Corvette LS1 Intake Manifold - SOLD
  118. tea Trick Flow 215 cnc genx heads
  119. Aeromotive A1000 fuel pump
  120. WTT: 4L80E + $ for T56 or TR6060
  121. 2005 C6 exhaust mani. and cam 4 sale
  122. Rare Lq4 373 iron cylinder heads
  123. ARP Rod Bolts.. BNIB!
  124. Fuel pump stock
  125. parting out heads, cam, intake.......ect
  126. Vigilante 3200 and some 17 inch torque thrust wheels
  127. Gto oil pan
  128. FIC 42# injectors - high impedance
  129. Must Sell! NEW SLP Loudmouth Resonator
  130. LSx garage sale
  131. Real tial Q 50 mm bov
  132. FS: TSP Torquer V3 cam & Comp Cams XFI 236/242 .621/.615 116 LSA
  133. WTB: Chevy 1500 99-06 parts
  134. 28 spline locker w/ 3.42s $125
  135. misc camaro/firebird 82-02
  136. racestar wheels and m/t drag radials
  137. F Body Oil pan sold
  138. 243/LS6 heads Z06
  139. Fs: comp cams gem3 cam
  140. Hughes SFI Flexplate
  141. Complete LTX TURBO KIT FOR CAMARO, FIREBIRD, TRANS AM....COMPLETE
  142. FS: BNIB Nick Williams 102mm tb
  143. WTB corvette ACC drive
  144. 1980 Camaro Roller + other parts
  145. 85mm maf w/5-3pin connector
  146. 243 heads from a 2006 GTO 49,000 miles PRC .650 dual springs
  147. FOR SALE! 2 bar and 3 mar MAP sensors
  148. 4L60E from bone stock 00' Z28
  149. Nick Williams 92mm throttle body
  150. AFR 225 heads with PAC 1521 dual valve springs
  151. FS: SLP LT1 SS Spoiler
  152. Yella Terra 1.8 Non Adjustable roller rockers
  153. LS2 bare block for sale *Pictures Added*
  154. wtb ls1 m6 ash tray lid
  155. Srp pistons for lt1
  156. Complete Alkycontrol injection system
  157. LS3 Intake complete
  158. Lots of Perf parts for Lsx
  159. Nitrous Express wet kit
  160. NNBS Truck Flex Fuel Injectors - $100
  161. Never used Ingersoel Rand Air Drill (SOLD)
  162. Bottle bracket (spare tire well) (SOLD)
  163. Ls1 summitt roller rockers with arp bolts
  164. Badlandz Ecutout 3" (SOLD)
  165. Brand new park lights 98+ T/A (SOLD)
  166. want to buy t56
  167. Fuel Pressure Guage Autometer (SOLD)
  168. OEM Floormats practically new (SOLD)
  169. stock ls2 pistons/cam
  170. 2000 LS1 Parts for sale + Batwing
  171. ls1 intake manifold and/or EGR stuff
  172. KBRacing T6 S480 turbo kit
  173. set of C6 injectors.
  174. Nitrous Outlet Nitrous Kit Never Sprayed
  175. LT1 motor with harness and ecu
  176. LS1 Engine...almost complete...
  177. Sheet metal intake for sale!!!
  178. Bmr tubular k-member/ Strange S60 for f-body
  179. LS1 motor with t56 transmission pcm wiring harness for swap
  180. 1995 trans am complete part out m6!!!!
  181. FS: 2-Hoosier QTP
  182. wtb s10
  183. Strange engineering s60 rear for 4th gen camaro or firebirds
  184. 18x9 tsw nurburgring matte gunmetal
  185. GM LT1 ram air hood. CHEAP!
  186. RoadRunner ECU
  187. 90mm Corvette Throttle body
  188. Stock 2001 Corvette ECU
  189. 85mm MAF Descreened
  190. LS1 intkae and throttle body
  191. NOS Wet Kit
  192. NOS time-based progressive nitrous controller
  193. used ls7 lifters
  194. Sway bar front
  195. CCW Drag Pack for Chevy Corvette, GTO, or Camaro
  196. FS: LT1 K&N cold air intake
  197. Torque thrust M
  198. 98-99 y pipe
  199. parts off of a 1998 and 2000 firebird
  200. OEM SS Passenger Fender 98-02 Silver
  201. BBC and SBC For sale
  202. LS7 Fuel Rail Covers
  203. 7.400 .080 wall harden pushrods
  204. 35th floor mats
  205. Nitrous Express Nitrous 3 switch panel $20 shipped
  206. 24" O2 Extentions
  207. 2011 Brembo Brakes (Calipers & Rotors) 500 miles FRONT ONLY *PIC ADDED*
  208. FS:Vette C5 Trans Parts *Pictures Added 9/2*
  209. (((Truck and c5 exh. mani. ECM 56k ls1 engine, ls1 intake 4l60 and more for sale))))
  210. ls1 pro magnum rockers dyno time only
  211. Precision 67mm Front Mount Turbo Kit (PICS,VID,DYNO)PRICE DROP 2300
  212. LE2 241's, LS1 shortblock, TOTL, OEM Firehawk hood, 1.8 YT RR's
  213. 410 gears & bearings 4th gen
  214. ls6 intake
  215. Used 35mm front sway bar fits 1982-92 camaro/firebird
  216. Eibach pro lowering springs (82-92 camaro)
  217. Brand new in box A/C Condenser for 98-02 Camaro, looking for $70 + $5 shipping
  218. Koni adjustable struts and shocks 3rd gen
  219. Bosch 36lbs injectors
  220. FS:CCW Corsair Wheels-18x10 & 19x12 w/Nitto Invo's 295/35zr18's Front,325/30zr19 Rear
  221. !WTS/WTT Monster level 4 clutch for sale. price drop.
  222. Aluminum driveshaft
  223. Gauging Interest: TEA Ported FAST 102 Intake | Godspeed 102 Throttle Body
  224. ls6 intake complete and Harris Speed works N20
  225. Accel dfi LT1 computer system
  226. waterpump coils progressive contoller springs etc
  227. WTB:Vette Rims for Trans Am
  228. Parking brake shoe AC Delco 171-806 / GM 12455804
  229. FS: C5 Z06 wheels
  230. C6 Halltech Short Ram Intake
  231. FAST 42lb injectors
  232. lq4 truck manifolds for turbo build!
  233. 18x9, 18x11 IForged Flux C5 fitment
  234. FS PLX Kiwi Wifi OBD II Dongle for iPhone, iPod, iPad
  235. FS: 3 factoy amps 99-02
  236. FS: 2 gray driver side air bags, Passenger air bag
  237. Qa1 10" 150lb Rear coilover springs (for Wolfe springs perches)
  238. FS: Left door speaker driver side 2 wire non-monsoon
  239. 4l60E transmission
  240. FS: steering coupler shaft joint
  241. 2nd Gen 8.5 inch 10-bolt, Moser axles, new GM diff
  242. FS: gray rear seat belts 97-99
  243. no parts left to sell
  244. WTS/WTT: 3" Ory $90 Shipped **Traded**
  245. billet specialties 15x10 street lite rear only
  246. OEM 2002 WS6 Ram air hood 4 sale
  247. big stuff 3 ls1 efi system
  248. Spohn Bumpsteer Kit - Manual rack
  249. 3.42 GM ring and pinion
  250. ASA Cam package with 241 heads
