View Full Version : Parts Classifieds
  1. (2) magnaflow 5x8 mufflers oBO
  2. 18" Bridgestone RE760's brand new! 1 Front 1 Rear
  3. UPR GM LS1/2/3/6/7 to Mustang 4.6 Swap Engine Mount Adapter Plate Kit
  4. Melling 10295 oil pump fs
  5. D1SC and parts for sale
  6. on3 t76 turbo .81ar + spare .96ar housing
  7. painless wiring harness 12 circuit
  8. Tremec TKO 600 kit for 67-69 F Body
  9. L92/Heads/Cam/Gaskets
  10. Crane Cams 99473-1 Valve Spring Compressor
  11. PRC .650 dual springs
  12. Ls6 intake with drive by wire tb
  13. 2000 pewter ss roller minus rear
  14. Complete heads and Cam 6.0 LQ4
  15. FTP 104mm lid
  16. FS: BBK SSI intake manifold ls1/ls6
  17. Full 3.8 motor, trans, rearend for sale
  18. 2002 5.3 heads
  19. 17'' C5 Corvette Wheels + Nitto Drag Radials
  20. LS1 LS6 head stud kit
  21. AJE Strut Style Front end/kmember/wilwood brakes/manual rack
  22. Scat 6.125" H-beam rods with upgraded ARP2000 bolts
  23. SOLD...LS1 Intake and Ported Throttle Body
  24. (1) 17x9.5 & 17x11 chrome C4 ZR1
  25. LQ4 Stuff, DBW, LT1 heads
  26. Longtubes and True Duals
  27. FS: LS1/LS6 chain damper
  28. 8 Sec combo for sale complete!!!
  29. Black VFN Pin-on Sunoco Hood
  30. ls6 crossover tube and blockoffs
  31. Longtubes and True Duals
  32. cam/springs/pump/seats
  33. M&H 325/40/18 drag radials BRAND NEW Pickup ONLY in CT 500$
  34. Complete NX 102mm plate kit brand new with everything needed. 950$shipped
  35. zo6 maf and plug
  36. FS: 76 ball bearing turbo
  37. Yank PY3600 for 4L60E....$700 obo
  38. TMS stock low cost long block motors 5.3 5.7 and 6.0 now available with warranty
  39. Goodyear Gatorback Serp Belts NEW
  40. 2000 Hypertech Power Programmer 3
  41. BMR safety loop, Spohn LCA relos, 880 fog HIDs
  42. Vette LS 1 intake, 3 CH F body rear plates & brakes, a few LS parts
  43. FS: Corvette C5 4L80E Conversion Transmission Kit!
  44. 2001 LS1 6spd Drop Out SOLD SOLD SOLD SOLD
  45. LS6 intake and throttle body
  46. pair mickey thompson et gto wheels 17"!!
  47. weld pro stars
  48. LS1 T56 Engine Harness
  49. Parting out 35th anniv 2002 Camaro SS
  50. FS: G5X4 / Green Top 42# Injectors / 85mm MAF & Harness
  51. Pewter Camaro SS spoiler
  52. LT1 4L60e BTE stall
  53. Monster Stage 4 Clutch
  54. Ls7 maf, new in package. Ls7 cam
  55. Racestar Industries Dark Star Wheels (15x10 & 15x.3.5 - GM & Ford)
  56. New - 90mm LS3 TB and Torque Rush X-link
  57. Stock LM7 Injectors - 14000 miles
  58. 2 Sets of Injectors + Acceleronics Driver Box. 96lb and 120lb
  59. LS Meziere Water Pump. New In Box
  60. FS-Fikse FM5s, 17X9.5,17X11
  61. GTO parts
  62. FS: 4L80E Transmission, Converter, and flexplate $460
  63. Trickflow Push Rods 7.5" ***********
  64. Brand New HD timing set LS engine
  65. Partial part out, 1999 WS6 auto
  66. RPM Level 5 + T56 Transmission for C5 Corvette
  67. C5 corvette system DVD headunit/2 amps/wires/12'' kicker&box $1200 shipped
  68. pacesetter painted lt's with custom 3" under axel true duals
  69. Corvette 9" housing IRS LG drag spindle rear cradle and more!
  70. SPEC Stage 5 clutch New in Box
  71. 17' vette wheels (replicas) with two good tires and 2 bald
  72. 317 heads, 853 heads
  73. Auto Meter Gauges
  74. Ls1 Intake
  75. ls1 valve spring tool and 99-02 racetronix hotwire kit both new
  76. 5.3 heads milled/valve job ls1 valves patriot gold springs
  77. UMI th400 crossmember and mad man dipstick
  78. Kenne Bell Boost-a-Pump
  79. FS: LS1 Throttle Body to LS2 intake manifold adapter
  80. tci torque converter 3,000rpm
  81. comp valve train components
  82. Advanced Induction 226/234 112 cam
  83. Magnafuel filter
  84. Diablo Sport CMR 300 Tuning Software for MOPAR- Chrysler/Jeep/Dodge FOR SALE!
  85. Brand new SPEC stage 1 clutch
  86. 3" Fbody Magnaflow catback
  87. WS6 Lower Air Box & FTP 98mm Lid For Sale
  88. gm 5.3 turbo setup
  89. Siemens Deka 60# LS1 long style injectors
  90. FS: SubThump Stealth Box and TA Gauge Bezel
  91. AES Built 408 For Sale
  92. Big Block Chevy 489 Bottom End 4.25 Stroker
  93. 2005 take off LS truck coils, complete with brackets and wire harness
  94. left over ls swap parts
  95. Cable driven n/w tb 92mm
  96. P&P throttle body, Stock MAF, and wiring harness
  97. slp lid .
  98. 93-02 Fbody Interior
  99. **NEW** PRW High Flow Water Pump for LS Engines
  100. Christmas special $70 shipped. Escort G Timer GT-2
  101. SUM_1102 cam BNIB
  102. FS: AC vents, lower console, pass airbag. Etc.
  103. Vortech V2-SQ
  104. ls2/ls3 fuel rail, ls1 intake bolts, f body tb
  105. 2002 ls1 front accessories
  106. Procharger p1sc or d1sc
  107. stock 98-02 Camaro parts
  108. LSx Trickflow 235 heads and Cam motion camshaft for sale
  109. 1998 Red Camaro Z28 LS1 T56 Complete Dropout and ROLLER
  110. Aeromotive high pressure fuel regulator
  111. 806 heads
  112. Autometer high pressure electric fuel gauge
  113. Edlebrock fuel rails and Deatsch Werks Fuel injectors
  114. Accufab 4500 dominator throttle body and complete setup for sale!!!!
  115. Tick master and NOS 78mm plate
  116. 4th Gen QA 1 struts and shocks
  117. **ProLine Racing Billet Elbow**
  118. LS1 6 Speed Pedals
  119. FS ARH 1" 7/8 step to 2" headers/Y-pipe w/extras and UMI k-member
  120. SPEC Stage 3 Clutch and Lightweight Flywheel (SOLD)
  121. Ligenfelter/Wiend 80mm intake *Black*
  122. Ls Parts For Sale
  123. LS6 Intake Manifold setup
  124. Trade/sale/buy my c5z for your speedlines/tt2s
  125. ARP Head studs 234-4317 Ls series
  126. Spintech Super Pro Street Mufflers
  127. Plastic Gas Tank
  128. 2012 OEM corvette grand sport wheels and tires
  129. 18" wheels off 01 camaro
  130. F/S: 2001 Camaro Roller/Bare
  131. Wanted Monsoon cd player for 1999 Trans Am
  132. Pre 04 LQ4 short block
  133. FS Meziere LS1 Electric waterpump
  134. LingenFelter Performance 160 Degree Thermostat
  135. BNIB pro comp head stud kit sbc/lt1
  136. trans, heads, springs, and ALOT more!
  137. ls1 gto cam
  138. ls1 valve covers
  139. LS1 front calipers and brackets
  140. FS: Brand NEW MSD fuel pump booster/ regulator
  141. GM 3.42 gear set
  142. FS: Direct Port LS7 intake manifold
  143. FS: BMR STB and ws6 stock springs
  144. ls7 rockers with comp trunion upgrade
  145. Fs: Knock sensors
  146. WTS/WTT Ported 317 heads with .600 lift springs
  147. not for the weak hearted, and soft stomach
  148. ls parts, cams, headers, lifters clutch
  149. Parting out wrecked 98' Trans-Am convertable
  150. th350, crossmember, th400 spacer and mount
  151. Procharger D1SC setup
  152. Pushrods
  153. GMMG tips. Standard Slash Cut
  154. Comp Cams Banner
  155. 226/228 .588 .588 114 custom grind cam
  156. Ls2 intake/rails/injectors/gaskets/Map
  157. Abs box, throttle cable with cruise and tcs, and truck heat sink coils
  158. Gi: ported 862 5.3 heads
  159. Nitrous Gauges, Pills. Filter, ect...
  160. Hughes Powerglide, 2 speed, rated @ 1700hp
  161. FS/FT t6 fbody turbo kit(sold)
  162. fuel pressure regulator setup
  163. nitrous cheap!
  164. LS1 front and rear brakes, Ported TB, LS1 flywheel, LT1 parts, etc
  165. 275/60/15 Hoosier DRs *SOLD*
  166. 12 disc cd changer
  167. ZR1 wheels and LS7 intake
  168. PSI 1511 Springs, Lunati Titanium Retainers, Diamond Comps, Stinger
  169. FS: LS1 breather, catch can, bellows, Autotap, plus more...
  170. 1 year old Hooker Headers 1 3/4 & ORY
  171. PTC "Race" 3200 Stall 10'' (maybe more) idk ---taking offers
  172. 98-02 Camaro CME Valance
  173. Lt1 hooker headers/y pipe. T56 lt1 wiring harness/ecu Parting out cars and trucks
  174. Turboetics Racegate PN 10307
  175. Iron Block 408 Shortblock, L92 Heads
  176. 10 Bolt parts
  177. 3 Sets of Cool wheels For Sale or Trade - Don't see these everyday!
  178. LS6 Intake Manifold
  179. WTS/WTT 2 Mickey Thompson ET Streets 28x11.5x16 (Additional pics)
  180. Act clutch, tick master and more
  181. complete LS1 motor
  182. $200 SHIPPED - CHEAP Hooker Super Competition Longtube Headers for 98-02 F-Bodies
  183. Tan Seats and Carpet Houston
  184. Sold!: SLP Strut Tower Brace for LS1 Fbody
  185. LSx parts (new parts and prices added 08/19/12)
  186. 19" Iforged Classics
  187. QTP 3" Electric Cutout
  188. Pistons and other misc stuff
  189. lt1 hi tq starter and aftermarket summit brand hub
  190. *SOLD*: Meziere Electric Water Pump
  191. TSP L92 LS3 cam 3 bolt, 8401 and 7.4 Hardened PR
  192. Textralia Exo-skel twin disc clutch SOLD
  193. LY7 Rotating assy
  194. SLP Line Lock, SLP shift knob
  195. LQ4 parts, covers, mounts, exhaust mani, TB, water pump...and more! CHEAP
  196. Green Tops and Bosch O2's
  197. 383 rotating assembly Callies/Mahle
  198. SDPC/Vengeance Racing LS2 402
  199. F/S 243 heads, 317 heads...sold
  200. Autometer phantom boost gauge
  201. refurbished LT1 CSR electric waterpump
  202. Motiv 4.10's lightly used
  203. 6LE chrome ac trim rings ,6LE double din adapter , k&n, shift knob adapter
  204. FS: "Genuine" GM Corvette C6 wheels (excellent condition)
  205. Ls1 rear brake set-up
  206. Procharger D1SC - New in the Box - Fbody - Head unit
  207. Summer Garage Sale
  208. Koni DA and SA rear shocks
  209. 2012,2002 headers etc... camaro ac compressor etc...
  210. Alpine Head Unit, Kicker Speakers, JL Audio Subs
  211. Bunch Of GTO Parts Forsale!
  212. 2003 Z06 Springs/Shocks, Hardbar Harness Bar, Weather Stripping
  213. YANK Eliminator 4000 stall 10 inch TH350 lt1 ls1 sbc
  214. denso o2 sensors
  215. tail lights, misc interior stuff, poly trans mount, flexplate, CHEAP
  216. Glasstek 4" Cowl Hood 98-02 Camaro $200
  217. prc 2.5 5.3 heads & ls6 intake
  218. 99-00 pcm
  219. Billet Specialties Ultra Lite M/T street radials w/front runners
  220. Comp Cam 247/255 .624/.624 and LS2 Timing Set
  221. LS6 Intake, Fuel Rail, Injectors and TB
  222. Monsoon stereo and 12 disc CD player
  223. pac 1518 beehives and patriot golds
  224. New 99-02 ractronix hotwire kit and misc parts
  225. some stuff laying around
  226. Weld Drag Lites FRONTS ONLY SKINNIES
  227. LS6 5.7,BES heads, long block
  228. TRADE: probox
  229. New B&M Pro Ratchet shifter
  230. Vortech LT1 Brackets
  231. New 75lb and 95lb Injectors
  232. LQ9 coil packs, brackets, and harness
  233. LS1 Hooker Longtube Headers
  234. Garage Cleanout
  235. Siemens 80 lb injectors
  236. SOLD! Random Technology Adjustable Torque Arm (Black)
  237. coil packs tach nitrous plate bbk intake l92 water pump lq4 short block
  238. Lq9 lq4 ecu harness stand alone
  239. El Torro 230/230 cam, 243 heads w new Patriot Golds and everything needed for swap>>>
  240. LIKE NEW Walbro 255 In-Line Fuel Pump
  241. Holly 90mm Throttle body
  242. Part out sale!!
  243. nitto drag radials-PRICE DROP
  244. $550 for used lowered setup
  245. 60lb Injectors
  246. FS Stock exhaust Make offer
  247. WELD ALUMASTAR FRONT WHEELS 15x3.5"
  248. Brand New F.A.S.T Air Fuel meter
  249. ls brake conversion
  250. Chrome ZR1's wheels with tires
