- 36 lb injectors
- Hooker Dual Exhaust Tips
- Trans Am
- FS:60lb Siemens injectors, NIB Eldebrock 2-peice timing cover,2.8 maggie pulley, ETC.
- LS-7 parts
- FIKSE FM5 with Drag radials and EXTRA tires -PICS!
- FS: LS1 forged Mahle pistons
- Patriot cam 226/226-585/585 on 112 SOLD!!!
- LQ9/LQ4 exhaust manifolds
- 241 heads, stock Ls parts (TN)
- Brand new comp cam 235-240
- 2002 Firehawk Front Cap
- 243 Heads Brand New ** SOLD*
- 99 camaro ss 17" wheels
- OEwheels Chrome ZR1s
- 2000 Camaro Z28 cluster and connector
- complete steering column from a 2000 z28 6speed
- (2) Silver 16inch snowflake wheels off a 2000 camaro
- Fs/ft bbk 85mm throttle body almost new!
- FS:Procharger Surge Valve, AEM Meth Kit, Polished Alternator Tensioner(Flip Drive)
- Red w68 rear bumper piece and red firebird bumper
- 10 bolt cheap!
- SLP stainless long tube headers and more (UPDATED)
- Patriot Performance Dual Gold Springs, 7.400" Hardened Pushrods, 241 Heads
- ARP Headbolts PN 134-3610
- 85mm ls1 typhoon intake
- LS1 Short block and turbo parts- MICHIGAN ONLY
- C5R Valve Covers
- TCI 351110 LS starter
- LS6 valves and PRC .675 springs
- 5.3 truck manifolds FOR TURBO!
- Used Comp Cam 222/222
- New in box Futral Motorsports F13 Cam
- Practically new optima red top
- Z28 chrome wheels
- 42 lb green top injectors $200 shipped
- LS1 GTO K&N Typhoon CAI
- WANTED ls2 intake
- FS: TSP 231/236 cam $250 shipped
- ls1 coolant crossover pipe!! $35 shipped
- Vortech system head unite and brackets
- Pro 5.0 Shifter
- FS - Many parts
- mcloud rxt twin disk, auburn posi for 10 bolt and misc.
- 6LE CME Tips
- Need gone f-body parts
- LOTS OF PARTS: Yank 3600 SS, Nitto DR's, 4 chrome snowflake rims + Much more
- 4l80e Torque Converter
- WTB a s475 or s480 turbo
- Pacesetter Ceramic Headers
- WTT: NITROUS OUTLET 78mm plate kit for CNC'd 243's ****FOR SALE****
- 06 5.3 long block 90,000 miles Sold!!!
- SOLD SOLD SOLD "GTO Spare" Drag Rims with M&H Front Runners
- Eagle 4inch stroker crankshaft
- Corvette Headlight Assembly Passenger Side 1997-2004 C5 Flip Up Headlight
- 245/45/18 BFGoodrich g-Force T/A KDW NT
- FS Strange S60
- stock ls1 cam rods lifters springs and crank
- Comp 1.82 Rocker Arms
- FS: 07+ Truck/SUV P1SC Intercooled Procharger System
- Crank Spacer
- rockers/aem driver box
- LPW ultimate 7.5 girdle cover
- t76 turbonetics turbo/3" v-band/tig'ed 3-4(pics inside)
- NEW Kooks longtube headers W/catted Y
- 799 Heads LS6 valves
- Prices reduced Ls1 parts intercooler, a/c, heads
- 2004 gto russell braided fuel line NEW $20 shipped!
- Brand NEW LS6 crate motor for $2900! (longblock)
- ls1 parts
- SLP Blackwing lid FS/FT *mint*
- Weld Prostars
- polished accufab 4150 throttle body
- Coil packs, th400 swap, belt loops, Camaro knobs, NOS Iroc Z , NOS fuel rail covers
- '98-02 SLP Flowpac CAI ram air setup
- G2 Black Harness Bar
- 1.5" Black Corrugated Wire Loom
- Torque Thrust II's 17x9.5
- Zo6 stuff T/A Side Skirts CARTEK ECM z28 wing Walbro 255 F.A.S.T. Injectors Fuel Pump
- Ultimate Tensioner
- SOLD!! Built 4l80 with yank converter and conversion parts SOLD!!!
- Full 5 speed silverado setup FS
- Comp 230/234 Cam
- 85mm MAF $50!!
- FS: Hurst pistol grip, Moroso valve covers, couple cam and crank sensors....
- LC9 Aluminum block 5.3 w/ 243/799 heads
- Brand New Monster LV3 with used 18lb flywheel
- 42 LB LS3 Injectors
- pacesetter longtubes and ory
- MSD 3 step
- 02 Z06 Speedlines (seperate set of brand new rear tires)
- Vortech YSI head unit and brackets
- Rubber mounting Isolators
- Fs: Boost and fuel pressure gauges - cheap
- LS truck intakes
- M6 pedals,
- 2010 TR6060 Transmission 5k miles
- LS1 Hooker Headers w/Bullets
- Night Vison Goggle NVG
- new edelbrock 90mm throttle body loaded $180 shipped
- Ms3 cam sold
- built t56, zoom cluth, pro 5.0 shifter
- 823 heads
- WTB: One Comp 918 Spring
- UMI LCA's and Panhard Bar (Black)
- ls1 intake
- $500 10 spoke ss wheels powdercoated black for sale or trade
- ls1 intake soldd
- Scorpion Roller Rockers FS
- Wilson 90degree elbow
- Rockers, Stands, Bolts, Lifter trays, and lifters
- Ported Intake Manifolds and Throttle Bodies from Peak Speed Shop
- Custom Stroker/Blower Cam and Oil Pump
- MOTORAD ls1 160 thermostat
- 85mm GM MAF with 3-to-5 wire adaptor
- 78mm Plate Kit BNIB
- Precision/Garrett 4788 Turbo
- FS: OEM Polished C6 Z06 wheels/tires
- 99 Camaro ls1 m6 car, rolling chassis
- diamond racing pistons 4.065
- New Granatelli 255 LPH fuel pump
- 6-Speed automatic trans! What is it worth?
- FS: Fiberglass Camaro SS hood (silver)
- GMPP LS1/LS2 carb intake
- LS1 Radiator and AC Condensor
- '97-98 Corvette fuel rail covers NOS (GM#12556455 & 12559261)
- stock z28 grill, spare tire, jack
- 98-02 Original Silver Berger Panel
- Mickey Thompson 28x10.5w15 slicks
- Hurst Shifter Ball and T Handle Combo - SOLD
- v6 camaro parts for sale or trade for lt1 parts
- FS Koni adjustables and Strano springs 93-02 Fbody
- Gauging Intertest 2004 6.0L Truck Engine for sale
- 427 short block with low miles 24x reluctor SOLD
- Turbo werx scavenger pump
- 6.0 truck motor complete 2005
- Garage Clean up Parts - LS1
- eagles h-beam rods
- GTO Parts
- RC 75# injectors like new
- callies compstar h beam rods
- FS: Air-Air Intercooler FS: Pics
- FS: Kooks 1 7/8 Long tube Headers for LSX Swap in a Mustang
- 98 Camaro & 96 Trans Am Gauge Cluster
- Innovate LC1 / SSI4
- Fresh LS1 , vic,jr. 90deg elbow, 38 mm tial wg
- Corvette FPR (GM GF822)
- Brand new DMH 4" electric cutout!! Other f-body parts!
- intake elbow,fuel rails,fuel line kit
- ls6 intake
- 2002 Tahoe 5.3 L59 - Flex Fuel
- Edelbrock Fuel Rails - AN Fittings
- 2001 Camaro SS Dash and Top $125 Picked up
- Comp Cams SHaft Mount 1.7 Rocker Arms
- Patriot xtreme springs and Harland sharp 1.7 rockers for ls
- Vigilante 4400 stall FS/FT
- WTB: Supercharger, Procharger, Maggie, ETC
- FS: Complete 2002 Z28 drop out**low miles**
- kooks 1-7/8s
- LS1 Manifold W/ blocked EGR and Steam crossover
- FOR SALE: Stock 04-07 CTS-V air intake
- LS3 Intake, injectors, rails
- strange drag brake setup madman rack
- SLP LS6 intake
- Lunati Pro Series LS Stroker 4" Crank $675 Shipped
- Koni Single Adjustable Front Shocks F/S
- BeCool aluminum radiator and spal fans 93-02 Fbody
- For sale or trade Ms4
- GTO bellhousing, Windstar Fans, LY6 Leftovers
- Used (low miles) Spec stage 3 clutch $150 shipped
- Wilson Fuel Rails
- L76 pistons
- bunch of parts, MAF, heads, etc
- Manley/ total seal piston rings 4.000 file fit
- Siemens 60 lb injectors barely used
- Spal Fan, Trade?
- Dual Stage Nitrous Outlet plate 90mm
- Billet Specialties Street Lites 17x7 -15x10 & MT ET Street Radials
- Trickflow 7.400" 0.080" chomoloy pushrods
- Kurt urban steam vent adapters
- Crane Gold Race 1.8 Rockers & comp cams pushrods 175shipped
- Melling M295 oil pump!! Sold!!!
- 98-02 Camaro/Firebird Springs
- 10 Bolt 342 Gears
- 2006 GTO LS2 & T56 Take Out
- TCI Flexplate
- 2001 ls1 long block
- 4l60E and converter NJ pick up only
- LSx F-body turbo plumbing C6/truck mani hybrid, keeps AC
- Buying drag radials need 18s
- 1998-2002 camaro black billet grille with plastic piece.perfect shape,WTT slp grille
- FS: LS1 block, valley cover with breather, intake gaskets!!
- T56 tranny LT1 FOR SALE and Ram Clutch
- Fs Nw 92mm throttle body
- QM600 LS7 cam
- Polished Procharger D1SC & Intercooler - Reverse Rotation
- Crankcase Breather
- LSX 6.0L Bare Iron Block **NEW**
- Chevrolet Racing LS valve covers/ custom painted
- lt1 partout
- sold
- 98-02 Ram Air Lid Base & Stock Fuel Rails
- SOLD C5 Z06 sway bars
- BRAND NEW! moser 9" 4.56's, strange center, detroit locker
- SOLD C5 TSW Nurburgring Matte Gunmetal wheels/tires
- WTB 1998 Camaro Tan Leather Front Seats
- NIB GM 7.5/7.625 Differential/Pinion bearings
- FS: Delco Pioneer CD 12 Disc Magazine Cartridge.
- California cam for sale! & Ford Racing, set of 8, 36lb.hr. skinny injectors
- Hypertech PP III and Crane/Vinci hand tuner
- MN12 6 Speed Trans from '05 GTO
- Fuel rail covers, valve covers, catch can etc
- Brand New Procharger Plenum
- Wings West Trans Am body kit, Firehawk style hood,Enkei V1's, Door Panels
- FS: ls1 lifters
- T56 Tick Performance Stage 2 Complete manual swap!!
- 4 Stock 17" 2006 GTO Wheels
- spectacle solutions air lid's
- 01 Camaro Z28 Black/Ebony Part Out(updated)*Lots of Parts Left*
- SOLD SOLD SOLD **PRICE DROP** OEM 2002 Black SS Hood
- Camaro cowl hood, t-tops, rear hatch for sale.
- MSD Wires
- 14 Patriot Gold Springs (Springs only)
- Assembled LT1 heads w/ 5 angle valve job and light porting.
- *SOLD* f-body ARH ORY off road y-pipe used $280 shipped (pic)
- Built 347 Shortblock and Trans
- LS6 Block needed!
- Stock LS1 Parts
- Black Widow Direct Port Nitrous for Fast Intake *Updated Price*
- strange 12bolt housing,gauges nitrous,motor mounts,roller rockers,ls7fuel rail,inject
- Monster Lvl3 Clutch Set
- Stock LS1 / LQ9 Parts FS or Trade
- FS:BMR Rad.support,160* tstat *NEW*, TR6s,Bosch starter *NEW*,Barry Grant Fuel Cooler
- FS: SDCE aluminum dual fan shroud with SPAL fans, made for Procharger fitting!
- FS: Vortech MaxFlow BPV.
- FS: Procharger Air pump/Cruise control relocation bracket.
- SOLD! FS: Procharger MODIFIED J bracket... no slip!
- (!!!SOLD!!!) New Texas Speed 1 7/8 Stainless Headers w/ gaskets + extensions
- 2001 Firebird 3.8L Engine/4L60E Transmission Dropout (PARTOUT)
- MWC Solid Motor Mounts
- LS6 DBW TBs, 220/244 Comp Cam, Pushrods, LY6 parts
- Raptor shift light NIB Green
- New Bullet Camshaft, Bolt-Together Neal Chance Converter
- LS1 PCM, EV6 injector pigtails and 5.3L injectors
- 643 bare lt1 heads
- FS/FT: 2004 GTO Oil Pan, Windage Tray, Pickup Complete!
- FS: BBK Long tubes with ORY , brand new!!
- new texas speed cam kit.
- WTB: Nick Williams 102MM throttlebody
