View Full Version : Parts Classifieds
  1. 1978-1981 G-Body LS engine swap mount kit 107-0018-60
  2. MOOG Ball joints, Tie rods, brand new alternator and scanner!
  3. FS: 12 bolt 4.56 gears & Strange spool
  4. Fresh 468 big block chevrolet ! ! ! !
  5. LS1 Motor/Trans with GOODIES
  6. Diret port kit with stand alone and controller
  7. need any gm big block 8100 8.1L parts
  8. New GM Crankshaft Flexplate Spacer and bolts
  9. Trailblazer ss intake
  10. tremec t56 transmission 13-86-020
  11. wipers parts, wipers, arms, trans, mount everything
  12. Gaskets, Stock parts from cam swap
  13. FS: Front seats and exhaust tips
  14. Fel-Pro MS 98016 T
  15. WS6 Lower airbox 4 Sale
  16. l92 accesories 6l80
  17. Megasquirt, EFI stuff, turbo stuff for sale..LOOK!!
  18. 2ea 0411 PCMs
  19. (((STS Meth Race Pump)))
  20. Diamond 4.8 forged pistons, 4.8 crank, 5.3 Aluminum block, LS6 valley cover
  21. FS - Trick flow pushrods 7.45" 0.080 wall
  22. PS return line for use with gm PS cooler
  23. Rear bumper cover for sale
  24. WTB: Alternator Bracket
  25. Kooks 1-7/8" x 3" Race Headers | Kooks Catted 3" Y-Pipe With Flowmaster Merge
  26. Black C4 ZR1 Replicas 17x11
  27. Energy Suspension 3.1108G trans mount
  28. Kevko Oil Pan, Cam Motion Hyd Roller Cam, JP Single 4X Timing Set, LS1 PCM, LS3 fly
  29. BMR Xtreme Torque Arm
  30. HP Tuners MPVI Pro Interface
  31. WTS-Wheels-Chrome 10 Spokes-Chrome Z06's with tires
  32. New (2) mt et street 2 315/35 17
  33. lq4 wiring harness's and pcm and misc
  34. valve covers, cam, lifters, pushrods, rocker arms
  35. 90mm NOS Plate Kit, complete
  36. Aeromotive a1000 FPR
  37. 10 bolt alum rear end cover with girdle
  38. TSP Texas Giant Camshaft
  39. Texas Speed Magic Stick 4 239/242 .649"/.609"
  40. Stock LS3 short block
  41. Slp double roller timing set.
  42. Black trans am air bag
  43. Random parts 241's,lt1 t56 parts...etc.
  44. 2005-2007 LS2 LS7 Throttlebody Drive by Wire
  45. Lingenfelter 100mm MAF and the harness
  46. F1-R head unit with 48 tooth cog pulley and belt
  47. fbody accessories
  48. LS7 Cylinder heads
  49. FS:Corvette Mcleod Clutch,Zr1 wheels, PRT exhaust etc
  50. LS6 coolant crossover/plugs SOLD
  51. trans am/ camaro sub enclosure, Massive audio subs
  52. UMI Drive Shaft Safety Loop
  53. 402ci or bigger stroker cam 251 dur
  54. RPM 2800 Stall
  55. Lt1 t56 build part out
  56. 799 heads
  57. LS1 goodies. slp pulley, mti x1 cam, ls6 ported oil pump
  58. Varrstoen Wheels 5x120
  59. SLP Lt1 Intake
  60. 241 heads, arp head studs, ls1 block(bad rod bearing), pushrods, front cover, valley
  61. Dynomax muffler
  62. C6 Z06 Front Brake setup
  63. C5 Procharger P1SC1 kit for sale
  64. C5 Z06 rims and tires
  65. Milled 241 heads
  66. ls1 powerbond pulley,new in box
  67. FS: ID850's
  68. LT1 T56 Bellhousing, Mid Plate, Input Shaft
  69. Aerospace brakes
  70. ls6 intake,t/b,injectors,rails
  71. 35 Spline Moser Axles & Spool for 12 bolts
  72. L92 823 Heads 26918 Spiings Titanium Retainers Seats Seals LS3 Intake 227/231 Cam
  73. Ported and unmilled LS1 heads 853
  74. P1sc for sale or trade
  75. New 3.5" DMH cutout
  76. FS: OEM 19" G8 GT Wheels W/O Tires
  77. 1999 Z28 Part Out
  78. looking for chevelle ls swap headers
  79. brand new pat g cam
  80. Griffin Radiator (typical turbo radiator)
  81. 8.5" posi gm 10 bolt
  82. 410 stroker short block
  83. Precision 7675 Turbo .96 a/r BRAND NEW
  84. Wtb 42lb injectors
  85. WTB 17" ccw classics
  86. Forged Mahle Pistons
  87. stuff 4sale! Need this stuff gone....
  88. Twin fuel pumps/bucket from CTS V
  89. F/S: 48 lb/hr injectors at 43.5 psi with EV1 connector and 8.5/8.6 3.73 gears
  90. Clarion NX501 7-Inch Multimedia Control Station
  91. Custom 12" Subwoofer Box for 93-02 Camaro/Firebird
  92. Kooks Catted 05/06 GTO Mid Pipes with DMH Electric Low Profile Cutouts
  93. Complete LS6 intake/TB SOLD
  94. '01 F-body LS1/A4 harness and PCM
  95. Mint red Z06 fuel rail covers
  96. stock throttle body
  97. New lower balljoint/inner tierod/upper balljoint
  98. Complete Aeromotive A1000 system Check it out!
  99. Spec flywheel and Super twin disc
  100. slp headers
  101. Strano Upper Control Arm Offset Bushings
  102. LPW Ultimate 7.5 rearend support cover
  103. C6 c5 Corvette chassis LS3 drivetrain
  104. 317s, Fresh from the machine shop
  105. Chrome 5 Spoke Wheels
  106. 275-50-15 M/T E.T. street radial tires
  107. fs or trade LT1 trans am TAILS
  108. FS: LS2portworks ported TBSS Intake manifold
  109. LS engine swap temperature sender for old GM cars/ U14 gauges
  110. LQ9 GM Gen III Truck Ported Throttle Body, Fuel Rails and injectors
  111. WTS Stock & Aftermarket Parts(Lugs, Spec Clutch, Flywheel, Springs, Rods etc)
  112. 2000 Trans AM Auto ECU
  113. 102 mm nick williams throttle body
  114. 440 - 454 LSx rotating assembly Wiseco forged & Scat H-beam
  115. Six speed console cut for auto shifter
  116. BMR driveshaft safety loop
  117. 2004 LQ4 Engine
  118. 20" Eagle alloy rims/tires
  119. GM OEM 16" Z28 wheels 245/50/16 Goodyear Eagle F1's
  120. fti 4000 stall for 4l60e and 4l65e must go
  121. WS6 Lower Air box and Whisper Lid
  122. LS7 specific rocker arm bolts
  123. lots of c5 parts in NY. wheel, tires, K&N, etc
  124. Forrester Racing Billet Aluminum Tensioner
  125. Truck manifolds, non-EGR
  126. ls3 swapped c5 full part out back to stock
  127. 1998-2002 Silver OEM Camaro SS Hood
  128. LS1 power steering pump, lines, bracket and bolts
  129. Hsw 78mm plate kit brand new
  130. beginner tuning the right way
  131. Truck Coils
  132. T6 Flanges, bends etc
  133. Grey T6 turbo blanket
  134. F/S: My complete SLP ZL402 - All Hi-Po parts
  135. Monsoon Radio, and 12 disc CD changer
  136. Ported Heads, Harlan Sharp Arms, Lifters, and Pushrods
  137. Pt-88
  138. 98-02 camaro/firebird EGR lines
  139. LS Lunati Cam 237/243 600" 113lsa
  140. Camaro SS Grill
  141. flowmatched Bosch SVO Green Top 42lb injectors
  142. Max flow ss mufflers, mandrel bends, 12200411, 100mm housing, spare parts
  143. Brand new LS3 heads complete and used ls3 intake
  144. S60 Detroit locker Carrier with ABS ring
  145. 99-04 Hypertech (vette/fbody) + 2.5" Magnaflow rectangle tips
  146. Madman Wheelie Bars
  147. F/S 2003 C5 Corvette Getrag 3.15 rear diff 3 rib case
  148. 80lb. Deka/Siemens Injectors, Solid Tensioner, & Billet Fuel Rails For Sale!!
  149. 99 trans am part out in ohio NO MOTOR/TRANS
  150. Kooks headers and mid pipe w/cutouts GTO
  151. CNC Brake Clutch Levers for CBR1000rr & CB1000r
  152. Nitrous outlet plate
  153. 17 x 4.5 Weld Racing RTS
  154. rocker arms with trunion kit installed
  155. Firesale! Ported Fast 92; 275 MT DRs; 600hp catback
  156. 98-02 brand new pacesetter y pipe
  157. LS1 Short block
  158. LS parts for sale
  159. FS: 05-06 Borla Catback w/5in tips
  160. ls1 ls2 parts
  161. lsx G-Body turbo hotside T4
  162. T76 Turbo(Chinese)
  163. Micro squirt 8ft harness
  164. RPM Level 4 T56
  165. ls2 parts and gto and gto spare
  166. Autometer Gauges
  167. Manley Stock size Ls1 intake Valves 2.08
  168. Lt1/ls1 parts CHEAP CHEAP CHEAP
  169. Custom 3" Stainless Turbo exhaust Made off Huron Kit
  170. Pontiac GTO parts for sale!!!
  171. Racetronix LT1 Fuel Pump Power Harness
  172. LS6 intake and ported throttle body
  173. Bosch 80lb injectors
  174. LS1 & 5.3 injectors
  175. De-Mod Sale, Procharger, ARH, SNOW performance, DSS axles, Pfadt, ADM
  176. WTB aftermarket ls1 intake
  177. LS6 Manifold Painted Gloss Black
  178. Warhawk ls, ETP LS7 Warhawk heads, Callies Magnum 4" crank
  179. FS: Comp Cam
  180. Comp Cams LS XER281HR 232/234 .595/.598 112LSA
  181. wtb champion 15x10 7.5 backspace speed series wheels
  182. GTO Oil Pan
  183. jba catless mids for 05-06 gto
  184. 98-02 Camaro/Firebird LS6 Intake, Fuel Rails, Injectors
  185. 98-02 F body D&D rebuilt T56, Centerforce clutch and aluminium driveshaft.
  186. Bunch of misc. SBC/BBC parts,carb, springs, distributor
  187. 4.065" JE pistons and pins on LS3 rods with ARP bolts
  188. Nitrous Outlet 78mm plate kit NEW SAVE $$$
  189. 98-02 camaro/firebird EGR lines
  190. 98-02 camaro/firebird AC Lines
  191. 98-02 camaro/firebird Coolant Crossover Tube
  192. 98-02 Camaro/Firebird Alternator
  193. 98-02 Camaro/Firebird AC Compressor
  194. FAST 102 for Cathedral port
  195. ls1 modded engine for sale/or maybe part out
  196. Ls2 manifold lg ported
  197. 18/19 x 9.5" Brand New Matte Black Miro 111
  198. Comp Cam 251/259 .62x/.62x 113+4 BRIAN TOOLEY Spec BRAND NEW
  199. FTI 9" Nitrous/Nasty N/A converter!!!
  200. Fog lights, bcm with ignition/key headlight switch, head light assemblies, A4 parts
  201. ARP Studs main & head, Pushrods, Cometic, Corvette FRC's, Connecting Rods
  202. 2003-08 350z Stereo CD player
  203. Full tan leather f body interior for sale or trade for ebony leather
  204. FS TSP 100mm maf, zo6 maf and ft 98mm lid
  205. S10 LS swap LT headers, fbody & vette parts left over
  206. bbk LT1 shortie headers
  207. Street/ strip TH350 transmission
  208. Corbeau VX 2000 seats FS & 82-02 F-body mounting brackets
  209. LS6 Intake SOLD
  210. slp springs
  211. New Derale 13261 transmission cooler
  212. Parting out complete 04 CTS-V
  213. Parting out complete 04 CTS-V
  214. Lots of parts for sale!!!
  215. 275/40/17 Eagle F1 GS Tires FS
  216. BMR Suspension parts,Stall converter
  217. f/s stock coil packs,stock cats,stock fuel rails,procharger idler
  218. Brian toodlley double springs and fast 46 lbs injectors
  219. COMP .675 Dual Spring Kit
  220. Parting out 2006 gto ........ will ship
  221. LS7 Heads / Cam / exhaust
  222. Some Stock & Performance Parts
  223. LS2 GTO Alternator (Need to replace clip)
  224. LS1 auto belt tension adjuster, Perimiter bolt valve covers
  225. Wtt/wtb
  226. 4.030 lq9 fs/trade
  227. 1500 series silverado clutch pedal conversion parts - 200$ obo shipped to main 48
  228. brand new autometer cobalt boost gauge
  229. hotchkis stb for ls1 f body brand new!
  230. Compstar H-beams brand new
  231. 2001-2002 Exhuast Manifold
  232. Lt1 Cast Iron 290
  233. Edelbrock 7139 Cathedral Port High Rise Manifold Ported/Polished & 3629 Fuel Rails
  234. LS2 oil pan, valley cover, front and rear covers, crank pulley
  235. tnt nitrous bottle plus extras PRICE REDUCED
  236. WTT Vigalante 4000 for a tighter converter
  237. Monster Clutch Bogart RTs & 317 heads
  238. Price Drop! Camaro Gray leather seats front and rear no rips
  239. 2000 Trans Am WS6 Complete Part Out
  240. 98-02 f-body power steering pump,SLP air lid
  241. TNT 150 Nitrous kit
  242. misc. parts. ls1
  243. ARP LS1 stud kit, Comp Cams 7.40 pushrods
  244. 383 Crank/Rods, Suspension, Heads, Stock, Body
  245. Hidden Hitch for Fbody
  246. trickflow cnc'd 215s
  247. LS2 Water Pump
  248. hardend chromoly 7.400 Trick Flow pushrod
  249. Tick Master LS6 Cam and more.
  250. Harland Sharp LS7 1.8 roller rockers
