View Full Version : Manual Transmission
  1. Is my clutch slipping
  2. How much HP can a spec 2 handle?
  3. Like I shifted into reverse...
  4. 1996 z28, putting in spec stage 3 clutch what else
  5. Slippage in 5th right after trans reinstall
  6. what do i need to do to make ls1 t56 to a lt1 t56
  7. [Q]how to remove clutch master-cyl hose
  8. Noise coming from bellhousing when clutch peddal is depressed.
  9. I am normally an auto guy, but considering getting a t56 car...
  10. clutch smells AWFUL at WOT!
  11. mcleod clutch for ls1 opinions please!!
  12. Clutch torque specs
  13. how long will it take to swap to m6 with a lift
  14. Tranny hissing
  15. Vert .vs Coupe chassis difference (pics) - Does your coupe have these?
  16. What would it cost?
  17. How Much For A Stock T56 Rebuild?
  18. need new clutch, im not gonna make more than 400rwhp, zo6 kit ok?
  19. Spec stage 2 Disk with stock pressure plate?
  20. Is g-force the only way to go for 1000+ rwhp?
  21. gm slave or ram slave
  22. how much should I bleed clutch?
  23. Who all use a harlan 2 step with M6 ?
  24. LS6 clutch still chattering after 1500 miles
  25. 5th is weak is that normal??
  26. 800 Horsepower 8000rpm Manual Tranny Needed
  27. pulled trans last night
  28. PN Throwout bearing connection
  29. Drill Mod / Adjustable OEM Master
  30. PN for LS6 throwout bearing and pilot bushing?
  31. T56 Rebuild
  32. Mcloed =P O S
  33. Tranny issues when cold..
  34. OK< HERES THE "CLUTCH" PROBLEM
  35. need help bad.
  36. T56 connection
  37. is the mm6 and t56 transmission the same transmission
  38. Clutch help
  39. T56 swap hard?
  40. buddys 6 speed ..
  41. No, my slave was not leaking!!!
  42. Master Or Slave?
  43. will aftermarket shifter reduce et in the 1/4?
  44. 408 Stroker, trans????
  45. Dynamat for shifter vibrations (Install Pics)
  46. Vibration problem
  47. stock knob fitment on short stick.
  48. Source for core T-56's? I need a good rebuilder
  49. TKO 600 to LS6 for TVR
  50. Pull M6 tranny out, what's the procedure?
  51. Slave cylinder connection
  52. Help!
  53. Stock Z06 Clutch
  54. Did my slave cylinder die?
  55. Rebuilt Transmission
  56. rear pinion seal not on??
  57. broken trans??
  58. T56 reverse lockout
  59. Anyone have a pic of the ram master?
  60. Shim with SPEC clutches...where does it go
  61. what is weong with my tranny this time!
  62. clutch time!!!! help
  63. installing Spec 3 what else to change
  64. Can you change the stick on a Ripper?
  65. Resizing the length of Ripper shifter shaft
  66. Stock Clutch w/ heads/cam: how will it hold?
  67. Black mud, time to change Master Cyl fluid?
  68. shifters?
  69. bleed the slave cyl?
  70. Recommended RAM pn's
  71. 4l60E to 6 SPEED
  72. anyone know the dry weight of the t56 and the dimensions
  73. Stuck in gear, then popped out?
  74. Help beef up my tranny!
  75. Clutch? Worn out?
  76. with mcleod twin disk is new TO bearing needed?
  77. LS1/LT1 T56 Difference
  78. 6 Speed shifters Which One?
  79. Automatic -> Manual... whats involved?
  80. Does anyone have pics of the inside of a T56?
  81. Spec Stage 4, need some help
  82. should i buy this clutch?
  83. What's the deal with 6th gear??
  84. trouble with clutch?
  85. T56 rebuild question
  86. Easy way to bleed clutch lines w/out removal?
  87. New 06 Z06 clutch??
  88. anyone know gear ratios for f-body T56?
  89. Multiple problems
  90. stock 2001 clutch
  91. Your opinions on the best clutch for....
  92. Shifter ID
  93. Need best price advice
  94. McLeod master leaking
  95. Damaged Clutch Disc?
  96. Spec 3 Enough For H/C + Spray?
  97. Hurst shiffter better or worse??
  98. "Drill Mod" good or bad ??
  99. M6 Conversion
  100. Which clutch do you recommend?
  101. Spec billet steel flywheel, lighter than stock?
  102. Spec Aluminum Pressure Plate??
  103. *Sale* TTP Stage 3 A-K Built T56 Trans Ends 1/31
  104. replaced my stock hurst shifter with a hurst probillet i have some coments and ques
  105. Is my slave leaking??
  106. Was the factory Hurst shifter avail in the 98 T/A's?
  107. Ferrari style gate shifter
  108. Clutch Engagement Point.
  109. whats the difference in materials?
  110. What's Wrong With This Car?
  111. speedo is wrong how do i fix?
  112. Max holding power for t56
  113. more tranny mount woes
  114. Use thread lock on the bolts for aftermarket shifter sticks!
  115. question
  116. Shifting at Low RPM, found CAGS?
  117. missing a shift..
  118. Best Place to order Spec Stage 1 ???
  119. shifter install
  120. how does a dual disc clutch work
  121. RAM powergrip HD stage 4
  122. M6 drag guys get in here...
  123. T5 Clutch adjustment
  124. What Clutch to get?
  125. sure could use some help troubleshooting...
  126. clutch problems....or i think...help fast!!
  127. For racing which is better short stick or..?
  128. Clunking, banging?
  129. adj master cylinder
  130. McLeod SFI bellhousing installed...pics/info within
  131. New clutch in, but pedal sits low and grinds
  132. What's up with getting the clutch master out!!!
  133. Is the exody triple disc out yet and who has one?
  134. clutch decision
  135. Problem with clutch return spring, need help
  136. Need help deciding on clutch, narrowed it down
  137. Is this an aftermarket hurst unit? Please help
  138. customer service on ram clutches?
  139. Anyone heard of Luk clutches?
  140. Shifter Boot
  141. Are Gear Sets Interchangeable
  142. manual transmission for truck
  143. Shifters
  144. wondering whats goin on...
  145. Running a Jerico?
  146. What fluid for new tranny?
  147. Are ram clutches good on LT1's?
  148. Do you have to replace Slave Cylinder -w- Clutch???
  149. 2nd gear help
  150. What are you road course and circle track guys using for a clutch?
  151. installation of shift light
  152. Quick Stick or LSS
  153. Are SPEC stage 1's any good?
  154. clutch and throwout question.
  155. Spec 3 shim or no shim?
  156. Hays Steel Billet Flywheel?
  157. who else makes shift knobs?
  158. HELP!!! What shifter to choose
  159. clutch question
  160. 2nd blown slave in 2 days
  161. How hard is it?
  162. converson
  163. drivetrain question=@390rwtq
  164. What else is new... Clutch problems!
  165. Problems in the Tranny
  166. whats a good short thrower shifter
  167. Trans mount question
  168. what does this sound like
  169. clutch advice ?
  170. swap help...
  171. Well, put in polyurethane trannymount and....
  172. requesting comments on shifters
  173. prob with short shifter
  174. Should the hydrualic line going into slave cylinder move?
  175. suspicious noise under my right arm
  176. Good grief, spec stage 3, 3i now the i is f...
  177. wheres the cheapest place for a 2002+ Z06 clutch?
  178. Anyone bought a T56 from ESP101?
  179. Pro 5.0 Question
  180. bleeding clutch problems... HELP!
  181. Z06 clutch can hold 490 ft lbs!!??
  182. Clutch sticking/slipping Need advice.
  183. Does anyone make/sell the solid slider keys?
  184. Help me to buy a T5 WC transmission.
  185. UMI short stick with pictures
  186. What kind of clutch to get?
  187. Tailshaft Bushing problem
  188. Noise engaging 1st gear, only when cold?.?.?.?
  189. 6 speed reverse problems-HELP
  190. clutch problems
  191. downshifted into 2nd at 80mph!!!!!
  192. Hard shifting, Need Experts within...
  193. 500rwhp ok on a stock T56 in a truck?
  194. bleeding question
  195. How to remove T56?
  196. thinking about going m6 and junking the a3
  197. Need some help from the experts
  198. Clutch Engangement Point?
  199. Whats the going rate on a used T56?
  200. Christmas day problem!
  201. where to get the good rebuild kit for our m6's??
  202. short stick for hurst billet????
  203. Converting to manual from automatic
  204. another shifting problem
  205. Anyone running SPEC 5?
  206. SPEC Stage 4
  207. Ram Clutch Nightmare
  208. LT1 to LS1 T56 parts conversion
  209. Flywheel Help!
  210. T5WC on a LS1?
  211. 3rd and 4th gear acting weird
  212. aluminum or iron flywheel????!!!!!
  213. Pro 5.0 question
  214. What's Wrong With My Tranny!
  215. T56 third gear and drill mod question
  216. Does McLeod make good clutches?
  217. Help with vibration
  218. pro 5.0
  219. LT1 hydraulic upgrade?
  220. what a mess-this sux
  221. I'm going to put a Mcleod bellhousing on soon...I'll document it for everyone
  222. Where can I buy a Jarrods Short Stick?
  223. Cartek clutch anyone using it ????
  224. What You Guys Think Of This One...?
  225. M6 with Spec stage 3
  226. Ram 910 vs 980
  227. BAD rearend noise!
  228. Is the hydraulics upgrade on the Spec Stage 3 necessary ???
  229. salve problems please help
  230. Clutch problem
  231. What clutches are SFI approved?
  232. Manual gearbox and 1000bhp+++
  233. New T/A with a squeaky clutch
  234. Z06 Clutch Kit p/n?
  235. What kind of Power/Torque can a t5 take?
  236. Weird noise
  237. new clutch????
  238. Will a 168 tooth SBC F/W work with the LT1 T56
  239. squeeking noise from clutch when letting it out
  240. grinding often
  241. High RPM Shifting
  242. McLeod Slave Cylinder (Yes Slave)
  243. Exedy multi plate clutch vs. Spec Stage 5
  244. How many clutches have u changed?
  245. What's the part # for the LS1 hydrolic line or where to get it???
  246. help with tranny please
  247. LSS Bolt size
  248. Help With Tranny
  249. Z06 clutch on a F-body?
  250. Noisy clutch...
