- M6 Swap...Quick Wiring Question
- putting a iron block that was in a auto truck in my M6 SS?
- clutch pedal sticks to the floor
- warrenty info on spec?
- Lenco or Liberty
- Sanity Check my clutch decision, please.
- bleeding new slave/ blew out seal???
- Which LSS model to get?
- How much use have you got out of your LS6 clutch setup?
- What's the weak link?
- HELP: Drivetrain vibration.
- clutch wanted
- How to tell which master!?
- 3rd and 4th gear grinding...(THE ANSWER TO HOW AND WHY)
- Clutch Install Costs?
- I need a budget clutch...
- broke my spec III?
- Help find me a thread/link on clutch install please
- rebuilt m6 stiff to go into gear after racing?
- What Are Signs of Crappy-Bled Clutch Hydraulics?
- All Aftermarket clutch owners come in
- T56 Master cylinder vs Slave cylinder info
- What slave cylinder do I need to get?
- What kind of clutch is this ?
- Is this the right one?
- using a Viper T-56 in our cars?
- GM part number for LS6 clutch kit?
- looking to buy a camaro.. what to watch out for in the t-56?
- Do I really need to get a new flywheel?
- RAM 980 Chattering
- question about 1/4 times
- Do I need anything else?
- Bit the bullet and ordred a Mc Leod twin disk
- Tranny question answers please
- Spec 3 Owners please...come inside
- Dropping the Transmission, How HARD is it??
- Feelin' stoopid but...
- Final word, whats the fix for a mushy pedal?
- slave cylinder bad?
- gto knob on stock shifter???
- About to order clutch, should I get kevlar or carbon?
- 3rd gear grinding, 3rd & 4th gear rattling noise
- how much did you cut off the pro 5.0 shifter?
- Mcleod Bellhousing???
- gm part # for slave cylinder
- Hurst black 6 speed pattern shift knob pic
- Need a TailShaft housing
- Slave / Master Problem????
- Just ordered Lou's short stick!
- sticking in reverse.??
- clutch problems
- Spec 3 = better 60ft. times?
- What kinda 60ft times???
- T56. help
- which short throw shifter is better?
- Couple easy questions pertaining to replacing the clutch and slave cylinder
- Spec Stage 2 Problem; Slipping After 2000 Miles
- Broken output shaft
- Rebuild 6 speed 2k C5 - Do it myself?
- actualy travel length of rod on master???
- which way do i turn my adj master
- replacing clutch...Is there anyone that recommends the Spec Stage III
- Shift Point?
- What Kind of clutch to get???
- The replacement!
- What possible causes for a changing engagment point?
- Opinions on the best clutch/shifter setup!!
- Bleeding Spec 3.
- Bleeding my Clutch? Spec 3
- Need a place to get a built mn6!
- Rear-end gearing?
- Syncro application ? All t-56's the same ?
- Decel noise just started yesterday..
- what is the best shifter?
- HELP! tranny mount....
- Could my trany handle 425hp?
- rebuild tranny
- spacers or shims, do they help
- T56 Swap for a Cleveland.
- Help...
- Spec Clutch sliping.
- T56 rebuild
- ls1 noob with trans problems
- What do I need?
- Should i M6 it?
- How Much HP will the T-56 Handle?
- LS1 T56 jumping out of reverse! HELP!
- Cluthc engagement points changing
- making M6 Solid?
- Spec clutch chatter
- Will a RAM powergrip require an adj master or shims?
- 95 Camaro LS1 retrofit
- how to remove master cyl in vette?
- New Clutch+Flywheel- Balance??
- Ram VDS in LT1
- opinions from those who have ran BOTH 3.73's and 4.10's.
- slave cylinder
- Grinding in first gear.
- Tranny ?
- Tranny Question??
- got new clutch in,but now need help with trans.
- Attn San Antonio area guys clutch prob
- Details on A4-->M6 conversion
- G force T56
- "Clutch needed" post, again..
- CTS-V Drill mod? fluid?
- how to remove line for DRILL MOD
- ram stage 4 910 need adj. master?
- Slave Cylinder Warranty work ? Or not?
- DTC 0704 - Any Advice?
- 7,000 rpm shifts...shift light, or tach w/ light?
- Mcleod Lt Dual Disc Clutch For Sale!!
- Shifter installation problem! Help!
- Clutch Pedal not coming up all the time
- jss from factory z28 shifter
- SPEC St 3 on ebay????
- Anyone in IL looking to help with Tranny
- instaling a new bearing in the front of the input shaft on a t 56
- master cylinder rod and retainer clip ?
- Need help finding a stupid little part
- wasn't the shift fork...
- how to bleed clutch/ new slave
- Buschman clutch bleeding procedure
- clutch wants to grab WAY to soon.. need help
- Dumb problem and i'm tired of it!
- Rock Crusher 4-speed In A 4th Gen?
- 3rd gear grind?
- Confused on gears and trans.
- Clunking sound?
- need help with clutch!!! stuck...
- Nasty Grind!
- has the cartech clutch been forgotten?
- question
- RAM 980 Impressions
- Who makes billet slider keys?
- Clutch Problem Help
- Do I need a rebuild?
- need a clutch!!
- Auto to a 6 speed? anyone want to trade ;)
- Car STICKS at certain RPMs?
- Still have problem after bleeding clutch
- Clutch Bleeding and Dirty Fluid!?!?
- Another clutch question??
- Spec 3 In; Shifting Problems
- Raidiator Question
- Clutch Inhibit Switch and RAM 402/980
- 5th gear question... 6th seems fine
- Spec 3i vs. Spec 5
- Drill mod and nitrous?
- Anybody have experience with a Spec Stg. V?
- Average lifespan of a Spec 3?
- I think my stock clutch is starting to slip but... I only have 8,500 miles > wtf?
- Clutch Question
- What did I blow up?
- Who makes a good tranny mount for the t56?
- t-56 question
- Any Drag racers using the Exedy Dual Clutch??
- Ok to start car with very low tranny fluid?
- Gear Whinning in Tranny T56
- shifter change
- Please help...clutch pedal issue...
- Faster et's with new clutch/flywheel
- What RPM to launch at with McLeod Twin Disc
- Heeeeeeelppppppp
- clutch pedal travel
- spec stage 3 question
- What would it take
- Jesus christ look at my flywheel
- Tranny Fluid
- if you have done the 6spd conv step in***
- Big clunk when shifting into second?
- magnet??
- RAM clutch recommendation for my Hawk
- Thickness of stock flywheel
- RAM Fitment Issues
- Question about a conversion - tranny specific
- Friction plate ques?
- Posi Traction
- Grinding feeling when I downshift
- proper break in for luk clutch
- What's the deal with 3rd gear?
- 4.10 gears...should I go lower?
- T56 Moving under acceleration?
- Swap is finally complete.
- 6th got stuck
- Steel shift forks???
- Spec Alignment
- Adjsuting stops in Hurst Billet Plus
- which clutch?
- Pressure problem
- spec stage 3
- clutch chatter/vibration
- Clutch Question
- g force triple cone sycros
- left car for tint and now loose clutch pedal!
- Resurfacing Flywheel,Plz Come In =)
- is it neccessary to update a 00 slave to a 01 slave?
- Racing a Manual Trans
- whats about to break?
- good cluch
- I'm going nuts with clutch problems
- what fuild to put in tranny?
- trans install ????
- Fed up with Hydraulic clutches. Anyone have any unusual leak experience?
- Tranny acting funny gimme some input please
- Clutch Questoins Please Help.
- Application questions
- Clutch braided line
- After 1,200mi My Ram 910 Clutch Is Shot,what The Hell?
- pilot bearing IS NOT MOVING!!!!
- question about trans swap
- How much did you pay for your 6speed swap?
- How to connect tranny to engine, and ram install?
- Resurfacing Stock Flywheel
- Will Clutch Bleed Help Pedal Return in Extreme Hot Conditions?
- clutch pedal assembly?
- Who Has The Best Deal On A Stage 5 Spec Clutch....
- McLeod Adj. Master Solves Clutch Problem
- Perfect clutch line disconnect tool
- New clutch question
- Place to get MN12 gears for T56??
- Whats The Best Upgrade For T-56?
- Will my stock clutch be ok?
- How many are running McLeod steel bellhousings?
- question about the drill mod
- McCleod Adjustable Master Cyl. Instructions needed.
- Just bought Spec Stage II, worried..should of bought Stage 3I?
- Need help quickly if possible. part # for NEW revised c5 slave cylinder
- Fluid change question!!!
- Any Luck with Centerforce dual friction?
- What do I need?
- Luk Clutch kit.
- Is my tranny dead!?!?!
- HELP!!! I think I killed my transmission
- Please Help, Cant find Problem!
- After Three transmissions and 2 PRO 5.0's..............
- tailshaft housing sealant?
- SPEC Stg 3 installed!
- Did I mess anything up?
- Review of New Mods: Moser 12, Spec II, Pro 5.0, and Lou's short stick
- Gas Mileage
- Spec 3i kicks assssssssssss
- rattling shifter
- Clutch issues after cam swap.
- Ls1/ls6 Camaro/corvette Mcleod Dual Disc W/billet Flywheel!!!!!!!!!
- HELP Clutch pressure question...
- Whats wrong with my clutch?
- LT1 T56 on a Big Block?
- Reverse Gear Grinding
- stock clutch -- whats my problem?
