- doing the drill mod, need both 01 slave AND master hydrolics?
- ? about my spec stage 3
- What are your 60' times on street tires
- Bent master cylinder rod...
- anybody know..
- Spec Stage 4 w/aluminum flywheel aint bad at all
- manual tranny , fine in reverse, no-go forward
- Is this the right trans mount for our cars? *PIC*
- Ticking sound coming from Trans?
- T56 rebuild what parts to use
- Ram 402/910 guys inside plz...
- torque specs
- clutch noise???
- New Billet flywheel, slave, master?
- Please advise URGENT!
- Which flywheel?
- Newbie Questions.
- Those who have installed a RAM 402pp on a stock flywheel...
- Can someone from RAM confirm....
- Clutch wont engage after running it hard....
- Loud pop sound came from clutch pedal this morning
- gasket maker on shifter?
- Please help. Clutch won't disengage.
- Ram adjustable master cylinder
- clutch pedal problem
- where can i find a built manual trans
- Replaced Rear Seal, Still Leaking?
- Anyone replace the banjo fittings on the hydraulic system with AN fittings?
- Flywheel resurface in Chicago subs?
- replaced reverse lockout solenoid, now it doesn't lock!
- Trans Prob. Went to dealer.
- ZO6 upgrade
- Help me rebuild my T-56
- Is this a synchro problem or a clutch problem???
- Attention Mityvac experts!
- Anyone ever break a rear shock on a miss shift?
- Synthetic ATF in 00' Camaro
- NEED SOME INFO...drivetrain/clutch/rearend
- synthetic fluid
- I dont want it busting/clutch/drivetrain???
- is there a way to put a t-56 on a 351W
- Clutch disk break in time?
- Adjustable Master.....
- Who has a good 60ft on motor or spray with a 6 speed
- What happened to my Spec Clutch?
- Anyone shipped a tranny?
- Is it fine to slip the Spec 3 clutch at 5000 rpm? will that hurt the clutch?
- Why Are My Slave Cylinders Failing?
- Clutch Advice
- Help ID another tranny!
- Shuddering problem... Help!
- Pro 5.0 bolt question.
- Clanking during initial shifts??
- Drill Mod On Slave
- replacing clutch
- trans fluid????
- clutches n stuff
- Master cylinder question
- Spec clutch chatter???
- Is this the clutch for me?
- Need help, not sure whats wrong
- What does this problem sound like?
- What is wrong with my clutch ...
- Does stock C5 master need the drill mod??
- Does Spec have a website
- Rear end is????
- My opinion on the Spec stage 3I
- Can clutch slip?
- Shed a little light for me. General transmission problems.
- Dirty hydraulic fliud
- McLeod Master Cylinder .... Can it be rebuilt?
- Speedometer Cable
- Predator shift light
- Help!
- Just bought a Pro 5.0
- Symptoms of springs falling out of spec 3?
- will this work?
- Updating GM Clutch Hydraulics...Question
- Question about spec stg 3.
- Cost of a built T56.
- Changing Fluid, How much do I need?
- 02 ls6 clutch being installed
- Question about C5 t56 and fbody t56
- clutch issues
- Hydraulic Clutch Line
- I have went through 2 mcleod clutchs now going to a specs what stage shoud I get..
- T56 Transmission Question HELP!!!
- Stock clutch still holding up to 11.5 at 119mph run(check the video)
- drag cags
- Anyone did an A4 to M6 swap please help
- Centerforce Dual friction or Spec 3?
- Any Harlan 2 Step Users?
- 4.56 in a M6
- clutch pedal raises up on hard launches
- Crap!!!!
- How much power can the mcleod single disk hold?
- help with spec clutch
- Please help me with choosing clutch!
- Adjustable master cylinder, picture?
- pro 5.0 or b&m ripper?
- Got done breaking in SPEC Stage 3!!!
- can't shift into 2nd 4th or 6th
- Stock clutch replacement, any suggestions?
- Jumps out of 1st
- A damn good question!!!
- tranny problem..help
- Where to send a t56?
- Custom disconnect ring
- Anyone try the Exedy clutches??
- Automatic to manual swap with a twist
- Auto to Manual conversion
- What n' World Please Help
- Clutch problem
- Chatter at low RPM w/ stock setup
- distance of shifter
- Factory Hurst Shifter???
- Drill mod or Spec Stage III?
- Crap, I got air in Master Cyl. please help!
- Shim please :- )
- Royal Purple? Is it really worth it???
- Mcleod masters do they work fine these days??
- parts in the spec kit?
- clutch went out >=(
- spec or ram clutch
- M12 tranny in 2000 Trans Am?
- What tools do you need to replace pilot/throwout bearings?
- East Side Performance hooked me up!!!
- Where to put ATF in on a T56????
- T-56 upgrade/rebuild kits
- Worried about my Spec st 3, any others worthy?
- Custom built t 56
- Clutch chatter, an unexpected solution.
- squeaking clutch pedal
- Spec Stage 3 Clutch is slipping!
- installing clutch, need torque specs
- poping noise when disengauging clutch
- transmission seal part number
- Installing spec 3 need help asap (fast).
- Viper/Mustang T56 behind an LS1?
- Do I need new clutch, slave and Adj. master cyl?
- D and D tranny
- Keep missing third:(
- did anyone else use the SPec supplied shim?
- Clutch Problems
- How often to flush the clutch fluid?
- weight differences between clutches
- Probably been asked a million times but I can't find it. Any rebuild guides for T56?
- A little compatability help please
- Just installed Spec Stage 3!!
- Clutch/tranny problem!
- Is the torque arm bracket on the tail of the tranny the same on the m6 and a4?
- WTB: LS1 T56 parts, where to get them?
- RAM clutch or spec stage 3 ?
- Flywheel Help?
- clutch choice
- Is this ok for my t-56?
- Just installed my Mcleod Twin Disk
- Question about T56.. Fluid Lines
- i had something weird happen today shifted into rev when drivin
- 4th Gear Grind
- Shopping List Needed for Replacing '98 Stock Clutch
- spec 3 chatter disappears with mcleod master cylinder? Help!
- centerforce or spec???
- Hard to shift 1-2 at high rpms
- Rebuilding a C-5 Tranny????
- Shifiting problem??????
- Thread Size?
- Borg Warner 6 speed?
- How many have had problems with Spec III Clutches?
- 02 Hydraulics
- Spec Warranty ?
- 02 C5 Pressure plate and disc interchangable with 98 Z-28
- question about slave clyinder
- 3RD gear trauma/rebuild
- rebuild/upgrade parts for T-56?
- The Clutch Prob Post
- Will the Z06 clutch hold up too......?
- which shift knob with B&m
- shifter questions
- WHAT OIL for my M6????
- GM 3/4 shift-fork recall??
- T-56 Upgraded parts kit?
- Anyone test hp limits of McLeod single disk clutch? I'm about to myself....
- Leaky Tailshaft R&R
- Let me try LS1tech for my last plea of help
- Anyone tried the Steeda Tri-Ax Shifter?
- New Hurst shifter
- jss installed on stock hurst
- trouble making 1-2 shift
- few flywheel questions
- Need help selecting clutch....spec 3i?
- Roasted clutch with a side of 'pedal to the floor'?
- 650+rwhp- Spec 3i clutch hold???
- My Z06 clutch kit only came with three pressure plate bolts!! WTF?
- Clutch engagment point changes
- Attn: Camarohaulic- rebuilding tranny myself
- where to find a spec 3?
- 1st gear grind after clutch replace
- looking to buy shifter with shift stops???
- spec 3 breakin?
- spec 3 on near stock car
- Ran 11.6 at 118mph with stock clutch-gonna need a clutch soon help!
- Does my shifter have stops?
- Lost 5th gear, what happened?
- How to take off/put on a T56
- WTF, car still wont go into gear at high rpm's.
- throw out bearing? hydraulics?
- quick ?
- T56 Problem: 4th Gear Completely Stuck!!!!
- Leaky MC
- Do I need to lube the trans input spline?
- Lightweight Crossmember
- centerforce vs ls6 clutch
- clutch and shifter question
- Rebuild t56 myself or pay someone?
- ARP Flywheel Bolts - Loc-tite or no?
- SPEC III - Love it.
- Should I change clutch slave?
- Drill mod experience
- Spoke w/ a tech from Ram
- stock or aluminum flywheel?
- 11's on Stock Clutch and Stock Suspension?
- Cartek Clutch
- LT1 T56 behind a LS1??
- pulled a 1.64 60ft-what are you guys launching at?
- Good day of racing= SCREWED TRANSMISSION
- how hard is it to change the clutch
- Clutch sticks to the ground when driving hard?
- my A4 sucks! i want a M6
- Super Detailed T56 Rebuild Sequence Pix/Description
- B&M RIPPER REVERSE PROBLEM!!!!
- CUSTOM T56 in the works
- Transmission problem?
- is this normal
- Straight foward answer...
- T56 experts needed
- Call me crazy, but I think the factory Hurst has positive stops built into it.
- Spec Stage 3 or Stage 4 or Ram???
- Please HELP! Tranny Locked!!!
- Swappin Shifters, Pro5.0
- RAM 910 clutch installed!
- Is my T56 gone?????
- cheapest place to get a spec, and one more ???
- Anyone know the difference in these slaves
- RAM 910 or 980? what is website
- Centerforce dual friction
- 99 z28 manual transmission gears
- A few Q's about a m6
- Getting Spec Stg 3 - One ?
- Ever here of a broken tranny tail from TA?
