- a4 to m6 pilot
- Pilot Bearing
- t56 98 to 95 t56?
- c5 clutch install question
- Need Help: Don't Know If Its My Shifter or Transmission?
- what did i buy????
- Difficulty Getting Any Gear w/ Tick Master
- Total change in clutch feel, warning sign or just glazed?
- Shift rail guide bolts..
- t56 swap
- Trans/Clutch problems...help
- Slave dies after 2 days?
- trans mount nut
- Went to start car. Depressed clutch pedal. Twisted key. Car lurched forward!
- LS7 Clutch/pressure plate - Is it normal to be banged up?
- monster clutch
- Removing ls1 from an m6 Trans Am
- LT1 T56 w/ early SBC Using LT1 Flywheel
- yet another clutch hydraulic issue
- Road Racing Clutch Help
- clutch issues
- Fix Hydraulics
- Clutch question
- Hydralics
- Let's talk clutches
- manual guys feel free to check out this poll
- CYBER MONDAY at TICK PERFORMANCE: 15% off ALL SPEC Clutches with FREE Shipping!
- will a ls9 clutch assembly fit a 4th gen
- Is there a smooth cluch for 600-800 hp out there ?
- Sticking Pedal??
- 98z28
- T56 annoying bolts!
- Transmission noob, trans is making me worry
- LS to LT
- 1-2 Shift fork pads
- will drill mod help this???
- Need help finding correct slip yoke. 30 spline t56
- History of Problems. Long read but help is appreciated!
- Um, is this possible????
- Anyone use 5th gear in the 1/4?
- t56 good or bad idea for around 800hp?
- t56 grinding in reverse
- just ordered my tick master and speedbleeder
- threads on pro 5.0 handle
- Price Question
- RPM Transmissions - Cyber Monday Sale 2011!!!
- Best place for dogringed T56?
- transmission T5 standard for LT1??
- transmission standard for LT1
- Where can I buy the #6 rubber shift boot?
- 2011 HOLIDAY SALE: $100 OFF Monster Clutches and FREE Shipping!
- Poly trans mount question
- Need Help Choosing Clutch
- Throwout Bearing??
- clacking noise coming from shifter?
- 94 LT1 6 speed Trans
- LT1 camaro standard
- Firm clutch pedal, still possibly air?
- how difficult is it to replace 5-6 syncro?
- Monster Clutch Co. Holiday Sale!
- What type of fluid should I put in my T5 transmission
- Replacement Slave cylinder
- What is the best clutch for the money for a stock 99 SS?
- Never EVER Buy A RAM Clutch!
- Reverse lockout gone willing have a check engine light??
- 1967 Camaro Small block T56 Swap Help
- Another Tick MC adustment question
- I need a beer
- What would my T-56 go for?
- OK, I'm diving right in.....
- Replacing Clutch Questions
- which t56 magnum for ls376/525 and 3.15 diff
- Can anyone help?
- HELP! changed clutch master cyl zero pedal pressure
- Clutch Suggestions for Z28 w/ Bolt Ons?
- Ls1 Slave with z06 ls2 flywheel question
- Spec 3 problems
- firm now soft clutch pedal?
- 10.5" GM Bellhousing and Clutch
- 3rd gear
- Difficulty Shifting in Reverse
- Any one have a LS1 t56 input shaft??
- Aluminum flywheel on McLoed Street Twin?
- t-56 magnum in an 02 z28??
- Clutch fitment question!
- DIY Rebuild Help: Testing the trans on the bench, it won't go into gears
- McLeod or Tick Clutch Master???
- LT1 T56 Rebuild question. *sponsors, tick, rpm flt, other companies*
- shift light
- McLeod RST or RXT for My Setup?
- How fast on a diamond clutch
- factory hurst shifter knob stuck on
- Burnout at the track causing hard clutch pedal.
- limp clutch pedal......
- LT1 T56 Trans
- Shiming Slave on f-body
- Wich t56 magnum ratio for 4:11 diff
- pedal sticks, is it slave or master cyl, at work no time to search
- More praise for the Tick Adjustable Master Cylinder
- Crazy Vibration
- Sticking clutch pedal, read sticky, clutch upgrade?
- Flywheel flex??
- Effect of flywheel weights?
- ls7 clutch question
- LQ4 + MN12 starter problem
- LT1 t56 Slave/Pivot fork issue
- How fast on radials
- Slave cylinder R&R in my garage on jackstands, am i crazy?
- LS7 clutch
- T56 magnum on lm7?
- Tick Performance Adjustable Master Group Purchase - FIRST 100 ORDERS ONLY Save $74+!
- Help! rock hard clutch pedal
- aftermarket shifters
- Will a triple disc clutch require more frequent shimming than a dual disc clutch?
- Sticking cluth pedal and fluid loss. Yes, I've read the stickies.
- Slave difference
- Master or slave?
- Transmission swap
- Issue with 2nd gear...
- Is there Aany clutch that will SHIFT PASSED 7000 RPM'S
- need info on a six speed swap
- need some advice. (jason over at tdp can chime in)
- T56 to handle 1000rwhp?
- clutch fitment problem
- how to move shifter back?
- Clutch or Trans?
- McLeod Twin Disk Street Clutch Cutaway
- Installing a pilot bearing with a drill, an axe, and a 2x4
- aluminum flywheel ?
- Replaced slave, no pedal pressure
- Is it time for a new clutch or ??
- Help me choose. T56 or auto
- M6 reverse issues.
- can you mix tranny fluid?
- T56 Parts
- Faceplated T56/SPEC 5/SFI Bell- Installed
- 2nd Gear Won't Engage
- where to buy a clutch bleeder valve.....
- Clutch/Master & Slave Suggestions?
- NV4500 Shifter Tower
- Best place for a 1-2 synchro blocker rings?
- t56 grinds 2nd gear
- trans swap???
- Odd Rattle coming from Shifter
- Two questions***
- Need new clutch. Trust Monster w/ 3rd clutch in less than 2 years???
- Broken Slave Bleed Fitting
- Transmission Experts needed!
- TKO 600 or T56, LS1 67 Camaro
- Thanks Jason and TDP!
- Clutch Replacement Question
- transmission question
- Difference between ws6 t56 and camaro t56?
- 2010 SS TR6060 into 4th Gen FBody (PICS)
- Best way to fill t56 with fluid on z06
- Trans fluid needs to be changed again?
- personal opinions: how difficult was your t56 rebuild
- Hurst shifter complete set up
- Maybe clutch?
- doesnt want to go into gear
- no 5th
- tr6060 and ls2
- TKO 500 vs t56 for camaro turbo
- Loud Scary Noise - Throw-Out Bearing Failure?
- T56 Upgraded Builds $850 shipped both ways!
- throw bearing
- Diamond Clutch $70-$90 OFF & FREE shipping!
- Firewall repair????
- Fastest stock bottom end 6-speed?
- Clutch chatter
- Pilot Bearing Will NOT Come Out!
- Faceplating Questions
- Ram or Tick master?
- 600+ TQ What Clutch?
- Replacing my slave cylinder, should i replace my clutch/flywheel?
- replacing tail housing in the car?
- upgrading trans.. whats a good kit to buy?
- Cutch issues....replacement?
- LS7 Clutch Help!
- RXT shimming?
- what clutch for my car
- How to tighten pressure plate bolts
- Odd Grinding noise occasionally with clutch disengaged
- C5 Throw Out Bearing
- FML blown trans - options
- any good t56 rebuilders on long island preferably close to 231
- New LUK Clutch, 'was' good. Now, Metal grinding/Clanking HELP
- Manual Tips and Tricks
- Is MGW Shifter Quiet?
- Conversion thread for C6 T56 to Fbody
- Anyone with experience on an Alum. FW on the McL Street Twin?
- WS6 short shift stick vs Speed Inc's
- New GTO just threw a code, clutch pedal position switch?
- Ram clutch question
- Master cylinder removal????
- Random pedal engagement
- T56 removal
- Clutch issues???
- Input Shaft bearing question
- completely bleed a clutch with just a mighty vac?
- Who needs a twin or triple...
- What happened to my clutch....? [PICS]
- 4l60e converted to t56
- Hurst shifter
- opinion on used ls1/clutch issues
- Clutch for LT1
- Manual & Auto; same tranny mount?
- Clutch Decision Made
- Textralia Exo-skel issues - slipping, not fully engaging
- T56 pops out of reverse?!
- Clutch Sticking to Floor
- LS7 clutch pressure plate bolts, ARP?
- what clutch is this?
- Custom built T56 32-spline SSR/Ford/LS1 F-body Hybrid
- Intermittent Clutch Issues!
- Duralast slave cylinder.. anyone?
- Clutch Slippage?? Please Help??
- Monster stg 3 round 2 Q's!
- t56 Case Differences
- Attn McLeod RST/XT users:CHECK stack height on clutch before installing!(blown motor)
- R&R clutch master cylinder... any tips
- High RPM shift issues... Please help!!!!
- RP Syncromax
- Need help diagnosing a slave cylinder
- home made speed bleeder?
- Hawks Third Gen
- About the center console with Pro 5.0 installed....
- Trans Fluid
- ebay chromoly flywheel?
- Does anyone know what kind of shifter this is?
- WTB 6 Speed Console
- B & M Trick Shift?
- what causes a hard clutch pedal
- Inconsistant clutch :(
- BEST clutch for street strip LT1?
- How to use tickmaster speedbleeder
- t56 third gear
- LT1 T56 breaking clutch forks.
- T56 vibration after clutch install?
- T56 Carnage(W/Pics)
- Best Clutch options??
- T56 Limits..How fast and what power levels
- Did you Shim your Diamond clutch?
- Clutch disengage problem!
- WTB: T56 Bellhousing for LS1 DeLorean Swap
- transmission mount (m6) help!
- SPEC Stage 3 Clutch Finally installed, New Tailshaft on T-56
- BEST T56 to buy
- Stuck to Floor
- Ls7 clutch in a ws6??
