- Probs with the SPEC 3????
- Clutch balance?
- What do I need?
- weird smell
- How much does a stock LS1 T-56 weigh?
- Finished Spec Stage 3 install! A little pissed.
- Stock Hurst Vs. Aftermarket Shifters
- T56 whoas
- T56 whoas
- 1993 LT1 T56 swap into auto car
- Cheapest place to buy 01-02 slave cylinder???
- T56 rebuild price?
- i need help guys
- Car losing power on take off
- Losing Hydro pressure
- Another question bout spec stage 3
- Installing SPEC 3 in the morning!
- Question for those runnin the spec stage 3
- Drill mod/done to connector that hooks to master cylinder right
- Quick disconnect fitting on Slave cylinder
- 01-02 slave discontinued??
- Confusion on bleeding clutch.
- Need some help...*please*
- SWAPPING 1994 LT1 M6 into 1999 LS1 M6 Z28
- McLeod?
- Which flywheel for Clutchmasters clutch?
- My first T-56 rebuild is done.
- B&M Ripper Peeps Come IN.....
- What must be done to an LS1 T-56 to work in an LT1?
- Grinding noise.. not clutch
- Another Mcleod Test question (Bugsquawsher..anyone)
- Launching a 2000 Z-28 M-6?
- Nitro Dave's Performance fixed Clutch problem
- does a throwout bearing make noise
- What causes my M6 to whine?
- 6 speed swap?
- What does a throwout bearing look like?
- replacing slave, & part number for 01' slave
- LS1 and T5?
- Which McLeod CenterForce Clutch?
- what is needed to swap a '96 t56 into a ls1?
- Strange M6 problem. Need help
- clutch pedal sticking on cold mornings
- can i resurface my flywheel or do i have to buy a new one?
- Slave is blown...now what?
- Rattling Pro 5.0 w/MBA Knob and Lou's Short Stick.
- Anyone have the SLP short shifter?
- Problems with my T56
- how much is a 99 wrecked LS1 worth
- Output shaft on T56 Getting Sloppy Need Help
- questions before i attempt this
- M6 Tranny Crossmember part #
- Transmission Install Quick Question
- Clutch pedal stuck to floor - need help
- Master or slave problems
- Help....
- Questions about Spec Stage 3 Clutch
- Mcleod Clutch
- Need T-56 Transmission ASAP
- I'm converting to T56 on a 94Z
- Nut size on Mcleod MC for adjusting
- Spec 3 Warranty Question?
- getting mity vac can i bleed this while its on the car
- Spec Stg 3 and stock flywheel,OK????
- Spec 2 Vs Spec 3
- How much did your A4 to M6 conversion cost?
- Replacing the Tremec T56 with the Borg-Warner unit.
- Binding in transmission or rear end?
- Anyone using the Spec Stage 3i yet?
- Questions about spec stage III
- I have to swap my RAM clutch disks!
- help! clutch doesnt completely disengage
- question about poly trans mount?
- T56 from LT1 to an LS1
- question about new master
- 3rd synchro bad ?
- Could it be the shifter linkage?
- ls6 clutch on 99 Camaro SS ?
- Tranny Rebuild Help
- How well do the ten bolts hold w/ new clutch
- Question about what GM Service Manager told me.
- Shifter resistance
- What is the size for stock gear?
- Reverse Lock-out ??
- Need opinions on clutch for 00 ss camaro
- Slave Cylinders ???
- t56 rebuild - good place?
- strange shifting...asap...help
- Third gear slipping
- Um.. I cant spin 2nd ????
- Do the 01/02's have the Z06 clutch or not?
- Carbon Fiber Synchros
- McLoed is shipping bellhousings
- Interesting noise
- The "I" option on Spec clutches.
- Master cylinder part number
- How do I bleed the clutch.
- Leaking Fluid Please help.
- Rear End Whine
- Pro 5.0 shifter
- Pedal engagement question with New Spec 3
- Well I pulled the Slave and that's not it.
- newer slave???
- Holy F'n $hit Little help here...
- Internal or External slave cylinders?
- Car wont go into gear when the engine is on.
- Real clutch problem
- Will Z06 gears work in a Fbody T-56?
- Do you need to change out the Slave C shim with a Spec 3?
- Billet Flywheel
- Spec III LIfe Span??
- Problem with 2nd gear
- Dumb ??? But Need Help!!!
- people with spec stageIII COME IN!!!!!!!
- BIG PROBS with reverse
- Need Help!!!
- ANyone in Northeast Ohio Work on T56?!
- Flywheel Resurfacing in Houston
- WheelHoppin
- Can a T56 handle this?
- Won't go into 6th!!
- Anyone barking 4th gear??
- Is there a way to test slave without pulling transmission?
- Clutch Time
- Plastic ring for steel line to slave disconnect...
- Whine in M6 after getting on it
- Does anybody have a pic of a T-56
- Might be a clutch issue..
- Clutch wont disengage, please help
- Mcleod dual disc pressure plate bolt torque
- Help on picking clutch setup for my car?
- clutch
- Who can rebuild my T-56
- First impression of Mcleod twin disk
- clutch pedal vibrates
- NE1 Break a 10bolt With Stock Clutch????
- Spec Stage 3 Installed!!
- Why want my clutch pedal push in...
- Best price for the 01-02 slave cyl.????
- Can you bleed a MC while on car?
- Please help me with spec 3 clutch Break in procedure.
- How much horsepower can a LS6 clutch handle?
- Flywheels. Whats the diff.?
- RAM clutch user's inside.....
- How to adjust Mcleod master?
- Yank transmount/TA mount
- spec clutch is here, as is another question
- Ending the speculation: Blocker rings, who's had them fail?
- help with bleeding the clutch
- Mcleod Slave Cylinder
- Help me please
- Anyone ever do a before and after dyno with a TH400 swap?
- LS1 382 stroker / stock T56. Will it hold?
- Throwout bearing noisey
- something to keep me busy this weekend
- Anyone using a Spec Stg 3 w/98-00 hydraulics?
- Hate Stock Friction Point
- where can i buy the lou's short stick?
- When cold, I grind into 2nd gear, when warm, no grind.
- Manual Transmission People
- differences between spec 3 clutches
- shifter noises
- shifting problems
- Other parts
- Problems. Help!
- What is the smoothest shifting shifter?
- Buy new slave or keep the one I have
- Around how much for a clutch install?
- Clutch Recommendation for 420hp NA + 175-300 N20
- Opinion on a clutch
- Clutch Pedal Spring Noise
- if u know about clutch install please help
- Differences between Viper and F-body T56?
- shifting problem...
- 4th Gear Failure when Racing
- need some help
- Tranny issues at the track.. what could the problem be?
- WTF happened ?!?!?
- a4 to t56 swap i need trans and all help me
- Pops out of third gear.......
- Shifter question
- Rebuilding t-56
- Spec Stage 3 not holding
- White Lithium Grease???
- I'm a little confused now, clutch help please.
- What's the best shifter 6 speed
- T-56 Questions...
- New aet is slipping big time under load.
- Revlock work with Mcleod flywheel and plate?
- Ram Clutch Slipping
- rubber bushing on Hurst shifter
- Who/where in PA does T-56 rebuilds that will last?
- Group Purchase for the Spec 3 Clutch with billet steel flywheel?
- power level on t-56
- Help clutch slave cylinder.
- rebuilding fried T56
- t-56 in silverado z71?
- Tranny fluid: Type, Amount
- The Truth behind Adjustable masters
- Having problems shifting into any gear
- Spec Stage 3 with stock master and slave?
- Strange problem with clutch pedal feel...please offer suggestions
- Part # for nylon bushing in trans
- just ordered the spec stg3 from TTP
- A4/M6 swap, just a couple questions
- Spec 3-I?
- Brand new OEM flywheels $50
- Do they make plugs to go into the ....
- Where to get a new/used T-56
- Who runs Redline ATF in the MN6?
- new clutch slipping
- A-4 To T-56
- Clutch sliping
- What clutch to get.....
- Denny's NR DS Weight -Inside
- New spec clutch what should i get
- anybody want to trade A4 for M6 setup?
- stock clutch ?'s.....and what to get?
- Bellhousing Pressure plate contact
- Master Cylinder Decision
- Help need with Ram install
- P/N for pilot bearing?
- Paging Ram 910 users...
- Pioneer Trans Mount
- Clutch Engagement is near full release of clutch pedal
- Bleeding: new ram master, new slave
- bent shift fork?
- Pro 5.0 install question...
- WTB: Braided slave cylinder line, where to get one?
- 11-10 second guys, what suspension tricks do you run on the street?
- HELP! on take-offs and shifts=hard thump under my car
- How will a RAM 910 disk hold up with 700+rwhp and how long?
- High RPM shifting Problem
- how to install new clutch cylinder
- Who's got the best deal on SPEC cluthces?
- who sells a mean t56 or sells solid parts?
- who makes a beefed up T-56?
- Corvette shift knob fit F-body?
- just installed!!!!
- 1st Gear Problem
- Aftermarket Shifters
- bad throwout bearing????
- 3rd gear vibration
- installing short stick
- Spec III or Spec IV??
- Question about flywheel
- Whats wrong with my t-56?
- I need a clutch for 700+hp
- Installed Hurst shifter, car wont start......
- please help!!!!!
