View Full Version : Manual Transmission
  1. High RPM shifting Problem
  2. how to install new clutch cylinder
  3. Who's got the best deal on SPEC cluthces?
  4. who sells a mean t56 or sells solid parts?
  5. who makes a beefed up T-56?
  6. Corvette shift knob fit F-body?
  7. just installed!!!!
  8. 1st Gear Problem
  9. Aftermarket Shifters
  10. bad throwout bearing????
  11. 3rd gear vibration
  12. installing short stick
  13. Spec III or Spec IV??
  14. Question about flywheel
  15. Whats wrong with my t-56?
  16. I need a clutch for 700+hp
  17. Installed Hurst shifter, car wont start......
  18. please help!!!!!
  19. T-5 vs T-56
  20. Does T-56 have Tremec gear box stock?
  21. What is the best clutch kit to buy?
  22. how much is my tranny worth
  23. How Much HP Does a Slipping Clutch Rob?
  24. grinding gears
  25. Mission Complete: Clutch installed
  26. STG 2 or STG 3 ???
  27. what did i break now?
  28. T-56 Questions
  29. T56 rebuild?
  30. paging matt at TTP again
  31. master cyl and slave question
  32. Nitro Daves:January Install Special
  33. Spec III Clutch??? 700rwhp???
  34. hurst vs.b&m
  35. Beat manual shifter for firehawk
  36. NEED Cluth help!!??
  37. Slight problem with Pro 5.0, any suggestions
  38. Strange noise from Trans
  39. Problem
  40. Who has the best deal on Mcleod Twin Disk
  41. paging Matt at TTP!
  42. What rpms are you guys shifting at?
  43. installing MSD Shift Light
  44. spec stage 2 clutch.......
  45. clutch upgrade..what else do i need?
  46. spec stage 3
  47. can someone tell me if this is the right master cylinder fpr a 2000 vette?
  48. clutch question
  49. Master cylinder line Help!!!!!!
  50. RAM flywheel studs??
  51. Grinding going into 6th...
  52. Syncros, steel vs carbon fiber ?
  53. Clutch Bleeding Help
  54. Need Suggestions Now.
  55. B&M ripper sucks ass!!!!!!!!!!
  56. do i need to bleed?
  57. Ford clutch disconnect tool
  58. Ram VDS 402-2550N weight
  59. popping sound?
  60. How to build solid M6
  61. should i bleed
  62. T56 Awd
  63. Bleeding a Clutch
  64. Viper t56 mate w/ ls1?
  65. clutch help
  66. is there a trick to linin up the clutch, pad, flywheel and pilot bearing nice and per
  67. KP is da' MAN on building T56s!
  68. SLP shifter (woof woof)
  69. Transmission fluid
  70. When I install my Zo6 clutch next week....?
  71. Aftermarket clutch line????
  72. Got problem with clutch when launching hard.
  73. Stock clutch question?
  74. Strange noises from gearbox area...
  75. Free fix for 5th gear grinding problem
  76. Need help with McLeod MC substitution
  77. Going round #2 w/ Mcleod Adj. Master (info inside)
  78. 103k miles on the stock clutch!
  79. spec, mcleod, or Ram
  80. clutch pedal squeaking??
  81. clutch "drill mod" question
  82. what does he need?
  83. Slave cylinder question..
  84. Transmission Grinding???
  85. Pro 5.0 or Ripper? which one
  86. hydraulic throwout bearing removal-need help asap
  87. not sure where to post this but I gotta question
  88. LS6 Hydraulics Part #
  89. 1LE trans mount
  90. What parts do I need for an M6 conversion?
  91. My M6 is hard to get into reverse.
  92. Help. Shims And Bearings And Ahhhhh
  93. T-56 price
  94. Would a new clutch plus drill out mod cure rough shifting?
  95. found out an ailing problem
  96. question regarding my t56 transmission
  97. Bellhousing I think we have good newss!!!
  98. Viper t-56 tranny?
  99. Spec III, are they SFI approved?
  100. Draining and filling the T-56 help
  101. lowering transmition
  102. Whats up with crappy shifting T56?
  103. who has best prices on spec clutches online???
  104. Bellhousing blanket
  105. G-Force T56
  106. anyway to delete hydraulics
  107. 5th gear problem?
  108. How long will z06 clutch last with 440rwhp under normal street driving conditions?
  109. WHich gears and clutch?
  110. LS1 T-56 in truck
  111. Defect with Ram pressure plate?
  112. Please share your launching technique
  113. upgrade hydrolics with stg3 spec
  114. Break-in time for the Zo6 clutch?
  115. What splines are the T56 input shafts???
  116. in the middle of a clutch install and need some info
  117. What does a T56 weigh?
  118. Tremac TKO
  119. hurst pro billet?
  120. Help
  121. wierd crap with clutch
  122. Flywheel questions
  123. Weird problem....
  124. Held in my clutch too long for the burnout
  125. auto to manual swap
  126. Need Specif questions I need answered on Spec stage 3
  127. Zo6 Clutch-any good
  128. How much can this stock clutch take?
  129. Has anyone ever heard of a LUKE clutch?
  130. which clutch
  131. help! huge bang/thump under my car
  132. I CANT stop misshifting even with a pro 5.0 shifter! I NEED a rocket scientest HELP!!
  133. How tough is it to change....
  134. McLeod Problems
  135. Mcleod clutch ussers inside
  136. Which Aftermarket Clutch Works Best w/ Stock Master Cyl?
  137. Bellhousing Help/info?
  138. Clutch questions
  139. spec vs mcleod
  140. which aluminum flywheel?
  141. Ram 980
  142. T56 conversion
  143. Self Adjusting?
  144. help
  145. Aluminim Clutch
  146. Anyone having problems with a 6 speed?
  147. Trans stuck in 4th gear!
  148. Quick disconnect?
  149. how many bolts?
  150. swapping a TKO into a 98 t/a
  151. Driveshaft was gone!!!
  152. Clutch install in 2000 C5 instructions
  153. Hows the driving with the Spec 3 clutch?.. is this true?
  154. New Trans Mount, New Noise?
  155. clicking sounds after clutch swap
  156. Poly trans mont???
  157. A4 considering M6
  158. what clutch to go with
  159. Have you seen this?
  160. Quick disconnect? not for me
  161. Clutch pedal issue...
  162. need help finding $0.50 part GM wants $70 for!
  163. Clutch for serious bolton car
  164. Ahhhh pops out of 3rd!!!
  165. I must have 1200 horsepower
  166. That's odd. 5-6 driven gear question.
  167. Shimming the Slave?
  168. Ram clutch
  169. Has anyone tried Pioneer 622817 trans mount?
  170. Pulled my t-56 tail housing off and found...
  171. Slave busted with only 1600 miles
  172. Is this the Master Cylinder or something else?
  173. Raptor shift lights? got issues.
  174. Trabsnission Squealing
  175. T-56 interchange
  176. 6 speed (manual) fluid change advise needed
  177. 5th-6th gear puller...anyone made their own?
  178. Won't Let Me Shift Quickly
  179. Spec 3X, Did you use the shim?
  180. Can I use synthetic gear oil in my T56?
  181. B&M Ripper install
  182. Wierd Vibration after new clutch
  183. D&D Tranny, acting up
  184. internal bumpstops HELP ASAP
  185. A4 to M6 conversion
  186. T56 gear ratios
  187. Can u buy the Z06 clutch minus the flywheel???
  188. which RAM clutch?
  189. anyone use RP Syncromax
  190. Why won't my clutch come back up?
  191. another Mcleod master cylinder question
  192. Clutch Madness
  193. Jerico questions, anyone do a swap???
  194. Blew the clutch?
  195. McLoed master cylinder users ...
  196. Master Cylinder part #s?
  197. m6 junkies..please help me bleed!
  198. Shifting Problem
  199. Master Cylinder???
  200. anyone had their pro 5.0 rebuilt?
  201. Just installed Spec Stage 3...First Impressions
  202. Am i paying too much to get my clutch done?
  203. grinding going into third?
  204. 600+ rwhp + cartek clutch = ?
  205. re-build your own t-56
  206. I've got 3 broken M6 trannies...going to make one good one out of them
  207. Spec 3 lightweight Pressure Plate, Help?
  208. Spec Stage III - Daily Driver - Master question
  209. RAM VDS users inside
  210. Vibration after clutch install?
  211. Go m6 or stay with my big stall A4
  212. How to determine bad slave?
  213. What the heck!?
  214. Crazy chattering after Pro 5.0 install
  215. M6 Short Throw
  216. Pro-shifting the T56
  217. Ever try and drive in 6th gear at 35mph?
  218. Flywheel ?
  219. Z06 Clutch vs Spec Stage II
  220. tranny 'scratch'?
  221. La-la-land between 3rd and 5th gear..
  222. Why so many flywheels?
  223. what clutch and shifters are best and whats the differnce?
  224. vibrations
  225. what is the Drill mod?
  226. T-56 shift forks
  227. WOT grinding, drill mod?
  228. people with pro 5.0, please read...
  229. info for rebuilding the mcleod master
  230. poly tranny mount backwards?
  231. shifting into reverse problems
  232. 98-00 to 01-02 slave cylinder difference
  233. How to shorten?
  234. Shifter Thread Size
  235. If you could would you switch from A4 to manual tranny if you had a 427 C5R LS6 motor
  236. Need Help with Drive line noise
  237. Did I mention @#$@% Centerforce?! More problems..
  238. Pulling motor out, how do i take off of tranny?
  239. NO more clutch pedal sticking to the floor!
  240. Hole in M6 Bellhousing
  241. Tranny Fluid: The "Why"
  242. Hard shifting issues
  243. Adjustable Master Help
  244. Opinions on Clutch and Flywheel
  245. Change rear main seal while clutch is out?
  246. Master Cylinder install question (in the process)
  247. Is it that important to balance?
  248. Just installed spec III
  249. Gear ratios for 6 sp ?
  250. 6sp. fluid
