View Full Version : Manual Transmission
  1. New Clutch Need Instructions!
  2. GM made better trannies in July 02! Tell me if this is true.
  3. T56 grinds going into second
  4. Slave quick disconnect
  5. Explain T-56 to me? Im new
  6. pre 01' hydraulics
  7. Mcleod master helped a bunch..
  8. Anyone send a McLeod clutch back 2 McLeod for new disks?
  9. T56 Hard Shifting
  10. free beer!
  11. Car not going into gear
  12. Slave connector wont go back in.. Why??
  13. Many Problems after Dealer installed new clutch
  14. Syncro's
  15. getting really mad
  16. HELP me prevent 2-3 mis-shifts! Tranny came down 3 times!!!
  17. LPE has new Corvette hardened T56 main shafts in stock
  18. Directions for the Mityvac bleeding method?
  19. Reverse lock out ? got a question?
  20. slave cylender
  21. Anyone try or know about Luk gold series clutches?Feedback?
  22. Tranny goes into gear, but doesn't do anything...
  23. Lets say i put new clutch disk in backwards?
  24. Spec Stage III clutch Install - slave bleed?
  25. In the middle of A spec clutch install Quick Question
  26. Transmission Swap
  27. FOR SALE: 6-speed
  28. Very hard to put car in Reverse
  29. Spec 3 users
  30. RAM clutch vibration :(
  31. McCleod Clutch with stock slave AND master?
  32. clutch pedal hanging???PLEASE HELP
  33. jumps out of 3rd
  34. Help, slave quick connect is leaking fluid!
  35. ARP flywheel bolts?
  36. Help me pick a clutch
  37. Car won't go into gear at high rpm's
  38. Mcleod Master/Drill mod complete!
  39. Cartek any good?
  40. Add shims to slave cylinder?
  41. need some opinions..which is best for RACING?
  42. using the evil skipshift for good???
  43. Clutch Recommendmeants?
  44. quick ? on current install of master?
  45. What is the highest rpm the LS1 can handle?
  46. corvette flywheel
  47. Stupid Piece Of Shit Centerforce!! Problems inside..
  48. which master do you recommend?
  49. Got my clutch replaced under warranty
  50. tranny problem help
  51. Ahh!! Trany Fluid
  52. Do you need to purchase a new flywheel?
  53. Grinding 4th gear??? WTF? read this.
  54. Multiple Problems After Clutch Install.....
  55. WOuld you buys a used clutch?
  56. GM Clutch Part#
  57. Street twin install tips?
  58. what tag # should i be looking for on my t56 swap
  59. NE1 Drive a Jerico On The Street?
  60. Is it possible to buy a McLeod clutch by itself? No package?
  61. Which tranny M6 or M12 for Corvette drag racing.
  62. trani
  63. what exactly do I need for a new clutch
  64. Best price for Clutch/Pressure plate?
  65. Does a fried clutch disc negatively affect dyno numbers?
  66. Drill Mod Problem
  67. Third Gear Problems.. Help
  68. Organic Clutch and Nitrous ... Durable?
  69. drill mod - how does it affect driveability?
  70. HIgh RPM shifting...
  71. This all I need to put a ZO6 clutch in a 2000 car(part#'s)?
  72. SFI?? Yup...
  73. Fresh rebuilt trans didnt work - found out why..
  74. Bleeding Slave
  75. Clutch Tottally Screwed up or what?
  76. JSS on stock hurst......WOW!
  77. Clacking noise from tranny when shifting...
  78. Where to go for T56 internal parts?
  79. HELP PLEASE!!
  80. shift boot
  81. Diagnose my tranny problems please.
  82. SPEC III, stock rear end, tires, ANYONE?
  83. question about the skip shift!
  84. Be Honest. Whats Better? Stock Hurst with LSS or B&M Ripper?
  85. Anyone ever use LUK gold series clutch's
  86. lowdown on short throws and Pro 5.0s?
  87. T-56 pull....
  88. Change Tranny Fluid in a M6
  89. Hurst Blllet plus shifter
  90. Can you mix/match a clutch?
  91. Leaking Slave Cylinder ... Is Clutch still good?
  92. Throw out bearing
  93. about new tranny mount
  94. I've tried everything.. Car still won't shift...
  95. Tried Search but answers on this one. SDK or TDK
  96. Spec 3 ... few Qs?
  97. Clutch pedal spring broke?
  98. pedal on the floor
  99. Cant shift over 5K rpms
  100. Syncro?
  101. clutch problem i think !!!!!!
  102. Would this be my clutch slipping?? (Long post)
  103. Which tranny?
  104. Has anyone tried both the McLeod Single and the RAM 980?
  105. McLeod Single Disk slipping on high rpm shifts, is it toast?
  106. Gears or Rear end?
  107. spec 3 pressure plate torque spec
  108. Do I need to readjust my adjustable master cylinder??????
  109. Left leg can press 500,000 lbs
  110. Intermittent vibration through clutch pedal - non-LS1
  111. going from tremec to borg werner
  112. Clucth Strength
  113. Shifter thread
  114. slipping clutch on the bottle
  115. clutch install? how do...
  116. clutch is acting strange...
  117. ok how do you get this off
  118. Car Starts without Pushing Clutch down??
  119. Clutch wont re-engage at high RPM's???
  120. skip shift eliminator HELP!!!
  121. Ram 980 install; use the ram shims?
  122. mcloed vs spec?
  123. Just installed poly tranny mount, not what I expected
  124. skip shift eliminator
  125. HP limits of t-56?
  126. Convert Hydraulics to Cable Clutch
  127. Mcloed adj master problems help PLEASE!!!
  128. Stock hurst shifter vs. 5.0 Pro? Oppinions Please
  129. new clutch..any suggestions
  130. 600+ rwhp + stock driveshaft = ?
  131. SPEC pressure plate failure??? what broke off my clutch?
  132. Hurst Billet with LSS to Pro 5.0 with LSS
  133. Should I use McLeod adjustable master cylinder?
  134. Hurst short throw shifter, was it a GM or SLP option?
  135. replacing clutch
  136. bleeding the clutch hyd.
  137. notchy shifter?
  138. Can you do the drill mod on 02 cars?
  139. ZO6 Clutch limitations
  140. clicking noise in clutch
  141. Tranny mounts the same from 93-02 for 6 speed?
  142. smoked my driveshaft and tq-arm today
  143. Cannot line up tranny to bolt on bell housing... M6
  144. can't seem to line up tranny to re install
  145. clutch gurus please help
  146. Clutch Problem?
  147. Insatlling new tranny in the morning!
  148. M6 Woes Again...
  149. Anyone ever replaced the springs in their shifter?
  150. Short Shifter
  151. Has anyone MIS-SHIFTED with Lous Short Stick (LSS) ???
  152. Which clutch for my setup?
  153. Richmond Transmission
  154. Clutch feels funny, is this normal?
  155. Whats the real story on bench bleeding???
  156. GF grinding gears
  157. Do I need to have my stock flywheel counterbored?
  158. 99+ Silverado transfer case behind T56?
  159. Problems going into second
  160. T-56 stuck in 4th problems ....not from bent 3/4th fork
  161. clutch super hard
  162. Question about clutch alignment tool...
  163. 98 and newer t56 master cylinder
  164. Spec stage 3 clutch is squealing still!!! Help!!!!
  165. Who has a D&D T56 ? got a question....
  166. Help finish my parts list for T-56 conversion
  167. New Clutch Adj master, cant switch gears :)
  168. Updated 01+ Clutch Master or McLeod Adjustable?
  169. V6 master cylinder vs. V8 master cylinder
  170. Differance between T56 and A4 tranny mount??
  171. 93-97 T-56 are good 98-02 T-56 are junk
  172. Questions Concerning Rebuild
  173. Pro-Shifted
  174. Shit for 60' times
  175. Is my clutch bad?
  176. M6 swap speedo question....need HELP
  177. How to make stock master adjustable
  178. crappy burnout? weak clutch possible?
  179. sorry guys, know this doesn't go here, but i need HELP
  180. how to tell difference in a LT1 T56 and an LS1 T56
  181. slave question
  182. How much is a stock T-56 worth?
  183. Pro Shifted T56
  184. Have Pre Bled Master. 01 car, do I need to bleed slave?
  185. STOCK Z28: optimum shift points?
  186. What is the T56 worth?
  187. Who has good Instructions for Spec Stage III Install?
  188. Which Part # is the latest slave?
  189. Clutch Problem...need help
  190. Manual or Automatic?
  191. power loss? clutch slipage possible?
  192. Won't Shift into 2nd Sometimes
  193. t5 to a t56 in a 2000 4.8 sierra?
  194. Pro 5.0 or B&M short shifter
  195. 430RWHP, Spec stg3, Do I need new hydraulics?
  196. clutch for pretty much bolt on car, no more than 380 rwhp
  197. adjusting my stock clutch??!?!
  198. Car does not go into 3rd sometimes??
  199. how to swap to a manual????
  200. Ever blow out a slave cylinder?
  201. Opinions on Clutches!!!!!!
  202. Stroker guys: How long has your T-56 held up for?
  203. mcleod master problem
  204. Hurting clutch?
  205. 3rd gear problem - kind of weird.
  206. Bleeding CM with Mityvac,Constant Air bubbles,notchy Shiftin
  207. clutch fork, tranny fork ?
  208. Anyone here use the Yank crossmember?
  209. ok... Why won't my car go into reverse??? Thanks
  210. OK, what did I break?
  211. After market slave.
  212. Clutch Break-in procedure SPEC Stage III ??
  213. Problem w/ new Pro 5.0
  214. transmission gearing??
  215. what kind of shifter do i have???????
  216. Star spec stage 3: Carbon fiber Vs. Kevlar Vs. Ceramic ?????
  217. Rattling after fluid change M6 Dexron 3
  218. Bad Mcleod Master Cylinder?
  219. LS6 & Richmond ROD (6 Speed)
  220. Gotta problem with my stage 4
  221. how muck HP will a 2001 6M trans take?
  222. Car still doesn't shift at high RPM's....After MC bled...
  223. hard clutch pedal after a run *DELETED*
  224. sort sift tranny noise ???
  225. Thank You TSP!
  226. M6 Gurus please help!
  227. What does this means?
  228. Twin disk with new hydraulics In but heard noises on startup
  229. Slipping a nasty clutch in stop+go traffic == really bad?
  230. tri-ax shifter for mustang t-56
  231. Tranny makes grinding noise in gear under accel
  232. Z06 Clutch/Flywheel install
  233. newbie question: what exactly is clutch chatter?
  234. hydraulics question
  235. Guys with 2001 + raptor shift lights,I need ur need help .
  236. Anyone have problems with MTI Skip Shift Eliminator
  237. High horsepower / streetable clutch needed.
  238. Powershifting
  239. where is the best place to buy a spec stage 3 clutch
  240. trans wont shift when hot?
  241. Does this sound like a hydraulics problem?
  242. Any special tools needed fot T-56 rebuild?
  243. Lou's Short Stick
  244. do i really need the adj. master ? or ...
  245. Clutch problem (long)
  246. Hurst Shifters...Questions
  247. Original Clutch?
  248. Which clutch should I use for my setup?
  249. anybody want to trade A4 for M6 setup?
  250. What Clutch does not need special shimming (want a bolt in)
