View Full Version : Manual Transmission
  1. BEST T56 to buy
  2. Stuck to Floor
  3. Ls7 clutch in a ws6??
  4. C5 Driveshaft
  5. Input shaft was rubbing on slave.. how to fix before replacement..?
  6. t-56 trans problems
  7. T56 to 4L80e conversion, please read
  8. 1998 trans am
  9. Clutch pedal not firming up during bleeding...?
  10. bleed clutch still goes soft after i get on it???
  11. LT1 T56 Bellhousing
  12. Tick MC rebuilds?
  13. finally got the SS back on the road! new clutch, and a buncha new shit
  14. Need help making decision to buy "Core" or buy "Useable" T56 for my swap
  15. Hurst comp plus stick?
  16. T56 What one do you recommend? What are you running. Street and Road Race
  17. very nasty metal on metal sound
  18. Going to have my T56 M12 FRESHENED up. What should I order
  19. Trans won't let me into reverse?!
  20. PLEASE SOMEONE HELP! ls1 camaro manual problem
  21. Hurst Billet owners please take a look [pictures inside]
  22. NEED DIAGNOSIS HELP ASAP!! clutch pedal goes almost to the floor :(
  23. Throwout bearing???
  24. T56 rebuild questions
  25. How thick should a 'New' Diamond stage 3 clutch be?
  26. 1999 t56 to a 05 ls6
  27. Clunk with slow gear change
  28. Spec or Comp Clutch for a 97 WS6
  29. C5 LS1 Torque Tube Bearing Snap ring
  30. 2000 Z/28 T-56 Swap
  31. what have I gotten myself into...
  32. cheapest place to get rebuild kit?
  33. 4th gear grind after Tick MC and mobil 1 ATF
  34. Clutch Suggestions please?
  35. 5.3/T56 just got running and now no reverse?
  36. clutch or trans
  37. ws6store short stick + hurst ball
  38. Driveline vibration
  39. Will C6 Twin Disk Work on F-Body??
  40. Throw out bearing
  41. T56...issues
  42. McLeod Street Twin on Stock Hydraulics?
  43. what are my options on a new output shaft?
  44. Did I break a spring??
  45. Help settle this debate....manual driving: 101
  46. bellhousing??
  47. Monster 11" Ceramic holds 965rwtq SAE
  48. SPEC 3+...Four seasons & "STILL" going strong
  49. Will LS7 clutch work with SPEC flywheel?
  50. can poorly rebuilt manual transmission slow car?
  51. t56 mock up specs
  52. trans is coming out this weekend, new to hydraulic clutch systems..
  53. Cruse control stopped working after clutch install?
  54. any1 know where i can buy a clutch shatter shield
  55. t56 upgrades
  56. throw out bearing?????
  57. Broke bellhousing....
  58. how many miles do you need to put on before the track
  59. Tough shifting at high RPM
  60. Worth rebuilding just to sell? lt1 T56
  61. release bearing differences
  62. Our Level 5 SUPER Magnum TR-6060 Conversion: Warrantied for 1 Year at ANY Power Level
  63. Going into 2nd gear issues
  64. Different bellhousing depths/options? LS1 DeLorean Project
  65. Stiff pedal with Tick Master on a ls1 t56
  66. shifting problems.. probably clutch related
  67. T-56 slave.....did I break it ??
  68. ram vds clutch problem?
  69. Whats needed to run t56 without it being hydralic?
  70. clutch pedal issue
  71. ls7 clutch in f body?
  72. Monster and Tick owners come in please!!! Clutch disengagement issues...
  73. T56 Leak (PICTURES)
  74. light weight flywheel
  75. Downshifting a cammed car (M6)
  76. ways to cool clutch off
  77. Time to upgrade clutch...opinions needed
  78. Replaced LS1 clutch with LS6 - now starter jams
  79. Mityvac wont work
  80. Need help asap Please!!!!!!!
  81. LT1-T56 magnum
  82. torque arm unhooked lead to missed shifts???
  83. best auto to manual pilot bearing conversion?
  84. Want clutch from ls7
  85. General manual transmission Question
  86. if the front seal is broken, does it require to disassemble?
  87. Faster shifts in T56
  88. wtf? trying to install master cylinder for t56 conversion...
  89. Trans rebuild / new selection help
  90. Wiring ?'s for T-56 swap
  91. clutch help noob
  92. opinions on which bellhousing to buy??
  93. Clutch Help Please
  94. Destroyed my clutch today! oh and the bellhousing. Pics inside
  95. Clutch issues and car shaking??
  96. Quick disconnect
  97. Owners of the Pro 5.0, did you cut your shifter down?
  98. BAD chatter problem ACT HD Clutch
  99. clutch engaging near the floor
  100. help!!!!
  101. 04 gto t56 problems!
  102. Any expierences with the "NEW" style mcleod master cylinder??
  103. rebuilt t56 - 3rd gear whining?
  104. T56 Female Quick Disconnect Fitting to -4AN???
  105. clutch slipping
  106. 28 lbs vs 18 lbs flywheel?
  107. a4 to zf6 swap , speedo is off !!
  108. t56 input shaft
  109. transmission fluid?
  110. T56 Maintenance.
  111. rebuilt t56 pops out of 1 and 2 on occasion
  112. transmission mount shot?
  113. F1 Racing clutch?
  114. Broken torque arm mount, couple of questions.
  115. Clutch fluid shelf life?
  116. Shifter?
  117. world class T5 behind LT1
  118. T56 trannys in stock and Ready to GO, Clutch SPECIALS, etc!
  119. Bleeding the clutch fluid?
  120. how can I check the fluid level of my manual transmission
  121. LT1 Clutch not fully disengaging
  122. trying to find problem help
  123. Blown T56
  124. T 56 swap
  125. I think I have a problem
  126. Possible to use a 153 tooth flywheel on LS?
  127. So lost! My shim measurements are backwards....whats wrong!!??
  128. Need a clutch for my 8.1l to viper t56
  129. Transmission went bad?? HELP!!
  130. Master cylinder Hole size
  131. ive seen a few of these threads but i need some more opinions..
  132. NEW Tick Performance Level 1 Standard T56 Rebuild is UNDER $1000 SHIPPED Both Ways!
  133. M6 cars with 2-step launch controller questions
  134. Transmission problem.. help
  135. Replacing Master, Slave, & Clutch -- Need Help/Opinions
  136. How bad really is power shifting? T56
  137. T56 How much power can they Hold (STOCK)
  138. Clutch makes a grinding noise
  139. Clutch Master Cylinder keeps failing!
  140. LS7 Clutch Swap, eh?
  141. Brand new Monster clutch burning smell
  142. hurt my GTOs t56 any ideas?
  143. clutch pedal stuck to floor in traffic 0 pressure
  144. T56 "Rollover" noise?
  145. ls6 oem pressure plate and upgraded disk
  146. Clutch Noise Lt1 T56
  147. LS1 to LS2 help Clutch wont go in!!!!
  148. Pedal issues/clutch assembly?
  149. Question on shims
  150. Master cylinder question
  151. Shifter rattling
  152. Need some help with the trans
  153. clutch master cylinder
  154. Clutch ?'s
  155. t56 fluid
  156. Help meeee
  157. best clutch for my set up?
  158. quick tranny question
  159. How much power did you make before your factory t-56 died?!
  160. Buzzing noise when shifting & shift rattle - ls1 T56
  161. M6 5th gear grind.
  162. what to do going boost
  163. VSS Conversion from 1993 to 1995
  164. shifter
  165. Trans Fluid Observation
  166. new m6
  167. Lous short stick thread?
  168. Is it necessary to replace fluid in an LT1 slave?
  169. Replacement clutch (disc only) options.
  170. Clutch Assembly Questions
  171. 5/6 gear issues
  172. Never installed a clutch before. How hard is it?
  173. .62 sixth gear in GTO trans
  174. replace clutch or flush? newbie
  175. Monster stg2
  176. Tick adjustable master for LT1
  177. T5 trans behind 5.3
  178. Pay for a rebuild or do it myself?
  179. Clutch and transmission issues. Will not shift jumping out of gear, all is NEW HELP!!
  180. Slave Throw out bearing travel question after bleeding
  181. t56 wont go into gear
  182. C5 Clutch Replacement Issues
  183. 2nd gear is MIA or KIA
  184. Best 6am for 1st gen w/sbc???
  185. Vibration upon deceleration
  186. T56 Swap... PCM Question
  187. Shifter knob install gone wrong!
  188. shifter cup contacting t56 housing (pic inside)
  189. How is your Spec Clutch working for you?
  190. Speed bleeder concave to concave fitting going to seal???
  191. TA wont even shift into 2nd
  192. Act!!!!
  193. Clutch Shimming Made EASY with NEW Tick Performance Slave Cylinder Shim Kit - 3 Pack!
  194. shift interlock system?
  195. question
  196. Car shaking In first gear
  197. Should I replace this input shaft?
  198. Come together...clutch trans diff etc
  199. Anybody having this problem reverse not going in.?
  200. Not your normal fluid question
  201. custom super t56 trans built by rpm!!
  202. Whats the difference between 04 GTO and 05 CTS-V T56?
  203. 3rd gear downshift issues after rebuild
  204. 2004 GTO cracked tailshaft housing
  205. t56 locking in 5th gear
  206. Hurst Sidewinder
  207. Spec Super Twin with TICK Master,not fully disengaged
  208. What to buy please help
  209. is my diamond stage 2 on its way out?
  210. Part #s shifter pins???
  211. help with setup need...ls3 to t56 magnum to driveshaft
  212. Will LS3 Spec dual clutch work with T56?
  213. Where to get Viper internals for an LT1 T-56?
  214. Bad Synchro
  215. Spec Stage 3+ ??
  216. Issues Shifting Into 3rd Gear - McLeod Twin Disk with Tick MC
  217. Gripforce ?!?!?!
  218. hydraulic issue
  219. Who makes a good quality TO bearing?
  220. New Spec Clutch
  221. TR6060 oil pump connectors ???
  222. is this natural?
  223. Ok, somebody explain this to me...
  224. 1993 T56 VSS vs 1994+
  225. F1 Stage 2 Clutch and Flywheel for my 01 WS6?
  226. Can't decide what to do about rebuild.
  227. Ford tko600 behind an lsx motor
  228. A4 to T56 conversion wiring
  229. was i sold a 2000 trans as a 2002?
  230. Reverse Lock Out
  231. 98 Formula grinding popping on take off.
  232. M6 camaro console
  233. clutches made simple?
  234. 2002 Camaro SS Shifter Vibration
  235. What gaskets for clutch installation?
  236. bellhousing - t56 magnum to ls3
  237. T56 vs TKO600, 7k shifts, 2700 lb car
  238. HELP! Can't remove the clutch slave
  239. Help with Tick master
  240. New ACT 6 puck (clutch like a rock)??
  241. Cobra shift knob w/Camaro threads
  242. T56 hates speed shifting
  243. Diamond Stg 2 clutch feels soft?
  244. How fast on stock shafts and gears?
  245. MN12 w/ SSR Mainshaft "Build"
  246. White disconnect o-ring missing??
  247. M6 Shift Knob Removal (98 Z28)
  248. where do i buy this part to my t56 asp
  249. ebay clutch options..
  250. T56 input shaft to handle 1,000 + HP??
